View Full Version : Malibu
Pages :
1 2 3 [ 4]
5 6 7 8 9 10 11 12
- 05 Malibu radio/lights on radio not working
- Anyone have problems w/ AC turning on & off??
- 99 Malibu - how long should brakes last????
- fuel rail inlet hose
- Which fuel grade is best for 2006 Malibu?
- Does 2006 Malibu LT has PCV Valve?
- Turning Noise
- 97-03 malibu short ram intake
- '98 won't go past 4000 rmp
- 1999 Malibu 2.4 hard start
- What does it have to do with.......
- Smoke
- 99 malibu coolant
- 2000 Malibu Motor Mount
- 2006 Malibu do not need to replace fuel filter?
- 2003 Malibu Remote Programming
- starter problems
- Please help me...Car doesn't start
- How can I drain the coolant?
- Radio Replacement
- 2.2L from pre '99 to post '04; how is it different?
- Problem with my 3.1 Heads
- Possible transmission noise in neutral from a coast to a stop
- 2000 Chevy Malibu Overheating Stopped
- Disabling DRL
- glovebox tag
- Malibu 2006 Brake Lights When Car is Off??
- Initial engine noise durning startup; 2.2 Ecotech
- Clunk in front end.
- Malibus' electric steering; good, bad or maybe?
- low fan speed (1-4) problems
- Replacing side mirror 2005 Malibu
- Passlock II Problem, Cranks but no start...
- 97 malibu tries to start
- No Rear Running Lights and Dash Lights??
- Gas odor From car Gets worse and Worse?
- 2005 Malibu Maxx Rear Brake replacement
- 05 malibu no brake or signal lights on back only
- 2001 Malibu overheating, coolent no ciculating
- Checking/Adding ATF to the 4T40E, 4T45E..
- Lights on radio out.
- Center Shifter Bulb Replacement
- 2001 malibe serpintine belt
- 99 malibu brake lights out
- 2001 malibu wont start
- Does my 04 Classic have keyless?
- 04 Malibu Classic Stalling w/ no code
- Teft light on in dash
- Temp Gauge Reading
- Outside Air
- 2002 Malibu- Hard to start
- 99 Malibu : stalling, P0102, and rough 1-2 shift
- Are the 3.1 heads reliable???
- How to clean '98 Malibu EGR???
- How to program 99 Malibu key fob?
- coolant leak
- CD player question
- Amp/Sub problems
- head unit removal
- OBD Code P0401
- 99 Malibu Strut and Shock Replacement
- PCM Problem
- need to know 92 chevy 3.1 rocker torque specs
- Can I put keyless entry in 05 malibu?
- Rad overfill cap gaining pressure and blowing off
- 2002 Malibu - Overheating
- K&N filter for 99 malibu
- 2005 Mailbu Heater-A/C controller upgrade
- 05 Malibu LS, Not MAXX Stereo
- Intake Manifold Gasket 2000 Malibu LS
- 99 malibu idles roughly when stopped. need advice before I take it to the mechanic
- 99 malibu - Alpine cda9885 install
- 03 Malibu Clicking when cold
- 98 Malibu cruise control problems
- 2003 Malibu LS
- Transmission Fluid or 98 Malibu LS
- 2001 Malibu Cd Player
- factory anti theft system
- factory amp?
- Need a techs advice...
- stereo question
- Defeating the 'auto' headlight feature on a 05 Chevy Classic (Malibu)
- 98-04 Malibu class action
- 98 Malibu break issues
- 99 Malibu: keyless lock/unlock fob is breaking down
- 1999 malibu stereo level converter
- 1998 Chevrolet Malibu problems...
- What rear end gear?
- 98 Mailbu noise coming from driver side front tire
- 99 malibu front hub assembly mistake
- 2002 malibu
- Another Passkey?
- 98 Malibu Tranmission problem
- 04 Malibu fuel pressure questions
- Nightmare PO113
- back seat problem
- good used car to buy
- starting issue (HELP)
- Water Leaks
- 2003 Malibu having problems starting
- 98 Malibu keyless entry
- 1999 front wheel bearings?
- More Malibu passlock crap
- How do we Check and change tansmission fluid for 2006 Malibu LT?
- 2005 malibu odometer problem!!!!
- I Need HELP!!!
- 01 malbiu strut mounts 81000 mls
- Malibu Surging Problem Advice Needed
- 2006 malibu SS
- DRL Module on 2001 Malibu
- stereo problems
- Defeating auto door lock and adding fold down rear seats
- 97 Grand Am misfires only in Park and Neutral
- hesitation on starting
- Problem with a turn signal.
- 98' malibu break noise
- 1999 Malibu paint problems and rust
- codes P0101 and P0108
- Vibration when braking
- Bad Accelleration!!!! Need Advice!!!
- 03 malibu random miss
- ABS Light
- AC service
- 81 Malibu... Come On Down!!!
- In a hurry
- Lemon law in Canada?
- Stock radio lights
- Coolant disappears
- 02 Oldmobile Intrigue vs 04 Malibu
- 2001 Malibu Suspension Noise???
- 2001 Malibu - Multiple problems
- 97 mali - removing ignition switch - interlock cable problems
- can't find a replacement reservoir!
- 2004 Front light conversion
- swaping engines...(tips)
- What is P0113- IAT sensor high input?
- please help
- Question about intermittent rough 1-2 shift on my 01 Malibu
- Emissions code
- Best oil filter to use with the 3.1 V6 ?
- No Heat
- Two catalytic converters?
- Great forum guys!
- New to the fourm, ABS Module Location 2005 Malibu
- leaking water
- 2001 cat converter
- Intake Manifold Bolts ?
- 2001 Chev Malibu Recall (pulled from my insurance co.)
- 2000 Malibu Cigarette Lighter Fuse
- Malibu body style change
- 2001 Chev Malibu factory stereo
- 03 malibu shudder
- How can I increase power to my malibu??
- Parking brake switch
- Bad Acceleration!! Please help!!!!!
- ABS light
- humming noise when turning
- car wont start
- Can someone help me find the fuse box?
- Something odd with my 2004 model gear shift.
- '04 Chevy Malibu front end thumping noise
- 2000 malibu start problems
- 2000 Malibu different issues..
- No High speed on heater fan
- Performance chip?
- Blower Motor not working
- Otc Code 410 What To Do
- Malibu 1999 Check Engine Light
- Custom question
- 97-00 front brakes manufacturer defect?
- ABS Warning light
- Intake gasket
- 79/80 Malibu Wagon Roof - Help Needed
- Poor wet weather performance 2001 malibu
- HELP!...Lights don't work
- 2001 malibu auto lights at start won't work
- 98 Malibu noise from rear suspension
- 99 Malibu: aiming the headlights
- 2004 malibu squeaking sound
- Transmission sensors...
- 1998 malibu problem! Help!!!
- HELP, put spark plugs wire wrong, need diagram
- Tech. question
- Stalling problem in car with potential IM Gasket leak ?
- 2001 malibu brake rotors
- My 98 Malibu missed
- 2000 malibu STUMBLE on start, need help
- How do you take off the window crank?
- 98 Malibu
- What are these made of?
- Trunk Lock Replacement
- Malibu Ignition 79
- Splash sheild and inner fender liner
- fuel leak
- Monsoon
- Car will not start
- Help! Accidentally took off 3 plug wires..Need Diagram!!
- How-To web sites??
- P0113 Chevy Malibu
- 2004 Malibu cd changer won't work
- Replacing rear speakers in Malibu 04
- break problems??
- `03 Malibu 3.1 lifter tapping.
- Upper Intake Manifold Conversion
- How many Miles on your Malibu? Late Problems?
- Misfire #1 after intake gasket replacement
- Cv?
- Slow Take Off
- '80 Malibu Wagon
- no spark 1997 malibu
- 01 malibu keyless entry
- 97 Malibu with lots of intake leak problems??
- Help Quick!!!
- Food For thought - North American Vs. Import
- 99 problems
- Remote Car Starter Problem
- 97/98 Factory CD Player
- Fuse 37 blown screws it all up
- 2002 Chevy Malibu...gettin exhaust stuff done
- 79 Trans leak
- Just got my first 99 Malibu and....
- Coolant leakage???Intake Mainfold gasket???
- '98 2.4L Alternator cont.
- 1998 Malubu Starting issue
- 03 Malibu random cylinder misfire 3100v6
- Starting and Dying problems
- Power Steering Problem
- Buzzing noise coming from vehicle when going slow.
- 2000 Malibu fuel leak
- 2004 LS front end clunk - revisited
- 2004 knock sensor
- new parts
- 2000 Chevy Malibu
- Odometer went blank
- Intake leak?
- 99 malibu problems, sound familiar
- 02 Malibu Coolant Flush
- Transmission issues when cold...
- How do you disable the seat belt chime? 98' Malibu
- 1999 intake gasket.
- Theft System Light on while driving
- Molding And Exterior Trim
- 2004 malibu audio
- Disabling the Passlock
- 2004 malibu cigarrette lighter
- Catalytic Converter
- 2004 malibu
- Car Vibrating After Shifting at highway speeds
- Windshield Wiper recall issue...
