Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Mitsubishi
> Montero/Shogun/Pajero |
View Full Version :
Web
AF
Pages :
1
2
Muffler
NEW BATTERY destroyed my Montero! HELP!
Noise when A/C is turned on
amp locale
Montero Sport Single Cd player for sale 98-up -See ad
Whining/Scrubbing type Noise Under Hood HELP!!!
coolant loss
could someone share the radio code # 98 Montero
Fuel Display Problems
Infinity amps preamp limits
License plate lights
Montero Sport License Plate lights
98 montero sport radio install
clicking noise and oil light
montero part out
prob w/ skipping @3k rpm in 96 Montero SR
Can U swap 3.0 liter into 3.5 liter Montero?
91 galant has a miss what is wrong
Looking for 84-91 Montero
Evap Emission control Leak
first post. need help with my 01 montero. possible differential problem
Alarm Problems - Montero Sport
86 montero lift ideas, deet's or sugest's !
lifting a montero
new 10-disc changer questions
Help with programming a keyless remote for 1998 Mitsubishi Montero. THanks
Whats wrong with my car?!?
How to Get Serial Number of Radio
montero smokes after being in idle?
1998 Montero Sport clicking noise from engine
98 Montero Sport Horn Problem
'95 Plenum vacuum loss issue
02 montero below dash auxilliary din removal
95 Montero Overdrive & stalls
After 5-10 min the car starves for fuel:(
Tachometer
1994 3.5 L. 6G74 Sensor Issue
Trouble starting - Possible fuse problem
RPM meter
Montero ticks
2001 montero limited 4x4 green light indicator
anyone interested in purchasing 95 montero LS
97 Montero Sport Airbag and Brake Light
Montero 3.0/3.5 Oil Consumption, etc...
No Brake Lights
2002 Montero Limited To Much Oil
Need Info.........1998 Montero Dakar
Help me, 95 montero starving of fuel
Loud and Annoying Door Actuator
95 Montero stalls
engine retrofit
Denver Area - Need a GOOD Montero Mechanic
89-91 parts????
Won't Shift out of 4H
What size tires fit 94' SR without lifting?
timing belt replacement
Starting problem - Pajero
1990 Montero engine rotates but not firing
2002 Montero Ltd-no start
Front Side marker/Turn Signal Lights
'93 and earlier question for potential owner
Hitch wanted 97-03 MTS
RPM too high!
ABS light is on
Running Board Lights
HELP! overheating!! plenty of coolant!!!
97 Montero -hold Light On
Factory service manual??
Looking for 94-96 DOHC bare block
transmission problems
Ignition Problem.
'95 leaks water between front door and frame
Front end question
platinum sprk plugs
GPS in a Montero Limited
MANY MANY 1995 Montero problems
Reset miles-to-empty for Montero Limited?
Remote entry for Montero Sport??
hood mirror
keyless remote programing-mitsubishi diamante 1993 wagon
OK to replace P-series with L-series tires on '89 montero?
wheels ?
Seat Covers
Electrical issue
Fuel Injector Replacement
antanna mast
burning the oil why??????
Hood Mirror From The Pajero..........
too many attemps.. stereo CODE
Montero Limited .. any input? =)
Web
AF
