View Full Version : Malibu
Pages :
1 2 3 4 5 [ 6]
7 8 9 10 11 12 13 14 15
- how do you remove relays from fuse block?
- Anyone have a used TIS 2000 CD?
- Service Vehicle Soon light HELP!
- 3.1 v6 overhaul question
- hub bearing replacement?
- 4T45-E Transmission
- '05 Malibu heater blowing cold air
- 2000 Chevy Malibu
- p0300 code
- 99 Malibu Plug Wires
- backflush 00 malibu 3.1
- Aftermarket Stereo install questions on a 2004 Malibu classic
- 00 malibu radio preset buttons
- defroster connector unhooked? help!
- po420 code
- 99 Malibu: How to disarm airbag?
- Passlock Bypass With A Resistor?????
- Tail lights odometer out fuse blows
- Malibu 3.1 2000
- 01 Malibu rough idle!!!
- 98 Malibu 2.4 rough idle
- 99 malibu will not start
- '99 malibu gas pedal problem
- 2003 Malibu Heat door motor
- Testing fuel pressure 2001 v6
- 2001 Malibu wierd electrical problems
- 2003 A/C High/Low side specs
- Enviormental controls out of control
- '04 Malibu Maladies
- 2000 Malibu with 1998 Camaro Rims?
- 01 Malibu with a PO141 code
- Noise (bearing?) only when turning left
- 04 Classic 2.2L
- 2000 Malibu No Crank/No Start
- 2000 Malibu Check Engine Light
- Help
- '99 Malibu Automatic Lights always on
- 2005 malibu brakes.
- New 2000 Malbu owner, service questions?
- Malibu 2000/ service manul on CD?
- 1998 malibu question anyone please help
- Cd player in 2001 Chevy Malibu shows "locked"
- Need help with serpentine belt
- 99 Malibu 2.4 Ignition Troubles
- 2000 Malibu brake light comes on
- 05 malibu power steering light?
- Change Dexcool to generic green?
- emmisions problem
- I Took The Grand Prix!!!!!!!!!!!!!!!!!!!!!!
- 2000 Chevy over heating
- 2001 Malibu Window.
- 1997 malibu I NEED HELP!!!!!!!!!
- 04 Malibu LS
- 2004 malibu
- 98 malibu pwr string pressure hose
- 99 Malibu: windshield fogging up
- Malibu ticking sound?
- A/C not cooling
- New engine, remanufactured transmission
- Comments on 2008 Malibu ?
- Cross Country recommendations
- Power Steering
- 04 Malibu Speed LImit and Supercharge
- '01 Malibu Temp Guage
- 99 Malibu Stalls as low rpm acceleration
- 1997 Malibu radio displaying LOC
- 99 Malibu Coolant in oil
- Performance Chip
- !!HELP!! My 98 Malibu keeps cutting off
- Belt Tensioner Movement
- Parts diagrams on the web?
- 04 Malibu LS Remote Start and Transmission Range Switch Issues
- 2001 Malibu Gas Gauge.
- 99 Malibu horn/airbag issue
- Transmission Range Switch Issue
- Theft System malibu 97
- 98 ls no oil pressure? *help*
- IAT Sensor
- 1998 Malibu Battery Light Problems! HELP PLZ
- 98 Malibu TPS question
- I need help with fuel pump
- 99 Malibu tranny probs
- Very slugish, engine ping 97 Malibu
- 2001 Malibu horn blows by itself
- Quad 4 misses at 2000 RPM
- ugh please help me(kinda long sorry)
- 04 Malibu turn signal problem
- 99 Malibu: Turns Won't Start, No Dash Lights: NO PASSLOCK
- help! 98 malibu suddenly cuts off
- Hard starting, Fan does not work
- replacing 98 malibu LS headlights
- 2001 Malibu V6 slow starting sometimes
- Hot Start Problems
- Air Intake
- Fel Pro
- Car Stereo Problems with Amp
- Malibu SS
- 2001 Malibu squeaking noise.
- factory cd players
- are head bolts the stretch type?
- 05 Malibu radio/lights on radio not working
- Anyone have problems w/ AC turning on & off??
- 99 Malibu - how long should brakes last????
- fuel rail inlet hose
- Which fuel grade is best for 2006 Malibu?
- Does 2006 Malibu LT has PCV Valve?
- Turning Noise
- 97-03 malibu short ram intake
- '98 won't go past 4000 rmp
- 1999 Malibu 2.4 hard start
- What does it have to do with.......
- Smoke
- 99 malibu coolant
- 2000 Malibu Motor Mount
- 2006 Malibu do not need to replace fuel filter?
- 2003 Malibu Remote Programming
- starter problems
- Please help me...Car doesn't start
- How can I drain the coolant?
- Radio Replacement
- 2.2L from pre '99 to post '04; how is it different?
- Problem with my 3.1 Heads
- Possible transmission noise in neutral from a coast to a stop
- 2000 Chevy Malibu Overheating Stopped
- Disabling DRL
- glovebox tag
- Malibu 2006 Brake Lights When Car is Off??
- Initial engine noise durning startup; 2.2 Ecotech
- Clunk in front end.
- Malibus' electric steering; good, bad or maybe?
- low fan speed (1-4) problems
- Replacing side mirror 2005 Malibu
- Passlock II Problem, Cranks but no start...
- 97 malibu tries to start
- No Rear Running Lights and Dash Lights??
- Gas odor From car Gets worse and Worse?
- 2005 Malibu Maxx Rear Brake replacement
- 05 malibu no brake or signal lights on back only
- 2001 Malibu overheating, coolent no ciculating
- Checking/Adding ATF to the 4T40E, 4T45E..
- Lights on radio out.
- Center Shifter Bulb Replacement
- 2001 malibe serpintine belt
- 99 malibu brake lights out
- 2001 malibu wont start
- Does my 04 Classic have keyless?
- 04 Malibu Classic Stalling w/ no code
- Teft light on in dash
- Temp Gauge Reading
- Outside Air
- 2002 Malibu- Hard to start
- 99 Malibu : stalling, P0102, and rough 1-2 shift
- Are the 3.1 heads reliable???
- How to clean '98 Malibu EGR???
- How to program 99 Malibu key fob?
- coolant leak
- CD player question
- Amp/Sub problems
- head unit removal
- OBD Code P0401
- 99 Malibu Strut and Shock Replacement
- PCM Problem
- need to know 92 chevy 3.1 rocker torque specs
- Can I put keyless entry in 05 malibu?
- Rad overfill cap gaining pressure and blowing off
- 2002 Malibu - Overheating
- K&N filter for 99 malibu
- 2005 Mailbu Heater-A/C controller upgrade
- 05 Malibu LS, Not MAXX Stereo
- Intake Manifold Gasket 2000 Malibu LS
- 99 malibu idles roughly when stopped. need advice before I take it to the mechanic
- 99 malibu - Alpine cda9885 install
- 03 Malibu Clicking when cold
- 98 Malibu cruise control problems
- 2003 Malibu LS
- Transmission Fluid or 98 Malibu LS
- 2001 Malibu Cd Player
- factory anti theft system
- factory amp?
- Need a techs advice...
- stereo question
- Defeating the 'auto' headlight feature on a 05 Chevy Classic (Malibu)
- 98-04 Malibu class action
- 98 Malibu break issues
- 99 Malibu: keyless lock/unlock fob is breaking down
- 1999 malibu stereo level converter
- 1998 Chevrolet Malibu problems...
- What rear end gear?
- 98 Mailbu noise coming from driver side front tire
- 99 malibu front hub assembly mistake
- 2002 malibu
- Another Passkey?
- 98 Malibu Tranmission problem
- 04 Malibu fuel pressure questions
- Nightmare PO113
- back seat problem
- good used car to buy
- starting issue (HELP)
- Water Leaks
- 2003 Malibu having problems starting
- 98 Malibu keyless entry
- 1999 front wheel bearings?
- More Malibu passlock crap
- How do we Check and change tansmission fluid for 2006 Malibu LT?
- 2005 malibu odometer problem!!!!
- I Need HELP!!!
- 01 malbiu strut mounts 81000 mls
- Malibu Surging Problem Advice Needed
- 2006 malibu SS
- DRL Module on 2001 Malibu
- stereo problems
- Defeating auto door lock and adding fold down rear seats
- 97 Grand Am misfires only in Park and Neutral
- hesitation on starting
- Problem with a turn signal.
- 98' malibu break noise
- 1999 Malibu paint problems and rust
- codes P0101 and P0108
- Vibration when braking
- Bad Accelleration!!!! Need Advice!!!
- 03 malibu random miss
- ABS Light
- AC service
- 81 Malibu... Come On Down!!!
- In a hurry
- Lemon law in Canada?
- Stock radio lights
- Coolant disappears
- 02 Oldmobile Intrigue vs 04 Malibu
- 2001 Malibu Suspension Noise???
- 2001 Malibu - Multiple problems
- 97 mali - removing ignition switch - interlock cable problems
- can't find a replacement reservoir!
- 2004 Front light conversion
- swaping engines...(tips)
- What is P0113- IAT sensor high input?
- please help
- Question about intermittent rough 1-2 shift on my 01 Malibu
- Emissions code
- Best oil filter to use with the 3.1 V6 ?
- No Heat
- Two catalytic converters?
- Great forum guys!
- New to the fourm, ABS Module Location 2005 Malibu
- leaking water
- 2001 cat converter
- Intake Manifold Bolts ?
- 2001 Chev Malibu Recall (pulled from my insurance co.)
- 2000 Malibu Cigarette Lighter Fuse
- Malibu body style change
