View Full Version : Malibu
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12
  1. 1999 Malibu - Best Intake Manifold Gasket
  2. Still smoking a lot after changing lower intake So frustrated
  3. 99 Malibu gas guage drops down
  4. After intake gasket problem... leaking radiator?
  5. 97 malibu stalled
  6. Brown sludgy coolant (oil in coolant?)
  7. Head gasket or Intake manifold Please Help Coolant in oil
  8. 99 malibu fuel mileage
  9. 99 malibu 3.1 not starting
  10. Keyless entry programming 2004 Malibu
  11. rsandstrom
  12. 99 malibu died on hwy, have spark, fuel pump buzz, but no fuel pres @ rail!?
  13. 06 Malibu Maxx, thump when steering turns
  14. intermittent no-start
  15. 1998 Malibu - check engine light
  16. Multifunction Switch
  17. Wouldn't you know it, now it's a P1404 code
  18. 98 Malibu will not start
  19. 98 Malibu runs rough/check engine light
  20. 05 malibu Maxx
  21. '98 Malibu broke cam 3.1
  22. 1997-2003 Malibu Control Arm Torque
  23. 02 malibu bad acceleration after warm up
  24. 2001 Malibu not wanting to start?
  25. smell and burning gas fatser
  26. What is this ?? see pic
  27. replacing ignition switch 2003 malibu
  28. 2002 chevy malibu door lock switch
  29. Gas filter blowing out on highway.
  30. malibu v6 3.1 and camaro v6 3.1
  31. 99 Malibu 3.1 logging in
  32. 05 malibu Maxx
  33. Rumbling Noise from wheels.
  34. 05 Malibu factory radio - adding MP3
  35. Cleaning the grease off the engine...
  36. 1998 malibu 3.1 trany leak
  37. Coolant smell, but no visible leak.
  38. Heater hose quick connect
  39. 99 malibu trans and abs
  40. 2007 Mailbu Drivers Side front end clicking
  41. 97' malibu
  42. Will a 1999 4 cylinder transmisson work in 1999 v6?
  43. 2000 Mailbu windshield defroster not working.
  44. 2003 Malibu High Idle Again
  45. 99 Malibu CVJoints
  46. 05 Malibu in glass antenna connection broke
  47. Is that possible to install in Malibu 05 radio from new Malibu(08+) or other GM car?
  48. 2001chevy malibu overheating
  49. 05' Malibu no heat?
  50. 1997 3.1 v6 broken cam
  51. 1997 malibu 2.4 head gasket
  52. Ticking from vents
  53. 98 Malibu Really excessive idle + more
  54. 99 malibu EGR insufficent flow code
  55. 3.1 Heads Shaved now no compression
  56. Electrical issue
  57. 2003 chevy malibu
  58. First Oil Change/Checking level
  59. How to replace power window switch?
  60. 1997 Malibu starts and runs then dies
  61. Malibu A/C Bypass Pulley?
  62. 2000 malibu Ac and heat not blowing
  63. 2004 malibu classic odo and speedo not workin.
  64. 04 classic/malibu Wont Start
  65. Ligher socket
  66. Help with yet another miss
  67. Location of EGR valve-2001 Malibu 3.1
  68. Gas Pump Problems?
  69. Will these rims fit?
  70. 2003 Malibu High Idle
  71. LIM replacement torque specs needed
  72. 1997 malibu car temp
  73. A/C kicks on and off intermittently
  74. Close to the end
  75. Car will crank; won't always run-- sometimes quits while driving
  76. 2006 Malibu 4-cyl 2.2L trouble
  77. 2000 Malibu ignition & shifter
  78. 2005 malibu classic
  79. 2003 Malibu wont start
  80. 2005 Malibu Maxx owners manual
  81. 2008 Malibu - 30,000 mile update
  82. Door lock switches
  83. help adding freon to 2004 malibu
  84. 2000 Malibu, Blinker keeps blinking
  85. Battery getting drained
  86. 2001 Malibu air conditioner Control Knob
  87. 06 steering linkage question
  88. Keyless entry?
  89. Will these fit?
  90. check engine light
  91. Block Coolant Drain Plug
  92. 09' malibu fails to scan
  93. No accessory power
  94. What years/models of 4T65-E work in a 99?
  95. 2005 Chevy Classic trouble starting after putting in gas
  96. 99 Malibu LS 3.1 107,000 miles: hi idle RPM
  97. 97 Malibu - should I keep it?
  98. 97 malibu power steering leak
  99. 2002 malibu
  100. ABS/brakes and more
  101. Rear Seat Back Removal
  102. 2003 Malibu starts but stalls immediatly?
  103. break peddle noisy
  104. Malibu maxx drag car
  105. A/C Light Flickers! Any Suggestions?
  106. 2006 Chevrolet Mlibu Maxx LT transmission cooler
  107. how do you check the transmission fluid level on a 97 malibu
  108. Go ahead and give me the dunce cap (2000 - Rear lateral rod bent)
  109. 2006 Malibu Maxx shifting hard
  110. 99 malibu, 3.1L wont take coolant
  111. Resistor or Blower Motor?
  112. Ignition Switch
  113. How to. Manual +/- shift not working and trans downshifts too easily.
  114. 2003 Chevy Malibu keyless entry
  115. sludge in antifreeze overflow tank 98-99 malibu
  116. My steering wheel is not able to steer
  117. 2007 Malibu, randomly jerks to left
  118. I am having steering problems
  119. 97 malibue intake-exhuast gasket - Need help!
  120. Cooling fan problems
  121. 2004 malibu ac
  122. malibu as project car?
  123. 00 Starter replacement 3.1 V6
  124. multifunction switch
  125. check oil light 1997 malibu
  126. After-market key FOB?
  127. 2000 Malibu Tranny issues
  128. CEL on, code 455 2007 Mal Maxx 3.5L
  129. tie rod torques 04 Z body
  130. Vibrating noise from DASH
  131. 2.2 Oil filter cap leaking oil
  132. malibu-2003 stops while driving
  133. 2001 malibu fuel pump
  134. Speed Controlled Volume
  135. Louder Music with Acceleration
  136. 2004 classic HVAC vent flow
  137. 2004 Malibu spark plug
  138. 2006 Malibu LS - Seat belt pretensioner & Air Bag light question
  139. Headlamps / DRL flickering
  140. 1998 Malibu PassLock Issue
  141. Engine light
  142. Door ajar
  143. ABS light constantly on
  144. Shocks or struts problem
  145. 06 Malibu Maxx LT--rear tail light question
  146. 1998 2.4 with 200,000 kms . to fix or not to fix ??
  147. 2000 Malibu axel wobbles - fixabel?
  148. Fuel pump on/off
  149. Passlock 2 bypass help
  150. possible coolant leak per GM
  151. 1999 Malibu Window wont go down
  152. Battery trouble Issue
  153. '99 Malibu Windshield Molding
  154. 1999 chevy malibu bad fuel pump
  155. Exhaust System
  156. 99 malibu this one has me stumped
  157. Scanner values
  158. 98 Malibu hard start when cold
  159. 99 Malibu electrical problems - update
  160. 05 Mailbu Runs on after turning off?
  161. Is extended warranty worth the money?
  162. Fog Light Bolts
  163. 99 Malibu 3.1L electrical problems
  164. lights dim and car wont start sometime
  165. 2003 malibu 3.1 jerking/serging?????
  166. The Coolant Air Bleed Stuck!
  167. '99 3.1 issues
  168. 2006 malibu and impallas
  169. 03 Malibu Brake Issue
  170. 2006 chevy malibu keyless remote
  171. Intake gasket: temporary fix
  172. Fuel gauge going crazy
  173. Instrument Cluster Inop Exc. Temp Gauge
  174. Installing Glow Gauges in 98 Malibu
  175. Gas Mileage
  176. 2005 Classic; premature wheel bearing hub wear?
  177. 2004 Malibu(bew body style) dash removal
  178. programming remote
  179. 03 malibu heater only works on 5
  180. Stub Shaft Removal
  181. Beaten to Death - Head or LIM Gasket?
  182. 98 chevy malibu ls engine mount problem please help
  183. Tranny Mount?
  184. Help
  185. Brake and ABS light on
  186. HELP!! scan Communication Error
  187. Replacing the lower IMG on my Malibu
  188. Cooling fans stay on
  189. Lower control arm bushing question
  190. 2004 Malibu Slightly Overheats
  191. replacing Transmission Filter
  192. Heater fan resistor
  193. Temp Sensor Replacement: to DIY or not to DIY?
  194. Dex-cool and Malibus
  195. '04 Classic tranny fill/level plug
  196. Ello Peeps!
  197. oil Filter gskt blows out
  198. How to change oil and oil filter on 2001 malibu
  199. 06 Malibu Maxx LT Braking troubles
  200. 2001 malibu has hesitation when i give it gas
  201. 2001 Malibu Overheating and Hard Start
  202. 03 Malibu gas and temperature meter go down
  203. HELP troubleshooting
  204. help please: is it a 1971 malibu?
  205. Oil Leak Question
  206. 99 Malibu, dashboard lights went out, check vehicle light came on
  207. 1998 malibu No Start
  208. Front Sway Bar
  209. 99 Malibu wont downshift.
  210. Malibu 2003 No Start
  211. 2006 malibu rear bulb replacement
  212. 2004 Malibu headlight replacement help
  213. 2001 Malibu front end noise after hitting a deep rut.
  214. 2003 Malibu brake light - opposite operation
  215. 2004 Malibu Maxx Grill
  216. 97 Intake manifold change-needs advice
  217. 06 Maxx Wheel Hub Issues
  218. Please Help! Big Problem!!!!
  219. Thleft system or starter
  220. 1997 Malibu Won't Start
  221. Changing PCM...What does it take
  222. 2002 Malibu hesitation
  223. A problem with replacing my left taillight cover
  224. Porisoty in a rim.
  225. 2002 Malibu Hesitation / Temp issues
  226. 98 Malibu AMP Installation - POWER WIRE
  227. 2004 Malibu shakes when braking
  228. 2001 Malibu Steering Wheel locks up
  229. CD Player Quit Working
  230. 3500 V-6 Check Engine Light
  231. 2005 4 banger gas gauge issue
  232. 99 Malibu dies inconsitantly
  233. 1997 malibu cuts off
  234. 02 Replaced Intake Gasket, now leaking/burning oil
  235. 07 Malibu block heater
  236. 2003 Malibu Interior Leaks
  237. 1999 Malibu Remote Programming
  238. Shift button won't release- stuck in park
  239. 05malibu ls
  240. 05 malibu ls govener
  241. Bucking?
  242. Engine won't warm up
  243. Fuel Gauge is Backwards
  244. RPO code sticker.
  245. Hi, does my car have ABS
  246. cv joints
  247. Do all malibus have rear tire wear problems?
  248. 98 malibu wont get out of park
  249. gas meter gauge problem
  250. Sudden Overflow from the coolant reservoir
