View Full Version : Malibu
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12
  1. Humming/Buzzing at 60mph?
  2. removing starter motor
  3. Wheel sensor diagnostic
  4. 2001 wiring diagrams
  5. Hazard Light Module Ticking
  6. tire sizes???
  7. Newibu & Stuff
  8. knocking in motor
  9. clunking in rear
  10. 2004 Malibu (v6) where is oil filter
  11. Synethic or Conventional tranny fluid
  12. 2000 Malibu Stalls NEED HELP
  13. 2002 malibu no power
  14. extended auto warranty?
  15. Winter is fun.......
  16. No help from my dealer on gasket
  17. 02' Fuel Filter and buzzing
  18. Brake pads low again
  19. adjusting clock
  20. cooling fans
  21. best struts for 99 Malibu
  22. 2001 Malibu Coolant leak
  23. steering wheel pulling to the left when accelerating
  24. PS recall question
  25. Keyless Remotes 2003 Malibu
  26. Malibu Performance Chip ?
  27. Looking into purchasing a 98 Malibu
  28. malibu cruise control
  29. Lights controller
  30. oil not pumping
  31. Front suspension noise
  32. Brake Question
  33. Brake job help
  34. Motor ?
  35. 4th time to dealer to try and fix same steering problem
  36. can a dealer also do a buyback/exchange?
  37. latest update on steering problem 04 maxx lt
  38. '98 Malibu-rack&pinion NE1 do it themselves?
  39. 2000 LS for sale with custom rims gottaa see!
  40. 2002 Malibu won't start.
  41. Malibu Heater
  42. sidemarker bulb size
  43. 2004 malibu maxx, called chevy cust. service assistance on latest steering problem.
  44. Remove Stuck CD
  45. How To: Blinker/Flasher/Hazard lights work intermittently
  46. How To: Radio Reception; FM=bad, AM=None
  47. How To: HVAC Blower fan only works on 3, 4 & 5
  48. How To: A/C & Recirculation intermittant/blinking
  49. Left Rear Shock broke......
  50. 99 Malibu LS LOUD metal noise coming from front right side...
  51. 2003 Malibu in-dash CD Removal
  52. 2004 MAXX steering problem update!
  53. 2000 Malibu Theft Lock ? again
  54. crazy electrical(?) problems
  55. thumping tire
  56. 2000 malibu woes
  57. 1998 Chevy Malibu Problem
  58. Struts causing tire failure
  59. 2004 malibu maxx lt steering column replaced
  60. Window deflectors for 2004 Malibu
  61. condensation in headlamp lens assembly
  62. Can't start - need a help!
  63. Fuel leak
  64. 98 Malibu pushrod order
  65. 98 malibu where is the OBDII port??????
  66. code P0305
  67. Mally with 127,000 miles
  68. Having Probs! Any Suggestions or Words of Wisdom?
  69. 04 Malibu Start Up Problem!
  70. Rear right flasher
  71. Navigation systems and Xenon headlamp, any plans on adding to the Malibu's or Maxx's?
  72. 2004 Malbu Maxx LT, squeeky belt attachment
  73. 2000 malibu parting out
  74. The little mexican under the hood of my malibu stoped pedaling
  75. 98 Malibu has died need help
  76. 99 remote starter kit
  77. Where is the intake air temprature sensor located?
  78. 99 Malibu: #2 and #5 radio buttons don't light up
  79. Wiring wipers
  80. 2001 chevrolet malibu
  81. How much to pay for rear shocks? 97 Malibu.
  82. wHAT POSSIBLE CUASES FOR A CHECK ENGINE LIGHT?
  83. Engine Oil/Coolant leak on the 3.1 V6
  84. 2004 Malbu Maxx LT, help on minor poroblems
  85. power steering question
  86. Removing Front Seats In Chevy Malibu
  87. No start
  88. Airbag Replacement costs??
  89. Back seat conversion? fold down?
  90. '00 Malibu stereo problem--Please Help!!!
  91. 97 Malibu LS Key Won't Turn HELP!
  92. Noise problem
  93. Water In The A/c Vents/ Passenger Side!!!!!!!!!!! Hellppp!
  94. Water In The A/c Vents/ Passenger Side!!!!!!!!!!! Hellppp!
  95. 77' Chevy malibu classic. Worth anything???
  96. 17inch TUNER WHEELS NEED HELP!
  97. Rear brakes - '98 Malibu
  98. Read this if your Malibu WONT start!
  99. water leak 97 malibu 3.1
  100. Any cheats for oil pan gasket leaks?
  101. Has anyone the ABS light NOT come on
  102. Lighting Fx kits
  103. REV limiter??? reliable?? HELp
  104. FronT Bracking Grinding Noise
  105. Is there an O ring where the fuel line connects to the rail?
  106. theft system? starter? fuel pump?
  107. need new fob for '00 malibu
  108. Chevy Malibu '81 info?
  109. 1999 Malibu, clicking noises from tires when pulling in or out.
  110. Best Tires for the Best Ride
  111. 1998 Chevy Malibu Gas Gauge Reversal
  112. Another kill story
  113. starting problems & high idle
  114. Sputter, Strong Gasoline Smell
  115. 2000 Noisy front end, possibly some play in it..
  116. 20'' rims...
  117. please read
  118. Remote starter for 2002 Malibu?????
  119. Stock or Cone K&N filter???
  120. 1969 Malibu project or parts $620.00
  121. Unable to put into drive when cold(below 40 degrees)
  122. How much should I pay to rebuild my injectors?
  123. 1998 Malibu Water Pump
  124. 1999 Malibu Radio Lights
  125. 99 Malibu 3.1 and 95 Buick Centruy 3.1 engine exchange
  126. What has been recalled on the malibus
  127. Gas Gauge Problem!!!
  128. 1999 Malibu heater blower problems
  129. i need help with my red and black wiring on my glo- gauges for my 98 malibu i dont kn
  130. Check Engine light on 2003 Malibu
  131. Malibu console codes?
  132. system in an 04
  133. Gauge Pod HELLPP!
  134. Coolant light comes on
  135. Coolant light comes on
  136. "Looks arent everything"
  137. Humming Grind at Startup
  138. Malibu 2004 LS; Fog lights ???
  139. 2001 malibu antitheft problem
  140. 99 malibu... Not accepting gas!!!
  141. Fluid flush or just fluid change?
  142. 12 Volt Switched Wire
  143. Ks Clear Sidemarkers???
  144. 2004 chevy malibu not starting and dying
  145. Subs for a 1999
  146. Chevy Malibu Brake Pads
  147. clunking noise in front suspension
  148. Light size behind dash gauges???
  149. Testing Fuel Injectors
  150. Wheels for 2000 Malibu
  151. Factory Repair Manual
  152. 2000 Malibu 75,000 Issue
  153. 02 Malibu Radio
  154. 2001 Malibu AC cuts on and off
  155. 2000 Malibu Dies! Help! Reaadd!!
  156. turbos and tranny
  157. Is there a place in this world for "4" doors?
  158. 1999 Silverado
  159. 3.1 liter 180 degree thermostat?
  160. 99 Malibu Alternator???
  161. turn signal/ hazzard lights intermittant fault
  162. Pink Flames a NO or a YES??
  163. i think im turning Japanese
  164. attention all readers
  165. Upgrading Wheels
  166. Daytime running lights
  167. 99 Malibu LS VS 98 Nissan 200SX S-er
  168. 1999 Chevy Malibu LS Stock Stereo
  169. starter then blinker problems today
  170. 99 Silverado 350 missing
  171. 1999 keyless remot programming
  172. 1999 keyless remot programming
  173. Coolant Flush
  174. keyless entry remote
  175. Code P0401 - Egr Flow Insufficient
  176. 2004 Malibu Maxx LT RADIO/GOVERNOR!!!!!!!!
  177. DYI vs "quick-lube" chains
  178. Squeeks are driving me crazy
  179. 99 Malibu Performance
  180. Malibu 2004, remote starter
  181. Cruise Control kicks off?
  182. Car stalled on highway two times!!
  183. 97 Malibu. Seized heater control. How do I replace?
  184. wanted: intake & exhaust for 99
  185. Defroster/fan Failure
  186. Exhaust/Intake Diagram for Push Rods?
  187. transmission measurer
  188. Making your own grill?
  189. Malibu VS 300M
  190. 1978 malibu valve cover problems
  191. Rpm's Are out of control
  192. White face gauges
  193. Fuel Injector Installation Help Please!!
  194. NAPA auto parts quality
  195. Fule Injector and Rocker Arms
  196. NEED HELP: Speakers!
  197. Lesson learned
  198. A/c control panel
  199. Malibu Strut Replacement
  200. 2004 Brake Noise!!!
  201. All 1964-83 Malibu owners, come inside!
  202. engine overide switch- adendem
  203. Engine Fan Over-ride Switch
  204. Fuel Filter
  205. '99 installing tweeters on factory stereo
  206. 97 malibu battery light.
  207. 97 malibu blower motor problem
  208. Malibu "Dash Kit" questions...
  209. 97 chevy malibu wheel hub replacement.
  210. 98 Malibu A/C
  211. Electrical Problems...
  212. Fog Light Rewire?
  213. 03 Malibu LS Service Vehicle Soon light
  214. Tranny Maint.
  215. Malibu Wont Start
  216. Where is the fuel pump located??
  217. loss of power
  218. 01 horn operation
  219. Tornado Fuel Saver
  220. headlights
  221. 1976 malibu
  222. body kit
  223. 97 malibu vs 96 grand am
  224. 01 horn staying on
  225. 01 radio replacement
  226. Just bought a 98 Malibu...next step?
  227. STALLS after 15minutes of driving
  228. Tranny in 2000 Malibu Classic same as Daewoo Nubira?
  229. Coolant Light
  230. '04 Malibu/Maxx Fuel Guage/DIC Warnings
  231. Starter Sticking
  232. Body Kit
  233. Engine light
  234. 98 Malibu Squeaks
  235. 2004 malibu brochure "typo" , sue?
  236. Compass Mirror
  237. Spoiler
  238. Dynamating trunk
  239. Malibu for sale
  240. Just Bought A New Malibu!
  241. ABS light and Fan problems
  242. rpm's rising
  243. Dash Warping
  244. brake pedal travel
  245. Battery Light, Trouble Codes PO443 and PO449: EVAP Solenoid Valve
  246. aftermarket hoods?
  247. Stock Intake Size
  248. other mfr fuel pump
  249. 01 malibu wont start after starting without problem an hour before
  250. clock setting..
