Our Community is 662,000 Strong. Join Us.
View Full Version : Trans Sport
Pages : [1] 2 3 4 5 6 7
  1. 1994 Trans Sport Radiator leak
  2. Intake Gasket Advice
  3. EGR fault
  4. wife driving with steering wheel 90 degrees to Left
  5. 1992 Transport window not working
  6. squeaking from engine
  7. Engine stop after 2 minutes-Pontiac Trans Sport 1996,2.3l,16v,Quad4 DOHC
  8. pontiac trans sport 2.3 16v- engine is stop
  9. 95 Transport, disable auto door lock on gearshift.
  10. 1997 Pontiac Transport Keyless Problem
  11. Crankshaft Pulley Fell Off. Ugh.
  12. Where to get spare parts in Miami
  13. Power steering is rocking
  14. 114,3 and 115mm ..... Hoax or fact?
  15. Loctite on starter bolts
  16. Now everything is good again
  17. 1993 TransSport Transmission Fluid Leak
  18. How do I know which radiator?
  19. 94 3.1 Transport no get up and go
  20. '91 Transport wheel hub
  21. Slow Cranking when Hot!
  22. How to change the LIM gaskets?
  23. SLow transmission response
  24. 1998 Trans Sport
  25. A/C rear tube is leaking. Where to order?
  26. TCC not engaging on a 3T40 Transmission ('91 Pontiac TS SE)
  27. 1998 Trans Sport blower speed and power lock
  28. 1998 Trans Sport Blue Vaccuum tube
  29. loss of oil presure what do i do
  30. Pontiac Transport
  31. 92 TS 3.8L cooling fans
  32. Miles before replace 3.8L timing chain?
  33. 3800 engine swap question
  34. Cooling fans question
  35. Time for a tune-up
  36. A/C R134 conversion
  37. 1992 TS doesn't switch on the front air vents
  38. Radio not working after repairs
  39. '94 TS leaking oil. Again.
  40. Coolant light starting blinking
  41. Something Simple (I hope)
  42. 96 trans sports surging, could be the MAF I repaired or the heated O2 that got some coolant.
  43. '95 trans sport alt issue
  44. Radiator fan (both) not working
  45. 3.8 GT low oil pressure on dash gauge
  46. Front Wheel Hub/Bearing problems 3.8 TS
  47. fuel gauge
  48. 1992 Pontiac TS 3.8 GT
  49. Top plastic rad pipe cracked, can It be fixed?
  50. at 70km/h uphill only in Overdrive, Transmission hesitates
  51. 96 trans sport 3.4 starting issues
  52. 1997 Pontiac Transport
  53. 1992 3.1 Transport
  54. Alternator failure: SOLVED
  55. Reverse Lights not working on '97 Trans Sport
  56. TS 95/96 - rear bumper dismount
  57. Timing adjustment for a '92 3.1 Pontiac Trans Sport
  58. AC Pulley to replace AC compressor
  59. 97 transport problems
  60. Can't figure out Ignition problem
  61. Wife: "The door is soldered shut!"
  62. Air suspension guts alternatives?
  63. Trans Port, Transport Transmission Vibration
  64. Running rich
  65. Measuring the actual oil pressure on a 3.1 Pontiac TS SE
  66. Best oil viscosity for an old 3.1 Pontiac engine
  67. Best brake-pads for Pontiac TS
  68. 1996 rear fan control
  69. Most confortable shocks for Trans Sport
  70. heater core replacement on 94 transport
  71. A one-time purchase air filter
  72. Occaisionally, seems to be missing on one cylinder...
  73. '95 trspo, 3.8L, No power brakes....
  74. 94 3800 won't idle up
  75. 98 transport ..short?
  76. high idle in park
  77. 1994 Pontiac Transport SE 3.8L
  78. Difficulty in replacing a/c compressor?
  79. Coolant Leak Cold Engine?
  80. Starting problems
  81. IAC Test?
  82. Request Help in Scarborough Ontario Canada
  83. Radiator leak fix (and power steering bonus)
  84. Charging system question
  85. '97 Trans Problem
  86. 95 Transport ABS Light
  87. Is my transmission shot....again!!?
  88. Vacuum Hose-'95 3.8
  89. 97 Trans sport bad trans.
  90. 97: How to disable ABS light?
  91. Engine Missing or Bad Tranny
  92. 1997 TP no fuel pressure
  93. '94 3800TS: power steering and coolant leaks
  94. Idle Voltage with AC on
  95. power window 92TP
  96. 1995 3800 fuel pump problem
  97. where to start with CC
  98. Central Locking Problem
  99. 1996 auto air level control
  100. Ignition Cylinder Replacement
  101. 95TS 3.8L Misfire REVERSE ONLY
  102. Testing Coolant level sensor
  103. 95 Starts and Dies
  104. Engine "shaking" resolved
  105. Left Exhaust Manifold TS 95
  106. Anyone use this Scanner?
  107. 1994 Transport Vacuum leak fix?
  108. Intermittent Erratic engine "shaking"
  109. TCC/Cruise riddle?
  110. Cooling fans
  111. Grille question
  112. 1995 Transport 3.8 Fuel Pump Relay Location
  113. 3.1 emission vac line routing
  114. Trans Rebuild Update 3.8 1995
  115. Trans Rebuild Back
  116. Transmission ?
  117. transmission oil line leak
  118. Turn signal snap back broken
  119. Wife=van won't drive forward
  120. A/C compressor replacement
  121. Needle bearing in oil pan
  122. Gear selector error and other ECU mysteries
  123. Electronic Level Control
  124. Auction's site ignition modules?
  125. 3.8 supercharged motor?
  126. ac problem
  127. Oil Pan Removal-95 Pontiac Transport
  128. Head Gasket?
  129. 95 3800 Jerks Left shifting into third?
  130. Rear Wiper (Lack of) Performance
  131. hey LMP got a question
  132. How long do you intend to keep your Trans Sport?
  133. Very Hard Starting Hot
  134. Buying a 3.8 Trans Sport
  135. want a radiator fan switch on inside
  136. 93 Transsport 3.1L -Won't Start
  137. High Idle
  138. Intake gasket replacement
  139. valve seals on 3.1
  140. OBD II codes
  141. help, chassis number
  142. Vibration when driving straight
  143. Won't go to overdrive (4th gear)
  144. small collant leak
  145. Part 2:Changed my alternator, won't shift outta 1st
  146. transmission not engaging guys i need your help
  147. [95 t-s, 3.2]Changed my alternator, lost my speedometer...
  148. '94 TS: transmission grinding in Park
  149. Oil Leak Repair
  150. Replacing door mirror cover
  151. 1998 Transport Brake Light Melting
  152. 2000 venture 3.4 engine in a 96?
  153. 1994 Transport - Having Acceleration Issues
  154. 1992 transport no spark
  155. Emissions test tune-up
  156. AutoGas (LPG) is it worth it?
  157. Wiper Arms
  158. 98 Transport trouble starting
  159. 1995 Trans port not shifting into OD
  160. 97 trans sport idle, but won't run
  161. 94 trans sport no shifting out of 1st
  162. ac control bulb
  163. transport 93 no spark
  164. 1993 pont,transport
  165. Trouble Code
  166. 98 ABS light trouble
  167. Electronic Readout on Ceiling Interior
  168. Van shudders
  169. TranSport Computer
  170. Fuel Injectors and Spark Plugs for breakfast
  171. Front Blower doesnt work
  172. tranny install
  173. 1998 Transport Humming
  174. going to try out 96 transport anything i need to look for than the usual?
  175. trans sport keyless entry
  176. 94 trans sport SE
  177. '94 TS 3800: RPM Question
  178. transports going to the scrap yard
  179. 98 Stalls in driveway on start up
  180. '94 3800: dies while driving...
  181. '94 Pontiac Trans Sport SE 3800 3.8L - Questions
  182. Aw crap...blew my transmission...(95 Trans Sport)
  183. '95 overhead console: orphaned cables
  184. '94 3800: OBD what?
  185. Pontiac trans sport 92. 3,8 code44
  186. 1990 TBI, Starts but dies immediatly. Sparks & FP runs but inj. pulse stops?
  187. Rear Control Arm Bushing Size
  188. 99 Transport Trans Noise
  189. Power Door Locks Fuse
  190. '95 3.8L Primary/Sec Resistance for Ignition Coil
  191. Metal intake plenum for 3800
  192. tranny took a dump
  193. My 3.8 is very fast
  194. Sensor middle top of windshield?
  195. Rack and pinion point of failure
  196. 94 Trans Sport-No voltage at fuel pump relay input
  197. new to these trans sports, relay question
  198. 2 3.1 Pontiacs, different electrical behaviour
  199. '94 TS 3800: HUGE coolant leak - and other fluids
  200. 1998 Trans Sport engine misses under load
  201. 95 Transport Charging system
  202. Greetings to you from Russia!
  203. 1997 TP 3.4 L Odor of anti-freeze
  204. 97 transport rough idle dies when warm
  205. 1998 Pontiac Transport 3.4 Driving like poo DTC codes!
  206. 95 Transport: Did the mechanic shaft me?
  207. headlights on when not running/ stoplight lenses melting
  208. Transmission oil in radiator:better watch for it
  209. 93 Trans Sports looking for good home
  210. 1995 Transport Lives on... 3800 III Transplant
  211. 95 TS 3.8 CEL on - codes P341-P321-P123
  212. Transport stalls when decelerating at slow speeds
  213. 1994 Pontiac transport back hatch metal top cover rusted
  214. 1997 TRANSPORT Surging
  215. 98 Transport - Overheating
  216. Fans in front
  217. Summer is still here and it's hot in the car.
  218. Do front 98 struts fit a 96?
  219. The Winter is coming and I don't have heating
  220. 95 Transport 3800 NO HEAT- how to flush system?
  221. ABS light on C1242 code... what gives?
  222. Cruise COntrol gets a new life
  223. Crankshaft Pulley/Damper
  224. Amazing MPG :D
  225. '95 3.8-Location of Neutral Start Switch?
  226. Driver's door lock
  227. 1990 3.1 Trans Sport Overheating
  228. 97 transport high rpms problem
  229. Po 366 which one?
  230. Cash for Clunkers: What should I save before turning in the Transport?
  231. Engine trouble
  232. 97 Pontiac Trans Sport Oil Pressure light
  233. Oil Pressure Gage Spikes when gas peddle is pushed
  234. Component Location Diagram
  235. 92 Trans Sport 3.1L v6
  236. Car Jerks in Cruising Gear
  237. Pcm
  238. 94 transport speakers
  239. Auto Lever PSI?
  240. Rack and pinion revisited
  241. 94 transport air pump
  242. brake problem 98 transport
  243. 96 Transport tranny problem
  244. 3800 TPS Stumps Local Repair Shop
  245. Trans Sport / Grand Am engine sparkplugs?
  246. Reversing the middle seatrow
  247. Engine Rattles when AC Engages
  248. 92 Dead Pontiac Trans Sport SE
  249. Overheating 98 Trans Sport
  250. GM Fuel Filter disconnect fitting
