View Full Version : Ninety Eight
- High altitude problems
- Code 26, Quad Driver Module "A" Fault problem
- Cooling fan control switch
- 92 Olds Regency Elec Issues
- 98 Starts better after sitting
- 96 OLDS Ninety Eight
- 1990 olds regency won't start when warm
- Recharging the AC
- 92 98 AC compressor inop?
- 1990 Olds 98 Regency Brougham Issue
- 1991 98 regency elite wont start
- Heater Core
- 87 olds 98 help please
- Code 26, Quad Driver Module "A" Fault..
- 93 Olds 98 Radio replacement
- 89 olds 98 problems when driving
- valve shims?
- Thermostat housing question
- 92--- 98 - 3800 security system
- SRS Airbag question
- 1995 olds 98 blower motor
- No Spark at Coil Pack...97 Olds 3.8
- Crank Sensor: 1989/not 1998 Brougham 98 -
- '91 olds 98 won't start
- crankshaft position sensor
- A/C Code 66 (low freon) at speed, but not a idle.
- 94 olds-98 regency elite
- 1991 olds 98 electrical problem
- getting at ignition cylinder
- Weird problem with 94 Olds 98 Regency Elite
- Olds Died 2ce while driving.
- 86 Olds Regency
- 1990 touring sedan help?
- Olds Ninety-Eights (and eighty-eights) Geneology
- reads 130 cold or hot..
- 98 misses under load
- Need Help guys
- 89 98 Radio
- 92 Olds 98 Problems, Help Please
- I need a door window
- 93 olds regency trouble
- Newbie
- head lights
- 89 olds ninety eight cuts out
- Possible cam sensor/magnet problem?
- Cuts out while driving. 88 Brougham
- Blower doesn't work
- Is this normal?
- 92 Olds
- Parking/Tail Laps, 84 Olds 98
- warning lights on while key is out of car
- Has To Be Jumped Every Start
- intermittent olds regency
- looks like h**l, rides like a dream
- body work questions :(
- I just picked up a 1981 OLDS 98 - known issues?
- Tachometer
- Fuel filter 94 regency
- 1990 98 Regency torque specs
- Horn plate for steering wheel
- Fan turns off when key turned off!
- 1990 98 Regency problems
- 1982 98 won't start
- Auto Leveler
- Just Got a 91 Ninety Eight, and...???
- Parking brake problems
- Radio / speaker problem
- mysterious problem...
- Olds 98 Regency Transmission
- need help removing lights
- need HELP finding a grille
- Oldsmess
- 1989 olds ninty eight 4.9 l engine swap
- gas smell
- shimming on front passenger side
- 1979 Olds 98- Need pillar lenses
- 57 Olds continental kit,I need some help/info.
- 88 oldsmobile 98 banging noise
- I want a supercharger on my 3.8
- 88 ninety eight touring can't find fuel pump relay..HELP!
- Several 1992 Oldsmobile Regency 98 Questions Plz Help
- few questions
- 1996 olds 98 whining noise
- Annoying rattle at idle
- 1996 Olds 98
- DRL's
- a/c problem
- AC temperature number blinking!
- somethings draining my battery
- cool morning starting problems
- How much fuel pressure drop when starting?
- Remove maf screen
- Re: Problems Charging the A/C
- Coolant temp?
- exhaust manifold
- Headlights Cut off while Driving
- Olds 98 blows fuse and dies on road repeatedly.
- What is a good swap for a 307Y5.0L 83' 98
- 96 Olds Regency (98) lost power
- Intermittent Glitches (AC, Locks, Windows)
- 1993 Olds, Battery dies while driving, but alternator works???
- cannot figure it out
- no spark
- Steering Wheel Wanted!
- 1996 Oldsmobile Auto Leveling probs
- '92 98 Tie Rod Ends
- 91' Niety Eight sputters then dies
- 1992 Olds 98 AC filter ??
- ac comp cause engine probs?
- 1992 Ninety-Eight AC Flashing
- '91 - My brakes are driving me nuts - don't work even after overhaul! Help? :(
- 1988 98 Regency 3800 no spark
- 1992 Olds 98, fan relay
- 1992 Olds 98 Regency air ride
- 97 cutlass security light runs for a few then dies
- Brake Line Overhaul, questions on sizing/procedure - pics enclosed
- Second Opinion
- 91 - 98 humming noise?
- Important: New and Old Members Please Read
- 59 holiday sedan, which engine fits??
- trans interchange olds 88
- Dash Malfunctioning!
- AC Compressor Question!
- Brake Fluid Leaking! What to do?!!?
- !!!i Need A Lot Of Help!!!
- Manually releasing Hood Latch
- Engine cutting out 1990 3.8L
- 92 98 Regency Shaking
- Original Repair and Parts Manuals coming soon
- 1990 98 Electrical Issue
- Water Pump
- idle sticks after certain speed
- Hose replacement kit
- Crank Position replacement?
- TBI Engine
- 1990 CPS changing???
- 1991 Olds Reg Elite stall at operating temp
- olds 445 question
- HVAC blower motor out to lunch
- crank sensor '90
- 1994 Ninety Eight Regency Elite FWD SC Axel Removal
- Thermostat
- Engine Swap Stress Relief
- 1989 olds quits running while driving
- 91TS ignition module interchange ...
- 92 Olds 98 Is there a set lowest temp for the AC in the ECC?
- 92 olds 98 self leveling struts probelm
- Olds 98 Low Coolant Warning
- 92 98 regency climate control dead
- 1991 Oldmobile 98 Regency Elite Edition, runs but stall out later...
- Low Brake Fluid warning ?!?
- My 91 ninetyeight is a guzzler
- Early FWD Oldmobile 88-98website needs your help!
- 98 BCM Location
- 1989 Olds Regency 98 Bro Water Pump
- tranny fluid
- waterpump, acceleration & gas tank level
- Interior lights won't go out on Olds 1995 98
- All i get is a clicking...
- Please Please Help ! ! ! !
- OBD or OBD II
- 88-olds98
- Anyone else had trouble with coil module?
- firing sequence
- cuts off while driving.
- 84 delta 98 starting problems.
- 1987 98 Regency Brougham 3.6 V6 FI
- A/c Issue
- '91 Olds 98 regency elite engine timing off
- 1974 beautiful with 455 ROCKET v8 muscle!
- Engine Swap`
- what is this?
- !!!rod help!!!!
- 1991 oldsmobile 98 regency elite won't start
- pcv
- Rebuild Kit
- won't start
- Oldsmobile Ninety Eight How To's
- Rear drums to rotors?
- 87 Oldsmobile Ninety Eight complete rebuild?
- I want to buy a 98, but
- 1993 olds98touring-whining noise near trans
- Service engine soon
- '90 Olds 98 Climate Control Fan
- 1990 98 olds regency window
- 1992 oldsmobile 98 regency
- economic data log disc.
- 1992 oldsmobile regency 98
- 1982 oldsmobile 98 or ninety-eight
- Need parts for my 1993: LF fender...
- Rough Ideling
- 1987 Touring Sedan (98) Rough Idle/Stalling
- calibrating for new TPS on '87
- 1991 olds 98
- 1992 vs. 1996 Olds 98 R-Elite
- 1987 olds 98 backup lights on in drive and not in reverse
- 1995 olds ninety eight won't crank
- 1996 oldsmobile 98. randomly will not start
- 92 bonneville motor fit a 1985 98
- 90 nintry eight regency putting
- 63 Old's Ninety Eight four door hard top
- Tension Pulley is Clicking
- 91 Olds 98
- olds 98 wont start
- Any RWD 80s Ninety-Eight enthusiasts???
- 1987 Olds 98 intermittent starting problem
- 1987 olds 98 stalls after driving 15-20 min.
- 1992 Oldsmobile 98
- 1991 Olds 98 won't shift into high gear.
- Diagnostic Code Info
- Check oil & Coolant Level Low messages on a 1992 Olds 98 Regency Elite
- No start 3.8 litre buick park avenue
- New website to check out.
- Car Keeps Shutting Off
- Searching for.......
- Olds "Ninety-Eight" 3.8L engine same as in Chevrolet Lumina?
- HVAC weak
- 1996 oldsmobile eighty eight LS dies going down the road
- 85 Oldsmobile 98 for sale 1000 obo
- sensor
- armrest bezel
- 87 Olds 98--problem Fixed--( For Sale)
- 1996 Olds "Ninety Eight" Any Chronic problems ?
- 3.8 injectors
- WTB hood emblem for 1988 touring sedan
- 1992 98 Touring / supercharger upgrades?
- 91 Air ride pump not shutting off
- WTB 57 Olds parts.
- Headlight Lense
- engine code 41
- 1993 Olds 98 Touring Sedan Suspension Repair
- Runs Rough
- Heater Elbow Hose fitting question
- 1987 Olds 98 Regency
- Belt Tensioner Issues
- Oldsmobile Wire Wheel Covers
- Battery Drain
- 89 Olds Regency 98 Not starting!
- 1984 98 regency brougham sunroof motor needed!!!!
- 1989 Ninety-Eight Regency Brougham Tranny Issues
- 1991 98 hood latch
- 1991 Ninty Eight Touring Sedan
- radio problems?
- my 91 98 olds regency likes to die
- It's sad to see her leave...
- 1989 olds 98 bumper removal & replacement
- In Search of an Engine
- paint used on intake plenum?
- Throttle positioning sensor nightmare
