View Full Version : Malibu
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15
  1. warning light?
  2. 98 Malibu Whinmg noise
  3. Coolant Light
  4. Overheating 02 malibu
  5. 1999 malibu cranks but wont start
  6. Motor Question
  7. Loosing Coolant
  8. Malibu-how To change the Radio
  9. Defunct Fuel Gauge
  10. 98 Malibu header panel
  11. malibu 04 BCm
  12. 98 malibu whining sound
  13. Ticking noise coming from dash
  14. ALL Guage Lights are ON!
  15. Fuel Pressure Regulator
  16. heater blower motor
  17. Neutral Safety Switch?
  18. 99 Malibu - Possible short in dash?
  19. turn signal issue
  20. Wipers won't shut off...
  21. 98 Malibu takes forever to get warm air
  22. 2001 gauges not working
  23. 2001 Malibu ticking sound
  24. Smell of gas
  25. Need Pictures of Engine Compartment or Detailed Description of Wire/Vacuum Routing
  26. Headers!! 1997-2003 V6 Malibu
  27. New Member
  28. Malibu coolant (Dexcool)
  29. 6 x 9 speakers
  30. odometer
  31. Transmission fluid level
  32. oil warning light
  33. climate fan sporadic, ac/heat work
  34. fuel tank replacement
  35. 98 malibu dies and not starting
  36. Spongy/no brake pedal
  37. vacuum hose leak
  38. 1999 Malibu 3.1 "fluttering" sound
  39. RPO Code Sheet Location
  40. 007 Car Accessories
  41. It Died
  42. 98 Malibu ABS problem
  43. Water Pump Stuck
  44. 98 Malibu - Alarm lights then horn honking
  45. 99 Malibu Radiator Drain (cant find it)
  46. Theft System
  47. Any suggestions?
  48. Egr Valve
  49. 98 malibu hesitation
  50. 1998 passlock
  51. If you could Sell your 99 Mailbu
  52. Stubborn Gear Shift Lever Button!!
  53. Reverse Glow gauges
  54. spark plugs
  55. Brake drum removal
  56. Wiper arm travel
  57. Trans Fluid Leaks After Replacing Radiator
  58. Fuel Pressure Regulator
  59. Changed intake gasket but dirt got in. What do i do?
  60. Flooding?
  61. Changing oxygen sensor & brake rotors
  62. 2006 Fuel Economy
  63. New Malibu's alarm system
  64. drain and refill the coolant for 99 malibu
  65. 2002 malibu cruise control cable
  66. 2000 Malibu Steering Wheel
  67. belt tensioner assembly replacement???
  68. 1999 3.1 acts like running out of gas
  69. Help. Warning Light?
  70. brake question
  71. Blown Power Steering Pump
  72. gm/delco cd in 99 malibu w/o factory cd?
  73. 2004 Malibu Rotors
  74. different battery types
  75. Fan Control Dosen't work
  76. Malibu, defective brake problems?
  77. malibu 4 cylinders?
  78. Cruise control and sticking gas pedal
  79. Remote Start
  80. 2001 malibu
  81. keyless entry remote
  82. '97 Malibu Turns over w/o starting fuel pump,Anti theft,Or ignition module?
  83. Intermittant wont start
  84. passlock on 2000 malibu
  85. check engine light on all the time
  86. 2003 malibu fog light wiring
  87. Bleed Cooling System
  88. sunroof wont close all the way
  89. Malibu locking me out
  90. Wipers only go low speed
  91. A/C kicks off
  92. Coolant Problem
  93. 3.1 shudders in gear
  94. windsheild wiper arm transmission
  95. Oxygen sensor
  96. Dragon Z Kit for sale
  97. 2004 Malibu Maxx Power Stearing Problems
  98. Timing set interval
  99. Throttle Body.
  100. malibu overheating
  101. Need help: Change 98 Malibu alternator
  102. 99 malibu fan and wiper speed question
  103. anti theft
  104. Intermittent stalling after fuel-up
  105. 1999 chevy malibu long crank time
  106. Heater core replacement
  107. 2000 Chevrolet Malibu Speaker Specs
  108. Gas/Brake pedal vibrating
  109. 2000 Malibu with No Temp Control
  110. I Need Help!!!!
  111. 1998 Malibu LS A/C
  112. Problem with Defogger
  113. Eating gas like crazy
  114. Several power problems
  115. New Guy Here
  116. 99 malibu ac/electrical problems
  117. pesky check engine light ?
  118. OnStar Conversion
  119. Rotating Tensioner to Replace Alternator
  120. rough idle
  121. God Awful grinding on new brake pads
  122. Malibu Maxx Hatch Strut Failure
  123. 2000 Overheating --- Please Help !!!
  124. Crap. Somebody worked on my windows
  125. Changing headlights
  126. Passlock System
  127. 2004 Malibu Key Fob Problem
  128. CLASS ACTION SUIT/brakes
  129. 00 malibu code 742 how i can fix it
  130. Theft System/Passlock
  131. 3.1 malibu leak
  132. AC Pressure on engine problems
  133. can pics be posted?
  134. Can pics be poster
  135. chevy malibu 99
  136. To Buy or not to Buy
  137. Remote Start Issues...
  138. new member
  139. problems starting ( cold )
  140. problems starting ( cold )
  141. H.O. powermaster alt for sale
  142. Old Change for malibu 97
  143. Sometimes very high idle
  144. Keyless entry.
  145. 2005 wind tunnel
  146. 98 malibu Supportes
  147. Electrical problems??
  148. steering issues
  149. 2002 malibu muffler
  150. How Do U Change Thermostat In 2000?
  151. Fuel Rail leak some help please.
  152. 2004 Malibu Classic 2.2L radiator fan removal
  153. How to get at that oil filter; 2001
  154. Cruise Control Dash Light
  155. Jet chip
  156. Find out if i have keyless entry
  157. keyless entry
  158. pushrods and rotating rocker arms
  159. 101 octane gas
  160. overheating
  161. malibu performance
  162. starting problem
  163. Cold Air intake
  164. Power Door Lock and Mirror Problem
  165. n-body meet in SoCal SEPT 24
  166. fan dial problems
  167. Serpentine Belt
  168. engine trouble code
  169. Low Idle
  170. Removing the window lift motor
  171. replacing OEM radio\cd with upgrade OED radio/cd/cass in a 2002 Malibu
  172. 68 conv.
  173. '05 Malibu @ 110mph
  174. 2000 malibu intake??
  175. 2005 Oil Drain Plug and Filter
  176. Where is 2002 Malibu transmission plug?
  177. This is a useless fourm!!!
  178. Lots of issues on my 98
  179. Engine Repairs
  180. Lowering my BU
  181. Towing a Trailer
  182. Extra external transmission cooler?
  183. Power Steering Recall question
  184. 2005 Malibu
  185. Need advice on 99
  186. radio
  187. keyless entry
  188. Removing the driver side door panel
  189. Bike Carrier
  190. transmission trouble
  191. Aftermarket Available
  192. 97 Malibu Transmission should I get a used one?
  193. 2001 Malibu
  194. Head Gasket Replacement
  195. the cd player
  196. Replacing 1998 Malibu LS Alternator.
  197. lowering springs
  198. euro tail lights
  199. check engine light stays on after starting car
  200. Horn Warning?? ('02 Malibu)
  201. 01 Malibu - clunking sound in front tires?
  202. rear seat
  203. 97 Malibu Lower control arm bushings?
  204. 1998 Malibu stalls after fuel up
  205. Cruise control on '01
  206. Pulley System Nightmare
  207. JET power control module
  208. 99 3.1L -> misfire and engine shaking
  209. '99 Malibu - Neutral Safety Switch?
  210. E 85 Fuel
  211. Head lights 2000
  212. 99 Malibu won't start, no cluster lights
  213. Heater control, vacuum line 97 Malibu
  214. 2000 malibu A-Arm loose
  215. 2001 malibu wont start
  216. 97 Malibu 3.1 auto Transmission noise
  217. 99 Malibu water pump
  218. 00 malibu problems
  219. fuses for brake lights keep blowing
  220. Theft Syste Light Stays On
  221. Battery light on, already changed battery and Alternator what could it be?
  222. Removing Battery cables
  223. Cost for shop to change fuel filter
  224. 2005 chevy malibu aftermarket parts?
  225. 1999 LS TheftLock Programming
  226. 1999 LS Programming Power Locks
  227. 1997 Malibu heater selector switch
  228. freeplay in steering sense recall work
  229. Fog Light Resetting?
  230. 01 Malibu blinker problem again!
  231. 2001 radio fuse
  232. Camshaft position sensor location
  233. Stalling Problem
  234. Be carefull when removing batt and cables
  235. transmission trouble
  236. '03 Accelerator Pedal Recall...
  237. HVAC resistor part number
  238. Just bought 2003 Malibu
  239. 03 Malibu front struts install.
  240. dash board problem
  241. keyless entry remote programming
  242. 2001 malibu starting problems
  243. 2005 malibu sedan stereo question
  244. Wiring to tow malibu behind motor home
  245. cigarette fuse
  246. coolant leak 2001 malibu 3.1
  247. 98 malibu no dash lights, fuel
  248. 98 Malibu transmission Slipping
  249. 2005 Malibu Maxx - Front end cover
  250. "Service engine soon" light won't go off
