View Full Version : Trans Sport
Pages : 1 2 3 4 5 [6] 7
  1. SLOW!!! to warm up
  2. Fixing my intake manifold coolant leak and need a quick answer..
  3. the song of the injectors
  4. 93 transport(3800) randomly won't start.
  5. code problems
  6. steering wheel radio controls swap
  7. programming keyless entry fob
  8. Radio does not turn off. Relation with electrical locks ?
  9. Engine stops when shifting into R
  10. Another Heating Question...
  11. trans sport outer door handle replacement.. help!!!
  12. Rear noise driver side96 Transport
  13. ABS TCS lights on
  14. Help!!!!! P1640, P1670
  15. 92 3.8 SE pulling right under accelleration, then left if I lift off..
  16. Transport 98 radio theftlock system
  17. Changing the Valve Cover Gasket!!
  18. Replacing valve cover gasket
  19. Transmission Hard shift Chevy Transsport Bj99
  20. Blowing Fuse (Mall/Radio/DIC)
  21. Fuel Presure Switch Location
  22. transport 3.8 1995
  23. 1998 ABS System
  24. 1998 Sales Brochure
  25. 1997 Tran Sport Montana poor heat
  26. Low coolant light and no heat related?
  27. Tcc
  28. Code PO449
  29. '97 Trans Sport--Fuel Problem? ECM?
  30. Help--Oil Leak!!
  31. 97 Transport starts then won't start
  32. heating problem
  33. Mileage has tanked - Oxygen Sensor ?
  34. Front AC Problem / Rear AC OK
  35. ehaust leak.. very loud!!!!help!!!
  36. trans sport wheels
  37. 98 Trans Sport/Montana - no start
  38. HVAC not blowing through dash
  39. Where is the OIL SENDING SWITCH??
  40. ABS acting up, 1992 Transport SE 3.8l
  41. blower function ok except for fastest (4)
  42. 1993 Pontiac Transport Transmission Problems
  43. 1997 transmission shift point
  44. '96 Transport AC Fan Quiting Intermitently
  45. transport 98
  46. 95 transport air pump?
  47. changing trans fluid, how much?
  48. HELP!! P0171 & P0300 codes
  49. 1993 3.1L V6 Firing Order
  50. A/C bypass on 94 3.8 trans sport
  51. Anyone have diagram of spark plug wires diagram for 98 transport?
  52. EGR Valve - 3.1 engine
  53. 1995 3.8L runing rough, stalling, shuttering
  54. tift deterrent relay 2000
  55. radiator cap hissing
  56. 97 Trans Sport Rear Power Window Intermittent Operation
  57. 97 Pont. Transport after frozen windshield wipers
  58. 1998 Transport power rear windows
  59. 1998 Transport Thermostat
  60. 1998 transmission unavailable?
  61. 1990 - No air (hot nor cold) coming out of vents
  62. 95 Trans sport new owner
  63. rear wiper doesn't work
  64. Where is the O2 sensor located on a '93 3800??
  65. 94 Pontiac TransSport won't crank fire up
  66. serpentine belt slip
  67. crankshaft pulley change
  68. Odd electrical problem
  69. automatic shifter won't engage
  70. Very Strange Electrical Problems.. Need Help Please!!
  71. HELP!!! 1995 electrical problems???
  72. Radio Backlight
  73. Heat gauge
  74. Automatic Door Cable!
  75. back hatch lock
  76. Pontiac Transport Electric Door Locks
  77. No HEAT and LOW engine temp solved!!!
  78. 1998 Pontiac Transport Drives Sluggish
  79. Tie - Rod End
  80. Low Engine Temp Since Cold Weather?
  81. 1997 transmission problem
  82. Power Window Dilemma
  83. 1994 3.8L Trnasport Tranny problem
  84. 1998 Transport NO HEAT!
  85. blower motor finally went
  86. GoPed Vs TransAm!!!
  87. bug shield
  88. 1992 transport won't start
  89. 94 Trans Sport and Bonneville tranny
  90. !993 Chevrolet Lumina APV occasionally no spark to start
  91. Rear door handle?
  92. Electrical heater
  93. wtb remote p/n 10202295
  94. 1994, 3.8, No Power
  95. Rather Urgent Headlight & Brake Problem
  96. 1992 Trans Sport Remote Progamming ?
  97. Stud length with new rotors 1995 Trans Sport
  98. snaping in front
  99. wheel interchange
  100. 1993 Trans Sport
  101. pink,red antifreeze and problems
  102. Van starts and then bogs down and dies after 5 to 10 seconds.
  103. HVAC Fan
  104. Timing
  105. rpm fluctuation at highway speeds
  106. 94 Transport ....no fuel
  107. no spark after fuel pump replaced
  108. AIr lock: just for the record
  109. Clear Service oil Light
  110. passenger side noise????
  111. over heating problems
  112. Heat Gauge
  113. 1995 Trans Sport rear bike tire air pump
  114. where is thermostat located
  115. Front Ball Joints/Tie Rod Ends 1995 Trans Sport
  116. Twisty, Lazy Seat Belts on my 1995 Trans Sport
  117. 1995 Transport: Exterior Door Handles?
  118. 95 Transport: Front Door Panel Removal?
  119. Oil in radiator and overflow bottle
  120. Air Bag indicator
  121. Transmission Hard Shifts
  122. head lights
  123. 1997 Lack of sufficient heat not due to thermostat
  124. where to buy an automatic transaxle
  125. Starting Problem
  126. power sliding door-diagram
  127. 1995 trans poart wiring diadram
  128. Compression
  129. rear/mid section clanking over bumps
  130. 1995 3.8 Crankshaft Position Sensor Replacement
  131. 1996 trans sport transmission swap
  132. My 1995 Pontiac Transport
  133. Hesitation
  134. Diagrams available
  135. 3.4L van intermittent no-startproblem/fuel pump relay chattering
  136. 1995 Transport Problems
  137. wirning diagram tp-sensor and egr-valve
  138. Wiring diagrams
  139. ECM-Problem (OVERDRIVE)
  140. 1995 Radio
  141. OBD Codes
  142. How to find the remote RECEIVER in a 1995 Trans Sport?
  143. transmision
  144. Hello all 1995 Transport issues
  145. 98 Transport - Doors do not lock (but unlock OK)
  146. 97 Transport cooling fans
  147. Update on "front end syndrome"
  148. automatic locks???
  149. 98 Transport "service engine" light
  150. Transmission problems
  151. Insane Lights on Transport
  152. 35mph-40mph not change 2-3 overdrive automatic-transaxle
  153. 1990 transmission
  154. Antifreeze going down ever so slowly
  155. Blue Smoke From The Exhaust TRANSSPORT3,8L-95
  156. hight hco and co in the gases 3,8l tpi engine
  157. What does code 53 mean???
  158. Wheel Hub Rip Off
  159. 1993 Pontiac Transport Wiring Diagram
  160. Fuse Constantly Blowing
  161. Bad vibration in puller fan
  162. 95 Transport Frt Rotors
  163. Radiator Fan Switch??
  164. 1993 headlights any different for the European model?
  165. 95 3.1 wont stay running timing?
  166. Slight "clunking" in the front end?
  167. 3.8 Transport is bucking and missing real bad from about 40-60 MPH.
  168. Buzzing Vibration at 2000-2500 RPM
  169. Need help for 3.1 engine
  170. 1993 3.1
  171. Front end syndrome
  172. 98 Trans Sport Window Regulator
  173. Best Place to Buy Hubcaps??
  174. OPINIONS on Rotors and PADS?
  175. HELP - Where can I order parts for my Trans Sport 2.3 ?
  176. weird OverHead Problem ! HELP Pls. !
  177. 1st mod thing
  178. 1995 Trans Sport Front End Noise
  179. Need Electrical Connector for Brake Light Assembly
  180. HOw to fix low fuel light?
  181. 95 Trans Sport Spark Plugs
  182. Speedometer reading too fast
  183. 1998 transport driveline noise
  184. 1995 Transport 3800 shutters sparaticlly
  185. Tire advice
  186. Low Coolant Light flashes
  187. Trans Sport 3800 1995 oil filter location?
  188. Reading trouble codes
  189. How to fix the 1996 Pontiac Trans Sport Power Sliding Door
  190. Cranking problems on 95 3.1 TS
  191. Stalling and Engine Light
  192. 2 button remote wanted
  193. intermittent window problem??
  194. Adjusting HEadlights at home
  195. Broke Rocker Arm Bolt During Gasket Replacement
  196. 98 transport cd player error
  197. How many have had their Trans Sports stolen?
  198. Steering column guard for a 1995 Pontiac Trans Sport?
  199. Door handle broke
  200. Turing over problems
  201. 1994 Transsport HELP!
  202. Yet another keyless entry question
  203. Greetings from German Pontiac Forum
  204. Imaginary rumble strips???
  205. Transmission Problems
  206. Difference between a '94 and '95 steering column? Steering column guard..
  207. service lights on???
  208. speakers in dash
  209. fuse problem
  210. Passenger window won't move???
  211. Low compression in 1 cylinder
  212. Overheating at idle 90% of time
  213. Changing drive belt
  214. Olds vs Pontiac same,but different
  215. 2.3i16v or 3.1 engine is better?
  216. ABS Codes
  217. Battery won't charge
  218. wacky wiper syndrom w/wacky AC too!
  219. Rear Turn Signal light
  220. 94 Transport 3.8L EGR Valve
  221. 1994 Pontiac Trans Sport
  222. Windshield washer fluid
  223. Brake light.
  224. What happens if i change from 3t40 to 4t60e
  225. A/C Panel dimming light
  226. QDM "A" code 26 what is this???
  227. Noise when blower motor is on
  228. BCM Programing...'99 Transport
  229. AC leak
  230. Interior Light Dimmer
  231. 91 Transport engine dies after warming up
  232. Front end growl
  233. smoothie steel rims w half moons
  234. New to me 95 Trans Sport High Temp
  235. electrical problem need help
  236. Engine overheats
  237. Transmission problem
  238. Pontiac Transport 94
  239. 96 Pont Transport headlight assembly and fog light
  240. oil pressure gauge shakes
  241. pontiac transport battery drain
  242. 95 Transport Seats
  243. Keyless remote
  244. Dash problems
  245. 96 Transmission shudder.
  246. 97 Transport: Transmission (P1870) Problems
  247. Trans Sport Engine Missing(i Already Checked Under The Hood)
  248. 1997 Pontiac Trans Sport *** POSSESSED! ***
  249. 94 lumina apv wipers grrrrrr
  250. 97 Bonneville stall,low idle,irrattic idle
