Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '88 - '91 Civic / CRX |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
Sea foam in high mileage engine?
Please advice on how to replace FUEL FILTER for Civic 90
Poor acceleration
guage face swap
DOHC ZC: PG7 or PM7?
pm8 ecu for mpfi
car update.....lots of pics!
Hard bush set for Civic
Timing Belt *please help*
cluster needle question
Body Shop
'91 Civic DX HB project, B16 swap w/ more to come
intermittent dieing...HELP!
just a few questions on performance mods/what to do next
Project CRX: Sir II swap with lots of extras in store
Does size matter? (Turbo)
head light bulbs
extended Vtec use??????
Tcu?
how to hide amp wires
How much coudl i sell my front bumper for?
Best Suggestions for a Nice Street Suspension Setup
What's Cheaper??? Turbo or Engine Upgrade?
updates on the CRX paintjob
leaking sunroof!! HELP
Did your ZC passed emissions?
5 speed clutch
idle trouble
91 Honda Civic just bought and died twice
Please help!!!!!! NEwbie!!!!!!!!!!!
Custom Body Kit
mpfi auto crx dx 5$ for the answers!
How much would this be worth
How do I change my oxygen sensor?
Whats That Part Under The Tail Lgihts Called????
just look
crx rear disc brakes on a 89 civic hatch
Head Gasket Q?
TRANSMISSION iSSUE
Cylinder Head Stuck On
new hatchie :D
d-series question
Can this be done?
Changing alternator
b16a 88-91 long block
Inhibitor switch
88 Civic won't to start when hot
Rally Car?
distributor questions
Sedan Taillights
b16a question
shift into rev kills engine with rev light
d16y7 question
checking timing on 91 civic dx?
91 Civic DX starting problem
error code 7
Help, What is the thing circled in red?
89 civic si springs
Backed into, asking for estimates on repair costs from you.
b series tb on d series?!?!?!
Body kit and Suspension
Cluster Question
Can't rev past 4500rpm, missing etc
d16z6 swap to d13 shell
throwing a code
Head Swap
b20 info needed and tranny
running light relay ?????
ecu throwing injector code
crx doors
vtech motor for 88 crx
where to buy rebuilt d15b2?
Need Engine
Cylinder Head
running lights, cutting out while driving!
can i get a size please
Valve Cover Cleaner
Snow is no match
88 CRX Dash into a 90 Sedan
having engine trouble
Out of control idle
d16a6 interchangable with d16z6?
ctr n1 crankpulley
When to upgrade fuel sys.& add adj. cam gears
Hate to bring it back up (pulley)
'91 Acura axles on '88 CRX Si
DOHC ZC Head Swap possible?
quik clutch question
DPFI to MPFI
Starter question
SOHC ZC Questions???
'88 Si W/'91 TEG BRAKES
thought someone might need this (cheap price)
Starting Probs
do i need to use sealant on the valve cover gasket?
head gasket
Block Check. Eh?
18 non vtec to vtec
Civic Dominator
head cleaning
coilover question
Alternator problem or something else?
Selling a sedan
wiring up halos... (sorry if you've seen this a million times)
d16a1 head on a D15B2 block
cost$$$
[Pics]Some new additions: Tein, Line-X
my 1 grand crx. check it out
brake booster question
dropped hatch, pics
not starting 88 crx
new pics (56k no-no)
custom gauges
skid pad
sizes of auto parts, bolts etc.
compression ratio
Exhaust question
Rear shock assembly...
Vitesse body conversion
Motor and tranny problems
question on z6 or a6 head
Saint Louis Area Help!!!!
88 civic 4wd wagon?
Crank pulley remover tool!!!!!!
engine problems
turbo a d15b2
b16 shift linkage
synthetic atf in 1988, is this ok?
Nitrous Question
Weird Clutch Noise
d16a1
91 honda civic HB LX
b16a engine swap tranny problems
taillights
zc civic into dx crx help
manual for ignition lock?!?!?!
it's gone
My new Project CRX
civic wagon parts onto a hatch?
i need d15b vtec specs
Headlight Cleaning
1988 CRX VTEC engine tranny swap??
How to destroy a cylinder
gas cap pressure
Seatbelt light on and beeping
Suspension
alternator in89 CRX
Problem with friend hatch
b16 tranny lever is stuck up!!!
trunk strut pics?!?!?!
Any mechanics?
Gas Gauge Quirks.
Distributor Help
speed channel tonight civic story thing...
stupid taillights
rough idle
Rear Disk Brake
weird fan problem
curious if these projectors will fit my car...
Rim hit, alignment problem.
Civic running problems - could it be moisture?
Electrical Problem
best handling fwd car
to buy or not to buy
thermostat
are the sedan front bumpers the same as the hatch ones?
replacing fuel filter/pcv valve(?)
Dynamat
What would you pay for my car?
Where can i get charge pipes for my turbo system made?
failed emissions test
OK b16a swap stopped need help from the best you guyz!
Big Plans!!!!need Some Help
This IS CRAZY!!!
will a 1.6 v-tec exhaust fit a 1.4gl hatch?
teg master cyl in a crx ?
89 civic 4dr for sale
DPFI to MPFI conversion "HELP!!!!!!!!!!!!!!!!!!!
Front bumper lense removal '90 Honda Accord
problems with honda accord... please help
questions about suspension
1990 LX going into park sticks when cold
weight reduction
B16a
Engine Help
how to make exhaust "cleaner sounding"?
What engine is this?
Engine swap
Exhaust
is there a way to make my intake louder?
sprayer nozzles...
Ticking noise
Brake Capiler
California Emissions
vtec activation
Help: CRX battery light on, tach down and radio problem...strange!
1.4GL 91 hatch modding tips
Christmas Break Project
v-tech head for D series
Shift Interlock lag...
Where can I find or have charge pipes made for my turbo?
help plz
car idles goovey
Ignition Lock cylinder question....
Where can I find a cheap CAT?
cleaning up used head
swap problems
home made air intake?
D16a1 swap
Rod Knock!!!!
Engine wire harness problem
Led
Just got my turbo today!!!
lower ball joint in a 89 si hatch HELP!!!!
k24 into a 91 si
Ebay intake and header?
Repair or replace black window molding?
what is this worth?
Hey yall I need a Sticker Guy...Can yall help out a former 4g owner
Code 17 VSS
Update of my ride.
Car Wont Start
perfect bodykit?
New Project pics and Questions
OBD0 obd1 ecu info needed
rear spoiler noisy
Good deal?
Need Help
b16 engine
civic front bumper
CAI on rainy days ?
Bulbs blow in pairs?
Few questions/need some help
header question
I got a gift from god
Nitrous gurus need some help
ignition lock????
Fuel filter
B16a info needed
what you guys think about this???
mini me help
My cars, a big update.
stock ride height?
oem honda site
Painting side mirrors and moldings $?
Tachometer bouncing, Honda, Accord, 1997
i just bought a WHAT?!?!?!
Bad behavior...tell me what's wrong?
Distributor failure
Web
AF
