View Full Version : Ninety Eight
- Rattling noise upon coming to Idle
- 1991 - Fuel / starting issues...
- Transmission Fluid Capacity
- PCV Grommet
- 94 Oldsmobile 98 Regencey Elite Issues HELP ME!
- Removing the cat
- 1987 oldsmoblie 98 fuse
- Loud noise coming from engine/overheating
- Evaporetor core
- 1989 olds 98 vibrates over 45 mph
- Cruise Control dead
- Rear Drivers Side Engine Mount
- Flushing Transmission Lines
- Neutral Safety switch problem???
- 1989 Rear Main Seal
- exhaust smoke problems
- Sway Bar Bushings
- 1987 Olds 98 won't start and has no spark
- 4T60E clicking in Park
- engine dies
- transmission fluid in coolant
- 1988 Ninety8 Stalling
- Axle Spindle Lock Nut
- 1991 olds 98 delay in the acceleration
- Lower Ball Joint Removal
- 89 98 Trans Removal
- code 41
- 1986 Olds 98 Regency Fuel Pump
- 1993 98 glove box lamp wiring diagram needed
- new owner delta 98
- 1989 Oldsmobile 98 Speedometer
- 1987 Olds 98 Regency won't start
- 89 Rear Brakes
- Trouble with coil module?
- EGR Valve Pintle Position Circuit "1406"
- 91 Oldsmobile 98 parts interchange w/ 94??
- Code 15
- 89 Olds 98 Trans
- 91 olds 98 no start ?
- Heater/AC issue
- Would you take $535 as a salvage value?
- transmission issue
- 1991 Oldsmobile 98 Regency Elite
- Any way around the Passlock Security system?
- Issues with lights
- Lower ball joint problems!!!
- 91 Olds 98 Fuse #6 Dash, Service Engine S
- 98 Regency Touring Sedan FE3
- 1993 olds ninety eight
- freeze plugs
- 91 starts sometime, then wont start
- Custom Work
- 1995 oldsmobile 98 problem please help
- Help! My 1996 Olds 98 dies while going down the road.
- 90 rear strut question
- Looking for used wheels
- 1992 Ninety Eight won't start after hitting a box
- Olds 94 98 fuel milage/ ignition problems
- Drivetrain : CV Half Shaft Assembly
- A/C Blower???
- Weird AC compressor issue
- Installing Keyless Entry
- Just fixed a flat...
- 1990 Olds 98 codes
- 1992 Olds 98 Regency trouble
- Turn Signal Won't Engage
- How much Freon to charge AC system
- Re: 1988 Oldsmobile 98 starting Problems
- 1992 Olds 98 Surging Problems
- information center on dash
- 98 ods 98 starting problems
- I'm about to change plugs and wires.
- 1991 98 No start
- brake problem
- 91 ninety eight no dash lights or radio?
- 1990 olds 98-no climate control or radio
- I need the firing order for an 85 Olds Regency 98.
- 1989 Olds 98 passenger-side speakers
- Axle/Rotor nut size?
- Subframe removal
- 1990 Olds 98 Regency - tried everything still wont run smooth or start reliably
- 89 oldsmbile 98 fixed one problem but still have one
- 89 Olds 98 Trans Rebuild
- Cruise control.
- 82 olds 98 possible trans issue help?
- stalls out
- transmission and temp question
- my oldsmobile 98 regency won't go pass 45 mph
- 89 oldsmbile 98 im about ready to junk it
- 89 oldsmbile 98 3.8
- Cel flashing when coasting to a corner.
- code 34
- 91 olds 98 doesn't start
- door hinge and bushing - what gm cars used the same hinges
- Air Conditioner problem
- 91 Olds 98 transmission problem?
- '91 Starter Enable Relay Location
- code 41
- i need help with something
- 94 regency starter
- Air ride on my 1992 regency
- Code 44
- Motor Mount plus CEL and more.
- Engine oil cooler lines
- crazy car
- 93 Olds 98 3.8 Digital EGR test
- 96 Olds 98 with a noise
- gas smell
- A/C compressor donīt engage
- Popping.
- 1989 olds touring sedan some times wont start
- Cel when coasting to a corner.
- Engine Swap
- Programming Keyless Entry 1994 Ninety-Eight
- Olds 98 Automatic Climate Control Temperature Blinks on Startup
- Heater not working.
- Choke.
- Seafoam?
- rear strut
- 1993 Regency hesitation on acceleration
- Recall!!???
- no spark,1994 olds 88
- Oil Light On After Oil Change
- 1977 Olds Ninety-eight transmission
- 1988 olds 98 electrical problem
- 93 SC 98 - Oil presure sending unit
- 4T60E, no gears when warmed up...
- '93 olds 98 relays
- engine swap
- Low Coolant
- olds back end sags
- rear ride level control,
- crossmember
- 96 OLDS Ninety Eight A/C doesn't work
- 1990 Olds 98 engine trouble
- Oil sensor
- Supercharging a non Supercharged 3800 V6
- Redline?Rev Limiter?
- 94 Ninety-Eight Horn sticks
- Squeel... Check Engine Light Blink!
- coolant light
- Engine Control Computer
- 94 olds 98 pass key fuel code
- 1988 Oldsmobile 98 starting Problems
- Horn won't stop !!!!
- Blower fan stays on!
- Low coolant.
- 92' ninety eight won't start
- 94 olds 98 problem azzkicker
- Need Help With Keyless Entry
- Transmission fluid change questions
- 94 olds 98
- Looking for some 98 Touring Sedan parts
- 1994 oldsmobile 98 regency P0118
- 1992 Olds 98 Heater core replacement??
- 94 Olds 98 Possible Security Problem...
- Quad Driver 1988 Old's Brougham 3800 eng
- 94 olds 98 cylinders 2 4 6 not firing
- 1992 olds 98 tranny prob.
- 1968 98 a/c problem
- High altitude problems
- Code 26, Quad Driver Module "A" Fault problem
- Cooling fan control switch
- 92 Olds Regency Elec Issues
- 98 Starts better after sitting
- 1990 olds regency won't start when warm
- Recharging the AC
- 92 98 AC compressor inop?
- 1990 Olds 98 Regency Brougham Issue
- 1991 98 regency elite wont start
- Heater Core
- 87 olds 98 help please
- Code 26, Quad Driver Module "A" Fault..
- 93 Olds 98 Radio replacement
- 89 olds 98 problems when driving
- valve shims?
- Thermostat housing question
- 92--- 98 - 3800 security system
- SRS Airbag question
- 1995 olds 98 blower motor
- No Spark at Coil Pack...97 Olds 3.8
- Crank Sensor: 1989/not 1998 Brougham 98 -
- '91 olds 98 won't start
- crankshaft position sensor
- A/C Code 66 (low freon) at speed, but not a idle.
- 94 olds-98 regency elite
- 1991 olds 98 electrical problem
- getting at ignition cylinder
- Weird problem with 94 Olds 98 Regency Elite
- Olds Died 2ce while driving.
- 86 Olds Regency
- 1990 touring sedan help?
- Olds Ninety-Eights (and eighty-eights) Geneology
- reads 130 cold or hot..
- 98 misses under load
- Need Help guys
- 89 98 Radio
- 92 Olds 98 Problems, Help Please
- I need a door window
- 93 olds regency trouble
- Newbie
- head lights
- 89 olds ninety eight cuts out
- Possible cam sensor/magnet problem?
- Cuts out while driving. 88 Brougham
- Blower doesn't work
- Is this normal?
- 92 Olds
- Parking/Tail Laps, 84 Olds 98
- warning lights on while key is out of car
- Has To Be Jumped Every Start
- intermittent olds regency
- looks like h**l, rides like a dream
- body work questions :(
- I just picked up a 1981 OLDS 98 - known issues?
- Tachometer
- Fuel filter 94 regency
- 1990 98 Regency torque specs
- Horn plate for steering wheel
- Fan turns off when key turned off!
- 1990 98 Regency problems
- 1982 98 won't start
- Auto Leveler
- Just Got a 91 Ninety Eight, and...???
- Parking brake problems
- Radio / speaker problem
- mysterious problem...
- Olds 98 Regency Transmission
- need help removing lights
- need HELP finding a grille
- Oldsmess
- 1989 olds ninty eight 4.9 l engine swap
- gas smell
- shimming on front passenger side
- 1979 Olds 98- Need pillar lenses
- 57 Olds continental kit,I need some help/info.
- 88 oldsmobile 98 banging noise
- I want a supercharger on my 3.8
- 88 ninety eight touring can't find fuel pump relay..HELP!
- Several 1992 Oldsmobile Regency 98 Questions Plz Help
- few questions
- 1996 olds 98 whining noise
- Annoying rattle at idle
- 1996 Olds 98
- DRL's
- a/c problem
- AC temperature number blinking!
- somethings draining my battery
- cool morning starting problems
