View Full Version : Impala / Impala SS
Pages :
1 [ 2]
3 4 5 6 7 8 9 10 11 12
- I bought an 2001 chevy impala Monday, and this happened
- 02 impala
- '02 impala, 3.8 slow crank, cut off ghost
- Thermostat & oil pressure switch location '01 Impala +
- '04 Impala LS 3.8L sounds doggy-low fuel mileage
- Evolution brake pads
- 2002 Impala LS Removing the center console
- Engine Miss - EGR Valve problem??
- Cause of the turning noise
- 2005 4t45e which is the return cooler line
- 2001 Chev.Impala SOUND while making turns
- terminology?
- cartuning turbo kit.
- 2001 Impala Overheating Issues
- Can I reprogram theft lock on a new stereo for 2002 impala
- What could that grinding noise be??
- 2000 Impala, Grinding Noise while turning
- 2000 Chevy Impala headlight aiming?
- 06 Noisy Cluster?
- 02 Impala SS???
- 2006 3.9l engine thoughts
- 05 Impala 3.4l fluctuting temperature
- 06 impala ss transmission troubles
- Level of 08 Impala
- '02 Impala - Cruise Control doesn't work
- Impala ls and ss owners with 6 pod cluster
- 2005 impala
- Impala Newbie, cutting off question
- oxygen sensor simulators???
- Another wheel bearing question
- 2005 Impala - Would you recommend?
- 06 a/c & power issues
- Is repacking hub assembly possible?
- Car battery dies overnight
- Door pannel removal 2000 impala
- What is this and why?
- 2000 Impala shutters when starting from stop
- 03' impala leather seats
- '05 Impala 9C1 HVAC blower not working
- brake light problem
- whelen UHF2150B Install help
- Off Track!!! Help Please!!!!
- 2006 Impala rear defogger problem
- fuel filter location on 2008 LT
- 2004 impala ss stall
- Impalas and other cars in its class
- 2002 Police Impala Overheating
- V-6 engine peppy enough
- Need 2000 Impala hood, left headlamp and headlamp support
- A/C compressor only kickin in every now and then
- Impala ABS Scan Tool
- BCM programming 02 impala
- 02 Impala, was stuck in the snow, now wont start!!
- 01 Impala steering issue
- starting problem
- anti freeze leak after getting cam and lifters done in my 3.4
- Synthetic oil
- 02 impala alternator or body control module problem
- Please Help Me!!
- 01 impala 3.4l prob need help
- 01 Impala 3.8 Slow Coolant Leak
- 06 Gas Cap / Engine Light
- '01 Impala, what would you do?
- Check engine light on and very sluggish
- 3,4 mising and rattling after oil change,just found out whats wrong
- 2006 Impala Mirror Inside Gasket
- Scan Tool
- High rpm at idle
- 2002 Impala 9c1 Questions
- splash guards for 08 LTZ
- 02 Impala seat question
- 02 Impala horn issue
- 02 Impala ticking
- 2001 Impala No power after grounding 12v amp lead
- Fuel gauge quit working
- Driver Side Window
- 2000 impala explosion
- "Running Lean"
- Where is the amp fuse located?
- Early Converter Engagement
- 2000 Impala blower motor & DIC doesn't work
- 2006 SS tire pressure monitors
- Factory Remote Starter
- engine noise after oil change/sticky lifter maybe,can some one help me
- 2001 impala no sound, radio works
- Broken Radio Control
- altenator/charging system/rear defroster
- help no heat...everyone read need input.thanxs
- 2000 LS Heater Controls Problem
- Transmission shift points
- Transmission Issues
- Ls bumper
- ABS an Track off
- side view mirror
- 03 Impala LS - NO COURTESY LIGHTS???HELP!
- Check Engine / temp gauge not working / loud fan
- Temp gage fluctuation
- O2 Sensor "too Much Activity"
- 2002 Impala w/120,000 Code p1811
- 01 trac light!
- 2003 impala overheating. Please HELP!!!
- 2006 Rear Defroster
- Disconnect panic button
- Pressure control solenoid
- Sunvisor?
- voltage hand moving in cluster
- ECM diagnostic shunt codes
- Rear Seat Replcement!!!
- Torque Strut Question
- 2005 Impala No Heat
- 2001 Impala schreeching noise near fans
- 2006 Ss
- Oil In Antifreeze !!
- Pcv Valve Issues
- Fog lights
- Impala 2005 Low Heat Ventilation System
- but its full of oil already
- sluggish acceleration
- Radio possessed
- 1996 goes dead at light
- Check Engine Light, Impala not starting
- 2000 Chevy Impala Ls "New Owner"
- windshield deicer in radiator reservior
- 96 impala ?'s for hopefully common problems
- purge solenoid cannister
- Fuel odor in the morning?? '04 w/ 3400
- 2003 Impala - Key won't turn, no previous security lights.
- my radio
- 03 Cruise buttons
- code reads : EGR flow insufficient ?
- Input, please
- Transmission slipping when cold
- 05 water leaking above drivers window
- heated seat problem on 2000
- steering problem
- 07 ltz
- 2002 LS, Coolant/Performance Issues
- Power window, security light issues solved!
- EGR replaced but engine light still comes on code shows EGR problem.
- 02 impala gurgling noise
- '02 Impala brake booster removal
- Noise, intermitent rapidity increases w/speed
- spark plugs
- Check Engine light
- sun visor
- 2003 impala LS
- Steering wheel radio controls
- 94-96 Corvettes/Impala SS have LT1's, how does vette have more hptq
- 2001 supercharger
- First the battery now the trans... what's wrong here?
- 2000 Impala
- 96 Impala SS
- '01 Impala 3.8 stalling problem
- 2001 impala no heat on pass side
- removing ign.sw
- 2003 Chev Impala 3.4 L Misfireing Cylinder One
- Yet ANOTHER "security light" thread.... except...
- Ignition Switch
- CC,HVAC,BLOWER,& DIC Problems
- Is Bluetooth in the Impala compatable with a motorola razr phone?
- 2002 radio speakers hiss when off
- noise in rear of 2007 ss
- 2001 impala wont turn over.
- air condtioner problems for a chevy impala
- 03 bad bcm, delay in door locks and high beam dash light
- Chevy Impala Sometimes Wont Start
- 02 impala ls, no crank, no interior lights, headlights, bad bcm?
- 2003 impala Air conditioning selector switch stuck
- Chevy Impala Cluster.
- 2002 3800 V-6 starts hard
- 2002 3.8l...oil up by the injectors?
- What is this brake part?
- 3.4 oil pump shaft install
- 2002 Impala Security Light
- 06 Impala Power steering
- Tranny fluid low and rough shifting?
- 2004 Impala SS engine noise
- Water coming from air cond. on pass side floor
- p0742+p1811
- '03 3800, sluggish
- 2002 Impala acceleration problem
- Different overheating problem??
- Clicking and rattling from front '03 base
- Door molding for 96 impala
- EGR Valve Issue - 03 Impala
- 2002 impala runs bad
- Transmission dipstick tube - 2000 LS
- What's the better buy or car and why?
- Sun Roof Won't Close!
- Lower engine noise 2001 Impala
- Intake gasket leak or head gasket
- 2003 Impala: are the driver side and passenger side wiper arms the same?
- racing, body roll.
- 2001 Impala LS Lound noise under hood, sounds like a belt or the fan
- Impala motor swap?
- 04 impala starting problem
- 2001 acceleration problem
- '03 3.4 Impala: P0442 Evap Emission Small Leak
- Heater/AC Fan Problem!
- 05 Impala Fuel Gauge and Transmission Connection?
- 2001 Impala Headlight Adjustment
- About to purchase police impala, questions
- Water leak around door
- '03 3.4 Impala: "Klunk" noise in rear
- '02 Impala: SECURITY issues back again...
- Grinding noise from the front
- Traction Control, A Dad's Delema
- 2006 Chevy Impala LT - Key stuck in ignition - max 20 mph
- '03 3.4 Impala: Trunk lock won't unlock w/key
- Hey guys question on 2005 Impala SS/SC
- 2004 impala 3.8 ss/ P0141
- 2 Questions: How to change cabin air filter and change heater control?
- Advise on 2002 transmission again
- Low Pressure AC hose?
- front brakes on 06 Impala
- Exhaust manifold
- 2007 Impala SS...Broken Steering Column
- 2001 Impala Headlights
- gas gauge
- Need advice
- 2002 3.4 transmission help
- Rusted 2000 Impala Subframe...how much to fix?
- 2003 - Impala, loosing pick up ability
- New Headlights Install
- 2006 Impala thermostat location
- 2002 Impala LS Center Console Removal
- 2006 Impala SS Transmision FAILED!
- switching overhead console to km. from mph
- fans won't shut off and bloe hot air with a/c on
- oil pressure/sending unit
- A/C Compressor
- 02 impala needs bcm HELP
- Limited Edition 05 ss cluster
- Impala 3.4 supercharger Will it fit??
- air conditioner doesn't blow air out
- 2000 LS Transmission Problem?
- replacing transmission
- 2002 Impala LS- stalls when driving and traction activates all the time
- '03 Impala LS with 3.8 running a little hot
- 2000 LS steering rack
- is it worth drag racing?
- 2002 impala 3.8L rear plugs
- my car wont start
- Oxygen sensor
- Spark plugs (rear)
- 2000 Imapala headlight problems
- How Many 02 Sensors?
- New indy pace car cluster,plug and play for 2000-2005 impala's
- Performance Shocks???
- Parking Brake Light Comes on during Hard Acceleration
