Chevrolet
> Malibu
View Full Version :
Malibu
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
Malibu Maxx 04 XM Radio stopped
Replaced Intake Gasket, Now experincing High Revs
02 malibu
98 Malibu 3.1 Howl or Whine noise from rear?
'99 Malibu 3.1 code 0442
Body Control Module (bcm)
Miles per tank & MPG on 99 Malibu
Ignition Cylinder
cabin filter
Malibu High Idle Problem
Check Engine Light
won't start without giving it gas
2000 malibu brake problems..need help asap...thanks
'99 Malibu fuel filter replacement.....how?
02 Mailibu Parking Brake Adjust.
need info on Dex-Cool
Tick-tick-tick noise only while driving
aftermarket head and taillights
2006 Chevy Malibu Stereo - Theftlock Enabled
noise from wheel or front end
Electrical????
04 Malibu Classic - Front end click/creak/rattle
2005 Malibu Max Break Lights and Rear Turn Signals Out
2003 Malibu abs light
2006 MALIBU FAULTY SES/GAS gauge
won't start
Won't start sometimes after warm
Rear Parking Brake Cable Equalizer Bracket
New Malibu,new scratch!
coolant coming out of over fill tube
Rear driver side power window problems on 97 Malibu
ignition cylinder
Help Identifying This Part With Picure
2000 Malibu LS Cruise Control Kicks Off
1997 and 1998 alloy wheels
2001 Chevy Malibu
AC compressor is not kicking on
3.1 Litre Oil Pump Shaft O-ring
Bad BCM?
Heater won't work and power windows don't work at time
00 Malibu Starts then shuts off
Programming Key Fob for 2000 Malibu...Is it possible to do yourself?
2005 Chevy malibu Shifting issues
04 malibu maxx steering lock
2004 Malibu LS remote entry FOB
Are they trying to get me?
Turning Signal Problem
Installing New OEM Factory Radio in 2006 Malibu
Installing Aftermarket Radio?
2002 malibu ac fan speeds
2001 Malibu Rear Speakers Problem
05 malibu oil not getting to top of engine
2001 Malibu Power loss
1999 Malibu w/ non serviceable transmission
rubbing brakes
Steering and brake noises
2002 malibu Transmission problem
Job Finished! But not without side effects
Brake Job Problems
03 malibu 3.1
which repair manual is better?
2004 Chevrolet Malibu Trunk Release Button
mp3 player
05 Malibu Maxx Rear bulb replacement
Transmission
When taking off the intake manifold
Need Programming Instructions for 2005 Keyfob Remote
LIM repair, Gasket Warning
07 malibu maxx 28000 miles SES light
Front end noises
Fuel Filter location on 2004 Malibu Classic
low beams dont work hi beams do
2002 malibu headlight replacement
1999 Malibu too many unset (not read) readiness codes(OBDII) inspection failed help ?
2000 malibu engine light
2000 Malibu transmission sensors
2005 malibu battery issue?
99 Malibu Help????
shaking
key switch removal
What is this warning light!!??
Malibu Problems
Keyless entry not available?
99 malibu overhting via res tube--how much air to bleed?!
Weird brake lamps problem
Driver door labels missing?
Need help removing KARR system
97 malibu keyless entry
2000 Malibu- three problems
2004 Malibu turn signal intermittent
Abs sinsor needs replaced plz help asap
Oil or Transmission Fluid in Coolant?
Parking light won"t go off/Head lights won"t stay on
so since no one is posting to my big thread ill ask it simpler
how hard is to raplce the intake gasket
im new here and have some issues
98' Malibu dashboard problem
o4 malibu weird noise
01 Malibu Intermittent Turnsignals
1998 Malibu heater problem
Pulley Snapped No idea what it is!!!!
Turn Signal and Rear brakes
replacing the temperature door actuator on a 2000 Malibu
Tire Size
ABS light coming on.
malibulls**t
98 Malibu brake light bulb keeps blowing
window knob wont come off any ideas
1997 hammers at start and antifreeze through exhaust
Anti lock break problem
Rusty coil springs
05 Malibu stripped oil pan bolt
I need help taking off my door panel
i need help
2001 Chevy Malibu - The fans will not turn on?
98 malibu trans problems i think
05 malibu gas cap prolems???
Thermostat needs to be replaced
What engines will fit 98?
Fuel filter/green clip problems
malibu maxx review plz
98 malibu wont stay running and the gauges dont qork
Rough start
clicking sound when braking
2005 Malibu has a creeking noise
'99 3.1 cranks no start
97 Malibu key wont turn in ignition
3.1 Malibu leaking coolant
03 malibu miss at idle
2000 Malibu alternator problem
problems after intake manifold repair
check oil light
2002 malibu blues..need help with electrical problems
shift solenoid
Accessories
how to take out headlight
99 Malibu Won't Start
Overheating Alternator???
97 Malibu 3.1 v6 hard to start when warm
2005 Malibu LS popping sound when making left turn
2003 Malibu Fuel pump
2006 chevy malibu maxx
Few problems with 2000 Malibu . plz help!
performance upgrades?
99 malibu coolant leak
key fob programming
Auto lock/ Unlock 2005 malibu classic
01 malibu trans problem
Wheel Bearing Nut Size? Need response asap plz
2001 Malibu fuse and collant question
2001 Malibu and the Cruise Control shutting off.
98 Malibu Coolant Leak - Please Help!
cylinder 1 missfire 99 malbu
Code Alarm GOH-MM6-101890 Problems! Help!
Should I....
Spark Plugs
abs light on
99 Malibu - horrible rust near gas cap/door??
98 malibu key will not turn
Pdf Format Manual
My Heater/ac 1 & 2 Does Not Work
97 Overheating
2001 malibu code 128
belt tensioner
02 Malibu won't start after new serpentine belt installed
Theftlock audio system
o4 malibu remote starting not working
99 malibu instument light bulbs
2005 chevy malibu classic stereo wiring
2008 Malibu LS....review, from an owner.
98'Malibu can't start
radiator coolant
2005 MAlibu Misfire
97 Malibu blower motor resistor pack location
electric windows stick in the cold weather only
I think its my fuel filter
antitheft light blinking - no start
Rough cold start, erratic idle for 1st few seconds...
2000 Malibu start & stall constant
Wiper motor Question ,99 MALIBU
Everyone gonna run right out for the 2008?
help
04 aftermarket radio pics
How To.....
fuses
03 malibu radio has no power
R&R heater core $1200
lights
lights
Information on The 2008 Chevy Malibu
98 Malibu Door locks and trunk release
08 malibu
Can I change the battery myself?
Spark plugs and wires
This is annoying
How to replace Wind Shield washer Reservoir
Heat blend actuator
OBD Scanner/Trouble Codes
01 malibu coolant temp sensor
Is my 04 Malibu Classic Falling Apart Already?
99 Malibu radio buttons don't light up
99 Malibu headlamp alignment
replaceing 98 malibu power streering pump ??
knock sensor
maxx tail lights out even after replacing bulbs
Code Problems 91 malibu LS 3.1
sunshade wont retract
Low beam headlight wont work, ck'd fuses! HELP!
Steering Vibrates
1998 malibu problems with gas/emissions code
97 Malibu gas mileage
99 malibu (IAT) sensor
Headlights on too long after key is off
Abs
Keyless entry stopped working
2005 Malibu remote start
no codes read but in trouble!
Power Window Problems!?!
1999 Malibu engine connector question
Where is the starter located on the 2000?
loose electrical wire? replace connector or blower motor?
Programming Keyless Entry Transmitter
How to Change 2003 Malibu Headlight
05 Maxx range selector not working
Engine Ideas
Solid blinker light
How do i remove the stock radio in a 98
Pulling front hub
class action settlement
Hard Start
Malibu eat my CD!!!!!
00 Malibu window switch problem
Cordovan tires on a Malibu?
replacing water pump on 97 Malibu
tire size
HK Drive and Play on 04 Malibu - ACC wire questio
Car won't start.....help please asap
another differential whine...
02 Malibu annoying beep sound
Adding Coolant to Dex-Cool
2004 Malibu battery drain
new fuel pump, fuel filter, and now the check engine light is on. Help???
97 Malibu hesitates at cruising speed
2004: Back of Stereo Diagram
Tune up question
Belt breakage on 1997 malibu.
03 malibu brakes
Help!! Can't fill up the car!!
Strange cooling fan behavior
