View Full Version : Malibu
Pages :
1 2 3 4 5 6 7 8 9 10 11 [ 12]
13 14 15
- 02 theft lock problem
- FOR SALE: Malibu aftermarket stereo installation kit and wiring harness
- Heat will not blow on feet in 97 Malibu
- yet another blower motor/resistor question...
- 1999 Malibu steering wheel lock
- Is WD-40 good for frozen door latches
- Antilock brakes??
- Dependable,mid-sized,4 door,RWD car
- 99 Malibu - ABS warning light
- Mechanics ... a 99 Malibu ABS Hydraulic Pump Question
- door lock actuator replacement
- Headlight Adjustment
- Exhaust
- Strut Tower Bar
- 98 Malibu LS Coolant leaking!
- Where has the filter gone??
- U want MODs I GOT MODS!
- rod knocking?
- Replacing rotors
- help rought idle
- Removing front axel,
- classic
- 2000 Malibu
- Windows fogging up
- Fuel Odor
- Newbi!!!! (im a girl! :/ Help)
- driving lights
- 99 bu- speed guade for 4 cly in v6's?
- Power Steering, Wheels and ABS System ... HELP!
- Seatbelt sensor light goes off randomly...
- 02 Malibu-JUNK ON WHEELS
- check engine light.....thinks the mechanic screwed up
- 01 malibu aftermarket stereo
- Mods on my malibu!
- Dual exhaust
- Power Steering
- Altezza Rear Tail Lamps
- ECU Tuner for 97?
- Engines stalls after 2 minute running
- changeing plugs in a 6 cyclender 97 malibu
- Headlamps
- Malibu 2000 heater guidance
- 2000 Malibu belt shred Crank pulley?
- '01 Malibu will not start - not a passlock prob
- mass air flow
- torque specs ,front wheel bearing?
- antifreeze shooting outs reserve when car overheating in 97 malibu
- Aftermarket Stereo
- Excessive brake pedal travel
- malibu or impala?
- gas leak
- P0113 "IAT Sensor"
- 01 Malibu. How serious is the code
- sidemarker bulb size anyone!? still cant find it!
- freeplay in steering after GM recall service
- A new Web Site!
- Help
- Headlight Bulbs
- Exhaust
- How to check auto tranny fluid?
- Help me! I need to remove main panel on Malibu 2000
- Coolant Flush Questions after Intake Gasket Replacement.
- anyone got pics of theyre malibus hooked up??
- 1999 Malibu heating problem
- 99 Malibu Wiper problem
- 02 Malibu Firing Problem
- 98 Auto Trans shifting problem
- 2000 Malibu ignition key won't turn! Help!
- automatic transmission problem.
- Struts for 1998 Chevy Malibu
- the no start problem
- Hazard Switch
- Warranty ran out...dealer helped
- Cooling Fan Problem
- ABS light and buzzer question..
- 1998 Chevy Malibu LS Exhaust Questions
- 97' Engine Swap
- programming instructions for 2003 mailibu
- 2004 Classic Malibu
- 99 brake lights
- Need help removing the dash on a 2004 Malibu
- Sevice Vehicle Soon Light
- 99 mailubu chain or belt timing????
- Malibu Brake bleeders
- noise when you go on above 80-90 km
- Change Headlight Bulb
- Theft system problem
- Engine code P1815
- 2002 Malibu LS Head Unit
- Advice for 03 rotor replacement?
- 98 Malibu-Engine just Shuts-off
- Engine Problem..Help!!!
- New Car Stereo installing
- "chirping" sounds from driver's door speaker
- Code 0442
- Bigger Intake Question!!
- Blower resistors
- 2000 Malibu - Speed Limiter
- Replacing intake gasket...
- 5x114.3mm wheels fit on a malibu?
- Humming/Buzzing at 60mph?
- removing starter motor
- Wheel sensor diagnostic
- 2001 wiring diagrams
- Hazard Light Module Ticking
- tire sizes???
- Newibu & Stuff
- knocking in motor
- clunking in rear
- 2004 Malibu (v6) where is oil filter
- Synethic or Conventional tranny fluid
- 2000 Malibu Stalls NEED HELP
- 2002 malibu no power
- extended auto warranty?
- Winter is fun.......
- No help from my dealer on gasket
- 02' Fuel Filter and buzzing
- Brake pads low again
- adjusting clock
- cooling fans
- best struts for 99 Malibu
- 2001 Malibu Coolant leak
- steering wheel pulling to the left when accelerating
- PS recall question
- Keyless Remotes 2003 Malibu
- Malibu Performance Chip ?
- Looking into purchasing a 98 Malibu
- malibu cruise control
- Lights controller
- oil not pumping
- Front suspension noise
- Brake Question
- Brake job help
- Motor ?
- 4th time to dealer to try and fix same steering problem
- can a dealer also do a buyback/exchange?
- latest update on steering problem 04 maxx lt
- '98 Malibu-rack&pinion NE1 do it themselves?
- 2000 LS for sale with custom rims gottaa see!
- 2002 Malibu won't start.
- Malibu Heater
- 2004 malibu maxx, called chevy cust. service assistance on latest steering problem.
- Remove Stuck CD
- How To: Blinker/Flasher/Hazard lights work intermittently
- How To: Radio Reception; FM=bad, AM=None
- How To: HVAC Blower fan only works on 3, 4 & 5
- How To: A/C & Recirculation intermittant/blinking
- Left Rear Shock broke......
- 99 Malibu LS LOUD metal noise coming from front right side...
- 2003 Malibu in-dash CD Removal
- 2004 MAXX steering problem update!
- 2000 Malibu Theft Lock ? again
- crazy electrical(?) problems
- thumping tire
- 2000 malibu woes
- 1998 Chevy Malibu Problem
- Struts causing tire failure
- 2004 malibu maxx lt steering column replaced
- Window deflectors for 2004 Malibu
- condensation in headlamp lens assembly
- Can't start - need a help!
- Fuel leak
- 98 Malibu pushrod order
- 98 malibu where is the OBDII port??????
- code P0305
- Mally with 127,000 miles
- Having Probs! Any Suggestions or Words of Wisdom?
- 04 Malibu Start Up Problem!
- Rear right flasher
- Navigation systems and Xenon headlamp, any plans on adding to the Malibu's or Maxx's?
- 2004 Malbu Maxx LT, squeeky belt attachment
- 2000 malibu parting out
- The little mexican under the hood of my malibu stoped pedaling
- 98 Malibu has died need help
- 99 remote starter kit
- Where is the intake air temprature sensor located?
- 99 Malibu: #2 and #5 radio buttons don't light up
- Wiring wipers
- 2001 chevrolet malibu
- How much to pay for rear shocks? 97 Malibu.
- wHAT POSSIBLE CUASES FOR A CHECK ENGINE LIGHT?
- Engine Oil/Coolant leak on the 3.1 V6
- 2004 Malbu Maxx LT, help on minor poroblems
- power steering question
- Removing Front Seats In Chevy Malibu
- No start
- Airbag Replacement costs??
- Back seat conversion? fold down?
- '00 Malibu stereo problem--Please Help!!!
- 97 Malibu LS Key Won't Turn HELP!
- Noise problem
- Water In The A/c Vents/ Passenger Side!!!!!!!!!!! Hellppp!
- 77' Chevy malibu classic. Worth anything???
- 17inch TUNER WHEELS NEED HELP!
- Rear brakes - '98 Malibu
- Read this if your Malibu WONT start!
- water leak 97 malibu 3.1
- Any cheats for oil pan gasket leaks?
- Has anyone the ABS light NOT come on
- Lighting Fx kits
- REV limiter??? reliable?? HELp
- FronT Bracking Grinding Noise
- Is there an O ring where the fuel line connects to the rail?
- theft system? starter? fuel pump?
- need new fob for '00 malibu
- Chevy Malibu '81 info?
- 1999 Malibu, clicking noises from tires when pulling in or out.
- Best Tires for the Best Ride
- 1998 Chevy Malibu Gas Gauge Reversal
- Another kill story
- starting problems & high idle
- Sputter, Strong Gasoline Smell
- 2000 Noisy front end, possibly some play in it..
- 20'' rims...
- please read
- Remote starter for 2002 Malibu?????
- Stock or Cone K&N filter???
- 1969 Malibu project or parts $620.00
- Unable to put into drive when cold(below 40 degrees)
- How much should I pay to rebuild my injectors?
- 1998 Malibu Water Pump
- 1999 Malibu Radio Lights
- 99 Malibu 3.1 and 95 Buick Centruy 3.1 engine exchange
- What has been recalled on the malibus
- Gas Gauge Problem!!!
- 1999 Malibu heater blower problems
- i need help with my red and black wiring on my glo- gauges for my 98 malibu i dont kn
- Check Engine light on 2003 Malibu
- Malibu console codes?
- system in an 04
- Gauge Pod HELLPP!
- Coolant light comes on
- "Looks arent everything"
- Humming Grind at Startup
- Malibu 2004 LS; Fog lights ???
- 2001 malibu antitheft problem
- 99 malibu... Not accepting gas!!!
- Fluid flush or just fluid change?
- 12 Volt Switched Wire
- Ks Clear Sidemarkers???
- 2004 chevy malibu not starting and dying
- Subs for a 1999
- Chevy Malibu Brake Pads
- clunking noise in front suspension
- Light size behind dash gauges???
- Testing Fuel Injectors
- Wheels for 2000 Malibu
