Chevrolet
> Malibu
View Full Version :
Malibu
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
The new Malibu is UGLY!!!!
Speaker Removal for a 98 Malibu
99' Malibu LS that dosen't want to start
Tire rattle noise
What's your mileage?
Damage to radio mountig area
INOP message after 7 tries for radio lockout
02 Malibu console removal?
'98 Malibu Ignition Lock Cyl Going for 7th Time!!
98 malibu check engine light
2004 Malibu Steering Questions!
Questions about 2002 Malibu
whats it worth?
Spark plug order or cylinder order
2000 Malibu CD Deck Problem "ERR"
2002 Malibu Keyless Q?
2004 Malibu IGNITION KEY PROGRAMING ????
dual key fobs?
Charging system indicator light
Cleaning interior
2004 Malibu Radio SRCE Button
Where to find parts
Programming keyless entry fobs
2000 malibu sputtering on hills/inclines?
97-03 Malibu In Movie
1999 Engine loud noise after chatter sound
removing auto shifter to replace
2000 Chevy Malibu Problem
2001 stalling issue
wanting to put cd player in
Torque setting
Idle Problem
Putting a pedal cover over the accel pedal
My gauges do not work sometimes. What could it be?
Electrical and Emmission System
reattaching door pull on '98 malibu LS
Change raditor fluid
keyless entry
Stock rims
malibu creaks...
horn not working
2001 Malibu keyless entry program?
a/c leak
HELP - Radiator Removal
Clear Tail Lights for Malibu
Cig lighter fuse
2004 Radio problems
Changing spark plugs
Newbie Radio Help.
A/C Blowing 10amp Fuse under hood
Eagle Alloy 18"x8" 077 - new
1997 malibu auto trans cap.
fuel and temp gauge problem
Need an 01 Malibu Factory Service Manual?
turn signal problem
Check Engine Light
2003 Malibu Keyless Entry Programming
Radiator Drain Plug Broke
Help Removing Trim Pieces
Replacing Radio
Radiator fans working only when A/C is on
Tire size with stock mags??
2003 Malibu Transmission Cooler & Synthetic ATF
Jetchip ECU Upgrade/Piggyback Available
Speed Limiter
Hard Shifting
NHTSA Initiates Investigation Into 2004 Malibu
98 Malibu Heater A/C Controls...Interchangable??
front door panel issues (changing speakers)
squealing in steering
1998 Malibu Brake Pedal Travel
Malibu not wanting to start
Won't start... fuel pump???
My 2004 Malibu brake light coming on update
Considering Buying Used Malibu
trunk broken need help ???
Malibu 2 Words Never-again...............
My 2004 Malibu LT (brake light going on and off while driving)
2004 Malibu steering
ECU performance reprogrammer
radiator fan(s)
Auto Trans fluid
used factory rims
FWD Posi
'04 Malibu Offset Crash Test Tonight
Malibu Wax
Cold air intake?
Class Action against Chevy...who is with me..
stutter w check engine light flashing
Connection between wipers and radio?
stock badging and logos
Awsome Hood For Malibus
Malibu Performance
Malibu Weight
Headlight replacement
Which Hose? trying to install flush kit
Hvac Fan
Timing belt or chain?
2001 Maulibu Check Oil Light
radio security lockout after 7 tries
Heat/AC Fans broken!
'03 Malibu Radio Harness
Help
Tips for removing fuel filter
po302
more speed for my 98 Malibu?
01 Malibu slow shifting to reverse
Abs
Cold Air Intake/Sensor Mod
2000 Malibu engine problem
Governer
'04 Malibu Bumper Tests- Press Release
2004 Malibu/Maxx
Sealed Transmission
Driving Lights
Throttle Body
blower speed switch
Egr
Malibu idle problem
2003 Malibu Problems
Fuel injector - easy to clean?
rims?
Passanger side axle
malibu front axle
Problem replacing rear speakers in 2002 Malibu
Speed regulator
Where is everyone???
intake gasget
can i stop vibrating dash
"Cal Err" on dash after ECM replacement?
Will a 02 Buick Century motor fit in a 98 Malibu
Any manual/technical info on 2k malibu on inet?
I Have Malibu Parts!!
why does only one wheel turns?
2001 Impala Security Problem
flashers
Brake warning light issue
Performance Parts
Oh damn! help please malibu fuse probelm
2000 Malibu engine revs a lot with little power to wheels
Need Parts For 77 Malibu
looking for
rough idle
turn signal 2000 mali
head lights
thermostat??????
Check Engine Light
nbody site
passlock problem
1998 - battery gone south?
rim size for 2001 malibu???
dome light-after mali is turned off does the light goes on?
Stereo/DIC replacement in latest model?
Engine Idle
HVAC fan control
GM 75k extended warranty worth it?
2004 Malibu Tech Question
Help Replacing Intake Manifold Gaskets
Changing mufflers
no heat
Door panel removal
98 malibu
passlock system on 2001 malibu
1999 Malibu no start
Mali Engine Problem
does anyone have directions for replacing the intake gaskets on a 3100 (3.1)
2001 Malibu Floor Mats - Part Number?
Body Parts
K&N filter helping out a bit
2000 malibu no start
Rear window defroster
'00 Malibu Turn Signal
2000 Malibu Lower Intakes Leaking
2000 chev malibu keyless entry box
Brake warning light flashes when accelerating
Brake problems
New gm forum
Cig. adapters inside dont have power
Keyless Entry Equipped?
Parking Brake light won't go out
2000 malibu tail light trouble
Addition of Fog Lamps
Engine for 81 Malibu
Cant get the ciggarett plug off my dash help please
Chevy Malibu Fuel Guage went down below dent
99 Malibu VS. 02 Cavalier Ecotec
Fuel Injectors out for 4th time on 99 Malibu........
1997 Malibu Problems
excessive condensation lingering in headlamps
Found Malibu Euro Tailights! Look!!
how many quarts of oil does the 3.1 take?
airbag light after rplacement
1998 Cutlass (a Malibu twin) Power Steering Noise
Transaxle problems---2000 Malibu V-6
malibu altezza tail lights
2000 malibu manual transmission conversion, need help??
new user - about my car
Radio locked out in 2000 Malibu
HEEELLP!!! My alarm won't turn off or start car
Malibu Reving after fill up
How to replace vent blower in 98 malibu??
how to remove malibu steering wheel
Engine temperature
Rear speakers - 2003 Malibu - Help?
ABS light
Heater and light controls
3.1l to 3.4l top end swap info
Putting in new Fog LightBulbs
Synthetic oil in Malibu
loose dashboard defog strip driving me crazy!
2000 Malibu Fuel Filter Location
98 Malibu wont start
Wiper blades on 2002 Malibu
2001 Malibu - Utility Trailer wiring harness question...
2001 Malibu - Signal Flasher Location..??
Some more Q's
My 2004 Malibu is total opposite of my 2003
Clunk Noise
Message for GMMerlin
2004 Malibu
2001malibu brakes
Cutlass parts?
Installing front speakers in 2000 Malibu
The great Malibu TRAP
thanks alot
01 Keyless fob reprogramming
Engine Light
2001 ECM Codes
Abs Light Problems
Pleeeease help me!
Who has a 77 Malibu?
99 Malibu Fuel Gauge
Brakes
intake
oh yea, I'm a shoobie
My passlock is going out so they say""
'81 Malibu engine swap
Head Unit
MALIBU Classic Landau 1979
amps
engine check
Chevy has decided to let me get another car
bro got an '01 Malibu LS
My 2003 Malibu died for the 4th and last time
Oil leak at filter
This is the final straw for my 2003 Malibu
My 2003 Malibu died again (3rd time)
Added Auto-Dimming RearView Mirror with Compass and Temperature
1997 Malibu Keyless Entry Programming
