View Full Version : Trans Sport
Pages : 1 2 3 4 [5] 6 7
  1. Fuse chart? Inj 7.5 fuse?
  2. Wipers keep getting stuck in up position!
  3. Heater not working
  4. Torque steer
  5. Torque steer
  6. Transmission bang and shake
  7. 93 Trans Sport Transmission
  8. Power Window
  9. What's up with these dash boards?
  10. Rear Heater Relay Location?
  11. Oil Pressure
  12. Rear noise while vehicle parked
  13. 94 Transport 3800 idle miss, no take off
  14. Heater fuse keeps blowing.
  15. New battery and Alternator still No Charge
  16. OEM Wheel interchange list
  17. Oil Light
  18. 1998 Pontiac Transport Power Sliding Door
  19. Throttle Body Tapping Noise
  20. 1995 TS Won't Start
  21. 1995 Trans Sport 3.8 problems
  22. transport won't start
  23. fuell filter location
  24. 1998 heating problems
  25. Has anyone ever modified one of these?
  26. front mount removal on 3.1
  27. 96 transport 3.4 no start
  28. Pontiac parts
  29. 95 trans sport heater core
  30. Tachometer is "twitching"
  31. Bypass A/C compressor on 3.1 litre
  32. 1995 3.8 stalling out when stopped
  33. Engine - inconsistant rattle at idle
  34. Retrofitting 2000 radio into a 98
  35. front suspention
  36. How to remove spare tire?
  37. 1994 transport 3.1 NO START, NO SPARK, NO FUEL HELPP!!!!
  38. EGR valve Standard Motors
  39. 94 Bonneville Tranny
  40. A/C fan high speed
  41. not for the faint of heart
  42. Would someone have
  43. 94 transport 3.1 no start no power to fuel injectors
  44. Engine rattle
  45. 3800 Spark plug wires
  46. 94 TransSport Pass. Power window problem
  47. wiring diagram for tow bar/tow hitch pont transsport 91
  48. Radio Problem
  49. 1995 Trans Sport transmission problem
  50. Pontiac Trans Sport '98 engine "surge/hesitation"
  51. Looking for Tail light surround
  52. Front wheel Bearings - how hard are they to replace ('95 w/3800)???
  53. 94 Transport 3800 problems
  54. Trans Sport 93 a/c-heater fan won't work
  55. mountain
  56. low voltage - engine missing at 65 mph
  57. 90 Transport SE-Speedometer and RPM
  58. 99 TS AC condensation water under right carpet
  59. Fuel Pressure
  60. How do you open hood when cable broke
  61. 1990 Transport
  62. Fuel tank vacuum??
  63. 94 Trans Sport losing power intermittently
  64. 96 transport BASIC ENGINE REBUILD FRUSTRATIONS!!!
  65. Installing A Tow Hitch 95 Trans
  66. Newbie in UK !!. Plus 3800 oil pressure problems.
  67. Outdoor Temp Display not working properly
  68. 97 Trans Sport How To Take Out Air Bag ??
  69. '98 transport squeeking
  70. 95 Transport Window issue
  71. Carpet Change In A 97 Trans Sport ?
  72. Oil pressure gauge not working
  73. Any Crankshaft Techs out there?
  74. Finally
  75. How does a 95 3.8L know that the EGR is inop? Help settle a bet.....
  76. temp gauge wont work
  77. 95 running rough
  78. 1990 Pontiac Transport
  79. 94 Transport Will not start
  80. Oil Pressure gauge low = knocking sound?
  81. I changed coils,module wires and plugs,,still misfires.
  82. I changed the Plugs and wires but still not right
  83. 95 Trans Sport motor locked up
  84. 95 Trans Sport,lunging and missing
  85. 95 Transport Power Window Problem
  86. Towing with a 95 trans sport
  87. High Idle condition
  88. Air conditioning not working
  89. severe front-end vibration
  90. transmission shift problem, no cruise
  91. 97 pontiac trans port roof rack repair
  92. temp guage not working
  93. Heater vent change
  94. Blue Exhaust on starting
  95. 96 transport Computer
  96. 1994 transport
  97. 94 Courtesy Fuse keeps blowing
  98. Help motor problems
  99. Cooling engine?
  100. '92 Transport egr valve
  101. relay switches
  102. wipers
  103. wipers
  104. 97 Trans Sport Head Removal ! Need Help !
  105. 94 Transport Alt not charging battery
  106. Starter problems on 97 Pontiac Trans Sport
  107. Browse through '93 scans
  108. power window not working
  109. codes 34 & 21
  110. 95 Anti lock working?
  111. ?? Difficulty Level of Replacing Ball Joint? '95 Transport
  112. 95 Trans sport 3 speed tranny slipping?
  113. 1997 transport "low coolant" and "oil pressure warning light"
  114. 97 pontiac transport starts then dies
  115. Interchange 95 Transport Cd/radio ? Anyone
  116. 94 transport unable to retrive codes
  117. 1995 Trans Sport 3.8 Water Pump Replacement
  118. computer codes
  119. 94 Transport Stalling
  120. AC Compressor replacement (which parts?)
  121. 1990 trans sport- help please
  122. 3800 PCV Valve location? ('95)
  123. TCS won't disable
  124. a/c break down
  125. 95 with 3800 lacks power on highway with A/C on
  126. Rear Hatch Fuse
  127. 1997 TransSport PCM Failure
  128. Radio has poor reception
  129. P0420 OBD Trouble Code
  130. what motor should I use.
  131. radiator fan motor burned up
  132. no exhaust gasket
  133. power window dead
  134. Rear Door Assembly
  135. Short of some sort - killing battery
  136. questions about starter replacement
  137. code 13?
  138. Problems Trans Port 1995...
  139. 1994 TRANS SPORT 17" RIM INSTALL
  140. Strange electrical problems
  141. 1995 3.8L AC compressor
  142. a/c fan motor don't run
  143. Pictures of amplifier install, MP3 and speakers
  144. Transport TH125 transmission
  145. 94 Transport Power Sliding Door
  146. 1995 Trans Sport rpm problem
  147. Where is the neutral switch?? 1994 3.1
  148. 1990 strange electrical problem
  149. what options?
  150. Turn signal drains a lot of energy
  151. Gas smell inside after fill-up
  152. Washer Pulse Board
  153. BCM program fuse question
  154. Power Door Locks
  155. 1997 Transport stalled, restarts with very rough idle
  156. EGR / MAF Help
  157. Broken Camshaft?
  158. 98 TransPort ABS light lit when driving
  159. Van won't start nor charge
  160. the engine runs but nothing else works!!
  161. replacing 3.1 to 3.8 ?
  162. Turn Signal Failing- Pontiac TransSport 3.1L VinD
  163. Stalling problem-could be from TCC?
  164. In stead of many treads
  165. oil pressure
  166. don't start when hot
  167. 1990 Trans Sport Speedometer reading high
  168. my 93 van 3.8 stalls
  169. Daytime light
  170. Front A/C BLower Control Malfunctioning
  171. Best place to by EGR Valve online?
  172. Chip tuned ???
  173. Bulb name
  174. Dome Gasket Shot?? Whats is a DOME GASKET???
  175. Cargo space in a TS -92
  176. TransSport 1996 3.4 pour running
  177. 95 Transsport won't shift into 4th gear after trans. hot!?!
  178. oil pressure indicator
  179. 1990 STILL dying (LMP) help !
  180. No oil pressure!
  181. Svenskt TS forum
  182. 1998 transport won't idle and stalls
  183. adding a power sliding door??
  184. Sweden calling
  185. 95 Factory Cd/radio
  186. ABS on TP -92
  187. Turn signal lever wont return
  188. speaker size ?
  189. fuel pump
  190. 94 Transport driver power window problem
  191. Stalling on turn
  192. OBDII Terminal Location (1997 Trans Sport)
  193. wont start, need help
  194. gaskets
  195. questions now that i fixed the fuel pump
  196. Towing
  197. overhead console temperature display light
  198. 1990 Transport Power Window Problem
  199. LMP: Which blower motor for my 1990?
  200. what could cause rough idle?
  201. 92 3.8 L EGR valve location
  202. hesitating- as if misfire, after running empty
  203. 92 stalling from erratic idle and at highway speeds
  204. 98 Trans Sport stalled on highway - now backfires
  205. battery/charging/cranking problems
  206. 1997 Transport Power window regulator
  207. oil pressure sensor
  208. help with low traction light
  209. front lights
  210. Gauge lights on steering wheel
  211. adding auto dim rearview mirror
  212. Clean cabin air
  213. 1995 Transport CD players
  214. 95 transport 3.8-egr valve???
  215. transmission problem
  216. Passenger window not working..
  217. Transport dies and won't start for 15 mins
  218. Hi, Just got a 1995 TransSport
  219. ODD PROBLEM - please help - clueless!!!
  220. Hard shift 1st to 2nd gear
  221. 93 transport-no start-but cranks
  222. 98 Trans Sport gauges
  223. LPG Conversion
  224. 95 Transport - dim lights/no power/speedo and tach not working?
  225. Tensioner pulley cutting into engine block - CAUTION
  226. sliding door replacement?
  227. 94 Trans Sport Power sliding door module
  228. 1994 Pontiac Transport *( ABS/ TCS lights are ON )*
  229. pwr locks/int lights/radio/pwr seats
  230. idle speed
  231. 94 TransSport Starting Problem
  232. 94 Transport wiring diagram
  233. 93 transport eratic idle
  234. 94 Steering Wheel Controls NOT working?
  235. 95 Transport 3.8 Overdrive TCC Sensor problem(s)
  236. 95 Transport
  237. missing @ highway speed
  238. OBD/REadiness Driving Procedures
  239. engine braking
  240. 3.1 versus 3.8 engine
  241. What is this part under the car?
  242. '94 blower motor, bolt on vs press on?
  243. Diagnostic With Obd1: Print That Page
  244. Replacing Heater Core
  245. Transmission - Please Help
  246. 94 transport burns a lot of gas
  247. Keyless Entry Remote Programming for 94-96 Trans Sport?
  248. intake manifold removal, fuel injectors and torque
  249. Another question regarding poor heat - aux water pump
  250. how many codes
