View Full Version : Montero/Shogun/Pajero
Pages : [1] 2
  1. 2001 montero runs hot
  2. Owners Manuel
  3. 2000 Montero Stalling after dead battery
  4. 2000 factory roof rack questions... Do you have simple answer?
  5. 93 montereo no spark
  6. 90 Montero burnt engine control computer
  7. HELP? where is the map sensor located on a 97 montero???
  8. Tire Upgrade for 97 Montero
  9. Headlights
  10. 1st gen monty parts?
  11. Transmission - Hard Shift ????
  12. 2002 Montero - 60/40 2nd Row Split Seat ?
  13. dashboard pics
  14. 2000 Montero transmission prob
  15. Does anyone know to find info on How to repair 1994 Pajero Clutch
  16. 2000 MonteSport... How to change fwd turn light?
  17. 1995 pajero owners manual
  18. blinkers not working
  19. wiring diagram ??
  20. 1987 Dodge Raider Shuts off after 5-6 minutes
  21. 95 Shogun cutting out problem
  22. High Pressure fuel pump filter
  23. No petrol to carbaretor
  24. Noise at start up
  25. radio removal montero
  26. 02 Montero Sport LMTD AWD / o2 Sensor?
  27. 4wd light
  28. Mont sport horn won't stop, had to pull fuse
  29. 1999 Pajero IO Questions
  30. Montero 3.0 DOHC leaking coolant
  31. slow acceleration at startup
  32. 1998 Montero Sport radio removal
  33. replaced alternator now it won't idle?
  34. Montero 4wd light????
  35. Custom Payment?
  36. Turn signal problem.98 sport
  37. MDS vs MAP
  38. Pajero io multicommunication system
  39. Timing belt question
  40. pajero atf hot light
  41. subwoofer replacement
  42. Anyone know how to change power antenna unit 2002 Montero Sport?
  43. Brake Light stays on
  44. 98 montero has no spark
  45. 2000 mitsubishi motero sport
  46. cam timing 3.2 Di d Pajero 2001
  47. Code For Sterio
  48. 2000 montero sport trany ?
  49. Changing Rear Brake Pads on a 2001 Montero Sport
  50. Radio code for Montero sport 2000
  51. smoking Montero
  52. Difference between headlamps 92-7 to 98-00 Montero
  53. 1998 Montero Sport Speedometer Problem
  54. Battery & Brake Warning Lights
  55. Back Door Panels
  56. power loss
  57. Parts
  58. need info parts general knowledge for my 94
  59. code help P0120
  60. Changing break pads on Pajero 1995
  61. 1998 montero sport
  62. 98 Montero compass reset
  63. The next 2008 motero sport (triton g-wagon)
  64. Diesel conversion for 94 3.0?
  65. Diesel conversion for 94 3.0?
  66. looking to buy Montero Sport
  67. Pajero 3.5 SWB 1999model ABS light problem
  68. Pajero 99 3.5 emmision problem
  69. Tune Up?
  70. Pajero IO, MMCS just a blank screen help!!!!
  71. 97' Pajero 2.5TDi. Aircon prob.nEEd Help pls
  72. 89 Montero~ New owner ~ Having issues with rust & finding parts
  73. Montero Sport outside mirrors fuse
  74. Ex-Japan 2000 Pajero io, blank screen
  75. 94 Montero won't start / blown fuse
  76. Replaced alternator now what? bad idle sensor?
  77. 2000 montero jerking..
  78. p0455
  79. 99 montero sport fuse box
  80. Montero Sport - Canadian Specifications
  81. What side 02 sensor on 2000 Montero sport
  82. Does a Mitsubishi Montero have 3 catalytic converters?
  83. starter on Mitsibishi Montero sport
  84. does anyone know that name of this part?
  85. 95 torque convert wont seperate from flywheel
  86. Steering box fluid checking.
  87. dual mass flywheel
  88. Timing marks/questions, 1994 3.0L montero
  89. Electric seat problems
  90. Repair Manual Book For 98 Mits Montero
  91. Pajero Engine Valve Clearance
  92. Montero 96 Auto Trans
  93. 95 Montero SR w/3.5L ABS light always on
  94. Looking to put in a manual transmission
  95. Pajero transmission
  96. Shogun Wheels
  97. shogun auto 2.8 1993
  98. 2001 montero sport xls
  99. Windshield Wipers
  100. Montero Question
  101. Pajero Shogun ABS problems
  102. 1998 montero sport
  103. 1998 montero sport
  104. gen 1 monty hitch??
  105. Brake Problems
  106. mitsubishi shogun
  107. 2000 Montero Sport wheel problem
  108. 2006 Montero review
  109. 2000 Montero Sport
  110. 2000 Montero Sport Cruise Light
  111. A/C now it works now it doen't
  112. pajero io gdi
  113. 2000 MS Fuel filter
  114. Whining coming from ABS pump (2001 Montero)
  115. Turn signal brain teaser
  116. 2006 Sierra Challenge prerun pictures (large)
  117. Front Brake pads on 98 montero sport
  118. 02 Montero Antenna
  119. timing marks 97 montero sport
  120. factory offset 2001 montero limited??
  121. 98 montero warning lights
  122. 6 Cypress CA is on July 29! (large flyer pic)
  123. Brake Light/Turn Signal Problem
  124. glow plug problem
  125. Rotor/drum removal (E-brake shoe disengage) '01 Montero
  126. Where can I buy a Multi Communications System Data Disk (Pajero)
  127. Tempermental Shogun
  128. Radio code Mistubishi Montero Sport LS JULY 1998
  129. Shogun door mirror.
  130. 3L v6 panjero any1 know cylinder head settings
  131. radio code free!!!!!!!!!!
  132. looking for a part number
  133. 2002 Montero Sport with All-Wheel drive not starting
  134. 1997 Montero SR Spark Plug
  135. 1988 Montero
  136. Thining about buying new montero
  137. DIESEL 2.5 TURBO I/C TIMING BELT REPLACEMENT, shogun, montero, pajero
  138. Radio Code Wizard - Not! (I'm toast.....)
  139. Parking Break Montero
  140. 95 Montero Dash Light called A/T
  141. 2002 Montero Vibration / Rumbling
  142. Replacing an alternator on a pajero(the cables)
  143. O Rings
  144. 1995 montero
  145. 03 montero v6 questions
  146. Rumbling/Low Rattle Under Hood
  147. my 99 montero/sport
  148. my 99 montero/sport
  149. IRS or SRS?????? Please help..............
  150. Pajero 3.2 Gdi 2000 Swb Engine Block Warning Light, Engine block warning + power loss
  151. Part time Power Door Locks
  152. Montero 2001 4WD Dash Light HELP
  153. Will starting in 2nd gear all the time kill my Montero?
  154. 2000 Montero Sport interior outlets cause horn to sound
  155. Installing 99 Montero Sport HEADLIGHT
  156. engine mounting
  157. 1999 Montero 4WD system
  158. high RPMs between 1st and 2nd Gear then Rough Shifting
  159. It was delivered this weekend
  160. Steps/Nerf Bars - Good ones?
  161. Pajero stalling
  162. timing chain diagram '84 nb pajero
  163. 4wd shifting
  164. swap diamante dbl overhead cam 3.5 to 95 3.5 montero
  165. 98 montero radio code need HELP me pl !!!!!!!!!!!!
  166. help me anyone. I need to unlock my volkswagen premium audio
  167. Performance modifications
  168. Winter blues?
  169. 98 Montero sport springs torque info needed
  170. 1997 Montero Sport Radio Code
  171. E-Brake light in 98 Mont. Sport
  172. 1998 Montero Sport smokes
  173. Need a part for 1995 Montero...any help?
  174. 98 sport springs
  175. i need some advice
  176. Please need radio code!!!!!
  177. Finding Lock Control Module to Program remote
  178. 98 Montero Sport check engine lt
  179. 98 montero, bad ABS sensor assembly
  180. Changing spark plugs looks too difficult
  181. Is it the alternator
  182. '99 montero seatbelt question
  183. 1998 Montero, resetting computer. How?
  184. I have a GREAT LOOKING '90 Montero for sale
  185. Air conditioning recharge port 98 Mont. Sport
  186. 1997 Montero Sport Radio Code
  187. Immobilizer malfunction code,what's dat?
  188. 90 3.0 L Won't Idle
  189. help - need radio code for 2K Montero sport
  190. Ethanol Fuel
  191. Oil Pressure Warning Light when A/C on (Shogun)
  192. What does this dash light mean??
  193. if you own a Montero Sport
  194. adding indash cd to MS Limited?
  195. Transmission change problem
  196. Battery group size/CCA rating requirement
  197. How to remove radio to get serial # on 97 Montero LS
  198. accessory plug shorted out
  199. emissions
  200. montero 2000 blower
  201. has anyone
  202. bad smelling montero
  203. Montero Trans
  204. montero 2000 sport
  205. Unsure on which manual to purchase
  206. Pajero auto transmission problems
  207. programming remote for 97 montero sr
  208. 1998 Montero Sport - Oil Pan drain plug question
  209. programming the keyless remote
  210. Need the radio code for 1996 Montero.
  211. Need information about the infinity sound system
  212. Fan Clutch Breaks Loose
  213. 97 Montero Sport radio code
  214. Brakelight 98 Montero Sport.
  215. 4 original montero rim caps--cheap
  216. 4 wheel drive light flashes
  217. Truck Won't Start!
  218. Diff ratios question...
  219. 2002 montero sport lowering springs?
  220. hmmmmmm
  221. Oil Light
  222. 95 montero
  223. replacement rear heat pipe (montero2001)
  224. 99 Montero Sport repair manual
  225. codes for Montero sport 1997
  226. 92 montero Leaking anifreez
  227. 2.5 intercooled turbo engine problems
  228. 98 montero sport doesn't spark
  229. '95 Mits Montero alternator
  230. 01 Montero Tach Wire
  231. need radio code for a 99 montero sport
  232. Pajaro/shogun Mk1/ Mk2 question
  233. Mitsibushi shogan headlights problem
  234. Differential Question
  235. Gen 1 vs Gen 2?
  236. 2000 Montero Sport Radio Code
  237. Strange noise w/ Montero 95
  238. 1999 Montero sport car stereo decode
  239. 2002 montero sport brakes
  240. Automatic Transmisssion what generally goes out first when driven low on oil?
  241. Need help with automatic transmission....
  242. dead speedometer
  243. 2000 Montero/ Pajero transfer case
  244. General Q: About the Montero Sport
  245. Montero-1992 or similar
  246. Remote Programming for 2000 Montero Sport
  247. Ralliart Pajero Blueprints
  248. fender flare?
  249. Montero vs Trooper vs Explorer-buying used
  250. programming 2001 Montero keyless remote
