View Full Version : '88 - '91 Civic / CRX
  1. Would you do it?
  2. grinding when giving gas
  3. mini me d15b2
  4. HELP, 89 civic 1.5 won`t start
  5. Distributor going bad
  6. swap woes
  7. alternator question
  8. bodykit help
  9. D15b2 surging issue
  10. what do you think?
  11. d16a6 how much should i sell this for on ebay
  12. Question about car model.
  13. keep loosing power!! help!!
  14. ZC exhaust manifold
  15. zc question
  16. 1991 honda civic rpm problems
  17. Turbo-ing a ZC
  18. Fender
  19. 90 Civic EX rear seat drama
  20. Gauge Cluster.
  21. brake bleeder question
  22. Suspension Question.
  23. Suggestions for a D15B2
  24. problem with 91 civic dx!
  25. 89 window/hatch fit 90?
  26. Sorry everyone
  27. Z6 Question
  28. vacuum line diagram help
  29. is this a good deal..
  30. looking for a gas tank
  31. ferders
  32. throttle cable sticking??
  33. head question
  34. Engine removal need help
  35. Shifter Squeaking
  36. timing belt help needed ASAP
  37. Weird cam gear problem!!
  38. My 91 honda civic has no power on ANY hill
  39. CRX Si options
  40. 5th gen fuel rail
  41. tps and multimeter
  42. problems with 90 civic
  43. Almost killed her last night
  44. looking for a 4 door
  45. quick ecu question..
  46. ground wire q..
  47. D16Z6out-D15Bin Help?
  48. Z6 Build Suggestions
  49. Suspension Techniques rear swaybar quiestion
  50. tps questiom
  51. my b16 swap *56k errr...sorry maybe?*
  52. selling question
  53. center consoles
  54. 88 crx SI swap in a D15 !! help
  55. Need Help Bad
  56. classifieds
  57. Have u guys seen this ?
  58. crx vtec bonnet and lights plus cat Q
  59. jdm exhaust
  60. 91 crx si seats for sale
  61. 91 crx si seats for sale
  62. Another Problem
  63. I speak highly of this product
  64. d15b2 rplacement
  65. obd1 conversion question
  66. Mudflap question....
  67. HB Hinges
  68. crx back bumper on hb does it work
  69. Koni yellows + Progress = bad
  70. 1991 Honda Civic 1.5L Conversion
  71. 88 Civic Lx Idle Trouble
  72. couple questions
  73. Clutch question
  74. Few new pics of suspension and rotors on rex
  75. hopefully the last tranny question??????
  76. Which spark plugs do i use for...
  77. stuck in 2nd gear
  78. ZC CRX Advice..where next?
  79. Clutch
  80. orange and green coolant
  81. question about replacing valve seals
  82. Anyone from BC, Canada HELP
  83. Any welders in here?
  84. Transmission mount
  85. cam
  86. b16 injectors in a d16 manifold
  87. blue screen of death
  88. 2kracing short ram intake
  89. Boooooooooooooooo.
  90. B-series stuff for sale in classifieds
  91. best gas milage possible
  92. resistor
  93. 91 tranny in 88 crx
  94. I think I may have found something odd, what ya think?
  95. brakes question (Shims)?
  96. tein suspension question
  97. si gauge cluster in a dx. 1989
  98. Zc
  99. Starting problem
  100. 1990 Honda Civic swap
  101. at the JuNkYaRds
  102. Can the cat ping? If so, I will kill it
  103. crx questions....
  104. Main relay
  105. just curious
  106. Mpfi Wiring
  107. installing brake pads
  108. Sohc Jdm Vtech?
  109. crx wheels
  110. Mystery No Start-- Please Help
  111. header..worth it?
  112. 91 std motor swap ! zc or si?
  113. Help Trouble with speeguage not working what to do and where to start
  114. Help Trouble with Rpm not working what to do and where to start
  115. fuel rail insulator
  116. e-brake handle
  117. Exhaust is bad, now is time to get new one
  118. need torque
  119. Ignition Coil Troubles
  120. Speedo Drive Popping
  121. 250,884 miles and counting
  122. Cheap upgrades for a SOHC 90 DX hatchback
  123. Thermostat problem
  124. install tranny
  125. msd ignition questions
  126. Hesitation
  127. Buying a subwoofer - wuts the best out there?
  128. throttle body question
  129. Looook
  130. I bet you had a better day than I'm had.
  131. front/back bumper question
  132. Finally Got My Pics Up!!!!!!!
  133. Hood wont open???
  134. volt guage
  135. How come my corner lights dont blink only my bumper lights?
  136. 4wd civic/crx
  137. Heating in my 89 Civic
  138. door popper question
  139. CRX SE Restoration - In progress pics.
  140. Cheap upgrades for my '89 Civic SI Hatchback
  141. Tires...
  142. D15B1 and D15B heads
  143. wiring up vtec
  144. zc ecu?
  145. eacv
  146. New tires for my 89 Civic
  147. electric ignition switch replaced... what'll break next?
  148. one of my jdm sidemarkers got stolen, does anyone have 1 to sell?
  149. Installation of throttle body.
  150. Engine Swap?????
  151. Pittsburgh people
  152. after market cams and rods & pistons 4 a SOHC zc
  153. Wierd problem
  154. cam inter changing question
  155. D15 Upgrade
  156. distributer Q.
  157. carbon covered spark plugs
  158. Water leak - 1990 Civic Si
  159. nitrous conversion
  160. Crx Hf Dx
  161. Tuning for a 90 DX
  162. D16z6 Into 1988 Dx
  163. Lots Of Noise Coming From my Head ex Pinging, Ticking
  164. Clutch Q's???
  165. want some serious advice on buying
  166. Need helms manual info
  167. Starting Question
  168. Honda Turboz
  169. i crashed....
  170. std hatch swap dohc zc or b16 vtec??? help !
  171. 60v fuse
  172. I have an odd question?
  173. Updates On The 88
  174. Internal Interference Engine
  175. 4x100 to 4x114.3 conversion
  176. Re to lighter flywheel
  177. carbbing a 88 crx Si
  178. Civic 91 Moding Help!!! 1.4 Gl
  179. electrical problem help. car won't stay running, etc.
  180. Giving up the project
  181. lighter flywheel
  182. need help with h23 swap
  183. engine swap 91 civic help
  184. Lookin for a good muffler...
  185. was this a steal or did i get the shaft
  186. will it fit?
  187. Looking to race a CRX...
  188. clutch question
  189. Magazine
  190. Help me tranny question
  191. omfg..someone... PLEASE HELP ME
  192. E.a.c.v
  193. Problem: Over 4000 RPM = mixture too rich
  194. 88 Civic Project.
  195. Help installing alarm
  196. what to do with a distributor core?
  197. what interior paint is the best to use
  198. Why The F***?
  199. Help
  200. cant start
  201. 88 Civic slow idle, and sputtering
  202. Feedback on sohc zc
  203. Fun Pulling Motors
  204. ebay "Civic/CRX" intake on a 4dr LX
  205. Oil in 3rd and 4th spark plugs
  206. cLutch won't go in when car is turned on
  207. mystery problem
  208. lucas?
  209. Tranny question
  210. Problems with my Harness?? Stumped
  211. get more performance with ZC
  212. si engine and the hf
  213. crx hf gas mileage question
  214. Need help with Boost
  215. spoiler on falken ef?
  216. Ticking in 2nd gear?
  217. another funny prob. after t-belt change.
  218. tranny????
  219. hood???
  220. h32a1 swap in crx?!?
  221. compresion psi
  222. 91 CRX Si Tach issues
  223. uhh yeah :)
  224. Fuel Pump access
  225. Bouncing Tech Needle.
  226. what dizzy do i need
  227. a small swap
  228. itr brake swap
  229. need help on this b16a swap im doin
  230. D16z6 Block W/d15b2 Head Problems
  231. how bizarre...
  232. This years pics of my shitbox! (12 pics, beware)
  233. nitrous switch
  234. CRX Instrument Cluster Swaps
  235. crx glass sunroof
  236. put-put-put- vroooom
  237. cheap & simple mod sugestions?
  238. Ingalls Camber Kits
  239. MY CIVIC IS PI**ING me off!!!!
  240. why street racing is bad
  241. tach question.
  242. motor swap need help!
  243. adjusting the idle on the zc
  244. specific headlight bulbs?
  245. Owner's manual
  246. Looking for a crx site
  247. starting problems
  248. Headlight flasher not working
  249. Whats louder Turbo XS RFL BOV or the Turbonetics Godzilla?
  250. effing condensation
