View Full Version : Trans Sport
Pages : 1 2 [3] 4 5 6 7
  1. 95 3.8 installed used tranny-1 gear in drv-help!!
  2. Injector cleaner 93 trans 3.8
  3. 95 transport kickpanel
  4. 1994 trans sport 3.1 wont start
  5. 97 transsport rebuilt tranny
  6. My 97 TransSport PSD problems
  7. Code 341
  8. 98 pontiac transport
  9. Crankshaft Position Sensor
  10. Knock sensor
  11. 98 Pontiac Transport - Brake Problems
  12. Tachometer Failure
  13. intermittant heater fan solved
  14. 95 transport stalls when in gear
  15. 98 Montana: PW switch problem
  16. were are the TS 3800
  17. 92 Transport won't start..
  18. Pulling to left when shifting - '95 Trans Sport
  19. 93 Transport oil in coolant?
  20. power door and locks issues
  21. Does DTC 38 illuminate the CEL?
  22. 95 Transport - Okay, I need to change the fuel pump. Give it to me straight...
  23. No Start - All other electrical OK
  24. 94 Pontiac Transport Surges
  25. 97 Transport turn signal / driving light problem
  26. '93 Antenna problem.
  27. Inaccurate Temp gauge
  28. 1990 Chev Lumina APV Parting out
  29. Quad driver
  30. Misfire Cylinder #3
  31. 500+hp Pro Street FOR SALE Only 10 miles on Motor !!!!!!!!!!
  32. Pro Lock Anti Theft System
  33. turn signal blinking too fast
  34. Turn signal problem with 2004 Santa Fe
  35. What would cause my headlights to flash
  36. '95 Transport 3.8 Finally Stranded me!!!
  37. 97 trans port electrical problem?(lights/alarm)
  38. LMP are you here!
  39. Anyone try and pull the engine out the front
  40. Looking for new wheels and rims
  41. transmission solenoid
  42. Lower Ball Joints 96 Lumina APV
  43. 95 TSP battery drain/ electrical?
  44. 93 trans sport suspension compatibility
  45. Transmission shudders
  46. 95 transport 3.1
  47. Electrical problems 93 transport.3.8 ltr
  48. 92 Auto Trans not quite right
  49. Service? Manuals from AC/Delco?
  50. 92 Delco car radio wiring
  51. transmiision
  52. Gas gauge pinned..mystery
  53. TCC Help
  54. ABS Brakes
  55. 97 Bad head gasket HELP!!!!!!!!!!
  56. 94 Trans Sport New alternator still not right
  57. 95 transport rad.
  58. tranny problems
  59. 2 problems
  60. Wacky wipers!!!
  61. '93 clicking noise after angine WARMS UP!
  62. TCC Location help
  63. 94 3.8L Power Problem
  64. fog lamps
  65. Wiper issue not found on here......
  66. more new and old
  67. more new and old
  68. Remote Control Keyless Door System
  69. Weird oil pressure needle indication
  70. Temp Needle Guage Stuck
  71. Heater only works on high ?
  72. 91 TransSport problem with transmission
  73. Low Oil Light but pressure gauge fine
  74. Trans Sport Part Numbers Needed!
  75. Little heat 98 Transport
  76. Battery draining
  77. 97 Trans Sport idling rough,won't shift out of 1st
  78. Tach problems
  79. 95 Transport Driver's Mirror - what years are compatible with this (for replacement?)
  80. Selling my 91 factory service manual
  81. 93 3.1 transport warm heat
  82. 95 transport..problems with starting
  83. 93 trans sports will start but won't shift into gear
  84. 93 Tsp CES light bucks jerks after warmup
  85. Strut replacemnt- 95 transport
  86. 97 transport clicking noise
  87. Check Engine Light
  88. FUel Pressure Gauge
  89. 96 3.8l brakelight/abs
  90. New file list
  91. 93 TS 3800 - transmission problem
  92. 93 Trans Sport Injector fuse
  93. 3.1 - Transmission Oil
  94. tie rods (ends)
  95. 98 TranSport (Chevrolet) Wiring Problem for TCC solinoid
  96. wheel interchange
  97. Original Audio(FM Transmitters)
  98. 95 Transport 3800- Help get us on the road
  99. transmission oil
  100. 96 transport help best way to pull motor
  101. 98 trans sport w/hi temp light on -- wont start
  102. Update on dying battery
  103. Gas Gauge Pinned
  104. Please Help!
  105. 1995 Trans Sport 3.8 Heater Not Working
  106. Difficulty level for front bearing replacement?? '95 Transport 3.8L
  107. 98 Trans Sport Mystery Coolant Leak
  108. Help I think it is electronic but I don’t know much about autos
  109. Need info regarding transmission fix
  110. MAKE IT STOP!! the buzzing that is.
  111. 1992 Pontiac Transport SE 3.1L keeps stalling
  112. 97 transport..new fuel pump..bad gas mileage
  113. 92 3.8 Won't Start
  114. Steering Wheel Alignment
  115. Window Help
  116. 95 Transport Power Window Issues
  117. 93 Pontiac Transport tranny slipping
  118. 98 rear tail lamp and ABS light problem
  119. 92 Trans Sport Codes 31 and 34
  120. 97 Transport Flutter and then stall
  121. wipers won't turn off 93 Trans Sport
  122. LMP need help on the vaccum line question
  123. weird noise? vibration? 93 tans sport 3800
  124. heater vent vaccum line location on engine
  125. Easiest Trailer Lights Hookup-95 Trans Sport
  126. What are common causes for 94 Trans Sports TBI's to Quit spraying fuel?
  127. What are common causes for 94 Trans Sports TBI's to Quit spraying fuel?
  128. 98 3800 serious 2 werid noise
  129. Engine Problem: Timing Chain 93 Trans Port
  130. simple: Is Pontiac Trans Sport a truck?
  131. Cruise Control Cable Broke - '95 Trans Sport
  132. 93 3.8 motor races after 3000 rpm
  133. 93 transport 3.8 crankshaft balancer
  134. Problem with stalling with a 94 Trans Sport SE Van
  135. accessibility
  136. 94 Trans Sport keeps stalling & electric rad fan not turning on.
  137. dead
  138. fuse?
  139. Need help with keyless remote PLEASE!!!!!
  140. Off and On RPM
  141. electric Scheme
  142. 1995 pontiac transport problems
  143. 97 transport delayed 2-3 shift
  144. Low fuel and water tmp. gauge ('94 3.1 TS)
  145. 93 trans sport fast idle
  146. 98Trans headlights Suck! Penny Pinchin' Solution..
  147. 1998 trans sport wrong temp displayed
  148. 1998 trans sport no interior lights
  149. 1995 Pontiac Transport
  150. 1995 Transport 3800 overheating
  151. 1998 Transport not shifting above 3rd gear, HELP
  152. Replacing manufacturer radio
  153. 1994 Transport Electrical problem
  154. Rear window defroster
  155. Starter cranks but the engine struggles
  156. 98 Ts Tranny Cooling Line Question
  157. Windshield broke...????
  158. 98' Coolant fans not working??
  159. Trans Sport Trailer Harness Needed....
  160. 1990 - Battery being drained - help??
  161. Engine Cooling
  162. Bleeding brakes-1995 Transport
  163. rear hatch '96 transport
  164. Instrument Cluster Removal
  165. AIRBAG light on
  166. 1995 3800 Trans Sport Rough idle
  167. Another power slider problem
  168. A few annoyances...
  169. Power Windows not working.
  170. wanted: complete trailer hitch
  171. coolant
  172. 96 Fan, temp gage, tach inop
  173. 95 3.1
  174. Temp Light Flashes While Driving
  175. HVAC module Part Deux
  176. 93 3.8 Idling rough
  177. catalytic converter
  178. HVAC module
  179. 1998 trans sport wont start after sitting a long time
  180. gasket
  181. Second or third gear?
  182. hello and thank you
  183. oil leak
  184. 93 3.8L Electrical problems haywire
  185. Removing dashboard of 1997 Trans Port
  186. 94 pontiac transport 3.8 wont idle till warm
  187. transmission/service engine light
  188. Rear Wiper Motor, Part Numbers.. HELP!!
  189. Help, looking Manual or Troble Code list for Transsport 97' 3.4L
  190. 1997 TransSport engine and starter problem
  191. 95 TS 3.1 problem
  192. OBD II code P0420
  193. Harsh reverse engagement
  194. how do you change low beam bulb on 93
  195. 98 Trans Sport Heater not blowing strong
  196. Another 3.8/95 transport problem.
  197. again code 41
  198. key-cylinder-star wirning diagram
  199. oil leak 3.1 V6
  200. POP or Bang in front end on bumps
  201. 1994 Trans Sport Keep replacing struts
  202. 1995 Transport 3.8 Injector Circuit Dead
  203. Misfire when engine is warm
  204. code 41
  205. Tailgate door handle broken
  206. Cylinder #'s
  207. 97 Tran Sport, Transmission Puzzle!!
  208. Front indicator lights
  209. Transport 3.8L
  210. 1993 3.8 tranny not staying in 4th
  211. 93 Transport fuel pump noisy
  212. Heatwave killed my blower!
  213. Easy way to get those rear 3800 spark plugs
  214. Alternator Woes... Sense Wire?
  215. 95 a/c pressure switch
  216. Alternator HELP !
  217. 93 TP keyless entry
  218. New here: '95 3.8 puller fan won't stop!
  219. Tranny help lost in the country!!
  220. wont turn over
  221. 1997 3.4 engine any good?
  222. Fuel Sender Adjustment
  223. http://www.automotiveforums.com/vbulletin/images/smOld wives remedy for new car smell
  224. 98 trans sport front a/c trouble
  225. 93 transport oil sender unit 3.8L
  226. 94 Intake manifold....
  227. 93 transport fuse circuits
  228. WTD: Trans Sport Rear Quarter Window Motor
  229. help with fuel pump installation
  230. 1994 Transport code 740
  231. Thermostat location in 1991 TRANS SPORT
  232. 93 Transport cruise control
  233. oil in water
  234. 1990 Transport 3.1
  235. 1990 Transport 3.1
  236. 94 transport cranks but no spark
  237. Draining battery
  238. 97 transport wiper problem
  239. 95 Transport problems with two rebuilt trannys
  240. 97 tranport high idle and turn signal
  241. 94 wiring diagram for heat/ac controls
  242. 1993 3.8 signal flasher
  243. Hot air from heater when turned off. 93 TS
  244. 96 3.4L Head Removal
  245. 97 trans sport code 101(mass air flow)
  246. 95 transport towing
  247. 1992 Pontiac Transport stalls
  248. Intermittent Spitting and Sputtering
  249. High speed mode of Cooling Fan
  250. Need Help: 1995 Trans Sport 3.8L need help removing transmission side pan
