View Full Version : Malibu
Pages :
1 2 3 4 5 6 [ 7]
8 9 10 11 12
- 2000 Malibu, 15 MPG HELP!!!
- 2006 Malibu
- 79 malibu V8 bucket seats
- front driver side leaning
- Radio and Speakers remplacement...
- Valve chatter on a 99 3.1 v6
- Radio harness??
- Sudden loss of power steering in 99 Malibu
- 98 Transaxle Output Shaft - Stubs and Seals
- carb outta wack!
- over heating
- Hp
- Headlights
- Will turn over but wont fire.
- Air Resonater
- Belt Tensioner Loose
- static issues with the door
- malibu Forum
- '00 Malibu drivetrain noise
- 1998 Radio
- Climate controls
- SOB, both p0440 and p0302 codes
- Ready to destroy 2000 Malibu
- 98 MAL Fuel guage and Battery bad ?
- 2003 malibu help needed
- wanting to take out stock stereo
- 2003 Malibu won't start
- How much is my car worth?
- starting problems
- No HEAT!
- front wheel hub bearings
- 02 malibu heater blower motor problem
- 98 ignition electrical not passlock
- Horn Honks for no Reason
- 2.4 thermostat
- Head Gasket Leaking?
- Finished Motor Swap
- 2000 Malibu internal engine failure
- RSD wiring diagram
- 99 overheating...still!
- 97 Malibu with surging idle
- Malibu CD Player Likes HP CD-Rs
- '04-'06 Malibu/Maxx Front Suspension Noise
- 97--any shop manuals?
- Cutlass trans cont...
- malibu clicking when brake
- rev-limiter
- Electric steering adjustable?
- Serpentine Belt On 2003 Malibu??
- 2003 Malibu problems,need help
- Vehicle Speed Sensor Wire?
- How many O2 sensors
- Passlock 2 Security Syatem
- Will a 2000 Glove Box fit a 98?
- cooling fans not working
- Trans question
- 2003 Chevy Malibu. Climate control blower.
- Solution to Ignition / No start / theft system problem!!!
- I need help ASAP
- 98 Malibu wiring for stereo??
- Motor Swap
- 1998 Malibu Computer reset
- Growling/Popping Noise: How to tell diff between bad CV joint vs. hub bearing?
- CD Stuck in warm weather
- computer readiness tests
- 2001 malibu stereo
- RDS Radio and Code for lock out
- 1998 malibu parts
- Tire pressure
- Malibu 2000 Injection service
- wrench size for drain plug 05 3.5l
- honk honk
- Headlight is not turning off -- any suggestions
- New to Forums ~ Have a question
- DIC "temp"
- Stereo bulbs
- 98 Malibu wont start!HELP
- rear defogger
- Malibu 99 won't start - need some URGENT advice.
- '99 Malibu Cooling System
- Replacing Computer on 02 Malibu
- Buying my first car, should i go for it?
- CEL, ECU location and pulling codes
- 79' Malibu
- rough idle
- Shorted out my signal/hazard?
- Malibu supercharge
- Crackling noise in dash when temperature is cold
- Check Engine Light
- 98 malibu electric windows
- 2005 Malibu Maxx gas cap - one that locks?
- rough starts
- water inside after rain
- Front end repair
- Check Engine Light!!!
- 2000 Malibu trans. fluid
- 1999 Malibu.. Change Headlights????
- 2000 Malibu 3.1L hard/no cold start
- Hum from Heater
- 1999 Malibu Won't Start
- 98 malibu transmission shifter
- 98 4cyl Starts then dies.....
- 04 Malibu/Maxx Automatic Lights
- 04 Malibu axle seal, check yours.
- 1997 Chevy Malibu
- Have Fuel and Spark, But No Start???
- Acetone increase fuel mileage ?
- Cold Engine Knock
- Warning Lights and Parking Brake
- Last question for now... Gas Recommendations?
- Anyone from Iowa with a MAXX?
- Window Tint in Iowa - Recommendations?
- New tires for 05 Maxx LS - Toughts?
- May sound dumb but need help
- Tape Deck
- Heated seat question
- Help!!! 99 Malibu is a bag of....
- 97 malibu won't go
- 2005 Malibu Remote Starter Faliure
- need advice, or a rough estimate...
- passlock sensor in 1998 malibu
- 05 Maxx vibration at hwy speed
- Does keyless entry have a fuse?
- also leaking coolant
- Theft Deterrent Password Relearn
- Radio Volume Problem
- No Start, No Spark?
- 2003 malibu starts for 1 second, dies. fuel filter??
- Passlock Toggle Switch
- 2001 Malibu Intermittent Start Failure and other similar problems
- transmission
- 99-how do I change the light above the back license plate?
- N-body subforum
- Check oil light- cold weather
- Intermittent Check Engine Light
- Urgent...Help me please!
- 97 Malibu 3.1 V6 Rough Idle
- 2003 - V6 : it just died..
- Transaxle question
- Opinions on 2000 Malibu V6?
- 04 malibu maxx front axle seal
- can you put an impala motor in a 01 malibu ?
- '01 Malibu Headlight Damage Help Plz!
- Loc message on radio
- 98 Malibu Whining, HELP?
- Check Engine Code
- Programming a keyless remote 02 Malibu
- Please, please. Help me.
- malibu
- factory door speaker size?
- warning light?
- 98 Malibu Whinmg noise
- Coolant Light
- Overheating 02 malibu
- 1999 malibu cranks but wont start
- Motor Question
- Loosing Coolant
- Malibu-how To change the Radio
- Defunct Fuel Gauge
- 98 Malibu header panel
- malibu 04 BCm
- 98 malibu whining sound
- Ticking noise coming from dash
- ALL Guage Lights are ON!
- Fuel Pressure Regulator
- heater blower motor
- Neutral Safety Switch?
- 99 Malibu - Possible short in dash?
- turn signal issue
- Wipers won't shut off...
- 98 Malibu takes forever to get warm air
- 2001 gauges not working
- 2001 Malibu ticking sound
- Smell of gas
- Need Pictures of Engine Compartment or Detailed Description of Wire/Vacuum Routing
- Headers!! 1997-2003 V6 Malibu
- New Member
- Malibu coolant (Dexcool)
- 6 x 9 speakers
- odometer
- Transmission fluid level
- oil warning light
- climate fan sporadic, ac/heat work
- fuel tank replacement
- 98 malibu dies and not starting
- Spongy/no brake pedal
- vacuum hose leak
- 1999 Malibu 3.1 "fluttering" sound
- RPO Code Sheet Location
- 007 Car Accessories
- It Died
- 98 Malibu ABS problem
- Water Pump Stuck
- 98 Malibu - Alarm lights then horn honking
- 99 Malibu Radiator Drain (cant find it)
- Theft System
- Any suggestions?
- Egr Valve
- 98 malibu hesitation
- 1998 passlock
- If you could Sell your 99 Mailbu
- Stubborn Gear Shift Lever Button!!
- Reverse Glow gauges
- spark plugs
- Brake drum removal
- Wiper arm travel
- Trans Fluid Leaks After Replacing Radiator
- Changed intake gasket but dirt got in. What do i do?
- Flooding?
- Changing oxygen sensor & brake rotors
- 2006 Fuel Economy
- New Malibu's alarm system
- drain and refill the coolant for 99 malibu
- 2002 malibu cruise control cable
- 2000 Malibu Steering Wheel
- belt tensioner assembly replacement???
- 1999 3.1 acts like running out of gas
- Help. Warning Light?
- brake question
- Blown Power Steering Pump
- gm/delco cd in 99 malibu w/o factory cd?
- 2004 Malibu Rotors
- different battery types
- Fan Control Dosen't work
- Malibu, defective brake problems?
- malibu 4 cylinders?
- Cruise control and sticking gas pedal
- Remote Start
- 2001 malibu
- keyless entry remote
- '97 Malibu Turns over w/o starting fuel pump,Anti theft,Or ignition module?
- Intermittant wont start
- passlock on 2000 malibu
- check engine light on all the time
- 2003 malibu fog light wiring
- Bleed Cooling System
- sunroof wont close all the way
- Malibu locking me out
- Wipers only go low speed
- A/C kicks off
- Coolant Problem
- 3.1 shudders in gear
- windsheild wiper arm transmission
- Oxygen sensor
- Dragon Z Kit for sale
- 2004 Malibu Maxx Power Stearing Problems
- Timing set interval
- Throttle Body.
- malibu overheating
