View Full Version : Trans Sport
- Converting from power to manual windows?
- 97' A/C Question
- 97 3.4l Underhood fuse # 28 blowing.
- 3.1 Engine - Slight Oil Leak
- More GM Madne$$...
- 1996 transport problem codes
- 94 Trans sport 1200 rpm max engine speed
- Tock
- Tock!
- 98 TranSport (Chevrolet); Engine interruptions at 60 miles
- What should i do
- 94 3.1L A/C Compressor Frozen?
- 97 Trans Sport A/C Compressor Line Seals?
- no power
- 1994 Transport Disengaes out of OD
- 1997 no start
- 93 Trans Sport SE 3800 with LPG for sale in UK
- dim headlights
- Transport 3.1 leaking sump pan.
- Battery loosing charge?
- 1991 worse after changing plugs and wires.
- Interior lights and rear heater blower?
- Heater Hoses & Neutral Safety Switch
- Changing idle speed
- Changing Rear Brakes-1995
- 93 TS 3800: Gear position indicator adjustment ?
- Wtf
- How to remove transmission 4t60e pontiac
- Finally it happened to me: '93 will not start
- electrical diagram for radiator front fan
- SES light when gas tank gets empty
- 94 Trans Sport unknown coolant leak
- Code P1870
- what plugs for 95 3.1???
- 97 Trans Sport, Different Wiper Problem..
- 95 Transport 3800 Starts Cold Not Warm
- still having problems with fuel pump
- Parts
- Help! Transmission fluid leak!
- Transmission problem?
- trouble code P1665
- 95 TransAm Won't Start, mechanic at a loss
- 95 Transport - "QDM Failure" + AC blows warm related? Where is this QDM?
- 95 pontiac transport miss fire under load
- 95 Transport 3.8 cranks no start
- wiring
- 97 Transport code P0756
- Code P0172 (Bank 1)
- 93 Trans Sport 3800. Surges under full power.
- -94 Trans Sport ABS problem
- Little thing are happening
- i changed the 92 transsport tcc solenoid
- 1993 transport fuel pump-no power
- Auto Level Control Solenoid Valve... HELP
- replacement of front/side turn signal lights (1993)
- 93 speedo sits at 140 miles per hour
- 95 transport shudder
- 97 Trans Sport, BCM Location???????
- Air Ride Suspension, Help Needed!!
- 93 PONTIAc with ALOT of problems
- man
- 98 Transport water leak
- 1996 Transport - inner tie rod ends, transmission filter change
- AC Condenser Fan
- 97 Trans Sport Puzzling PSD problem!
- 95' Transport keeps blowing the ECM Fuse
- 1st post---any info appreciated
- 1993 3.8L low oil pressure at 900-1000 rpm
- a/c condenser fan relay
- Windshield wipers?
- 93 trans sport code 34 problem
- Help TRANS SPORT With Loud Fuel Pump
- 92 Transport 3.8l Engine Shudder
- fan not working on notch 1 or 2
- Drop Diode for DRL
- 3800 TPI, TPS sensor adjustment ?
- crappy trans sport help
- 1994 Transport 3.8 Injector Circuit Dead
- QCM where the heck is it and what is it.
- Reprogramming For Gear Ratio Change
- Where is the motor no
- accessory codes
- Over heating 1998 3.4
- Question about keyless remote.
- Transport designations
- 3.1 v6 1992 tcc problem
- 93 Trans. heater vents not changing
- Accessories for my 98 Transport Montana
- remote lock control receiver location?
- Tempeture sensor
- 1992 Pontiac, could start but couldn't gear
- 93 TS SE 3800, still Idles rough. GOD HELP ME !!
- changing fluid in torque converter
- Knock sensor
- rear disk breaks
- Me again
- 97 transport crankshaft pulley out of line.
- 97 transport water in oil
- 98 Trans Sport I bought in October 05
- 95 Transport Door Lock Problems
- 95 trans sport wiper arm removal
- 94 Power Sliding Door *( pops open )*
- Remote Starter
- 94 transport check engine light codes
- wiring diagram for power windows or help
- How to change Spark plugs
- Exhaust Downpipe
- Buzzing noise Trans sport 3,8 '96
- New water pump time? But first...
- 93 TS SE 3800. No Drive.
- 94 Pontiac Transport broken door handle
- HELP!!! 1995 electrical problems???
- 1995 Transport.
- Alternator Woes
- 95 transport heater
- Front A/C blower broke. Tried lots of stuff but, now STUCK
- 98 TSP driver side window off track??
- 93 3800 ECU part number ??
- 94 transport transmission howl
- 95 TransSport brake dash light
- How much can it handle?
- 97transport wiper won't park
- What battery?
- Back...after a long abscense...heartbreak...
- Breaking for spares?
- 93 TS SE 3800 TPI, hunts at idle.
- Tach not working/DTCP0336
- Need to do a tune-up on 95 3.8L Transport...suggestions?
- 93Trans Sport3.8 Transmission shifting problem
- Service Engine Light
- exhaust problem?
- no spark
- dash light location for heater/AC switch
- 98 Trans Sport Heater Not Blowing FIX Re-Visited.
- Frustrated with CEL...
- 93 3.8 trans overdrive
- 1994 Pont Trans Sport bulb
- Windshield wiper problem?
- Transmission will not go into gear when cold
- Wiring diagram for TCS module
- Integrated child seat TRANS SPORT'95
- ?stuck lifters
- Bad Headlight Fix ! Info For All !
- 3800 tranny how difficult?
- 93 Trans Sport SE 3800. No.5 Injector dead.
- Loud 3.8 under acceleration
- Front Heater Not Blowing Very Strong FIX ?!?!
- won't take fuel
- obd1 interface and software
- 93 transport 3.8 acceleration problem
- 97 Pontiac Trans Sport engine temp increase
- 96 Daytime Running Lights Inoperative
- 95' Pontiac Transport is possessed! Please help!
- oil pressure
- Starting Van after sitting two weeks in sub zero temps. !?
- 98 Transport clicking noise under dash
- 93 Transport Intermittent problems
- Steering Wheel Removal for New Ign.-1995
- 98 transport LEAKS water inside dashboard
- Rear Hub Replacement
- Searching for (digital) owner manual
- 98 transport power sliding door
- location of rear wiper refill? Newbee!
- Clock/Radio display
- 95 transport 3.1L stalls below 1500rpm
- power windows again - wirering
- '95 3800 SLOOOW to warm up!!!
- all gauges reading high
- A/C doesn't work and fan in motor don't turn
- Help! Fuel leak.. Broken gas line...
- 93 transsport 3.8L - Throttle Position sensor
- alternator problem
- Burned out ignition wires
- Different versions of the 3800 engine ??
- Light that illuminates the radio controls burned out
- 93 trans sport not getting spark
- -98 Transport overheating
- 94 Trans Port will not start
- 94 Transport 3800 MAF sencer question
- 98 Transport door locks
- 98 Transport Heater
- HELP!!! 94 Transport problems
- Lost all guages but speedo and tach
- 95 transport molding removal?
- change '95 liftgate lock
- 97 Trans Sport radiator spicket
- idle rpm
- 94 Transport 3800, with abs, bleading brakes
- 95 Trans Sport NO Acceleration at all ?
- engine wont fire, then starts alright in the morning
- Replacing master cylinder on 93 transport
- 97 Transport with electrical issues
- 93 Trans Sport Changing Plug wire basics??
- 1998 Transport - Overheating
- Exaust manifold gasket, or not?
- 1992 Transport SE - seat motor fixable?
- 1993 Tans Port Codes & Shifting Problems
- code po140b
- '95 ECM Diagram
- Heated oxygen sensor
- blower help
- '95 Keyless entry
- '95 wipers stuck
- Keyless Entry
- Hello from a newbie here!
- sliding door
- alarm
- cat sound from engine
- Oil pressure sender
- hazard
- replacement of transmission speed sensor
- '95 no rear heat
- 1992 Trans Sport SE FOR SALE/BEST OFFER
- No Brake Lights
- temperature dissplay
- driveability problem
- Wheel bearings
- Dashboard
- Tach signal/ hookup location??.. 98 TransSport.
- headlight relay
- 91 trans sport factory service manual
- 95 Transport - Washer Fluid Pump
- heater is out in front
- Fuel Pump Run On
- Wiring Diagrams
- '96 Transport computer read out
- '96 Transport heater is blowing cold air
- Some problems
- Intermittent start/no start
- 1998 trasport ABS light on
- 1992 Trans Sport Rear Bumper Pieces
- 4t60e transmission... came in what other vehicles?
- 96 starts then stalls
- Considering replacing 3800
- 1998 Transport front blower 1, 2 & 3 dont work
- Front end Clunk on accel
- 94 Transport no start, no lights, nothing
- Front heater fan switch
- 98 Trans Sport... Headlights have moisture on the inside!!??
- 98 Trans Sport... No rear heat !!!
- 98 Trans Sport headlight switch problems!!??
- Cheap Fix for TCC/4th Gear Problem
- 93 Trans Sport 3800 won't start
- 95 Tsp stalling
- My awesome luck
- Front end clunk, $300.00 in parts later
- Trans Sport Reverse Gear Malfunctioning
- 96 transport fuel pump relay chattering/no start
