View Full Version : Malibu
Pages :
1 2 3 4 5 6 7 8 [ 9]
10 11 12
- New '04 Malibu/Maxx Recall
- Malibu Cruiser Bodykit Group Buy
- Window tints
- 98 Malibu A/C and fan problems: more feedback needed
- Wtb: Ecu
- i'm retarted
- swapping engines
- Engine Serial Number
- XM Radio in an '01
- Hard Start?
- Stiffness and noise in power steering
- 2003 mali crashed
- Alignment after Outer Tie Rod End replacement?
- Look at this beauty!
- tie rod end removal, 1997 malibu, how to?
- 2004 Malibu engine temperature
- my radio is locked
- no more malibu
- 01 Malibu - front end collision kill switch?
- New Malibu
- exhaust mod help
- euro lights
- malibu fuel pump
- over heating
- leaky trunk
- help me!
- Sunroof adj.
- 1999...Replacing Tag Lights
- Coolant leak rough idle
- Environmental controls shorting
- Shaking in front end at highway speeds
- obd II scanners, and emmisions testing
- Oil in Coolant Tank?
- 99 Malibu with random cylinder misfire.
- 1998 rear strut replacement
- Theft system question! '98 Help Meeee
- 2001 Chevy Malibu For Sale
- wheel question
- over heating in my 78 malibu need help
- side marker light
- 2003 Keyless Entry Programming
- 1997 Malibu Mystery
- carbon fiber hood
- 2003 Malibu Quit
- Car Won't Start - Losing Power
- 2001 Malibu Problems
- FLipflop trunk? ANyone try it yet?
- Euro tail lights 97- 03 malibu
- what wheels fit an 04 malibu
- Noise and shaking in front end
- Major Mali Problem
- 1997 Malibu For Sale! Nice!
- Headlights
- 1998 3100 SFI Malibu COLD AIR INTAKE!!!
- rough idle and dies in morining only
- Tune Up Needed?
- Cannot put car into gear when cold.
- Looking to Buy
- Brake
- Trunk lid
- Trany Problem
- Buttons peeling
- Timing chain?
- radio mute wire
- Trannie Whine/'04 Maxx
- AfterMarket Upgrades
- Trunk Light
- GUNN Chevrolet
- $260.00 for a fuel pump!!!? What the F*ck
- Power Loss
- Brake lights don't work!
- 17" rims?
- Battery Cables
- awsome
- Replacing 99 Malibu front hub assembly - Looking for torque specs
- keyless programming instructions for 2001 Malibu
- 04 Stereo Wire Harness
- safety feature, or prob??
- Malibu/Maxx Restyled for '06
- Help me pick a rim!
- How To?
- So has anyone tried the Tornado thing?
- Radio Replacement
- Stereo Removal...
- is the fuel pump a DYI project?
- Door Lights Need Replacing
- Aftermarket Radio in '99 Malibu
- Where are the oxygen sensors for 1999 malibu 3.1
- Engine surging after I put gas in it, rusted fuel line going into filter - Input?
- 2000 Malbiu not reaching Normal Operating temp
- Zapped
- Gauge Lights
- Headlight problem!!
- auto rx or other flush/cleaners
- 2000 Malibu hesitates at idle stopped at red lights, Any Help?
- 03 Malibu heater blower resister location?
- DexCool or Antifreeze?
- should i throw my Bu away?
- Chevy 350 Guys
- Tough in a wreck
- 98malibu keyless remote programming
- front end shake
- Malibu features
- 98 Malibu clicking and shift indicator lights
- battery indicator light on
- Warm-up problems 1998 Malibu
- intermittent fuel pump?
- 01 malibu grille pn a 98? Will it work?
- 97 malibu Lock Cylinder needs replaced
- starting problems HELP needed
- U Guys Suck
- Seeking Opinions on 04 Classic with 2.2L ecotec
- Transmission Rebuild Cost
- Lambo doors???
- sunroof?
- fold down seats?!
- Programming Keyless Remote
- brakes squeak after I changed them
- My Dash lights dont work!!!
- chevelle malibu 1972
- Battery Replacement Terminal Question
- Car won't start
- Striped bolt! HELP?
- 99 Malibu ECU Swap
- Fluid Capacity?
- 2001 headlights hesitating to come on
- please help
- I have been told 20inch rims will fit on 2004 Malibu anybody who actually has them on
- Grinding when braking
- P0172 code
- 2001 Malibu Front ABS Disc Brakes
- Installing Automatic Locks and Cruise Control on 99 Malibu
- passenger windows won't defrost
- What is my bu worth?
- Transmisson Questions?
- lamp dimmer module location plz reply!
- Power steering pump
- FYI: 98-01 Malibu Brake Pad Recall Rejected in Texas
- Technical Question PLZ Help
- 1998 Malibu Shifter
- 2004 malibu radio problems
- knocking in engine 1999 Malibu LS
- 2003 stereo question
- I need inputs. Will these look good on my 98 malibu?
- 1972 Malibu covertible
- 1998 Malibu
- '01 Malibu Perfomance
- Malibu won't start on warm enging
- Theft Sytem and Ignition
- Exhaust Systems
- '03 Malibu Cluster removal
- 2001 Malibut Blower Switch Malfunction
- 1966 Malibu
- If you have rims on your malibu send pics
- Rear wheel cyinder
- Front license plate bracket install?
- Engine Swap
- 02 theft lock problem
- FOR SALE: Malibu aftermarket stereo installation kit and wiring harness
- Heat will not blow on feet in 97 Malibu
- yet another blower motor/resistor question...
- 1999 Malibu steering wheel lock
- Is WD-40 good for frozen door latches
- Antilock brakes??
- Dependable,mid-sized,4 door,RWD car
- 99 Malibu - ABS warning light
- Mechanics ... a 99 Malibu ABS Hydraulic Pump Question
- door lock actuator replacement
- Headlight Adjustment
- Exhaust
- Strut Tower Bar
- 98 Malibu LS Coolant leaking!
- Where has the filter gone??
- U want MODs I GOT MODS!
- rod knocking?
- Replacing rotors
- help rought idle
- Removing front axel,
- classic
- 2000 Malibu
- Windows fogging up
- Fuel Odor
- Newbi!!!! (im a girl! :/ Help)
- driving lights
- 99 bu- speed guade for 4 cly in v6's?
- Power Steering, Wheels and ABS System ... HELP!
- Seatbelt sensor light goes off randomly...
- 02 Malibu-JUNK ON WHEELS
- check engine light.....thinks the mechanic screwed up
- 01 malibu aftermarket stereo
- Mods on my malibu!
- Dual exhaust
- Power Steering
- Altezza Rear Tail Lamps
- ECU Tuner for 97?
- Engines stalls after 2 minute running
- changeing plugs in a 6 cyclender 97 malibu
- Headlamps
- Malibu 2000 heater guidance
- 2000 Malibu belt shred Crank pulley?
- '01 Malibu will not start - not a passlock prob
- mass air flow
- torque specs ,front wheel bearing?
- antifreeze shooting outs reserve when car overheating in 97 malibu
- Aftermarket Stereo
- Excessive brake pedal travel
- malibu or impala?
- gas leak
- P0113 "IAT Sensor"
- 01 Malibu. How serious is the code
- sidemarker bulb size anyone!? still cant find it!
- freeplay in steering after GM recall service
- A new Web Site!
- Help
- Headlight Bulbs
- Exhaust
- How to check auto tranny fluid?
- Help me! I need to remove main panel on Malibu 2000
- Coolant Flush Questions after Intake Gasket Replacement.
- anyone got pics of theyre malibus hooked up??
- 1999 Malibu heating problem
- 99 Malibu Wiper problem
- 02 Malibu Firing Problem
- 98 Auto Trans shifting problem
- 2000 Malibu ignition key won't turn! Help!
- automatic transmission problem.
- Struts for 1998 Chevy Malibu
- the no start problem
- Hazard Switch
- Warranty ran out...dealer helped
- Cooling Fan Problem
- ABS light and buzzer question..
- 1998 Chevy Malibu LS Exhaust Questions
- 97' Engine Swap
- programming instructions for 2003 mailibu
- 2004 Classic Malibu
- 99 brake lights
- Need help removing the dash on a 2004 Malibu
- Sevice Vehicle Soon Light
- 99 mailubu chain or belt timing????
- Malibu Brake bleeders
- noise when you go on above 80-90 km
- Change Headlight Bulb
- Theft system problem
- Engine code P1815
- 2002 Malibu LS Head Unit
- Advice for 03 rotor replacement?
- 98 Malibu-Engine just Shuts-off
- Engine Problem..Help!!!
- New Car Stereo installing
