View Full Version : Malibu
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12
  1. Reliability
  2. 2002 Malibu starts but resets radio
  3. 1998 Malibu Rumbling
  4. 2000 Malibu - Rear Defrost not working
  5. Flasher relay
  6. Speaker size question 98 malibu
  7. 1998 Cutlass/Malibu starter replacement
  8. chevy malibu advice - all years
  9. replacing oil pan on malibu
  10. Need Help Malibu 2003
  11. 04 Malibu 2.2L
  12. passlock problems 99 malibu ls
  13. Catalyst Efficiency Below Threshold PO420??
  14. Bad compressor, bearing grinding
  15. what do i need for good suspension?
  16. 2005 Malibu w/locking center console?
  17. 2006 Malibu Aux In?
  18. more trouble with malibu 1998
  19. Troubles while Idling and Driving slowly
  20. 2001 Malibu rough idle and engine ticking
  21. 2002 Malibu Power Locks Relay Location
  22. malibu hitch for sale fits 1997 - 2003 classic
  23. Trunk wont open
  24. malibu cd/cassette radio
  25. 98 Malibu Delco radio stock number
  26. 2002 malibu coolant flush
  27. multifunction switch cleaning 'tech' post
  28. Malibu fuel filter connector
  29. 2000 Malibu - Starting Issue
  30. Power Steering Fluid
  31. Oil, coolant capacity
  32. 2003 Malibu Coolant Light
  33. 2003 Malibu Keyless Entry & Low Coolant
  34. 2003 Malibu antenna connection question
  35. P0714 TCC question
  36. exhaust tip
  37. Force A Recall
  38. 99 Malibu: how to remove blower motor? Replace blower wiring harness?
  39. 2000 Malibu cylinder firing problem
  40. 2ooo Malibu Ls Remote!
  41. 98 Malibu: Blower motor electrical connection
  42. 98 Malibu cig. lighter and accessory outlet problem
  43. Malibu Guages
  44. 98 Malibu opening center console (how to)
  45. 2000 Chevy Malibu Ls..stereo Installation Questions
  46. Torque values for Motor Mount?
  47. 15w50 mobil 1 motor oil ?
  48. 2001 malibu
  49. More Malibu Troubles
  50. Obtaining Codes for 2001 Malibu
  51. 98 Malibu Crankshaft/camshaft sensor
  52. 2005 2.2 L good???
  53. The 2008 Malibu
  54. No AM stations...but it's NOT the radio!
  55. 04-06 Epsilon loose shifter fix
  56. FS: 1998 Chevy Malibu $1500 Negotiable
  57. Sound system lights
  58. Low Coolant Light
  59. Screechy Sound On 2001 Malibu Cold Start
  60. Stock '06 stereo have pre amp out?
  61. Oil Life reset?
  62. Running my power wire for my stero amp
  63. glove box removal
  64. Floor lights in 98 malibu
  65. Dash Lights 99 malibu
  66. How do i remove the shifter in my malibu
  67. High volt alternator?
  68. Small jerks when leveling off to normal speed (45 - 65)
  69. Instrument Cluster Replacement Lights Bulbs
  70. Stock Radio 02 Malibu 3.1 V.6
  71. Instrument Cluster Overlays
  72. More Malibu troubles
  73. Intake Gaskets????
  74. How Much PSI In Fuel Line
  75. 99 Malibu, Radio won't light
  76. Installing Xm Radio Question
  77. 99 Malibu horn
  78. Repaired Sticking Door Lock Switch
  79. surge after getting gas
  80. Wierd idling and surging
  81. 2004 Classic remote programming instructions
  82. would you buy again ??
  83. 99 Malibu won't start
  84. 98 Malibu Alternator issue
  85. 2006 malibu ltz, looking for exhaust system
  86. Speaker wires HELP!
  87. Delco Moraine VI ABS schematic?
  88. 2005 malibu LT performance rotors
  89. Battery Indicator Light came on
  90. Drivers door chime
  91. 2000 chevy malibu wheel hub replacement
  92. Shocks and Springs
  93. Difficult to shift from park
  94. 2004 V6 Chevy Malibu Will Not Start
  95. Torque Converter Solenoid
  96. Speaker Mounting Depth
  97. window relay
  98. Knocking in Engine
  99. 79 Malibu
  100. 99 Malibu: Blower motor faulty, not resistor
  101. "Code reader- who sells a good one?
  102. Sourcing malibu parts & hardware
  103. Engine Sound
  104. Trunk Leak
  105. 2000 Malibu LS, LOUD grinding sound from engine
  106. Fuel pump question
  107. Clicking Noise When Braking
  108. DExCool- How long to change?
  109. o5 malibu classic aftermarket stero installation
  110. Low Coolant Light
  111. Alternate Carbon Fiber Hoods?!?!?
  112. 2000 Malibu turning noise/vibration
  113. backseat bolts
  114. Can a "not so fresh battery" cause problems?
  115. 2000 Malibu: Intake Gasket & Water Pump
  116. Wiper Motor Help!!
  117. can i clear airbag icon on dash?
  118. 99 malibu hard starting in morning and after turned off for 5 min.
  119. Ignition switch in 2001 Malibu
  120. idle issues/ lower intake tips
  121. Fan speed heater
  122. little heat?
  123. 2000 Malibu - 1-2 shift flare
  124. 01 malibu low oil pressure light comes on & off
  125. Starter problems?
  126. Service engine soon PO443 & PO449 codes
  127. Weird Idling when stopped! (2000 Malibu)
  128. '79 Malibu Classic
  129. Brake problems
  130. Electronic Brake Control Module
  131. 01 Malibu service vehicle soon light
  132. Steering noises(2005 malibu)
  133. after 144k in 35 mos
  134. Steering Column / Tilt Lever
  135. vacuum and wiring
  136. 98 Malibu change the lifters ?
  137. wiring diagram (speakers wire colors)
  138. Knocker Sensor on 2001 Malibu
  139. P0300 Code and Rough Idling
  140. misfires and loss of power
  141. Rear Deck mounting depth
  142. Need help again
  143. 98 Malibu Stereo Rewiring
  144. 2001 Oil Pressure Sender Location
  145. Radio is on "LOC"
  146. 04' Front door speakers
  147. Connection between Passlock & ignition switch
  148. 04 Malibu No heat but Air works?
  149. Malibu 98 power windows and A/C problem
  150. 650 or 750 carb?
  151. 99 Malibu, starts and dies after 2 secs, Battery dead, gas guage showing empty
  152. Winsheild Wipers have gone wild!
  153. Headlights wont turn off!! HELP!!!
  154. P0304? or a sign of a bigger problem?
  155. Oil Life Monitor
  156. Malibu won't start! Passkey Security?
  157. Straight pipe
  158. Help!!! How to reset the theft system???
  159. Want my malibu faster...
  160. Fuel Pump reset button
  161. 06 3.5L Malibu Maxx fuse size
  162. Sluggish 200 Malibu
  163. How do you?
  164. 2002 Malibu Code P0300 and P0420
  165. no tail lights or tail lights
  166. Lock out (park lock?) solenoid in '98?
  167. Installing aftermarket car starter
  168. Have to hit the gas when cranking
  169. Dextcool question...do I have to?
  170. Overheating issues with my Malibu?
  171. 2001 Malibu Wiper Help
  172. 2004 Malibu transmission fluid level check
  173. Keyless Remote Programming
  174. Transmission Probs
  175. 99 malibu radio locked?
  176. Light "squeel" in steering wheel
  177. 2004 Malibu Maxx FM Antenna Modulator Question
  178. 2000 Malibu / hazard switch
  179. Help me find the noise
  180. Replaced intake manifold gasket, now theres crap in the coolant
  181. Low coolant light on, but the coolant isnt low?
  182. radiator drain plug
  183. 99 Mailibu shut off while driving
  184. Coolant Smell
  185. Name that connector! Pics inside..
  186. '97 3.1 Trouble Starting
  187. 98 Malibu.... engine noise/cease running
  188. 98 Malibu low idle while in gear and intermittent stalling
  189. 1998 Malibu stalling when idol
  190. 98 malibu hesitating badly
  191. 2003 Chevy Malibu interior help needed
  192. VATs passlock
  193. keyless remote - service vehicule soon light problem
  194. no heat or ac??
  195. fuel pump removal?
  196. 97 Malibu Ticking And Sluggish At First
  197. Gas gauge fainted....
  198. 2003 Malibu/door locks
  199. 97 Malibu Low Coolant Light
  200. EGR and EOP problems
  201. Over Heating Problem
  202. 2004 Malibu Maxx OEM Radio with Subs?
  203. Does any one have a V-6 3.1 Malibu 98 engine for sale? or knows where I can find one?
  204. 98 Malibu misfires when hot
  205. is it worth it to put 700 or 800$ into a 1999 chey malibu?
  206. 2.4l random misfire
  207. Malibu LS 2.2L is Underated
  208. Air Bag controller problems
  209. Fan Vibrates?
  210. 2001 Malibu starts, but dies with no gas applied, cussing does not help
  211. 2000 malibu ???????
  212. Evaporative Emissions Control System Failure P0440
  213. 1998 Malibu ABS
  214. Malibu 2002
  215. Loud popping noise in steering.
  216. 02 Malibu Not the hazard flasher
  217. HELP!! Put steering fluid in brake reservior
  218. Won't Start...?
  219. DIC Problem/Questions!!! HELP!
  220. Dex cool gooo
  221. Attacking the "BEAST"
  222. Spark Plugs
  223. beeping under left side of dash
  224. 98 malibu shifter problems
  225. ABS Speed sensor harness
  226. anti-theft system
  227. For Bu lovers...
  228. Shop Manual
  229. problems w/2000 malibu
  230. problems with 2000 chevy malibu!
  231. vapor canister
  232. Transmission replacement...rebuild
  233. 98 Malibu 4 cyl (what problems have you had?)
  234. 2005 3.5L Front Passenger Turn signal out
  235. Found a service DVD on Ebay.
  236. Has any one bought and tried this?
  237. Transmission code p1810
  238. Need some guidance
  239. Install CD player on 2000 malibu
  240. where is thermostat in 99 malibu?
  241. 2000 malibu overheated and now won't start
  242. Fuel Injector/Rail clips...
  243. 1999 malibu turn signal flasher
  244. Fuel Pressure Spec
  245. 1998 Chevrolet Malibu Starter/Solenoid
  246. Changing your coolant EARLY!!!!!
  247. 1998 Chevy Malibu Fan relay
  248. Radio Removal / Replacement
  249. 97 Malibu A/C Controller
  250. Is it easy to replace front coil spring?
