View Full Version : Trans Sport
Pages : 1 2 3 4 5 [6] 7 8
  1. 98 Trans Sport... No rear heat !!!
  2. 98 Trans Sport headlight switch problems!!??
  3. Cheap Fix for TCC/4th Gear Problem
  4. 93 Trans Sport 3800 won't start
  5. 95 Tsp stalling
  6. My awesome luck
  7. Front end clunk, $300.00 in parts later
  8. Trans Sport Reverse Gear Malfunctioning
  9. 96 transport fuel pump relay chattering/no start
  10. Fuse chart? Inj 7.5 fuse?
  11. Wipers keep getting stuck in up position!
  12. Heater not working
  13. Torque steer
  14. Torque steer
  15. Transmission bang and shake
  16. 93 Trans Sport Transmission
  17. Power Window
  18. What's up with these dash boards?
  19. Rear Heater Relay Location?
  20. Oil Pressure
  21. Rear noise while vehicle parked
  22. 94 Transport 3800 idle miss, no take off
  23. Heater fuse keeps blowing.
  24. New battery and Alternator still No Charge
  25. OEM Wheel interchange list
  26. Oil Light
  27. 1998 Pontiac Transport Power Sliding Door
  28. Throttle Body Tapping Noise
  29. 1995 TS Won't Start
  30. 1995 Trans Sport 3.8 problems
  31. transport won't start
  32. fuell filter location
  33. 1998 heating problems
  34. Has anyone ever modified one of these?
  35. front mount removal on 3.1
  36. 96 transport 3.4 no start
  37. Pontiac parts
  38. 95 trans sport heater core
  39. Tachometer is "twitching"
  40. Bypass A/C compressor on 3.1 litre
  41. 1995 3.8 stalling out when stopped
  42. Engine - inconsistant rattle at idle
  43. Retrofitting 2000 radio into a 98
  44. front suspention
  45. How to remove spare tire?
  46. 1994 transport 3.1 NO START, NO SPARK, NO FUEL HELPP!!!!
  47. EGR valve Standard Motors
  48. 94 Bonneville Tranny
  49. A/C fan high speed
  50. not for the faint of heart
  51. Would someone have
  52. 94 transport 3.1 no start no power to fuel injectors
  53. Engine rattle
  54. 3800 Spark plug wires
  55. 94 TransSport Pass. Power window problem
  56. wiring diagram for tow bar/tow hitch pont transsport 91
  57. Radio Problem
  58. 1995 Trans Sport transmission problem
  59. Pontiac Trans Sport '98 engine "surge/hesitation"
  60. Looking for Tail light surround
  61. Front wheel Bearings - how hard are they to replace ('95 w/3800)???
  62. 94 Transport 3800 problems
  63. Trans Sport 93 a/c-heater fan won't work
  64. mountain
  65. low voltage - engine missing at 65 mph
  66. 90 Transport SE-Speedometer and RPM
  67. 99 TS AC condensation water under right carpet
  68. Fuel Pressure
  69. How do you open hood when cable broke
  70. 1990 Transport
  71. Fuel tank vacuum??
  72. 94 Trans Sport losing power intermittently
  73. 96 transport BASIC ENGINE REBUILD FRUSTRATIONS!!!
  74. Installing A Tow Hitch 95 Trans
  75. Newbie in UK !!. Plus 3800 oil pressure problems.
  76. Outdoor Temp Display not working properly
  77. 97 Trans Sport How To Take Out Air Bag ??
  78. '98 transport squeeking
  79. 95 Transport Window issue
  80. Carpet Change In A 97 Trans Sport ?
  81. Oil pressure gauge not working
  82. Any Crankshaft Techs out there?
  83. Finally
  84. How does a 95 3.8L know that the EGR is inop? Help settle a bet.....
  85. temp gauge wont work
  86. 95 running rough
  87. 1990 Pontiac Transport
  88. 94 Transport Will not start
  89. Oil Pressure gauge low = knocking sound?
  90. I changed coils,module wires and plugs,,still misfires.
  91. I changed the Plugs and wires but still not right
  92. 95 Trans Sport motor locked up
  93. 95 Trans Sport,lunging and missing
  94. 95 Transport Power Window Problem
  95. Towing with a 95 trans sport
  96. High Idle condition
  97. Air conditioning not working
  98. severe front-end vibration
  99. transmission shift problem, no cruise
  100. 97 pontiac trans port roof rack repair
  101. temp guage not working
  102. Heater vent change
  103. Blue Exhaust on starting
  104. 96 transport Computer
  105. 1994 transport
  106. 94 Courtesy Fuse keeps blowing
  107. Help motor problems
  108. Cooling engine?
  109. '92 Transport egr valve
  110. relay switches
  111. wipers
  112. wipers
  113. 97 Trans Sport Head Removal ! Need Help !
  114. 94 Transport Alt not charging battery
  115. Starter problems on 97 Pontiac Trans Sport
  116. Browse through '93 scans
  117. power window not working
  118. codes 34 & 21
  119. 95 Anti lock working?
  120. ?? Difficulty Level of Replacing Ball Joint? '95 Transport
  121. 95 Trans sport 3 speed tranny slipping?
  122. 1997 transport "low coolant" and "oil pressure warning light"
  123. 97 pontiac transport starts then dies
  124. Interchange 95 Transport Cd/radio ? Anyone
  125. 94 transport unable to retrive codes
  126. 1995 Trans Sport 3.8 Water Pump Replacement
  127. computer codes
  128. 94 Transport Stalling
  129. AC Compressor replacement (which parts?)
  130. 1990 trans sport- help please
  131. 3800 PCV Valve location? ('95)
  132. TCS won't disable
  133. a/c break down
  134. 95 with 3800 lacks power on highway with A/C on
  135. Rear Hatch Fuse
  136. 1997 TransSport PCM Failure
  137. Radio has poor reception
  138. P0420 OBD Trouble Code
  139. what motor should I use.
  140. radiator fan motor burned up
  141. no exhaust gasket
  142. power window dead
  143. Rear Door Assembly
  144. Short of some sort - killing battery
  145. questions about starter replacement
  146. code 13?
  147. Problems Trans Port 1995...
  148. 1994 TRANS SPORT 17" RIM INSTALL
  149. Strange electrical problems
  150. 1995 3.8L AC compressor
  151. a/c fan motor don't run
  152. Pictures of amplifier install, MP3 and speakers
  153. Transport TH125 transmission
  154. 94 Transport Power Sliding Door
  155. 1995 Trans Sport rpm problem
  156. Where is the neutral switch?? 1994 3.1
  157. 1990 strange electrical problem
  158. what options?
  159. Turn signal drains a lot of energy
  160. Gas smell inside after fill-up
  161. Washer Pulse Board
  162. BCM program fuse question
  163. Power Door Locks
  164. 1997 Transport stalled, restarts with very rough idle
  165. EGR / MAF Help
  166. Broken Camshaft?
  167. 98 TransPort ABS light lit when driving
  168. Van won't start nor charge
  169. the engine runs but nothing else works!!
  170. replacing 3.1 to 3.8 ?
  171. Turn Signal Failing- Pontiac TransSport 3.1L VinD
  172. Stalling problem-could be from TCC?
  173. In stead of many treads
  174. oil pressure
  175. don't start when hot
  176. 1990 Trans Sport Speedometer reading high
  177. my 93 van 3.8 stalls
  178. Daytime light
  179. Front A/C BLower Control Malfunctioning
  180. Best place to by EGR Valve online?
  181. Chip tuned ???
  182. Bulb name
  183. Dome Gasket Shot?? Whats is a DOME GASKET???
  184. Cargo space in a TS -92
  185. TransSport 1996 3.4 pour running
  186. 95 Transsport won't shift into 4th gear after trans. hot!?!
  187. oil pressure indicator
  188. 1990 STILL dying (LMP) help !
  189. No oil pressure!
  190. Svenskt TS forum
  191. 1998 transport won't idle and stalls
  192. adding a power sliding door??
  193. Sweden calling
  194. 95 Factory Cd/radio
  195. ABS on TP -92
  196. Turn signal lever wont return
  197. speaker size ?
  198. fuel pump
  199. 94 Transport driver power window problem
  200. Stalling on turn
  201. OBDII Terminal Location (1997 Trans Sport)
  202. wont start, need help
  203. gaskets
  204. questions now that i fixed the fuel pump
  205. Towing
  206. overhead console temperature display light
  207. 1990 Transport Power Window Problem
  208. LMP: Which blower motor for my 1990?
  209. what could cause rough idle?
  210. 92 3.8 L EGR valve location
  211. hesitating- as if misfire, after running empty
  212. 92 stalling from erratic idle and at highway speeds
  213. 98 Trans Sport stalled on highway - now backfires
  214. battery/charging/cranking problems
  215. 1997 Transport Power window regulator
  216. oil pressure sensor
  217. help with low traction light
  218. front lights
  219. Gauge lights on steering wheel
  220. adding auto dim rearview mirror
  221. Clean cabin air
  222. 1995 Transport CD players
  223. 95 transport 3.8-egr valve???
  224. transmission problem
  225. Passenger window not working..
  226. Transport dies and won't start for 15 mins
  227. Hi, Just got a 1995 TransSport
  228. ODD PROBLEM - please help - clueless!!!
  229. Hard shift 1st to 2nd gear
  230. 93 transport-no start-but cranks
  231. 98 Trans Sport gauges
  232. LPG Conversion
  233. 95 Transport - dim lights/no power/speedo and tach not working?
  234. Tensioner pulley cutting into engine block - CAUTION
  235. sliding door replacement?
  236. 94 Trans Sport Power sliding door module
  237. 1994 Pontiac Transport *( ABS/ TCS lights are ON )*
  238. pwr locks/int lights/radio/pwr seats
  239. idle speed
  240. 94 TransSport Starting Problem
  241. 94 Transport wiring diagram
  242. 93 transport eratic idle
  243. 94 Steering Wheel Controls NOT working?
  244. 95 Transport 3.8 Overdrive TCC Sensor problem(s)
  245. 95 Transport
  246. missing @ highway speed
  247. OBD/REadiness Driving Procedures
  248. engine braking
  249. 3.1 versus 3.8 engine
  250. What is this part under the car?
