Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
> Impala / Impala SS |
View Full Version :
Impala / Impala SS
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
broken exh.man bolt
Traction Control Problems
Help!: '02 Impala Radio stuck ON/battery draining
64 impala
Drilled and slotted rotors
instrument lights
SLP aftermarket Grille.
Replacing Factory radio with Kenwood Double din
First car - Impala 2001 police pkg - Questions inside
Car turns off while driving
18 inch wheels.
Driving condition Radio
Reinforcements for hydraulics
Largest collection of modified 94-96 Impala Pictures
HELP... heater doesnt work & kills at take off.
Air on continuously
window weather stripping..
'02 Impala: "Low Coolant Level" Message
Is this a factory setting?
2006 Impala SS - Tech Docs/FOB reciver
1968 IMPALA 61000 miles CLASSIC CAR FOR SALE
2oo5 impala with 3.4 engine
LEAKE from ANTI FREEZE
shaking at high engine speed
changing thermostat
01 Impala fan only works on #5 setting, 1 thru 4 don't work...
Aux Inputs on stock system
01 Impala heater blower resistor
Slow heating and defrost
2001 Impala leaking rain water behind firewall...
2001 Police pkg 3.8
"Tupperware" lids for '01 headlamp assembly
CD installation '03 Impala
Radio antenna & XM Radio
Heated Mirror Not Working
oxygen sensors?
online service manuals?
'01 slow cranking
Heated Seat not working
could it be the engine? 05 impala
Low Tire Pressure Warning Light
Headlight Aiming
exhaust
Impala or Not?
leaky door seals
burning oil
shaking/weak acceleration
02 Impala heater/mode control?
windshield wiper sprayer clogged.
Pcm
Flasher.
Lemon????
100k Tune Up
gas mileage.
Rear wheel hub removal
Power Steering Cap location
Battery intermittently dead
highbeam out light
2005 impala tail lights?
keeps turning
coolant flush
2000 fuel filter replacement?
sludge
reving
Removing the stock air box
I Need Interior From A 94-95 Or 96
Got Rid Of The Impala!!!!!!!!!!!!!!!!
2000 Impala cooling problems!
Stereo wont take cd
How do I find out...
to turbo or not to turbo
'02 Impala: Detecting Coolant in oil
'06 Impala?? WHAT??
Best way to maintain my Impala for a long life?
fans
Air Temperature Sensor
'02 Impala: P0440 - Evap Emiss Control Malf
Car Stereo
2005 starting like 1980
Impala LS 3800 acceleration
Recalls ???? Where to find ????
Eclipse 5435?
96ss emisions test problems
'05 Impala-can't disable auto door locks
deletion of u-bend
Which Wheel ?
I found 4 Where are the other 2 ?
air bag light stays on
Impala vs alero
new ISS
cooling fans`
reseting change oil light
OMG -- now what???
P0442 OBDII Code
Flickering headlights
How to replace the front passenger window
no reverse
ride quality and brakes
Rare water pumps?
Naioa
Impala Clock
ideas
accelerate pause?
overhead MPG readout..
steering wheel squeaks..?
www.goravin.com down?
impala interior
Impala vs Buick Lacrosse
Considering purchasing an Impala
mass air flow sensor
installing tach
3400 CAI & WAI
list of things i found on Ebay
doors for the exhaust that route exhaust..
Heater Core/Radiator NIGHTMARE !!! DEX COOL !!!
Need HELP to figure out problems with my '01 3.4 Impala
NEEDED Sport Appearance Group Tail Light Covers
Creaking Suspension
Temp gauge
Sorry i've been gone for a while...
need the link..
'05 GXP brakes on an '04 IMPALA????
I need some help finding a part.
02 Impala Poor Acceleration/Flashing Light
onstar/phone question.
fog lights...
What does this mean?
02 Impala LS (steering)
Buy 2004 base, what to look for/expect?
2005 bench seat
RPO (option) Codes
My Radio Is Throwed
impala features..
'96 Impala problem
Security light
stereo
2000 Impala LS 3800 hot starting problem
What does the manual say?
Chrome trim rings... noisy and moving...
2000 impala keyless entry dosnt work
Silverstars
2001 Impala Won't Start....New battery, clean terminals...
sound like a deal?
valve cover breather
1977 Impala Station Wagon
Burning Rubber Smell
Buy or Not
Anyone have an 06' Impala SS
How to ReCalibrate gauge cluster???
gas mileage..
Evil ABS Light
2002 LS vacuum problem
1964 Impala Station Wagon 4 Sale
Steering rumble
engine starts rough; high idle cutout
RPO (option) Codes
'01 Impala Keyless Remote
Dashboard gauge face plate for 2000 impala
Impala Brakes
bleeding brakes
Any Bug Shields Avail for 05 ~ Will 03 Shield fit an 05 Model
Intake Leak 3.8L EGR Problem Solved BY GM '04/'05 s ? ? ?
Relocating pcm in 2001 impala
20 inch wheels on impala..
Front seat DVD Install?
Day lights to parking lights
2001 Impala dash lights
Working Center Tail Lights!
Wipers!!!
1961 Impala Convertible
I need some help
Rear Defrost????
Dvom
Tinting Glass
impala modifications
front end making noise
subwoofer on 2005 impala
impala convertible?
AM Antenna
2003 9C1 Impala
GM will replace Catalytic converter
Steering issue (yep, another one)
tire inflation monitor?
flooded floorboard
Low Oil Pressure 2003 Impala
Temp gauge
check this ride!!!!
Making my base model into a bestie Impala
187K is it worth it to repl transmission
I Need Help!!!
Lower Grill Slot Fog Lamps
2001 impala blower resister
traction control
'02 Impala dimmer switch
1965 Pieces
For Sale: LT1 long block, complete or parts, dirt cheap
Fuel Pressure Regulator
Oxygen sensor
2003 Impala SuperCharger etc etc...
Be Warned: Theftlock
products for changing brakes
02 Impala dangerous stall at highway speed
Remote Starter..and more Please help..
Power Steering Noise
Do it yourself test for clogged cat?
Catalyic Converter Question
Window Tinting?????
2002 impala please help
a PASSlock theft-deterrent system
fog lights
rough idle?
?changing brake pads?
Trans Dtc 0751
16" Trim Rings
dexcool coolant change
Gas gauge
1994 Chevrolet Lingenfelter Impala SS
Police Look-alike impalas
02 Impala Acceleration Degrading
Factory service manual
Find out what the OBD II code means
check oil light when car is started
'03 charcoal canister location?
what whines under a certain speed range
Home Made Police Impala
1966 Impala Suspension Question
'01 impala engine shuts off / check engine light
2001 Impala No Start-Security light
Red LED on Radio Blinking 2005 Impala
lighter died
Looking at buying a used Impala
drum to disc brake conversion for 66 impala
2004 impala mirror
service traction system
Impala stuff for sale (1967)
Jet chip
Mystery ABS Light
impala wanted
2001 impala question
Tape stuck in deck
Need some info
low oil pressure sensor light
sig test
passlock #2
passlock
96 Impala bolt pattern to 2000 impala
changing fuel filter....
Broken Fuel Guage
warning lights on
Web
AF
