View Full Version : Impala | Impala SS
Pages :
[ 1]
2 3 4 5 6 7 8 9 10 11 12 13
- Grinding noise from water pump area
- 06-12 impala black pillar cover by carboncovers
- Battery Light and exterior lights blinking
- Road noise between 35-60 MPH have changed wheel Bearings
- Rim for my car is cracked.....
- What's your age?
- 4T65E Trans whining after freeway run
- P0440, P0405/0404, MIL insconsitently on
- Installing a New "Boss BV9155B in-dash double din" stereo
- 2003 3.4 P0420 Post intake coolant leak
- ABS Diagnostics - ELM327 help!
- 2002 impala electric door locks
- 2005 Impala vibration drivers side
- 2003 Ls 3.8
- New Tire Time
- 03 Impala LS not starting
- Cant go over 30 mph!
- How do I get at my throttle body flapper?
- Tach Question
- 2008 Impala SS engine hesitation/shudder
- 08 Impala Trans Slip
- Daughters 2000 Impala
- Should I replace the head gaskets when I replace the lower intake gasket?
- "coolant loss-protection system" question
- Can't get rid of 301 code
- 03 Impala making a thumping noise
- OEM Rotors are problematic for newer Impalas - Any Quality Replacements?
- Battery Issue/Question - High Output Alternator Installed
- 2010 impala more problems
- 2002 impala 3800 crank no start
- Why so many fan control fuses?
- 04 Impala- Where is the heater fan resister located?
- 04 Impala- AC/Htr Fan not working
- 2001 impala 3.4l
- 08 Impala Power Steering Whine
- 2004 impala 3.8 rear head removal?
- 2004 Impala - Transmission issue after fluid change!
- 2009 impact heater not working on idle.
- 2002 impala losing radiator fluid
- 2002 Impala won't shif into 2nd
- Need help understand sparkplug wire ohms?
- 2002 impala floor leak FIX.
- AC Fan went out - where is it?
- 07 impala Leak?
- 2004 Chevy Impala
- Washed motor, no juice to battery now
- 2000 Impala Trailer Wire Harness
- brakes are thumpy... sometimes
- 2006 Impala keyless entry not working
- Dash Bulbs
- ORIGINAL Key Fobs do NOT work - NO STOCK RADIO - Please help!
- Dead heater blower
- 2010 impala interior lights
- door ajar & lights on after changed door lock
- engine oil
- Low Oil Pressure Indicator
- Dash lights turning off at night
- program a keyless remote
- 2001 Impala intermittent no start
- Powerdyne Supercharger kit 90's Impala
- 2003 Impala 3.4L loss of power/miss only at high speed
- 2004 impala stalls
- 04 Impala LS everything vibrating as driving at cruising speed
- 2007 Impala P0172 code solutions?
- 2009 impala ltz purchase
- 04 chev Impala randomly every 30 day no stater engagement.
- 2006 Impala 3500 Massive oil leak when cold and water pump leak's.
- Goofed somewhere!
- 2006 impala check engine light
- heat bypass hose
- Impala high pitch whistle when step on gas
- '02 Impala: No Start, Then Brake Pedal Start
- 08 Impala rear door locks not working
- Driver door actuator
- hid lighting
- 2004 Impala no start
- 09 Impala problems
- '01 Impala Steering Rack
- cruise control
- RPM's bouncing between 2000 rpm to 1500 rpm
- Outside ambient air temperature sensor
- Adding Bluetooth
- 04 Power Steering - Any way to make it into a dipstick?
- Would appreciate speculation on my ABS issue
- Serp. belt help......
- 2000 Impala starting problem
- 2003 3.4 impala vibrates (not shakes, vibrates) at low RPMs
- oil everywhere
- 2001 Chevy Impala P1404 Code.. EGR ?
- 2003 impala ls
- 2011 Impala LT Engine Decals
- Muffler Rattle?
- 03 impala misfiring problem
- 3 Codes...are they all tied together?
- Ignition code?
- A/C Charging: In Progress...
- Resetting programs
- Any common coolant leaks on p-side of 3.8?
- 2002 Impala w/police package cant find key fob ecu harness in dash
- Factory Radio
- key wont turn
- 2005 Impala 3.8 L leaking transmission fluid
- 01 Impala Not starting, No lights whatsoever
- 06+ Charging System Question.
- Warm Weather Power Loss
- Dead Blower 05 Impala
- 07 Impala - How to change Evap Solenoid?
- 2003 Impala stalls and ABS/TCS light is on
- Subframe bushings
- 01 Impala 3.4L
- '03 Impala LS ABS/TCS Issues 3.8L
- 2003 3.8L Engine VIN Location
- 2001 chevy impala headlight problem
- Temp slider light out
- 2003 impala front bearing hub assembly
- 2000 Impala Running Rough
- Control arm bushings
- 2000 Impala CD Radio Stopped
- ate brake rotors
- XM Harness
- The 15min $5.00 ISS "Clunk Repair"
- Brake Issues
- 2000 Chevy Impala Electrical problem
- Known issues and MPG with '07-'10 impala
- Jelled substance in pcv channel?
- 2004 Impala police packege horn?
- 2002 Impala - Neutral Safety Switch
- 2002 Chevy Impala
- Will pulling a 01 impala tear up trans????????
- small motor noise/ coolant issue
- Replacing a tire pressure sensor
- 01 impala 3.4 overheating problems. Advise please
- power window
- 2005 impala
- Keys stuck in the Ignition but driveable
- 3500 water pump
- 2000 Impala 3.4 Thermostat Housing torque Spec?
- 01 Impala ignition cylinder
- Wacko Horn
- Gas pedal sticks after car sits for a while
- Fuel Injector hat in the Manifold
- 2006-11 temperature sensors location
- 3.8L (3800) Head Gasket Replacement Advice
- anti freeze
- weird knocking noice
- 2005 Impala...all lights turn off!!
- Parking brakes stuck
- Rear Window Defogger
- 06 Impala Visor
- 2003 Impala 3.4 ltr code p0420a
- How does one check the heated seat elements?
- Replacing brake booster
- cat converter location
- 2002 Impala Cat Converter Problems
- Winter Tires 205/65r16 install
- ABS and Traction Control lights on?
- 2001 Impala Radiator
- 2003 ls 3800
- infamous speed selector issue
- 2008 Impala throwing P0340 code
- Headlight housing replacement
- 2003 Impala LS tranny won't go into gear.
- Clciking noise coming from engine...
- Weird coolant system problem
- Does not make sense
- power seat adjuster driver's side 2010 imp.
- 2004 3.8 LS Burning Oil
- To Max Wedge or any other's (pcs) tranny
- 2007 blower motor erratic
- 2000 impala 3.4eng code P0405
- Please help me identify a part name!
- 2000 impala 3.8 brakes hanging up...
- 2005 LS SS Super Charged
- blower fan won't ever shut off??
- starting issue
- spark plugs
- Dex Cool Change Out
- Wheels
- shaking and whistling
- Brake Line Leak
- 2002 Chev Impala - Headlamps Not Working
- 2004 Blower Motor Related Electrical Issue...
- 2004 LS Headlights dim
- Door key turns but doesn't engage/disengage lock
- 01 Impala 3.4L Idle issues
- '02 Impala 140.2k, Coolant Drip
- 04 Impala Blower Fan Motor
- 1995 Impala SS - Transmission Removal and Reinstallation
- Low Fuel Pressure
- Sensing and Diagnostic Module
- new strange problem with SECURITY
- engine swap question
- 04 Impala LS. Change engine oil light, and i just changed oil!
- door handle issues
- Odd recurring heat problem, 2007 Impala
- 3rd time replacing the Blower Motor Relay
- 2000 Impala SHUTS OFF while Driving....
- 05 Impala Oilpan removel 3800
- 2005 Impala Intermittant blower.
- stripped spark plug
- 01 impala no 3rd or drive
- whining in overdrive
- 2000 Impala 3 problems at same time.
- hey max wedge or whoever,mass flow air sensor
- Impala window off track
- homelink
- loss of power
- 07 impala tire pressure monitors
- died on me in the middle of I95
- 04 LS Passenger Mirror Heat Really Slow
- 04 LS Temp. Control(s)
- 2008 Impala LTZ developing Anti-Freeze smell
- Transmission Problem
- downsizing impala from 16 inch rims to 15 inch rims for the winter
- Question about air intake systems
- 2005 Impala No Heat
- 2000 Chevy Impala ABS and Traction OFF Light
- '07 Impala Air Condition
- nasty vinegery, "roadkill" smell from a/c.
- HELP! 03 impala won't shift
- 2004 traction control question
- 04 3.8 Where is the power steering fluid reservoir?
- 2001 starting issue
- problems removing exhaust manifold and cooling fans
- 2002 Impala LS No Start
- 2004 Chevy Impala 3.4 not starting
- 04 intermittent no start
- 2003 Impala Ignition Stuck, Please help
- shake in 05 impala
- 02 impala problems
- steering wheel shake and vibration in front floor driverside
- 03 Impala Interior Lights Out, Except front floor
- OIL LEAK CAUSED BAD Mounts? + Overheating
- exhaust
- 2004 LS Cannot put transmission in park
- 2009 Impala
- 01 Impala rear sway bar nut
- 02 Impala not starting right! Please help!
- impala has many prob. HELP!
- Changing lower intake manifold
- Removing outer door trim 03 impala
- 2008 Impala rear tire pressure monitor failures
- 2006 Impala 3.5LT Pulls left after alignment
- 2000 Impala 3.8 Misfire and turnsignal probs
- Possible paint problem 2008 Impala
- speedo light replacement bulbs?
- 2005 Impala making helicopter noise, even when off PLEASE HELP!!
- AC blower slow to come on 2000 impala
Automotive Network, Inc., Copyright ©2012
