View Full Version : Impala / Impala SS
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12
  1. 2000 Impala V6 3.8L VIN K loud shrill
  2. a/c question
  3. Code P0481
  4. My 03 impala DIC (drivers' information center)
  5. Impala
  6. hub not pulling out
  7. CEL code P0440
  8. Anybody Know What The Top Speed Of An '06 Impala Ss Is???
  9. 04 impala Ls 3800 vs 06 Cobalt supercharge SS
  10. Tail Light covers
  11. 2002 impala change oil light reset
  12. Removing Dashlight bulbs
  13. 2007 Keyfob Programming
  14. 04 Impala Ls Stock Vs Honda Civic 05-06 Manual
  15. 2000 3.8L MAF Wiring
  16. 06 Impala SS Trans Fluid??? Help
  17. Security Light On constantly
  18. Rear amp in the trunk, How do you bypass the wiring to get sound from the speakers?
  19. Replacing Rear Pads & Rotors HELP!!
  20. 2000 Impala, ABS and Trac question.
  21. Aftermarket Floodlights/Brighter Bulbs/Quad Lights
  22. 2003 Impala PO742 code
  23. Cargo Nets for 2000-2005
  24. Air Bag problems
  25. Better performance for a 02 impala
  26. Heat/AC Actuator R&R
  27. impala wont start when temp drops
  28. broken pulley?
  29. Gas milage
  30. How do i prevent headlights on when unlock
  31. Low Tire Pressure Light
  32. 96 impala ss review
  33. best oil for 3.4 impala
  34. 2003 Impala oil light comes on and then off
  35. 3rd gen impala ss vs 4th gen trans am
  36. Help Finding Frame VIN 58 Impala
  37. Low coolant level again
  38. Problem to Start Engine
  39. Help cleaning the inside of my Impala
  40. 77 timing mark?
  41. Message Center Needs Help
  42. Re-starting problem...again...again
  43. Water leak on passenger side fr& back,under the carpet was over 10 gallons of water
  44. transmission removal tips??
  45. 2004 LS Brakes Thumpy- how do I stop that?
  46. Stock Caprice/Impala SS Rims For Sale!!!
  47. '02 Impala 3.4: Piston Slap on Startup
  48. 2003 Impala 3.4 14k $9,000 - Good Deal Or Bad Deal???
  49. 2000 3.8L MAF sensor bad?
  50. CEL: P0455 help
  51. Climate control problems
  52. Found out what was wrong with the short in my radio,IT BURNED
  53. Location of coolant temp sensor?
  54. HVAC, and ashtray lights
  55. 2003 IMPALA intake and head repair cel light
  56. valve train?
  57. radio/stereo doesn't work
  58. Changing the Supercharger oil
  59. Loud surging and noises from my speakers
  60. 04 SS replacement tires?
  61. On Star antenna
  62. 2003 impala head gasket installation
  63. Please help...2003 Impala LS
  64. Fixing side mirror--need help
  65. Brakes and rotors
  66. A couple of "Issues"
  67. 2000 Impala base instrument panel cluster
  68. comments on 2007 Imp LT1 w/3.5
  69. Transmission and OBD code P0300
  70. 2002 Impala 3.4L Exhaust upgrade question
  71. 2002 3.4l speedo and transmission...
  72. Where is my LOW OIL warning light????
  73. starting to have a few symptoms.....
  74. How to replace insturment lights 2003 9C1
  75. Transmission Iussue - 3.8L
  76. help replacing third brake light
  77. knocking in steering wheel
  78. 05 impala wiper blades stop in vertical position
  79. driver side door 01 impala
  80. intake gaskets
  81. Help! Car Won't Start!!!
  82. 96 impala odometer
  83. Seat replacement......
  84. Front right wheel bearing
  85. Horn goes on by itself
  86. Floormats?
  87. Squeaking sound from glove compartment
  88. 2004 Impala SS upgrade suggestions?
  89. Catalytic Converter is clogged?
  90. Cold air intake or short ram intake?
  91. 2000 Impala 3.4 - Transmission Problem?
  92. aftermarket stereo install help
  93. 2005 Impala LS Noisy A/C Compressor!!
  94. GM extended warranty?
  95. extended warranty
  96. Make ac blow colder air.
  97. Can i install new stereo in 03' impala without interfering with service of car?
  98. Service department insider
  99. Camshaft Problems
  100. Rocker panel mouldings ,fr & rear bumper and door moldings
  101. how to remove back seat
  102. 2006 3.5 question
  103. What kind of paint for my front grill,do I need some kind of plastic primer 1st
  104. Resurfaced original rotors, how many times can they be cut
  105. How to replace Hub Assembly (bad speed sensor)
  106. Sent from Buick......... Over heating RoadMaster
  107. Any problems noted with new 3.5/3.9 engines?
  108. How can I cheaply stop my 05 impala from eating the GAS?
  109. Anyone drill holes in their impala headlamps to stop the fogging?????
  110. Vintage 71 Impala
  111. Shifting Problems in 2003 Impala 3.4L
  112. Stuck open thermostat
  113. Anyone know hoe to fix my fogging headlamps on my 05 Impala
  114. Best replacement rotors & pads for 05/impala
  115. Coolant drops under my car
  116. Any suggestions to improve gas mileage for the 3.4 in the impala
  117. 2006 impala ss gas mileage
  118. Best battery for Northeast?
  119. Best Bike rack for 2000-2005 Impala
  120. 2006/07 Impala
  121. ABS Light - any tips
  122. Largest Wheels On Stock?
  123. ACC / Lighter plug
  124. recirculating air
  125. whining sound from engine compartment
  126. Windshield wiper help.....PLEASE
  127. 2002 headlamp relay
  128. 03 rear defrost
  129. 02 impala overheating
  130. Fans always running
  131. Transmission just acted up,did not change properly
  132. When did GM change their intake manifold gaskets?
  133. 2001 Impala starting problem
  134. Will the A/C run in cold weather ?
  135. Looking for 2000-2004 Model Impala !!
  136. Turn signal problems
  137. Front seat mount??
  138. Daylight running lights stopped
  139. Excellant web site reference
  140. Intermitting clump and thump from left rear strut, mount maybe?
  141. 2003 impala LS 3.8 hards shifts
  142. Cruise Control Not working
  143. Thermostat
  144. 2003 impala overheating problem
  145. Cheap Foglight Bulb Replacement
  146. tick tick ticking....injectors?
  147. left button on mirror?
  148. Range when low gas light comes on
  149. 2001 Impala intermittent start
  150. A/C Odor
  151. 2001 impala blower motor problem
  152. 2006 Impala Ss
  153. control arm bushings???
  154. fragile defroster dash grille trim
  155. 2002 Impals LS Dome lights
  156. Lifter knock
  157. 2002 Impala Locked Factory Cd/Tape Player....Help
  158. Is High Mileage oil Worth it?
  159. How can i check my catalitic converter
  160. 2000 impala cd player issues
  161. 2002 impala under throttle engines revs up and down erraticaly
  162. spark plugs ??
  163. 03 Monte Carlo LS heating problems
  164. What pressure do you have in your tires?
  165. 2001 Impala cuts out around 20 MPH
  166. 2005 impala ls
  167. Dash Lights
  168. 06-07 EQ preset question?
  169. Side Mirror Repair
  170. does remote starter suck gas????
  171. OEM wheel vs China made
  172. chevy 2000 ls po410 code
  173. 69' Impala Heater Core
  174. impala ss
  175. 01 Impala--how do i set my clock?
  176. Tail lights and dashboard lights out , help please
  177. weird situation
  178. Fuel Leak, WHAT IS THIS PART?
  179. suspension upgrades
  180. low oil level light pops on--- car turned off
  181. 02 Impala Ls cuts off during driving
  182. 1970 Chevy Impala
  183. 2001 Impala Ls
  184. Updates on my POS 2004 LS
  185. Used BCM no good??
  186. New to the Impala crew....
  187. 01 Impala-High rpm shift/Tran slip
  188. apply gas or brake-slight feeling in steering wheel
  189. ticking sound
  190. popping noise
  191. front cigarette lighter power supply???
  192. heater control lights/remote programming
  193. 01 Impala LS pointer shows full-empty tank. What is problem?
  194. Battery draining
  195. Traction control/abs light come on
  196. Thoughts on a seat transplant?
  197. 65 with bad alternator
  198. 2002 Impala starting problems
  199. A/C Only works on High
  200. p0441 incorrect purge flow.
  201. Overhead Info Center Install
  202. CV Joint grease??
  203. TRUNK OPEN warning light?
  204. Which year should I get? Base or ls?
  205. 96 impala ss loses all power
  206. Fuel gauge sending unit wiring
  207. Impala SS 1995 Stolen
  208. 2000 Impala Power Window Switch
  209. Screaching Window
  210. 2002 Impala. Starts, then dies immediately
  211. Fog Light Bulb Replacement
  212. considering a 2004 impala......thoughts?
  213. 2003 impala stereo wiring pins
  214. 01 Impala B2960
  215. Computer Reader
  216. Intermittent starting problems, 2002 Impala
  217. I need help installing a remote starter
  218. Please Help Wobling Front In
  219. 2003 impala 3.4 oil leak
  220. Trunk light (re)installation
  221. What is a good by on an impala ss
  222. EGR-related performance issues
  223. Questions on Dexcool and leaks
  224. Chrome Alternator, but...
  225. 283 with powerglide
  226. rear defroster
  227. RADIATOR FANS not spinning correctly + CHECK ENGINE LIGHT
  228. Thermostat 2001 Impala ASAP
  229. Instrument cluster noise ?
  230. Tire Monitor Sensor - 2002 Impala LS
  231. Traction Control On 03 Impala 3.8l
  232. 2003 ipmala supercharged
  233. 2002 Impala Air bag light on
  234. 2004 Impala Instrument cluster problems
  235. 2000 Impala 3.4l Supercharged
  236. all lights flicker when i turn on the rear defroster
  237. Low Coolant level
  238. Please, Whats Wrong With My Impala?
  239. steering wheel lock
  240. p0141B
  241. California Emissions Cat vs standard
  242. Help with struts
  243. passlock
  244. Pennzoil Experience: Need Window Motor, Heater fan replacement, brake rotar+pad?
  245. Passlock information
  246. 2006 impala ss growling noise
  247. '01 Impala Power Locks Quit Working.
  248. Fuel Injector Service?
  249. Relay question
  250. '03 Impala headlights won't work... Need advice..
