View Full Version : Malibu
Pages :
1 2 3 4 5 6 7 [ 8]
9 10 11 12 13 14 15
- 99 Malibu, starts and dies after 2 secs, Battery dead, gas guage showing empty
- Winsheild Wipers have gone wild!
- Headlights wont turn off!! HELP!!!
- P0304? or a sign of a bigger problem?
- Oil Life Monitor
- Malibu won't start! Passkey Security?
- Straight pipe
- Help!!! How to reset the theft system???
- Want my malibu faster...
- Fuel Pump reset button
- 06 3.5L Malibu Maxx fuse size
- Sluggish 200 Malibu
- How do you?
- 2002 Malibu Code P0300 and P0420
- no tail lights or tail lights
- Lock out (park lock?) solenoid in '98?
- Installing aftermarket car starter
- Have to hit the gas when cranking
- Dextcool question...do I have to?
- Overheating issues with my Malibu?
- 2001 Malibu Wiper Help
- 2004 Malibu transmission fluid level check
- Keyless Remote Programming
- Transmission Probs
- 99 malibu radio locked?
- Light "squeel" in steering wheel
- 2004 Malibu Maxx FM Antenna Modulator Question
- 2000 Malibu / hazard switch
- Help me find the noise
- Replaced intake manifold gasket, now theres crap in the coolant
- Low coolant light on, but the coolant isnt low?
- radiator drain plug
- 99 Mailibu shut off while driving
- Coolant Smell
- Name that connector! Pics inside..
- '97 3.1 Trouble Starting
- 98 Malibu.... engine noise/cease running
- 98 Malibu low idle while in gear and intermittent stalling
- 1998 Malibu stalling when idol
- 98 malibu hesitating badly
- 2003 Chevy Malibu interior help needed
- VATs passlock
- keyless remote - service vehicule soon light problem
- no heat or ac??
- fuel pump removal?
- 97 Malibu Ticking And Sluggish At First
- Gas gauge fainted....
- 2003 Malibu/door locks
- 97 Malibu Low Coolant Light
- EGR and EOP problems
- Over Heating Problem
- 2004 Malibu Maxx OEM Radio with Subs?
- Does any one have a V-6 3.1 Malibu 98 engine for sale? or knows where I can find one?
- 98 Malibu misfires when hot
- is it worth it to put 700 or 800$ into a 1999 chey malibu?
- 2.4l random misfire
- Malibu LS 2.2L is Underated
- Air Bag controller problems
- Fan Vibrates?
- 2001 Malibu starts, but dies with no gas applied, cussing does not help
- 2000 malibu ???????
- Evaporative Emissions Control System Failure P0440
- 1998 Malibu ABS
- Malibu 2002
- Loud popping noise in steering.
- 02 Malibu Not the hazard flasher
- HELP!! Put steering fluid in brake reservior
- Won't Start...?
- DIC Problem/Questions!!! HELP!
- Dex cool gooo
- Attacking the "BEAST"
- Spark Plugs
- beeping under left side of dash
- 98 malibu shifter problems
- ABS Speed sensor harness
- anti-theft system
- For Bu lovers...
- Shop Manual
- problems w/2000 malibu
- problems with 2000 chevy malibu!
- vapor canister
- Transmission replacement...rebuild
- 98 Malibu 4 cyl (what problems have you had?)
- 2005 3.5L Front Passenger Turn signal out
- Found a service DVD on Ebay.
- Has any one bought and tried this?
- Transmission code p1810
- Need some guidance
- Install CD player on 2000 malibu
- where is thermostat in 99 malibu?
- 2000 malibu overheated and now won't start
- Fuel Injector/Rail clips...
- 1999 malibu turn signal flasher
- Fuel Pressure Spec
- 1998 Chevrolet Malibu Starter/Solenoid
- Changing your coolant EARLY!!!!!
- 1998 Chevy Malibu Fan relay
- Radio Removal / Replacement
- 97 Malibu A/C Controller
- Is it easy to replace front coil spring?
- Problems on Malibu 98 LS to fix??anyone
- Malibu 98 LS fog light replacement instructions
- 2004 Chevrolet Malibu PCV valve location
- '99 Drifts Left Even After Alignment
- weird problem.... passlock????
- Newer Malibu any good?
- Class II radio on my malibu?
- 1998 Chevy Malibu Electrical problem
- engine go off when a/c turn on
- 2003 Malibu Overheating
- 2001 malibu won't start
- Another Intake Gasket Question
- Rusted Coil Towers
- 2000 malibu tune up
- 03 malibu a/c
- chirping sound from the belt area
- Changing battery/avoid radio lockup
- 1998 Malibu AC Recharge Help
- CD Player
- Another AC problem...help!
- Flasher Replacement
- Radio Code
- Drive belt Replacement
- Installing new stereo on 05 Malibu
- New (to me) Malibu?
- 05 Temp gage inop
- can this happen
- Malibu, Grand Am, Alero interchangable body Panels?
- radio will not turn off
- 2000 Malibu + faulty Fuel Gauge
- 1998 different kind of AC problem
- 03 malibu missing
- 2005 Malibu Cruise Control
- Lower intake bolts didn't go back in, now holes are fouled...
- Mass Air Flow Sensor
- How Does One Change The Spark Plugs? (2000 Malibu)
- 1998 Malibu - Weird Clicking
- Catalytic Converter
- 2001 Malibu OEM cruise control
- Leaking Anitfreeze ?
- 2004 Malibu Maxx DVD
- installed new stereo, now no tail lights etc...
- ac light blinks and ac stops cooling.
- Gauges at 0, no start occationally
- New key from vin #
- 98 Malibu hard starting
- 98 Malibu ac problems
- 02 Malibu break Creaking and abnormal wear
- 1999 Malibu brake noise
- Installing a keyless entry system first time
- Is front spring replacment a DYI project?
- 98 malibu AC problem help
- power windows
- The new Malibu 2007
- A C problem
- 01 malibu - noise when i brake
- 2000: Oil light comes on around curves
- 1998: new alternator, now fuel gauge is incorrect
- '97 Malibu electrical issue
- 1999 malibu
- 2001 3.1L V6 Oil Leak
- 98 Malibu 3.1L
- Headlights: one brighter than other.
- Sticking Key Problem ???
- Transmission Problems
- won't start
- transmission questions???
- Hard-starting 2004 Chevy Malibu Maxx
- lower intake manifold gaskets, dexcool
- 2001 AC Recharge
- ABS Upgrade
- 2000 Malibu - Worth it?
- Transmission problems (i guess)
- Fuel System Problem - pump or regulator?
- Front spring is busted; 99 Malibu
- Red threadlocker and lower intake manifold
- AC question
- 2000 Malibu Sounds like a diesel on Startup (cold)
- 99" Malibu Check Engine Light
- Driver's Side Mirror
- How Do I Drain the Fuel Tank?
- Wont Start
- how to read error codes?
- 99 malibu a/c leak
- no heat 05 malibu ls
- rev on cold start
- Overfilled Transaxle
- 2006 Ss
- things i had to do to my malibu
- heres some advice
- Car won't start... Give it 15 Minutes...
- Another a/c question, '99 Malibu v6
- 98 Malibu new starter tripping main fuse
- Mailbu Transmission Problem
- ABS Light
- new 97 Malibu owner questions
- Motor Swap?
- 04 malibu killer headlights
- lighter/Fuse Box Layout
- Trunk ACC outlet, '05 Malibu LS Sedan
- Fuel Filter Change - How to
- Air Condition
- 98 Malibu Brakelights
- Take gas cover off car dies
- Stripped out rockerarm mounting hole
- 03 malibu brakes
- Fuel Pump
- changing coolant
- 98 Malibu won't start fuel gage at E has gas
- interior trim
- Clicking noise on start up
- Malibu Hazard/Turn-Signal Inop Problem
- 2002 Malibu Air Conditioning Inop
- Oil pump
- overdrive gear ratio?
- How do I remove alternator bracket
- Speakers
- Need Help with A/C on 98 Malibu
- 98 Malibu A/C Problem
- cyl #4 misfire
- 02 Malibu radio/door chime problem...Help!!!
- 1998 Malibu
- Bad Starter, Bad Battery or Bad Alternator
- 98 chevy malibu
- Lets force GM to change its Building Suck Cars culture
- 2003 mbu front end rattling noise
- 03 malibu brakes
- 2002 Malibu Ran Yesterday, Won't start today...Fuel Pump???
- oil change, engine light on
- 3.4 intake
- 1999 3.1 Heads
- adjust headlights
- 2002 Malibu LS Tranny Problem?
- 04 Malibu Maxx - Another Week in Service
- progress 56k beware
- radio bulbs
- 98 Malibu Parts
- 97' Problems
- Vacuum induction intake cleaning
- 98 malibu window problem
- &9 Malibu
- Gauges out
- Master/distribution block
- 2005 Chevy Malibu Maxx Keyless Remote Programing
- Help with Passlock 2 system
- 2002 Chevy Malibu - General questions
- 2000 Malibu front suspension problem
- Oil pulled a Houdini on me..
- Engine Vibrations
- Intake Gasket Class Action Suit
