Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
> Malibu |
View Full Version :
Malibu
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
01 Malibu Problems W/factory Radio
Turn Signals
red spots on tan malibu paint!
replacement fob
Considering 200 Malibu
engine swap
Car Stereo Installation Kits
light covers
Do Malibus eat rotors?
billit grille
Passenger side window
new tires?
winter traction: Narrow vs wide tires
a/c clutch not engaging freon psi ok HELP
tranny fluid change 100Kmi
Auto Airconditioning Shut Down Procedures
Unbelievable/'04 Malibu
Proplem With Windows .. 98 Malibu
Crashed a 2000 Malibu, need CD player!
2004 Chevy Malibu Bad Gas Mileage??
a\c recharge port
Keyless Entry
2004 Malibu Airbag Warning Light
Recommendations on a muffler for a '00?
malibu mystery
Parting out 97 Malibu
will a 3.8 supercharger fit on a 3.1 engine??
Fog lamps on a '01 LS
Overheating....Help
your opinion please
Removing CD player in '04 Malibu?
Jet Performance Module
2003 Anti-theft
98 malibu E brake light stays on
I hate my 2000 malibu brakes please help!
Auto Tone Settings Arent Saved
Cracking noise
98 Malibu Reverse lights out
Need help removing rear bumper cover 2000 malibu
97, 2.4 malibu engine pulsing
Update on '04 Malibu/Maxx Trannie TSB, etc.
Will removing car battery blank the key fob program?
2001 Chevy Malibu uncontrolled acceleration
Passenger Seat Belt locking
Air Conditioning
Rear Speaker Problem
performance parts 04 Maxx
saving the incontenent 3.1 V6
98 Seat Swap to 99 leather
intermittant charging on 98 Malibu
About the speakers...
2000 Malibu Engine performs poorly in cool/cold weather
2000 Owners Manual - Maintenance Schedule
Light gone in cd player and gear shifter
Part numbers needed...
auto start
Malibu 2000 fuel system problem
2004 Malibu Classic vs 2004 Malibu LT
awesome gas milage on 03 malibu ls
Automatic TransaxleService
2004 Malibu LT electronic power steering problem
Noise from behind the dash
New TSB for '04 Malibu/Alero/Grand Am
Coolant Leakege
A/c Control Unit Question
99 malibu engine light code po122
Trouble removing bolt from power steering pump...
Malibu won't start
Steering problem 2004 Malibu
Brake Master Cylinder Cap For Sale
Vents always on
Xenon Headlights
2001 Malibu - slight knock in engine
2000 Mali has problems--> please help!
2003 Malibu A/C Control Issue
A Tale of Two Maxxes
modifiers?
2002 Malibu for sale..
Changing the automatic shifter knob
Totally Innocent Question
what the hell?
I need taillights!!
JD Power 3-Year Quality Results
2001 wheels
Malibu Maxx Skylight Sunshade "Fix"
2004 Malibu Power Steering
Gas Tank size
ABS/Brake light coming on
2001 malibu tires/ wheels
how to change serpentine (drive) belt?
Custom Brake lights
02 Malibu Stalling Prob
2000 MALIBU LS (parting out)
How much transmission fluid in 4cyl '99?
Idle:Revisited
no lights in dash panel
97 malibu LS help - don't know how this happened, but, funny gas guage question
Idle Speed and adjustment
2004 Malibu Fuel Type
98 Malibu brake problem
98 Malibu Check Enhine code P1374
Color Guide (01 Mali)
Therostat Location
Fuel and Temp Gauge Out
worth the buy 79 malibu ??????
99 Brakes
Keyless Entry not working well
97 malibu pop in suspension?
$4,000 Owner Loyalty Rebate on '04 Malibu
how to change brake pads on my 98 chevy malibu
check engine light!
Wheel sizes
Extended Warranty Company
My Spring Broke
Trouble replacing front speakers in 2002 malibu.
2001 Malibu Antitheft System
New here!
Recharging a/c
Removing Dashbord Trim on '99
Brakes Grinding
Malibu wouldnt start...
98 Malibu Fuse Box
2001 Malibu AC/Heater
97 malibu oxygen sensor codes.
What is the best year Malibu??
Nos
12-volt switched accessory wire for 2001 malibu stereo??
80 Malibu grille
3.1 in place of my 2.4
tire problems...
Adjusting headlights
question about selling?
110 mph engine shut off
Need help with 2001 Malibu stereo replacement Harness
98' Malibu
Weird Radio Problem 2001
Problem with my Radio
Automatic Door Locks
00 malibu door ajar light stays on
Blinker problems
AC Light flashes on 99 Malibu
flasher, AC light -> bcm problem?
Wiring for new sound system
belt diagram
2004 Malibu BRAKES???
Scratches on wheels
5 spd conversion
Air Conditioning INOP
ABS light & loss of Power HELP!!!
How to re-attach rear speaker covers??
The new Malibu is UGLY!!!!
Speaker Removal for a 98 Malibu
99' Malibu LS that dosen't want to start
Tire rattle noise
What's your mileage?
Damage to radio mountig area
INOP message after 7 tries for radio lockout
02 Malibu console removal?
'98 Malibu Ignition Lock Cyl Going for 7th Time!!
98 malibu check engine light
2004 Malibu Steering Questions!
Questions about 2002 Malibu
whats it worth?
Spark plug order or cylinder order
2000 Malibu CD Deck Problem "ERR"
2002 Malibu Keyless Q?
2004 Malibu IGNITION KEY PROGRAMING ????
dual key fobs?
Charging system indicator light
Cleaning interior
2004 Malibu Radio SRCE Button
Where to find parts
Programming keyless entry fobs
2000 malibu sputtering on hills/inclines?
97-03 Malibu In Movie
1999 Engine loud noise after chatter sound
removing auto shifter to replace
2000 Chevy Malibu Problem
2001 stalling issue
wanting to put cd player in
Torque setting
Idle Problem
Putting a pedal cover over the accel pedal
My gauges do not work sometimes. What could it be?
Electrical and Emmission System
reattaching door pull on '98 malibu LS
Change raditor fluid
keyless entry
Stock rims
malibu creaks...
horn not working
2001 Malibu keyless entry program?
a/c leak
HELP - Radiator Removal
Clear Tail Lights for Malibu
Cig lighter fuse
2004 Radio problems
Changing spark plugs
Newbie Radio Help.
A/C Blowing 10amp Fuse under hood
Eagle Alloy 18"x8" 077 - new
1997 malibu auto trans cap.
fuel and temp gauge problem
Need an 01 Malibu Factory Service Manual?
turn signal problem
Check Engine Light
2003 Malibu Keyless Entry Programming
Radiator Drain Plug Broke
Help Removing Trim Pieces
Replacing Radio
Radiator fans working only when A/C is on
Tire size with stock mags??
2003 Malibu Transmission Cooler & Synthetic ATF
Jetchip ECU Upgrade/Piggyback Available
Speed Limiter
Hard Shifting
NHTSA Initiates Investigation Into 2004 Malibu
98 Malibu Heater A/C Controls...Interchangable??
front door panel issues (changing speakers)
squealing in steering
1998 Malibu Brake Pedal Travel
Malibu not wanting to start
Won't start... fuel pump???
My 2004 Malibu brake light coming on update
Considering Buying Used Malibu
trunk broken need help ???
Malibu 2 Words Never-again...............
My 2004 Malibu LT (brake light going on and off while driving)
2004 Malibu steering
ECU performance reprogrammer
radiator fan(s)
Auto Trans fluid
used factory rims
FWD Posi
'04 Malibu Offset Crash Test Tonight
Malibu Wax
Cold air intake?
Class Action against Chevy...who is with me..
stutter w check engine light flashing
Connection between wipers and radio?
stock badging and logos
Awsome Hood For Malibus
Malibu Performance
Malibu Weight
Headlight replacement
Which Hose? trying to install flush kit
Hvac Fan
Timing belt or chain?
2001 Maulibu Check Oil Light
radio security lockout after 7 tries
Web
AF
