View Full Version : Malibu
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15
  1. 2001 malibu blinker problems
  2. 78malibu 350 swap
  3. idle and stall
  4. help with radiator fans
  5. 1965 - 67, 327 cu in motor, starter problems
  6. Gas Gauge Reading
  7. 1990 sierra a/c clutch
  8. Should I/can I walk away?
  9. 2005 Chevy Malibu Aftermarket radio
  10. A/C Clutch
  11. Crazy MPH
  12. malibu good for noobs?
  13. intake gasket?
  14. Replaced blower resistor; didn't fix fan speeds
  15. Battery Cables
  16. 1999 Malibu Brake Problems.
  17. 01 Malibu clunking hard in to drive and shifting hard?
  18. gaude pod
  19. FS: Dragon Z kit urathane
  20. Anyone interested in Carbon Fiber parts?
  21. 2 Problems: Engine Surges & Overheating Issues
  22. 98 Malibu running hotter since gasket repair
  23. Engine Surge
  24. Temperature Reading
  25. 99 malibu electrical problem?
  26. Cross drilled rotors
  27. Newbie needs advice on speaker buzzing/humming
  28. Overheathing?
  29. Chevy 55 BelAir !
  30. CD-R and CD-RW
  31. Rear Disk Conversion Question
  32. 2005 malibu keyless entry programming
  33. Malibu 2005
  34. Rear drum removal on 98 Malibu
  35. 1998 Malibu 4 cyliner-thermostat?
  36. 1998 Malibu
  37. 2001 Malibu tranny fluid check
  38. Intake manifold Gasket replacement
  39. 6x9 install problem!!!!!!!
  40. 1997 malibu power steering pump removal
  41. what do you think?
  42. 2002 Malibu LS V6 won't start
  43. front oil seal
  44. 18" KONIG APPEALS with TIRES 4 SALE***
  45. 2002 Malibu brake problems!
  46. Malibu 2001 Air Filter compartment
  47. AC Condenser leak
  48. Automatic Transaxle question '97 malibu
  49. Fuel filter on '99 Malibu, rusted fuel lines :(
  50. mass air flow sensor
  51. No horn, or taillights
  52. Gauge not right
  53. Thinking
  54. I need to remove my left side panel of an 97' malibu
  55. Class action vs. Dexcool
  56. Ignition switch will not turn on 98 Malibu
  57. tranny problems
  58. malibu wheel set
  59. New '04 Malibu/Maxx Recall
  60. Malibu Cruiser Bodykit Group Buy
  61. Window tints
  62. 98 Malibu A/C and fan problems: more feedback needed
  63. Wtb: Ecu
  64. i'm retarted
  65. swapping engines
  66. Engine Serial Number
  67. XM Radio in an '01
  68. Hard Start?
  69. Stiffness and noise in power steering
  70. 2003 mali crashed
  71. Alignment after Outer Tie Rod End replacement?
  72. Look at this beauty!
  73. tie rod end removal, 1997 malibu, how to?
  74. 2004 Malibu engine temperature
  75. my radio is locked
  76. no more malibu
  77. 01 Malibu - front end collision kill switch?
  78. New Malibu
  79. exhaust mod help
  80. euro lights
  81. malibu fuel pump
  82. over heating
  83. leaky trunk
  84. help me!
  85. Sunroof adj.
  86. 1999...Replacing Tag Lights
  87. Coolant leak rough idle
  88. Environmental controls shorting
  89. Shaking in front end at highway speeds
  90. obd II scanners, and emmisions testing
  91. Oil in Coolant Tank?
  92. 99 Malibu with random cylinder misfire.
  93. 1998 rear strut replacement
  94. Theft system question! '98 Help Meeee
  95. 2001 Chevy Malibu For Sale
  96. wheel question
  97. over heating in my 78 malibu need help
  98. side marker light
  99. 2003 Keyless Entry Programming
  100. 1997 Malibu Mystery
  101. carbon fiber hood
  102. 2003 Malibu Quit
  103. Car Won't Start - Losing Power
  104. 2001 Malibu Problems
  105. FLipflop trunk? ANyone try it yet?
  106. Euro tail lights 97- 03 malibu
  107. what wheels fit an 04 malibu
  108. Noise and shaking in front end
  109. Major Mali Problem
  110. 1997 Malibu For Sale! Nice!
  111. Headlights
  112. 1998 3100 SFI Malibu COLD AIR INTAKE!!!
  113. rough idle and dies in morining only
  114. Tune Up Needed?
  115. Cannot put car into gear when cold.
  116. Looking to Buy
  117. Brake
  118. Trunk lid
  119. Trany Problem
  120. Buttons peeling
  121. Timing chain?
  122. radio mute wire
  123. Trannie Whine/'04 Maxx
  124. AfterMarket Upgrades
  125. Trunk Light
  126. GUNN Chevrolet
  127. $260.00 for a fuel pump!!!? What the F*ck
  128. Power Loss
  129. Brake lights don't work!
  130. 17" rims?
  131. Battery Cables
  132. awsome
  133. Replacing 99 Malibu front hub assembly - Looking for torque specs
  134. keyless programming instructions for 2001 Malibu
  135. 04 Stereo Wire Harness
  136. safety feature, or prob??
  137. Malibu/Maxx Restyled for '06
  138. Help me pick a rim!
  139. How To?
  140. So has anyone tried the Tornado thing?
  141. Radio Replacement
  142. Stereo Removal...
  143. is the fuel pump a DYI project?
  144. Door Lights Need Replacing
  145. Aftermarket Radio in '99 Malibu
  146. Where are the oxygen sensors for 1999 malibu 3.1
  147. Engine surging after I put gas in it, rusted fuel line going into filter - Input?
  148. 2000 Malbiu not reaching Normal Operating temp
  149. Zapped
  150. Gauge Lights
  151. Headlight problem!!
  152. auto rx or other flush/cleaners
  153. 2000 Malibu hesitates at idle stopped at red lights, Any Help?
  154. 03 Malibu heater blower resister location?
  155. DexCool or Antifreeze?
  156. should i throw my Bu away?
  157. Chevy 350 Guys
  158. Tough in a wreck
  159. 98malibu keyless remote programming
  160. front end shake
  161. Malibu features
  162. 98 Malibu clicking and shift indicator lights
  163. battery indicator light on
  164. Warm-up problems 1998 Malibu
  165. intermittent fuel pump?
  166. 01 malibu grille pn a 98? Will it work?
  167. 97 malibu Lock Cylinder needs replaced
  168. starting problems HELP needed
  169. U Guys Suck
  170. Seeking Opinions on 04 Classic with 2.2L ecotec
  171. Transmission Rebuild Cost
  172. Lambo doors???
  173. sunroof?
  174. fold down seats?!
  175. Programming Keyless Remote
  176. brakes squeak after I changed them
  177. My Dash lights dont work!!!
  178. chevelle malibu 1972
  179. Battery Replacement Terminal Question
  180. Car won't start
  181. Striped bolt! HELP?
  182. 99 Malibu ECU Swap
  183. Fluid Capacity?
  184. 2001 headlights hesitating to come on
  185. please help
  186. I have been told 20inch rims will fit on 2004 Malibu anybody who actually has them on
  187. Grinding when braking
  188. P0172 code
  189. 2001 Malibu Front ABS Disc Brakes
  190. Installing Automatic Locks and Cruise Control on 99 Malibu
  191. passenger windows won't defrost
  192. What is my bu worth?
  193. Transmisson Questions?
  194. lamp dimmer module location plz reply!
  195. Power steering pump
  196. FYI: 98-01 Malibu Brake Pad Recall Rejected in Texas
  197. Technical Question PLZ Help
  198. 1998 Malibu Shifter
  199. 2004 malibu radio problems
  200. knocking in engine 1999 Malibu LS
  201. 2003 stereo question
  202. I need inputs. Will these look good on my 98 malibu?
  203. 1972 Malibu covertible
  204. 1998 Malibu
  205. '01 Malibu Perfomance
  206. Malibu won't start on warm enging
  207. Theft Sytem and Ignition
  208. Exhaust Systems
  209. '03 Malibu Cluster removal
  210. 2001 Malibut Blower Switch Malfunction
  211. 1966 Malibu
  212. If you have rims on your malibu send pics
  213. Rear wheel cyinder
  214. Front license plate bracket install?
  215. Engine Swap
  216. 02 theft lock problem
  217. FOR SALE: Malibu aftermarket stereo installation kit and wiring harness
  218. Heat will not blow on feet in 97 Malibu
  219. yet another blower motor/resistor question...
  220. 1999 Malibu steering wheel lock
  221. Is WD-40 good for frozen door latches
  222. Antilock brakes??
  223. Dependable,mid-sized,4 door,RWD car
  224. 99 Malibu - ABS warning light
  225. Mechanics ... a 99 Malibu ABS Hydraulic Pump Question
  226. door lock actuator replacement
  227. Headlight Adjustment
  228. Exhaust
  229. Strut Tower Bar
  230. 98 Malibu LS Coolant leaking!
  231. Where has the filter gone??
  232. U want MODs I GOT MODS!
  233. rod knocking?
  234. Replacing rotors
  235. help rought idle
  236. Removing front axel,
  237. classic
  238. 2000 Malibu
  239. Windows fogging up
  240. Fuel Odor
  241. Newbi!!!! (im a girl! :/ Help)
  242. driving lights
  243. 99 bu- speed guade for 4 cly in v6's?
  244. Power Steering, Wheels and ABS System ... HELP!
  245. Seatbelt sensor light goes off randomly...
  246. 02 Malibu-JUNK ON WHEELS
  247. check engine light.....thinks the mechanic screwed up
  248. 01 malibu aftermarket stereo
  249. Mods on my malibu!
  250. Dual exhaust
