Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '88 - '91 Civic / CRX |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
Automatic Transmission Reliability?
Fuel Tank Repair
is this true about a stock intlk
left blinker goes on
strange problem after t-belt replacement
VTEC controller
What does crx stand for?
d16a1
89 Civic si ZC swap
Chrysler Conquest Turbo on a CRX, good gains?
shaking steering wheel at low speeds
Help !!!! How do I get a 89 civic hood and bumper to work on my 89 hatchback civic!
In need of a help!
swap question
confused ... what kinda bseries tranny is this?
89 civic questions..
1995 D16z6 Block W/1988 D15b2 Head
better to boost a d16y8 or zc?
Good deal?
SIR bumper
Riding the Rev limiter
How to put DSM injectors in my b16 turbo
looking for 91 crx si or sir
V8`s lately
Hub removal
88dx--->sohc ZC swap questions! help me!
car wouldn't start
shaky CRX
89 civic si ZC swap
crx
d16a6 obd1? posible?
water temp guage.
CAI & O2 sensor
Tranny swap on a STD civic?
Interior painting
ALignment
help finding out whats involved in importing a crx
How do you know if FUEL pump is going out?
CRX SIR help
91 crx SI
which d-series tranny would be best for...
Hood latch blues cure...
radiator fan?
Help me out..let me know what you think
1990 Civic Erratic Idle Problem
CRX dash in 89 si hatch need sum help
Predict my quarter E.T.??
HELP!! car wont rev past 3250 RPM's only code is 4??
coolant flush - couldn't find the engine block drain plug.
Full DA Integra Front/Rear Brake set-up
... tail light trouble
need bright corner lights
Tranny swap (hf)-(4spd)
Thinking about getting in on the Ethanol fuel scene
b20/vtec help
how can i tell..?
pr3 code list?
Problem with MAP sensor NEED HELP!
90 Civic HF ZC SWAP 1.6 SOHC 4spd Tranny
bet you cant figure this out
stupid brake lights stay on
won't stay on
H series transmission adapter plate
tie rod end problem
Ok Ok Ok, Here Is The Pic Of The Wing
0BD-0 List
need a couple of questioned answered
angel eye head light instalation
B18, B16 motor help
dumb comment...
D series block
91 civic wagon sidemarker assembly
B16a custom turbo setup
front brakes
help! need any advice
hood
Which Exhaust for my CRX?
1.6L Swap, mount questions HELP!
crank shafts
Swapping a 4G
crx swap, help!!!!
automatic engine swap?
all clear taillights
Dash light problem
Valve cover difference
exhaust on an std?
CTK: new engine pics
hello hello, quick question
92 b18a1
motor swap questions
ls b18a1 swap in my 91 civic
Highest octane i can put in my car?
Ebay Turbo Kits ok?
Anyone good or alteast know anything about working with fiberglass? or any websites
engine question
It wont stay fired!
white smoke
Look at what some jerk did to me yesterday
What Wing Is This?
88 si cluster in my 91 hatch
91 HB lowering help
Fluidyne Half Size Rad doesn't fit. 91 CRX
'92 Civic first time changing brakes
help
89 Civic SI ZC swap
Need major MPFI swap HELP!!!! PLZ
turbo civic hatch, how fast?
lightened flywheel for zc?
how to build a LS VTEC
Turbo Honda Civics
d16z6--d16y8
Widebody CRX SI FOR SALE!
backseat removal
bumpers
crx seat brackets????????
single wiper on a 89 civic
so what's that nub on the door where the top window is?
Tail Lamp Mod!!...
Question about ZC intermediate shafts
small exhaust
timing belt
how to put cruise control on a car w/o cruise??
90 Civic is throwing odd ECU code...
can you get a turbo to play nice with a d15?
allright this civic 'z bak in busness well soon enough
98 Integra b16 swap
Help wiring a B16A1 in my 89 CRX Si
1993 maxima cam gear set
89 civic si ZC swap
I have FINALLY chosen my motor after some research!
trade civic for 97 talon
axel problems in my b16
D15B VTEC was rev'n hard until...
what size tire iron do I need for my CRX?
single cam vtec head on dohc zc block
GSR Leather in 91 HB???
clutch and spedometer problem
zc help
88 4dr civic need help with linkage
Few problems with Y8 swap
Intakes...
STD. Hatchback front end swap
still no hp
Update
Clutch slipping on my 89 crx si!! Please help
Quickest way to reset the timing belt??
90 civic wont start
Will this instrument cluster work?
mini-me swap
ebay lovers
crx d16z6 swap distributor help
CRX hatch wont stay locked
No codes-Engine Turns-No Catch WTF!!??
Is this right?
accident report!!!
AEM cai or ICEMAN cai ....
Front end
90 civic water leak
Rear Disc Brake Conversion CRX DX
Swapping steering columns??
Need Help on my Hatch
Previous owner SUCKS!...Help please.
2 bored 16 year olds, $1000, 10sec crx
2007 Crx
need head for 1.5L cheap
Got my new car
Been a while... been having some problems with the hatch
wing mod!!!!
smokes on re-acceleration
high idle at startup?
4g4d update..
NEED HELP WITH MY B16 SWAP IN MY 89 SI HATCH need knock sensor info an ecu pins 4vtec
car overheating
Convertible CRX How To???
I'm in the Fo Do crew now!
Idle trouble..Code 10 and 14!!
If you build it...
what distributors?
sohc vtec time slips
no power after attempted start up
need help
burned head gasket ?!?!
no vtec help!!!!!
Tail light match up?
97 gsr seats
89 civic Si wheel bearings
91 civic clutch help
role cage.
Another rust problem...
Finally got some pics of my GF's Civic up
my heat sensor or somthings wrong help?
Engine Swap 1.5TBFI to 1.6MPFI Help
ride height question
CRX HF Price '88 wit 200k mi
I need help with 90' civic wiring problem!
p28
'89 Civic Exhaust System
Rust
Brake lights won't go off.
D15B2 turbo setup, done correctly
New Car Teaser Pics
Help With Engine Swap
FUEL problem?? Need Help!!
ZC lowest compression motor?
radiator overheating,gushing out
banshee vs CRX fire :(
code 20 on ecu and starting problems
running warm after new water pump
Axels for my b20
will a civic turn signal light socket fit my 89 crx?
steering hub adapter.
what are the symptoms of a bent rear sway bar???
i need help please
blown head.
Gauge Cluster Removal
Thread size for shifter knob
I need info about timing belt on 91 civic
help take off a part
Trade b16a for 300zx?
I know you guys are gonna hate me but here it is...
4x100 to 5x114 wheel adap?
Sunroof only opens once in a while.
question about Avid motor mounts, Problem
Code 20 on ECU
Help! Car turns over, but no ignition or fuel pump
what is this...
My Ef Civic Suspension. Cry For Help!!!
where is the intake air tempature sensor on a 88 civic Hb Dx D15b2??
Thinking about getting one
highway shake
idle weird
Cam/Distributor Keyway
whats the best cheap motor for 91 crx with some hp
Car does not start always needs a jump ??Alternator??
88 civic HB DX "im getting 10 flash'es on my ecu... HELP
Clunk after sharp right turns?
B16 runs rich on start-up
XM radio Question...
91 crx si b16 ecu swap options
got my new audio console today...
Just FYI...
help on my crx's hatchback
just put on a new head now my engine light comes on?? help
Is there such a thing as CRX Shadowline
Can a SI Engine be used with a Auto Transmission?
Battery light on below 3500 rpms, is it the alternator?
obd conversion
thinking of turboing my d16A6
last day for the Duryea Hill climb... whose gonna..
Bad Day, how do i get my hood open without a cable?
Web
AF
