View Full Version : Malibu
Pages :
1 2 3 4 5 6 7 8 [ 9]
10 11 12 13 14 15
- 99 Out
- Steering Freeze Crash
- Class Action Filed in Canada for Intake Manifold Gasket
- drl delay is out
- new 99 malbu ls owner
- Radiator replacement
- Avoid Rust
- Hi all
- 2002 Fuel filter change schedule?
- 2002 Malibu feels rough when cornering.
- running day light out
- FS: 98 Malibu - 3.1 v6 - Leather - Loaded
- New owner questions
- front windows
- How Many Miles on Your Malibu?
- Lamp dimmer module
- radiator installation question
- Coolant Leak , Check This
- 2004 Malibu Classic rubbing noise turn left
- engine computer
- 1997 Malibu Ignition problems
- Injector O rings
- Leaking coolant
- Trans fluid level
- How to support engine
- 2004 Malibu Gas Gauge Problem
- Loud Hum on 02 Malibu
- Extremely high RPM output
- 03 malibu a/c question
- Rear speaker wiring
- Stereo anti-theft code lost
- Keyless Entry or No?
- Advice on buying a 2001 Malibu
- See ya later POS Malibu
- Lower Intake Manifold Gaskets
- swap
- Jet Chip
- Multiple/Random Misfire
- 99 clicks but won't start
- Dash Warning Lights Going Crazy
- 2000 Malibu Transmission
- 2001 malibu will not start
- Intake Gasket and GM Reimbursement
- Front end hum
- Seafoam and 2000 Malibu???
- cylinder misfire
- start/stop problem
- Milky oil on '98 3.1L filler cap
- 98 Taurus Position Sensor
- 2004 Malibu Maxx - Starting Problems!
- 2001 malibu temp gauge quit on me
- Multiple problems with 2000 Malibu
- Passenger side Transaxle seal
- Wiring Question
- Cooling fan blades and shroud
- Egr parts for sale
- Fuel injectors F/S
- Painted Intake manifold for sale
- Coolant Leak 98 Mal V6 3.1l
- 98 blinker comes on when brakes are hit
- run on starter on maxx
- 2000 Malibu keyless entry reprogamming
- 99 Malibu Dies until hood is opened then shut!!
- 98 malibu difficult to start
- Intake leak
- 99 malibu front strut mount
- 2000 malibu quits running differant conditions
- Lacks power and surging
- 2000 Chevy Malibu Serpentine belt
- My Malibu
- swap 01 GP 3100 in 1998 cutlass
- Head Gasket Question on 3.1L
- Newbie
- Malibu blues
- passlock...fuel pump relay???
- Malibu 03 trouble starting , and turn signal
- Thermostat House /Lower Intake Manifold on 2000 Malibu 3.1L V6
- Horrible oil leak 2000 Malibu 3.1L V6
- brake lines
- 2001 Malibu turns off while driving....
- 2005 Malibu Lx dashboard noises
- 98 oil light
- 98-03 Trenz Billet grill for sale!!
- 03 malibu a/c
- 1998 cruise control
- 2001 Malibu overheating problem
- 1998 AM/FM Radio woes
- Aftermarket CD changer
- Two Questions
- Two Questions
- 1999 Water Pump
- 2000 Malibu - Weird Clicking, polterguiest? LOL
- 2003 malibu stereo installation problem
- chevy malibu 2003 dash
- Lose Heat after 30 minute drive in 2000 Malibu, Not the resistor
- 2000 Malibu - First 2 air settings don't work?
- 2000 Malibu...NO HEAT....need help
- Auto window issues
- 2000 Malibu, 15 MPG HELP!!!
- 2006 Malibu
- 79 malibu V8 bucket seats
- front driver side leaning
- Radio and Speakers remplacement...
- Valve chatter on a 99 3.1 v6
- Radio harness??
- Sudden loss of power steering in 99 Malibu
- 98 Transaxle Output Shaft - Stubs and Seals
- carb outta wack!
- over heating
- Hp
- Headlights
- Will turn over but wont fire.
- Air Resonater
- Belt Tensioner Loose
- static issues with the door
- malibu Forum
- '00 Malibu drivetrain noise
- 1998 Radio
- Climate controls
- SOB, both p0440 and p0302 codes
- Ready to destroy 2000 Malibu
- 98 MAL Fuel guage and Battery bad ?
- 2003 malibu help needed
- wanting to take out stock stereo
- 2003 Malibu won't start
- How much is my car worth?
- starting problems
- No HEAT!
- front wheel hub bearings
- 02 malibu heater blower motor problem
- 98 ignition electrical not passlock
- Horn Honks for no Reason
- 2.4 thermostat
- Head Gasket Leaking?
- Finished Motor Swap
- 2000 Malibu internal engine failure
- RSD wiring diagram
- 99 overheating...still!
- 97 Malibu with surging idle
- Malibu CD Player Likes HP CD-Rs
- '04-'06 Malibu/Maxx Front Suspension Noise
- 97--any shop manuals?
- Cutlass trans cont...
- malibu clicking when brake
- rev-limiter
- Electric steering adjustable?
- Serpentine Belt On 2003 Malibu??
- 2003 Malibu problems,need help
- Vehicle Speed Sensor Wire?
- How many O2 sensors
- Passlock 2 Security Syatem
- Will a 2000 Glove Box fit a 98?
- cooling fans not working
- Trans question
- 2003 Chevy Malibu. Climate control blower.
- Solution to Ignition / No start / theft system problem!!!
- I need help ASAP
- 98 Malibu wiring for stereo??
- Motor Swap
- 1998 Malibu Computer reset
- Growling/Popping Noise: How to tell diff between bad CV joint vs. hub bearing?
- CD Stuck in warm weather
- computer readiness tests
- 2001 malibu stereo
- RDS Radio and Code for lock out
- 1998 malibu parts
- Tire pressure
- Malibu 2000 Injection service
- wrench size for drain plug 05 3.5l
- honk honk
- Headlight is not turning off -- any suggestions
- New to Forums ~ Have a question
- DIC "temp"
- Stereo bulbs
- 98 Malibu wont start!HELP
- rear defogger
- Malibu 99 won't start - need some URGENT advice.
- '99 Malibu Cooling System
- Replacing Computer on 02 Malibu
- Buying my first car, should i go for it?
- CEL, ECU location and pulling codes
- 79' Malibu
- rough idle
- Shorted out my signal/hazard?
- Malibu supercharge
- Crackling noise in dash when temperature is cold
- Check Engine Light
- 98 malibu electric windows
- 2005 Malibu Maxx gas cap - one that locks?
- rough starts
- water inside after rain
- Front end repair
- Check Engine Light!!!
- 2000 Malibu trans. fluid
- 1999 Malibu.. Change Headlights????
- 2000 Malibu 3.1L hard/no cold start
- Hum from Heater
- 1999 Malibu Won't Start
- 98 malibu transmission shifter
- 98 4cyl Starts then dies.....
- 04 Malibu/Maxx Automatic Lights
- 04 Malibu axle seal, check yours.
- 1997 Chevy Malibu
- Have Fuel and Spark, But No Start???
- Acetone increase fuel mileage ?
- Cold Engine Knock
- Warning Lights and Parking Brake
- Last question for now... Gas Recommendations?
- Anyone from Iowa with a MAXX?
- Window Tint in Iowa - Recommendations?
- New tires for 05 Maxx LS - Toughts?
- May sound dumb but need help
- Tape Deck
- Heated seat question
- Help!!! 99 Malibu is a bag of....
- 97 malibu won't go
- 2005 Malibu Remote Starter Faliure
- need advice, or a rough estimate...
- passlock sensor in 1998 malibu
- 05 Maxx vibration at hwy speed
- Does keyless entry have a fuse?
- also leaking coolant
- Theft Deterrent Password Relearn
- Radio Volume Problem
- No Start, No Spark?
- 2003 malibu starts for 1 second, dies. fuel filter??
- Passlock Toggle Switch
- 2001 Malibu Intermittent Start Failure and other similar problems
- transmission
- 99-how do I change the light above the back license plate?
- N-body subforum
- Check oil light- cold weather
- Intermittent Check Engine Light
- Urgent...Help me please!
- 97 Malibu 3.1 V6 Rough Idle
- 2003 - V6 : it just died..
- Transaxle question
- Opinions on 2000 Malibu V6?
- 04 malibu maxx front axle seal
- can you put an impala motor in a 01 malibu ?
- '01 Malibu Headlight Damage Help Plz!
- Loc message on radio
- 98 Malibu Whining, HELP?
- Check Engine Code
- Programming a keyless remote 02 Malibu
- Please, please. Help me.
- malibu
- factory door speaker size?
