View Full Version : Malibu
Pages :
1 2 [ 3]
4 5 6 7 8 9 10 11 12
- 1998 Malibu heater problem
- Pulley Snapped No idea what it is!!!!
- Turn Signal and Rear brakes
- replacing the temperature door actuator on a 2000 Malibu
- Tire Size
- ABS light coming on.
- malibulls**t
- 98 Malibu brake light bulb keeps blowing
- window knob wont come off any ideas
- 1997 hammers at start and antifreeze through exhaust
- Anti lock break problem
- Rusty coil springs
- 05 Malibu stripped oil pan bolt
- I need help taking off my door panel
- i need help
- 2001 Chevy Malibu - The fans will not turn on?
- 98 malibu trans problems i think
- 05 malibu gas cap prolems???
- Thermostat needs to be replaced
- What engines will fit 98?
- Fuel filter/green clip problems
- malibu maxx review plz
- 98 malibu wont stay running and the gauges dont qork
- Rough start
- clicking sound when braking
- 2005 Malibu has a creeking noise
- '99 3.1 cranks no start
- 97 Malibu key wont turn in ignition
- 3.1 Malibu leaking coolant
- 03 malibu miss at idle
- 2000 Malibu alternator problem
- problems after intake manifold repair
- check oil light
- 2002 malibu blues..need help with electrical problems
- shift solenoid
- Accessories
- how to take out headlight
- 99 Malibu Won't Start
- Overheating Alternator???
- 97 Malibu 3.1 v6 hard to start when warm
- 2005 Malibu LS popping sound when making left turn
- 2003 Malibu Fuel pump
- 2006 chevy malibu maxx
- Few problems with 2000 Malibu . plz help!
- performance upgrades?
- 99 malibu coolant leak
- key fob programming
- Auto lock/ Unlock 2005 malibu classic
- 01 malibu trans problem
- Wheel Bearing Nut Size? Need response asap plz
- 2001 Malibu fuse and collant question
- 2001 Malibu and the Cruise Control shutting off.
- 98 Malibu Coolant Leak - Please Help!
- cylinder 1 missfire 99 malbu
- Code Alarm GOH-MM6-101890 Problems! Help!
- Should I....
- Spark Plugs
- abs light on
- 99 Malibu - horrible rust near gas cap/door??
- 98 malibu key will not turn
- Pdf Format Manual
- My Heater/ac 1 & 2 Does Not Work
- 97 Overheating
- 2001 malibu code 128
- belt tensioner
- 02 Malibu won't start after new serpentine belt installed
- Theftlock audio system
- o4 malibu remote starting not working
- 99 malibu instument light bulbs
- 2005 chevy malibu classic stereo wiring
- 2008 Malibu LS....review, from an owner.
- 98'Malibu can't start
- radiator coolant
- 2005 MAlibu Misfire
- 97 Malibu blower motor resistor pack location
- electric windows stick in the cold weather only
- I think its my fuel filter
- antitheft light blinking - no start
- Rough cold start, erratic idle for 1st few seconds...
- 2000 Malibu start & stall constant
- Wiper motor Question ,99 MALIBU
- Everyone gonna run right out for the 2008?
- help
- 04 aftermarket radio pics
- How To.....
- fuses
- 03 malibu radio has no power
- R&R heater core $1200
- lights
- lights
- Information on The 2008 Chevy Malibu
- 98 Malibu Door locks and trunk release
- 08 malibu
- Can I change the battery myself?
- Spark plugs and wires
- This is annoying
- How to replace Wind Shield washer Reservoir
- Heat blend actuator
- OBD Scanner/Trouble Codes
- 01 malibu coolant temp sensor
- Is my 04 Malibu Classic Falling Apart Already?
- 99 Malibu radio buttons don't light up
- 99 Malibu headlamp alignment
- replaceing 98 malibu power streering pump ??
- knock sensor
- maxx tail lights out even after replacing bulbs
- Code Problems 91 malibu LS 3.1
- sunshade wont retract
- Low beam headlight wont work, ck'd fuses! HELP!
- Steering Vibrates
- 1998 malibu problems with gas/emissions code
- 97 Malibu gas mileage
- 99 malibu (IAT) sensor
- Headlights on too long after key is off
- Abs
- Keyless entry stopped working
- 2005 Malibu remote start
- no codes read but in trouble!
- Power Window Problems!?!
- 1999 Malibu engine connector question
- Where is the starter located on the 2000?
- loose electrical wire? replace connector or blower motor?
- Programming Keyless Entry Transmitter
- How to Change 2003 Malibu Headlight
- 05 Maxx range selector not working
- Engine Ideas
- Solid blinker light
- How do i remove the stock radio in a 98
- Pulling front hub
- class action settlement
- Hard Start
- Malibu eat my CD!!!!!
- 00 Malibu window switch problem
- Cordovan tires on a Malibu?
- replacing water pump on 97 Malibu
- tire size
- HK Drive and Play on 04 Malibu - ACC wire questio
- Car won't start.....help please asap
- another differential whine...
- 02 Malibu annoying beep sound
- Adding Coolant to Dex-Cool
- 2004 Malibu battery drain
- new fuel pump, fuel filter, and now the check engine light is on. Help???
- 97 Malibu hesitates at cruising speed
- 2004: Back of Stereo Diagram
- Tune up question
- Belt breakage on 1997 malibu.
- 03 malibu brakes
- Help!! Can't fill up the car!!
- Strange cooling fan behavior
- how do you remove relays from fuse block?
- Anyone have a used TIS 2000 CD?
- Service Vehicle Soon light HELP!
- 3.1 v6 overhaul question
- hub bearing replacement?
- 4T45-E Transmission
- '05 Malibu heater blowing cold air
- 2000 Chevy Malibu
- p0300 code
- 99 Malibu Plug Wires
- backflush 00 malibu 3.1
- Aftermarket Stereo install questions on a 2004 Malibu classic
- 00 malibu radio preset buttons
- defroster connector unhooked? help!
- po420 code
- 99 Malibu: How to disarm airbag?
- Passlock Bypass With A Resistor?????
- Tail lights odometer out fuse blows
- Malibu 3.1 2000
- 01 Malibu rough idle!!!
- 98 Malibu 2.4 rough idle
- 99 malibu will not start
- '99 malibu gas pedal problem
- 2003 Malibu Heat door motor
- Testing fuel pressure 2001 v6
- 2001 Malibu wierd electrical problems
- 2003 A/C High/Low side specs
- Enviormental controls out of control
- '04 Malibu Maladies
- 2000 Malibu with 1998 Camaro Rims?
- 01 Malibu with a PO141 code
- Noise (bearing?) only when turning left
- 04 Classic 2.2L
- 2000 Malibu No Crank/No Start
- 2000 Malibu Check Engine Light
- Help
- '99 Malibu Automatic Lights always on
- 2005 malibu brakes.
- New 2000 Malbu owner, service questions?
- Malibu 2000/ service manul on CD?
- 1998 malibu question anyone please help
- Cd player in 2001 Chevy Malibu shows "locked"
- Need help with serpentine belt
- 99 Malibu 2.4 Ignition Troubles
- 2000 Malibu brake light comes on
- 05 malibu power steering light?
- Change Dexcool to generic green?
- emmisions problem
- I Took The Grand Prix!!!!!!!!!!!!!!!!!!!!!!
- 2000 Chevy over heating
- 2001 Malibu Window.
- 1997 malibu I NEED HELP!!!!!!!!!
- 04 Malibu LS
- 2004 malibu
- 98 malibu pwr string pressure hose
- 99 Malibu: windshield fogging up
- Malibu ticking sound?
- A/C not cooling
- New engine, remanufactured transmission
- Comments on 2008 Malibu ?
- Cross Country recommendations
- Power Steering
- 04 Malibu Speed LImit and Supercharge
- '01 Malibu Temp Guage
- 99 Malibu Stalls as low rpm acceleration
- 1997 Malibu radio displaying LOC
- 99 Malibu Coolant in oil
- Performance Chip
- !!HELP!! My 98 Malibu keeps cutting off
- Belt Tensioner Movement
- Parts diagrams on the web?
- 04 Malibu LS Remote Start and Transmission Range Switch Issues
- 2001 Malibu Gas Gauge.
- 99 Malibu horn/airbag issue
- Transmission Range Switch Issue
- Theft System malibu 97
- 98 ls no oil pressure? *help*
- IAT Sensor
- 1998 Malibu Battery Light Problems! HELP PLZ
- 98 Malibu TPS question
- I need help with fuel pump
- 99 Malibu tranny probs
- Very slugish, engine ping 97 Malibu
- 2001 Malibu horn blows by itself
- Quad 4 misses at 2000 RPM
- ugh please help me(kinda long sorry)
- 04 Malibu turn signal problem
- 99 Malibu: Turns Won't Start, No Dash Lights: NO PASSLOCK
- help! 98 malibu suddenly cuts off
- Hard starting, Fan does not work
- replacing 98 malibu LS headlights
- 2001 Malibu V6 slow starting sometimes
- Hot Start Problems
- Air Intake
- Fel Pro
- Car Stereo Problems with Amp
- Malibu SS
- 2001 Malibu squeaking noise.
- factory cd players
- are head bolts the stretch type?
