View Full Version : Malibu
Pages :
1 2 3 4 5 [ 6]
7 8 9 10 11 12
- Malibu 98 LS fog light replacement instructions
- 2004 Chevrolet Malibu PCV valve location
- '99 Drifts Left Even After Alignment
- weird problem.... passlock????
- Newer Malibu any good?
- Class II radio on my malibu?
- 1998 Chevy Malibu Electrical problem
- engine go off when a/c turn on
- 2003 Malibu Overheating
- 2001 malibu won't start
- Another Intake Gasket Question
- Rusted Coil Towers
- 2000 malibu tune up
- 03 malibu a/c
- chirping sound from the belt area
- Changing battery/avoid radio lockup
- 1998 Malibu AC Recharge Help
- CD Player
- Another AC problem...help!
- Flasher Replacement
- Radio Code
- Drive belt Replacement
- Installing new stereo on 05 Malibu
- New (to me) Malibu?
- 05 Temp gage inop
- can this happen
- Malibu, Grand Am, Alero interchangable body Panels?
- radio will not turn off
- 2000 Malibu + faulty Fuel Gauge
- 1998 different kind of AC problem
- 03 malibu missing
- 2005 Malibu Cruise Control
- Lower intake bolts didn't go back in, now holes are fouled...
- Mass Air Flow Sensor
- How Does One Change The Spark Plugs? (2000 Malibu)
- 1998 Malibu - Weird Clicking
- Catalytic Converter
- 2001 Malibu OEM cruise control
- Leaking Anitfreeze ?
- 2004 Malibu Maxx DVD
- installed new stereo, now no tail lights etc...
- ac light blinks and ac stops cooling.
- Gauges at 0, no start occationally
- New key from vin #
- 98 Malibu hard starting
- 98 Malibu ac problems
- 02 Malibu break Creaking and abnormal wear
- 1999 Malibu brake noise
- Installing a keyless entry system first time
- Is front spring replacment a DYI project?
- 98 malibu AC problem help
- power windows
- The new Malibu 2007
- A C problem
- 01 malibu - noise when i brake
- 2000: Oil light comes on around curves
- 1998: new alternator, now fuel gauge is incorrect
- '97 Malibu electrical issue
- 1999 malibu
- 2001 3.1L V6 Oil Leak
- 98 Malibu 3.1L
- Headlights: one brighter than other.
- Sticking Key Problem ???
- Transmission Problems
- won't start
- transmission questions???
- Hard-starting 2004 Chevy Malibu Maxx
- lower intake manifold gaskets, dexcool
- 2001 AC Recharge
- ABS Upgrade
- 2000 Malibu - Worth it?
- Transmission problems (i guess)
- Fuel System Problem - pump or regulator?
- Front spring is busted; 99 Malibu
- Red threadlocker and lower intake manifold
- AC question
- 2000 Malibu Sounds like a diesel on Startup (cold)
- 99" Malibu Check Engine Light
- Driver's Side Mirror
- How Do I Drain the Fuel Tank?
- Wont Start
- how to read error codes?
- 99 malibu a/c leak
- no heat 05 malibu ls
- rev on cold start
- Overfilled Transaxle
- 2006 Ss
- things i had to do to my malibu
- heres some advice
- Car won't start... Give it 15 Minutes...
- Another a/c question, '99 Malibu v6
- 98 Malibu new starter tripping main fuse
- Mailbu Transmission Problem
- ABS Light
- new 97 Malibu owner questions
- Motor Swap?
- 04 malibu killer headlights
- lighter/Fuse Box Layout
- Trunk ACC outlet, '05 Malibu LS Sedan
- Fuel Filter Change - How to
- Air Condition
- 98 Malibu Brakelights
- Take gas cover off car dies
- Stripped out rockerarm mounting hole
- 03 malibu brakes
- Fuel Pump
- changing coolant
- 98 Malibu won't start fuel gage at E has gas
- interior trim
- Clicking noise on start up
- Malibu Hazard/Turn-Signal Inop Problem
- 2002 Malibu Air Conditioning Inop
- Oil pump
- overdrive gear ratio?
- How do I remove alternator bracket
- Speakers
- Need Help with A/C on 98 Malibu
- 98 Malibu A/C Problem
- cyl #4 misfire
- 02 Malibu radio/door chime problem...Help!!!
- 1998 Malibu
- Bad Starter, Bad Battery or Bad Alternator
- 98 chevy malibu
- Lets force GM to change its Building Suck Cars culture
- 2003 mbu front end rattling noise
- 03 malibu brakes
- 2002 Malibu Ran Yesterday, Won't start today...Fuel Pump???
- oil change, engine light on
- 3.4 intake
- 1999 3.1 Heads
- adjust headlights
- 2002 Malibu LS Tranny Problem?
- 04 Malibu Maxx - Another Week in Service
- progress 56k beware
- radio bulbs
- 98 Malibu Parts
- 97' Problems
- Vacuum induction intake cleaning
- 98 malibu window problem
- &9 Malibu
- Gauges out
- Master/distribution block
- 2005 Chevy Malibu Maxx Keyless Remote Programing
- Help with Passlock 2 system
- 2002 Chevy Malibu - General questions
- 2000 Malibu front suspension problem
- Oil pulled a Houdini on me..
- Engine Vibrations
- Intake Gasket Class Action Suit
- 99 Out
- Steering Freeze Crash
- Class Action Filed in Canada for Intake Manifold Gasket
- drl delay is out
- new 99 malbu ls owner
- Radiator replacement
- Avoid Rust
- Hi all
- 2002 Fuel filter change schedule?
- 2002 Malibu feels rough when cornering.
- running day light out
- FS: 98 Malibu - 3.1 v6 - Leather - Loaded
- New owner questions
- front windows
- How Many Miles on Your Malibu?
- Lamp dimmer module
- radiator installation question
- Coolant Leak , Check This
- 2004 Malibu Classic rubbing noise turn left
- engine computer
- 1997 Malibu Ignition problems
- Injector O rings
- Leaking coolant
- Trans fluid level
- How to support engine
- 2004 Malibu Gas Gauge Problem
- Loud Hum on 02 Malibu
- Extremely high RPM output
- 03 malibu a/c question
- Rear speaker wiring
- Stereo anti-theft code lost
- Keyless Entry or No?
- Advice on buying a 2001 Malibu
- See ya later POS Malibu
- Lower Intake Manifold Gaskets
- swap
- Jet Chip
- Multiple/Random Misfire
- 99 clicks but won't start
- Dash Warning Lights Going Crazy
- 2000 Malibu Transmission
- 2001 malibu will not start
- Intake Gasket and GM Reimbursement
- Front end hum
- Seafoam and 2000 Malibu???
- cylinder misfire
- start/stop problem
- Milky oil on '98 3.1L filler cap
- 98 Taurus Position Sensor
- 2004 Malibu Maxx - Starting Problems!
- 2001 malibu temp gauge quit on me
- Multiple problems with 2000 Malibu
- Passenger side Transaxle seal
- Wiring Question
- Cooling fan blades and shroud
- Egr parts for sale
- Fuel injectors F/S
- Painted Intake manifold for sale
- Coolant Leak 98 Mal V6 3.1l
- 98 blinker comes on when brakes are hit
- run on starter on maxx
- 2000 Malibu keyless entry reprogamming
- 99 Malibu Dies until hood is opened then shut!!
- 98 malibu difficult to start
- Intake leak
- 99 malibu front strut mount
- 2000 malibu quits running differant conditions
- Lacks power and surging
- 2000 Chevy Malibu Serpentine belt
- My Malibu
- swap 01 GP 3100 in 1998 cutlass
- Head Gasket Question on 3.1L
- Newbie
- Malibu blues
- passlock...fuel pump relay???
- Malibu 03 trouble starting , and turn signal
- Thermostat House /Lower Intake Manifold on 2000 Malibu 3.1L V6
- Horrible oil leak 2000 Malibu 3.1L V6
- brake lines
- 2001 Malibu turns off while driving....
- 2005 Malibu Lx dashboard noises
- 98 oil light
- 98-03 Trenz Billet grill for sale!!
- 03 malibu a/c
- 1998 cruise control
- 2001 Malibu overheating problem
- 1998 AM/FM Radio woes
- Aftermarket CD changer
- Two Questions
- Two Questions
- 1999 Water Pump
- 2000 Malibu - Weird Clicking, polterguiest? LOL
- 2003 malibu stereo installation problem
- chevy malibu 2003 dash
- Lose Heat after 30 minute drive in 2000 Malibu, Not the resistor
- 2000 Malibu - First 2 air settings don't work?
- 2000 Malibu...NO HEAT....need help
- Auto window issues
- 2000 Malibu, 15 MPG HELP!!!
