View Full Version : Trans Sport
Pages : 1 [2] 3 4 5 6 7
  1. 95 Transport tailgate power lock
  2. Engine sputters and stalls - '95 Transport 3.8L More Details Inside.
  3. power sliding door
  4. Advice needed re: changing pads/95 with abs...
  5. 1994 Pontiac Transport Door Handle problems
  6. wiring diag for power mirrors
  7. Ignition Switch Replacment?
  8. 98 transport engine swap
  9. 93 3.1 no fuel
  10. goran MK
  11. 1997 3400 Coolant fans where is the sensor?
  12. 97 Trans Port 3400 Drained coolant can not run engine more than 3-5 minutes high temp
  13. 1995 3800 v6 low operating temp effecting economy?
  14. wont shift
  15. 93 Trans Sport, ECM a bit crazy
  16. Keyless entry FOB
  17. Trans Sport cruising speed
  18. Procedure for coolant drain/refill?
  19. 95 Ts Se 3.8 (3800)
  20. 97 Ts Se 3.8
  21. 97 Transport backfiring instead of starting
  22. strut through top of body support
  23. 1996 TranSport Transmission trouble when cold
  24. 1995 Trans Sport - no Brake Lights
  25. Motor Swap
  26. Engine stalled now jumping
  27. 94 transport loss of acceleration-please help
  28. Oops No Spare!!!!!!
  29. Need for new/used windshield wiper motor :(
  30. After Market sunroof
  31. Trans Sport Thermostat
  32. 1995 3800 losing coolant
  33. HELP! Broken Hood Release Cable!
  34. 98 TS Stalls, won't idle
  35. Radio display bulbs?? Replaceable?
  36. remote door locks
  37. Dead ignition modules??
  38. Passenger Electric Window issues
  39. Gas Tank Harness
  40. Disable TCC
  41. Wiper arm removal??
  42. Anyone else with a DOHC 2.3 litre Four?
  43. 94 TS 3.8 Auto Gearbox Removal
  44. 95 Pontiac Transport Door Handle problems
  45. Fuel Sending Unit
  46. 95 Trans Sport 3.8 Rear Head Removal?
  47. Dash Board Lifting up
  48. pwr door and pwr seats
  49. OBD Confusing me
  50. Clearing the DTC P0420
  51. 1998 pontiac transport -- electrical problems
  52. TS Antenna
  53. Cradle Mounts 92 Transport
  54. after the holidays got over the silencer filled with dirt
  55. Short term fuel trim question
  56. light problems with my 1998 pontiac transport
  57. 1992 Trans Sport Power Mirror Problem
  58. Connecting CD player with factory casette radio
  59. 97 Trans Sport A/C blowing fuse
  60. Misfireing at Speed
  61. 1996 Rear Heat or A/C, Coolant smell
  62. sliding doors not working
  63. Wimdshield Question on 95TS
  64. 95 Transsport 3.8L CEL ON - No OD - No cruise control
  65. 1994 transport stalls when accelerating
  66. heater fan still runs after engine off - drains battery
  67. Struts 98 trans sport
  68. 1998 Content Theft System
  69. Cracked Damper or Pulley Photos
  70. Dtc P0300 & P0304
  71. Service Engine Soon Light On
  72. computer of pontiac 1990 doesn,t work
  73. computer of pontiac 1990 doesn,t work
  74. Unique Heater Problem
  75. HELP! TS won't fire up
  76. 97 transport - need help replacing tranny modulator
  77. 97 transport programming help
  78. 98-Pontiac Spewing Coolant Then Died
  79. New problems
  80. Liftgate lock
  81. 95 Transport Power Locks Kick in and Out When Pressing Brake Pedal...
  82. engine overheating of my pontiac transport 1990
  83. 1995 Pontiac Transport Question
  84. lost the owner's manual of my pontiac1990
  85. overhead console
  86. Need help with Electical Problem
  87. Just wondering about aftermarket headlights for 1997 trans sport
  88. passenger sliding door
  89. No Heat!!!
  90. Pontiac ts 1995 v6 3800 3.8 heating actuator
  91. dtc 36 and 39...
  92. 96 Trans Sport Rear Wiper Won't shut off
  93. What is the ball under my 97 Pontiac Transport for?
  94. weird start problems
  95. 1992 Trans Sport Heater Core Hose Removal
  96. Get fuel out Pontiac ts 1995 v6 3800 3.8
  97. Paint problems?
  98. 1990 Trans Sport Liftgate Lock?
  99. Fuel Mileage for 1995 Trans Port w/3.8L
  100. 1998 transport 3.4 antifreeze odour
  101. Highway 'hickups'
  102. 92 pontiac transport wont start
  103. 95 3.8 Spewing coolant
  104. Need help and details fast!!!!
  105. Runs like **** !
  106. ignition modules- price difference
  107. Rough Idle SES-Lite on- OBD1, No Codes Found
  108. 92 Pontiac Trans Sport Heater Fan - works only on high
  109. 94 Trans Sport 3.8 no power, stalls...
  110. rubbing grinding front passenger side
  111. 7x Crank Sensor 97 Trans Sport
  112. abs/tcs lights on after hitting pot hole
  113. 1995 3.8 Engine Problesm Worse When Hot
  114. No Start, Very wierd
  115. 97 Trans sport Oil Pressure Light
  116. door
  117. Cooling Fan Not Working 95 Transport
  118. 1997 pontiac trans sport head gasket
  119. DTC P1361 and IAC testing
  120. Sad day for my 1993 T/S
  121. Trans Sport 1994 AC/Heater blower????
  122. Blower motor - resistors
  123. Crank Position Sensor & Tach
  124. 96 T/S died
  125. 97 Transport Cylinder 6 Mis-Fire
  126. Runnig Hot!!!
  127. 1992 trans sport won't start....
  128. Help 98 trans sport ABS, TCS and brake lights
  129. 94 Transport Cranks Wont Start
  130. Vacuum line diagram for 97 Transport
  131. 99 Transport minvan brake problem.
  132. Blown Headgasket
  133. Air Intake/Mileage question
  134. 3.1 V6 MAF Sensor Location
  135. 94 Trans sport- unstable RPM and floping noise when getting gas.
  136. 1995 Trans Sport Engine Dying While Driving
  137. 1995 transport tire jack
  138. intermittent starting problem
  139. 95 transport engine stalls
  140. 94 3.8 freeway hesitation
  141. 1995 Trans Sport - a few things.
  142. Egr Valve For A 96 3.4
  143. 93 transport engine swap
  144. 98 Transport - Codes and confusion !!!
  145. 95 Broken door handle
  146. 98 Transport Climate fan control resistors...
  147. 98 Transport rear wiper wiring diagrams
  148. Free 94 Trans Sport N. Cal.
  149. 98 pontiac trans spot oxygen sensors
  150. 1996 Transport No Hazard or Right Hand Turn Lights
  151. 97 Transport strange engine problems
  152. Erasing Trouble Codes
  153. Transmission Modulator
  154. 94 3.8l plug wire loom
  155. 1994 3.8 Transport throwing alot of codes
  156. help with a transport
  157. 97 3.4L Need help with Temp Switch, Sensor & burnt wire
  158. Electrical Symptoms
  159. Trans Sport average life
  160. Tight Steering To Right Only
  161. Cold weather starting
  162. Fuel Pump Power???
  163. GM 3.1 V6 cold knocking
  164. GM Radio/Car stereo wiring color codes HELP!
  165. Light sensor
  166. 96 Transport stalls at star up
  167. Trans Sport Timing Specs
  168. 97 Pontiac Trans Sport Fuse Relay Box
  169. Brake light!
  170. 98 Transport Sliding Power Door
  171. 98 Transport - Weird Electrical problems
  172. Power Sliding Door 98 Transport
  173. how to reprogram keyless entry
  174. 5 speed transport pictures
  175. transport 95 5 speed manual....wow !
  176. Pontiac Transport has started but.......
  177. Piston Slap
  178. Testing starter
  179. Parts compatibility with Chevrolet Lumina
  180. Wants to start...but doesnt
  181. 95 Transport No Heat
  182. 1997 Trans Sport Fuel Level Sending Unit Needed!!
  183. 97 Trans Sport code P0441
  184. Transport wipers-again
  185. 95 Po101
  186. Transport/Montana no power to fuel pump
  187. cruise control driving me mad
  188. 1993 Transport - Battery not charging with a good alternator
  189. Changing muffler in a 1997 Trans Sport?
  190. Wheel Hub Assembly replaced now squealing
  191. 3400 timing belt replacment
  192. Air conditionning compressor connectors
  193. 95 transport front end noise
  194. More window problems on a 1992 Transport
  195. 98 with a p0101
  196. Radio
  197. Ignitionlock
  198. 1993 transport flooding??
  199. Oil gauge
  200. 97 Trans Sport. Electrical Issues
  201. the heater
  202. Radiator Fans Not Working
  203. Coolant smell in engine compartment
  204. Power Windows
  205. Another problem
  206. Tach on speed?
  207. 97 pontiac transport power seat
  208. weird noise
  209. 1994 Trans Sport trans fluid leak
  210. Code P136, P0300 and P0705 question.
  211. Poor Gas Performance
  212. Engine light after Tune up !
  213. Please...any thoughts???
  214. 95 3800 shudder in right turn
  215. 1995 power sliding door motor replacement
  216. How Hard to Remove Rear Head-3.8?
  217. Valve train noise, what is normal?
  218. Oil Level
  219. Mechanical hammering at idle
  220. Hot Trans and No TCC/OD Problem
  221. testing relay on 3.8 fuel pump
  222. Pontiac Trans Sport shakes./shudders/jerks at 2400 RPM
  223. Engine swap 3.4 to 3.8
  224. Tach and Instrument Lights Problem-1995
  225. TCC thanks & repair question.
  226. 1995 3.8 Part Throttle Miss-Sometimes
  227. 98' Trans Sport Tranny Question
  228. oil pump 97 transport 3.4
  229. With or without rear A/C
  230. 92 Trans Sport, 3800, odd electrical problem
  231. Rear Automatic Levelling Shocks
  232. vibration 93 transport
  233. Harmonic balancer
  234. Spare tire wench
  235. Fuel economy
  236. Transport
  237. Help Please! 94 Trans Sport Puller Fan
  238. 1995 Pontiac Trans Sport Low Fuel Pressure
  239. 95 Trans Sport's back hatch lock can't be locked.
  240. Starter Fuse '94
  241. What Language does a 92-3.8 speak
  242. Rear AC, Where to find.
  243. OBD2 Pontiac Transsport v6 3.8 L 1996
  244. 1998 Pontiac Transport Engine code P0420
  245. 1997 transport code 300
  246. Freeze plug.
  247. Location on ECM Computer-1995
  248. Computer ?
  249. transsport 3.8 wheel alignment
  250. 96 transport heater core
