Our Community is 662,000 Strong. Join Us.
View Full Version : Malibu
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14
  1. 2001 Chevy Malibu Overflow Tube
  2. Replaced PCM
  3. Adding factory keyless entry to 2000 Malibu?
  4. 2004 Classic replaced passlock cylinder
  5. 2008 Malibu w/ clicking A/C & Heat.
  6. 2005 malibu p0449 codes
  7. 2004 Chev Classic chiltons/haynes manual?
  8. Malibu LX9 3.5L Coolant change
  9. 98 malibu wheel n front drive ruff
  10. power steering hose ??
  11. Abs cel lights and gas gauge
  12. Gold Edition 'Bu
  13. 2004 Classic 2.2 Ecotech
  14. Power Door locks not unlocking
  15. Camshaft position sensor
  16. 04-05 Malibu Classic General Thoughts?
  17. af news video: 2
  18. RPM's go up but no acceleration
  19. Thermostat going up and down
  20. verify crank bolt torque spec 1999 3.1
  21. Oil pressure light never come on
  22. 03 Malibu Crank Position Sensor
  23. 05 malibu gas problem
  24. 2000 Malibu no heat or a/c
  25. EGR cleaning/diagnosing
  26. 05 2.2 ecotech p0826 andp0026
  27. P00300 - Any ideas on how to solve that?
  28. Theft-proofing vanity plates
  29. 2005 Malibu classic overheating
  30. 2000 malibu no oil to rockers
  31. 1999 ls Find Ball joint boot
  32. 2001 Malibu won't start after head job..
  33. 2006 Malibu Starter Wire Hookup
  34. 2002 malibu radio disable lock out
  35. Car shakes when stopped in drive.Which Mount?
  36. Clogged converter ruined engine?
  37. 02 malibu stalling
  38. Making silver cars more noticeable in stormy weather
  39. Emissions Test( Readiness Monitors )
  40. 2001 Malibu overheating/brakes issue
  41. malibu issue
  42. theft light on consistantly and car still runs fine???
  43. air conditioner electrical issue
  44. Body Repair
  45. 2007 Maxx Remote Door Lock
  46. 2005 Malibu 2.2L Catalytic Converter
  47. Mal Maxx KS
  48. help! 97 malibu engine removal problem
  49. 2000 Chevy Malibu Electrical issue
  50. malibu 3.1 fuel rail reassembly help??
  51. 2000 chevy malibu start car but shuts right off
  52. malibu 3.1-just changed head gaskets. now it just cranks and backfires??
  53. 1999 Malibu 2.4 Running Rough
  54. 2005 Malibu LS V6 - Scrub radius
  55. Radiator Fluid Leak???
  56. AC question
  57. ignition switch???
  58. 2006 malibu ss HU replacement
  59. Cooling Issue...Please help
  60. any ideas??
  61. ABS light, no codes
  62. Just got the heads off, now I have some q's
  63. Third Coolant Reservoir Cracked and Leaking
  64. Is it possible to put a 350 rocket in a chevy?
  65. 98 Malibu LS won't start
  66. Malibu Maxx dvd lcd
  67. 98 malibu 3.1 hard starting
  68. High Idle and Trans Shifting Problems
  69. Considering buying a 2000 Malibu with a few problems, is it worth it?
  70. ABS scan
  71. All turns lamps out, fuse fine. Any thoughts?
  72. Correct ABS resistance reading
  73. Really Mad Malibu!
  74. 99' Malibu PLEASE HELP
  75. 00 malibu leaking coolant
  76. Radio problems
  77. Humming/whining noise from front end
  78. 03 malibu hubcap with plastic lug nuts behind cover
  79. passlock or cylinder 98 Malibu
  80. 2003 Malibu heat on full?!?
  81. A/C Noise
  82. oil in head valley please help
  83. 2000 Chevy Malibu, Won't go over 4k RPM
  84. Fuse Box?????
  85. 2001 malibu wierd noise from dash
  86. 1999 Chevy Malibu starts up, dies, then starts fine
  87. 02 malibu theft system problems
  88. 2001 Malibu pass power window problem
  89. 98' w/3100 - no spark, randomly starts
  90. 2005 door lock issues
  91. Need to replace front passenger door actuator 2002 Malibu
  92. no fuel (pump, filter, fuel pressure regulator?)
  93. 2000 malibu no fuel gettin to motor
  94. no fuel to motor
  95. 1999 chevy malibu fuel filter disconnect broke?
  96. 1999 V6 Cooling fan issues.
  97. 1999 malibu rear 3 spark plugs, best way to change
  98. A/c hot
  99. a/c problem
  100. 2010 Malibu headlight
  101. 2003 Malibu wont turn over.
  102. Half of HVAC lights out?
  103. Need advice on EGR Valve
  104. RCDLR location on 06 Maxx
  105. 0442 code and vacuum leak
  106. Coil Packs on 2.4?
  107. 99 Malibu 2.4 Bad Cylinder???
  108. 99 Malibu EGR
  109. 2003 won't start
  110. 2005 Malibu 3500 Eating Oil
  111. 2001 Malibu Power Steering Gear
  112. Park/Neutral saftely switch
  113. Check engine light
  114. 2001 malibu 3 problems
  115. Help with trouble codes
  116. Tire wear
  117. 2001 radio security light
  118. 05 Malibu Maxx VIN# question
  119. 05 Malibu Maxx LS rear wiper arm
  120. 05 Malibu Maxx LS sunshade won't retract
  121. 2003 Chevy Malibu...Can't turn key
  122. intermittent heat
  123. 2004 Drivers side low beam doesn't work hi beam does
  124. 99 malibu speed sensor
  125. DexCool gunk in the reservoir.
  126. 1998 malibu transmission question
  127. What are the torque specifics for a 2001 Chevy Malibu 3.1 V6 Model J?
  128. need help with 2001 malibu battery drain!!!
  129. 03 malibu
  130. Rpms fluctuate when slowing down
  131. 2001 Malibu will not fire
  132. 1998 Malibu rough starting
  133. classic forces to speed up
  134. 2006 Malibu Maxx Door Locks and Alarm
  135. Front end noise??
  136. seatbelts tensioners?
  137. 08 Malibu Headlight problems
  138. 99 Malibu - blower motor only works at startup for 3 mins, nothing else
  139. 2002 malibu rear wheel bearings
  140. 1999 Malibu rear speakers problem!
  141. 2004 malibu doesn't go into gear....
  142. Malibu Maxx Color
  143. Ticking sounds
  144. Remote stopped working
  145. 05 Malibu 3.5 fuel gauge fail
  146. 99 Malibu 3.1L-major tuneup
  147. How do you reinstall an ashtray in a 2003 Malibu?
  148. 2.4 or 3.6 in new Malibu?
  149. 2003 Chevy Malibu fuel pump fuse question
  150. 2001 Malibu - No Oil Pressure
  151. Electrical Problem?
  152. 2006 with 405,000 and only one repair
  153. Windshield washer fluid pump-06 Malibu
  154. Intake gasket fixed, but now the car
  155. 2005 malibu trouble code po455
  156. Sounds like a bearing going bad...
  157. Malibu wont start when cold
  158. cd player swap
  159. 2000 malibu 3.1
  160. 2005 classic = cabin drafty=-
  161. rear window regulator 99 malibu
  162. car wont start.....?????
  163. 2010 2.4 oil filter location
  164. possesed right directional
  165. El camino frame on a Malibu?
  166. theftlock question
  167. 2011 Malibu(USB IPod connection)
  168. 2005 Chevy Malibu Wipers
  169. 2006 malibu
  170. 99 Malibu no brake pedal
  171. 2002 malibu heater switch or fuse or relay?
  172. 2008 Malibu Brake Job
  173. 98 Malibu LX 2.4; dies after few miles ; will start again after about 1/2 hour
  174. classic malibu
  175. Buzzing? No - Sounding like a moped
  176. 2010 Malibu headlights
  177. 2003 Malibu EVAP Purge valve location
  178. Need Advice 99 Malibu- Timing chain failure 2.4L
  179. 2006 Chevy Malibu Maxx Rear Wiper Removal
  180. Replacing Serpentine belt
  181. 1999 Malibu stalling out with codes.
  182. '02 Malibu 4T40E Trans Noise
  183. no start
  184. 99 Malibu Headlight Repair
  185. malibu 2003 passlock?
  186. Torque Specs: Upper Intake manifold? lbs/per bolt?
  187. 05 Malibu cruise control steering wheel light out
  188. 99 3.1 V6 coolant loss overflow tube
  189. 2000 No turn signals no flashers
  190. MY BLINKERS! urgent!
  191. Body Control Module location
  192. Malibu's must be improrving...
  193. 04 maxx blend door location?
  194. could use a little help please
  195. 2000 Ambient Air Temperature Sensor Location
  196. 2006 Malibu Maxx AC Low/High side values.
  197. The 2010 chevy malibu
  198. 2002 front motor mount
  199. rust just below tank fill up door
  200. 2001 Malibu
  201. rear brakes 2005 malibu
  202. 2009 Malibu Hybrid Retrofit to Standard Ecotec?
  203. 98 malibu, head gasket replacement, now no start
  204. break problem
  205. 1999:engine knock
  206. P0420
  207. 00 Malibu 3 issues
  208. 2000 malibu overheating stumped
  209. 99 3.1 auto malibu, Dies at highway speeds.
  210. 2002 power window problem
  211. 2005 chevy malibu
  212. 2005 chevy malibu
  213. outlets not working-possibly others
  214. 2003 malibu coughing start
  215. 99 Malibu hard steering question
  216. problem bleeding the brakes
  217. pass key 3 or pk3
  218. Passlock Issue - 2001 Chevy Malibu
  219. 2004 Chevy Malibu instrument light problems
  220. Failed E-check
  221. 2004 Malibu Ticking
  222. buzzing door
  223. 1999 Malibu - Intermittent missing
  224. Airbag light stays on when car is shut off
  225. whats your operating temp on 06
  226. Tail light help please
  227. Malibu '07 knocking noise when turning..
  228. Remote start install
  229. 99 Malibu ABS light
  230. will a '98 3100 V6 fit in a 2000 malibu?
  231. got the correct CPSensor but it will not slide in..
  232. A place to buy weatherstripping for 03 malibu
  233. Intermiten A/C
  234. can you change transmissions from 98 to 01 malibu?
  235. 2005 engine type
  236. 2005 engine type
  237. 2005 engine type
  238. 2005 engine type
  239. 2001 Malibu Engine Light
  240. How many bolts in the oil pan?
  241. 99 Chevy Malibu Overheating PLZ HELP
  242. 99 Chevy Malibu Overheating PLZ HELP
  243. 99 Chevy Malibu Overheating PLZ HELP
  244. lookin at an 06 malibu
  245. 2005 Malibu V6 LS -- Pulls/Drifts to the left
  246. 99 Mailbu LS 3.1Intermittent Issues
  247. Degree of difficulty - Timing belt replacement
  248. Bad brakes or air in line
  249. Be Careful Replacing Wiper Blades on Chevy Malibu
  250. 1997 Malibu steering wheel don't lock
