View Full Version : Impala / Impala SS
Pages :
1 2 [ 3]
4 5 6 7 8 9 10 11 12
- Heater fan and turn signals problems on 2001 Impala
- The Need For Legal Speed! Not The Lt4.
- spark plugs!!!
- WTB - 1967 Upper Eyebrow Passenger Side
- 2006 Impala - Driver Side headlight won't come on
- help me, help me please ENGINE/INTAKE ISSUE
- theft deterrent system
- Oil Filter Location
- 01 Impala LS stops running - cannot find the problem
- 2004 center console
- Low Coolant only when cooldown startup
- 2004 Impala SS Starting Problem
- 06 Impala SS smoking & using oil - Is it the PCV Valve???
- Thinking about buying an Impala....
- 3 days of having car with an overheating issue..
- coolant flush
- radio swap
- 2003 3600 V6 Shifting issues
- 2000 Impala PS Dies when put in any gear
- left front speed sensor wire,hey maxwedge you there
- Service Vehicle Soon light?
- 2003 Impala engine shuts off after starting it up.
- 2005 Impala SS - sound of liquid when accelerating?
- 2001 Impala fuel filter removal
- Gear Shifting
- 02 Police package rear windows
- Question about a 2002 Chevy Impala base model
- 2003 impala
- Overheating
- '01 Impala 3.8L please heeeeeeellllllppppp me
- '02 Impala (3.4L) Intake Project Complete, but...
- Any photos of chopped 90's 2 door Impalas
- Turn Light Question...Please Help!
- 02 impala plastic hubcaps peeling
- Engine Oil Light
- head lamp cluster
- how to check Egr valve
- Clicking in front,steering
- A/C problem - 2000 Impala LS
- rear suspension creaking
- Changing Water Pump in '05 Impala
- '02 Impala 3.4L Base 105K: Removing Injectors from Fuel Rail
- Car will not full throttle
- torque spec for rear hub bolts
- Seats
- courtesy lights
- Stuck in Park!!!!!!
- Cruise Control decals on steering wheel
- Water Under Dash
- 2000 Impala V8 intermittent no start
- Need some help: '96 SS swap LS6
- replace 02 impala rear wheel bearing/hub
- '02 Intake Manifold Project in Progress: Day 1 Problems
- 03 Impala Stalling
- 2005 Impala Powe Loss
- Steering Noise
- Engine Swap Question...
- OBD 2 code 0327 on my 2004 Impala 3.4
- knocking noise
- Steering binds on left turns - 2k Impala LS
- more Impala trouble
- 03 Impala Intermittent Hard Shifting with 1811 code
- Scratched tint and weird smell....
- 3.4L Intake Gasket Leaking Too Long, Now What?
- '03 Chevy Impala, Check Engine Light, OBD II Code 420???
- Transmission Slipping
- my left side lights are too dim and the right side are normal
- 01 brake rattle
- Need Drivers side window service info
- 2002 Impala: Moisture in headlight assembly
- 02 impala trans shift lever sticking
- Duralast ignition wires
- security light intermedite cranking
- Wtb..96 Impala Ss Mirrors
- 1994 SS 4L60E Help
- WANTED Impala police hubcaps
- Trans shifts hard
- '02 Impala 3.4l 103K: Loud(er) Upper Engine Clicking
- Key switch, Radio, BCM or what??
- Bad Gas Mileage
- 2001 Impala 3.8 I have no clue what this part is called
- brake pads and rotors
- where is the headlamp relay located
- supercharger on a 96 impala ss?
- 2002 impala head lights wont turn on
- Need the name for a certain part
- ABS Light On - Speed Sensor OK
- Left Front vibration
- cd player
- 2005 Electrical problem!
- 2003 chevy impala trouble code 0420
- Looking to buy an impala.
- 2 wire alternator in a 3 wire car?
- Alarm on a 2004 base
- 22" rims rubbing back struts
- What kind of mufflers for 04 impala SS?
- Imapala SS Mufflers
- 02 Impala won't start - Suspect fuel delivery problem
- 2001 Chevy Impala Turn Off Message Center Lights w/ Aftermarket Stereo
- p0128
- Cruise Control Disengages
- 2006 Impala Ls Performance Parts?
- 2004 impala ss grille
- Failed inspection for only Steering binding! wtf? i got into this to get feedback
- Ignition Is Locked!!! Help!!!!!
- Problems with my 02 Impala: Trunk Pops when I put the car in park..
- Face Lift...
- reverse power steeing pump rotation
- 2001 hard starting after sitting
- 1st good car. nj emissions?90k?
- dash lights and trunk button wont work
- Vent Solenoid Location
- fuel injectors
- Shake & Rattle when I Roll...
- 95 Impala Wiring harness plug designation
- Power window doesn't work
- 2002 Impala quick strut - How to suggestions?
- fuel injectors... can I do them???
- 2002 Impala LS dies at idle when warm
- Installing a kill switch
- heater doesnt blow heat when idling
- Impala LS Service Tracking System Problem
- No Overdrive
- 01 impala serious problems
- 2001 Impala Starting Problem
- Noisy Lifter...now....!
- tire pressure reset
- need help with check engine codes
- 06 Impala Remote Start
- Cruise Control
- Instrument cluster with tach and gauges
- Alternator Regulators keep failing
- Gas gauge sensor ground wire
- K&N airfilter verses stock air filter
- Why no trunk light?
- NEED HELP FAST VERY URGENT about rims and tires
- 1st, 2nd, 3rd.......No 4th Gear!!!
- 2000 Chevy Impala coolant system
- Whining and leaking
- 00 impala rds radio unlock?
- 05 Impala cooling problem
- Evap Emission Control Code 0440
- Heater fan switch? Or Relay problem?
- oil in radiator
- 2002 Impala headlights go off while driving
- 01 Impala Starting Problems
- cost of a radiator change?
- Frost on inside of windows when cold outside
- Can an LS become better than an SS?
- Wheel fitment
- Engine Failure
- Crisis!!!!!!!
- Collasped valve lifters??
- interior lighting and aesthetics
- Power windows wont work and security light on.
- low air pressure light is on
- Turning my lights off
- EVAP solenoid on 2006 impala
- 2004 Impala SS
- RPMs
- 2006 Impala SS
- 2001 Imapla
- 2003 Impala 3.8 Oil Pressure warning
- 02 ABS light when wet?
- Overheat-newbee here
- impala cuts off when driving
- Please help, the horrid intake manifold gasket problem....
- 02 impala gas mileage
- make my impala fast
- 06 impala washer fluid pump location
- peak antifreeze
- Knock sensor for 95 LT1
- Driver Side Window
- 1994 - 1996 Impala SS, Parts Source...
- Heater Control Head shorted??
- Impala 3.8 2001 - Lower intake gasket ?'s.
- 00 impala radio ?'s
- temp not reaching 195
- Transmission Fluid Change - Dexron-III to Dexron-VI
- 95 chevy Imp
- washer fluid in coolant?
- What Is The Firing Order For a 2003 Impala 3400 V6?
- 205/60/16 verses 225/60/16's
- Transmission or sensor?
- 2000 Impala PS - High Idle
- 02 LS hard starting
- fuel or ignition problem???
- impala 3.4 vs 3.8
- Pressure control soleniod/valve
- Bright Headlight Switch
- Remote lock and unlock settings
- 2004 Overdrive
- 2007 Impala lights flicker 3 cyl mode
- Fuel filter
- 2002 Impala Rear Suspension
- Cruise Control Switches & Adjustment
- can't fix noise
- 2003 Impala 4t65e transmission problem
- 2001 3.8 oil pan question
- 03 Impala Diagnostic Code PO128
- 02 coolant problems
- No heat on just the driver side
- Anything to look out for in 94-95 Impala SS's?
- Tires,205/70/16's
- Loud ticking noise when engine started
- Overheating
- Converting impala's 16' to 15 inch rims
- 2002 Wipers stop upright
- Hard on gas this winter,3.4 05 Impala with 58 000km'
- Horn
- Warning Lights when start 2003 Impala
- Leaking water in 04 SS
- 2001 Impala 3.8 Whining Sound?
- 2003 Impala - 9C1 Police Package
- 2003 Impala bcm problem?
- can i run flow master mufflers on 04 ss sc
- Oil Leak where?
- 02 impala PW question
- Starting and shutting off
- How to remove Moisture from my Headlights
- 2002 Radio Dimmer Problem
- car will not start after changing water pump
- 2004 Impala, Lack of Power
- Hub or not the Hub?
- 01 impala keyless issue
- Dashboard light problems
- 02 Impala - Left Front wheel issues
- 06 Impala - tire eater?
- Loss of power during acceleration
- Washer Fluid Fuse/Motor
- 2002 Impala - Constant noise like a weed-eater while driving.
- '02 Impala 3.4L: Intake Gasket Morass
- 2003 Impala Erratic starting problems!!!
- 02 hvac fan/blower acting up?
- Mirror courtesy lights will not shut off
- aftermarket stereo install static
- 2003 impala gas mileage
- Mystery Coolant Leak
- Classic Impala
- "nugg" sound coming from front wheel areas.
- 01 impala fuel filter problem
- Fan Control - Blower Motor
- Steering Rack leaking Impala 2001
- P0128
- New T47H Torx and T60H Torx.
- Radiator Swap
- Replaced battery and now radio won't turn on
- 2001 Impala P0306 code
- Which is Cyl #6 2001 Impala ?
- Sluggish performance
