Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
> Malibu |
View Full Version :
Malibu
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
Need help: Change 98 Malibu alternator
99 malibu fan and wiper speed question
anti theft
Intermittent stalling after fuel-up
1999 chevy malibu long crank time
Heater core replacement
2000 Chevrolet Malibu Speaker Specs
Gas/Brake pedal vibrating
2000 Malibu with No Temp Control
I Need Help!!!!
1998 Malibu LS A/C
Problem with Defogger
Eating gas like crazy
Several power problems
New Guy Here
99 malibu ac/electrical problems
pesky check engine light ?
OnStar Conversion
Rotating Tensioner to Replace Alternator
rough idle
God Awful grinding on new brake pads
Malibu Maxx Hatch Strut Failure
2000 Overheating --- Please Help !!!
Crap. Somebody worked on my windows
Changing headlights
Passlock System
2004 Malibu Key Fob Problem
CLASS ACTION SUIT/brakes
00 malibu code 742 how i can fix it
Theft System/Passlock
3.1 malibu leak
AC Pressure on engine problems
can pics be posted?
Can pics be poster
chevy malibu 99
To Buy or not to Buy
Remote Start Issues...
new member
problems starting ( cold )
H.O. powermaster alt for sale
Old Change for malibu 97
Sometimes very high idle
Keyless entry.
2005 wind tunnel
98 malibu Supportes
Electrical problems??
steering issues
2002 malibu muffler
How Do U Change Thermostat In 2000?
Fuel Rail leak some help please.
2004 Malibu Classic 2.2L radiator fan removal
How to get at that oil filter; 2001
Cruise Control Dash Light
Jet chip
Find out if i have keyless entry
keyless entry
pushrods and rotating rocker arms
101 octane gas
overheating
malibu performance
starting problem
Cold Air intake
Power Door Lock and Mirror Problem
n-body meet in SoCal SEPT 24
fan dial problems
Serpentine Belt
engine trouble code
Low Idle
Removing the window lift motor
replacing OEM radio\cd with upgrade OED radio/cd/cass in a 2002 Malibu
68 conv.
'05 Malibu @ 110mph
2000 malibu intake??
2005 Oil Drain Plug and Filter
Where is 2002 Malibu transmission plug?
This is a useless fourm!!!
Lots of issues on my 98
Engine Repairs
Lowering my BU
Towing a Trailer
Extra external transmission cooler?
Power Steering Recall question
2005 Malibu
Need advice on 99
radio
keyless entry
Removing the driver side door panel
Bike Carrier
transmission trouble
Aftermarket Available
97 Malibu Transmission should I get a used one?
2001 Malibu
Head Gasket Replacement
the cd player
Replacing 1998 Malibu LS Alternator.
lowering springs
euro tail lights
check engine light stays on after starting car
Horn Warning?? ('02 Malibu)
01 Malibu - clunking sound in front tires?
rear seat
97 Malibu Lower control arm bushings?
1998 Malibu stalls after fuel up
Cruise control on '01
Pulley System Nightmare
JET power control module
99 3.1L -> misfire and engine shaking
'99 Malibu - Neutral Safety Switch?
E 85 Fuel
Head lights 2000
99 Malibu won't start, no cluster lights
Heater control, vacuum line 97 Malibu
2000 malibu A-Arm loose
2001 malibu wont start
97 Malibu 3.1 auto Transmission noise
99 Malibu water pump
00 malibu problems
fuses for brake lights keep blowing
Theft Syste Light Stays On
Battery light on, already changed battery and Alternator what could it be?
Removing Battery cables
Cost for shop to change fuel filter
2005 chevy malibu aftermarket parts?
1999 LS TheftLock Programming
1999 LS Programming Power Locks
1997 Malibu heater selector switch
freeplay in steering sense recall work
Fog Light Resetting?
01 Malibu blinker problem again!
2001 radio fuse
Camshaft position sensor location
Stalling Problem
Be carefull when removing batt and cables
'03 Accelerator Pedal Recall...
HVAC resistor part number
Just bought 2003 Malibu
03 Malibu front struts install.
dash board problem
keyless entry remote programming
2001 malibu starting problems
2005 malibu sedan stereo question
Wiring to tow malibu behind motor home
cigarette fuse
coolant leak 2001 malibu 3.1
98 malibu no dash lights, fuel
98 Malibu transmission Slipping
2005 Malibu Maxx - Front end cover
"Service engine soon" light won't go off
18" tires
1999 malibu alternator replacement
2001 Malibu
Please help with Questions...
1999 Malibu Speedometer cluster went
Malibu Starting Problem
When is tune-up
2000 chevy malibu ls gauges not functioning right.
2004 LS trasmission problem
2004 V6 noisy at 5500 rpm
Odd problem with RPMs
04 Malibu Classic
99 chevy malibu
03 malibu anti-theft problem help
2000 malibu power windows
02 transmission
02 transmission
Experts needed
Oil filter 2.2 Ecotek
Getting the Intake Gasket Repaired
new Malibu
Facotry speaker and headunit specs
How to reprogram 1998 Malibu Keyless entry?
Grinding noise on brakes for a 2000 chey Malibu
Trans Fluid Level
trouble code PO412 help!
Wheel size?
whining when in gear
OEM RIMS and TIRES
Baffled
Sticky Pedal
Check Engine Light
Replacing Serpentine Belt
deposit for the malibu cruiser body kit
Climate control is pooched
2001 malibu blinker problems
78malibu 350 swap
idle and stall
help with radiator fans
1965 - 67, 327 cu in motor, starter problems
Gas Gauge Reading
1990 sierra a/c clutch
Should I/can I walk away?
2005 Chevy Malibu Aftermarket radio
A/C Clutch
Crazy MPH
malibu good for noobs?
intake gasket?
Replaced blower resistor; didn't fix fan speeds
Battery Cables
1999 Malibu Brake Problems.
01 Malibu clunking hard in to drive and shifting hard?
gaude pod
FS: Dragon Z kit urathane
Anyone interested in Carbon Fiber parts?
2 Problems: Engine Surges & Overheating Issues
98 Malibu running hotter since gasket repair
Engine Surge
Temperature Reading
99 malibu electrical problem?
Cross drilled rotors
Newbie needs advice on speaker buzzing/humming
Overheathing?
Chevy 55 BelAir !
CD-R and CD-RW
Rear Disk Conversion Question
2005 malibu keyless entry programming
Malibu 2005
Rear drum removal on 98 Malibu
1998 Malibu 4 cyliner-thermostat?
1998 Malibu
2001 Malibu tranny fluid check
Intake manifold Gasket replacement
6x9 install problem!!!!!!!
1997 malibu power steering pump removal
what do you think?
2002 Malibu LS V6 won't start
front oil seal
18" KONIG APPEALS with TIRES 4 SALE***
2002 Malibu brake problems!
Malibu 2001 Air Filter compartment
AC Condenser leak
Automatic Transaxle question '97 malibu
Fuel filter on '99 Malibu, rusted fuel lines :(
mass air flow sensor
No horn, or taillights
Gauge not right
Thinking
I need to remove my left side panel of an 97' malibu
Class action vs. Dexcool
Ignition switch will not turn on 98 Malibu
tranny problems
malibu wheel set
New '04 Malibu/Maxx Recall
Malibu Cruiser Bodykit Group Buy
Window tints
98 Malibu A/C and fan problems: more feedback needed
Wtb: Ecu
i'm retarted
swapping engines
Web
AF
