View Full Version : Lumina
- very poor acceleration
- Poor Gas Mileage
- misfire at 2000 rpm and above
- Broken manifold vacuum port 3.1 L
- 98 lumina dieing out after warmed up
- 96 lumina, blinker sound & lights flash??
- Throttle Bottle to Rear Valve Cover tube?
- Chiming when driving like doors are open
- correct keyless entry transmitter for 99 Lumina?
- 98 Lumina 3.8L Power steering reservoir replacement
- 97 Lumina No strat/rough start/loud noise/backfiring.....
- not sure what to do or how to get it checked out
- 96 lumina
- 2001 lumina bypass vats
- '97 Lumina (5) lifters problem
- 3.1L lifter position?
- 1991 Lumina Z-34 cruise control inoperative
- 95 Lumina Hesitation trouble- thought I had it fixed
- 4T60E Trans Trouble
- 97 Lumina 4T60E trans questions
- 1999 Limina Axle Nut
- Alternator Replacement, 95 Lumina, 3.1. ?
- P0422 Code. Any ideas?
- 1995 W-body, fuel pump?
- 1994 Lumina 3.1 intake backfire
- 94 Lumi Euro Dash/Door lights randomly on when car is off
- ABS computer box location
- 97 Lumina Trouble Starting
- 96 Lumina P0300 code
- 98 Lumina - A few problems...
- Wiring diagram
- No hot electrical power!!!
- ARGH! Coolant Pipe came loose!
- 1995 Lumina still wont shift!!!
- Lumina Misfiring After Intake Manifold Gasket Change
- wont turn over / passkey II
- ac condensate
- won't shift into overdrive
- How much A/C PAG oil?
- Shift Solenoid
- Low Coolant Blinking - 94 Lumi Euro
- Can 95 Lumina A/C Condenser be flushed?
- Where is the starter located on a 2001 chevy lumina?
- 1997 chevy lumina-More A/C Problems
- not sure if my raidiator fans are coming one how can i check.
- 95 lumina transmission removal
- Replacing master cylinder - 95 Lumnina w/ anti-lock brakes
- 1994 Blue Lumina Eurosport Paint Color??
- 97 lumina brake lights
- a few questions about a new to me 1990 Euro 3.1L
- A/C not working
- Car starting problem 1995 Lumina
- Wrecked my lum
- where is my iac and whats it look like.
- 94 Lumi rear strut question
- Low Coolant Light problem
- Hating my lumina...
- 91 lumina stalling issue . unplugged tcc nothign changed
- Need help with parts
- Current draw #10 fuse circuit
- 96 lumina wont start
- how to take off the left dog bone/ engine braket
- Help 90 lumina
- My 94' 3.1 V6 Lumi w/ Short Ram Intake or Not?
- Random Overheating At Idle
- obd codes 102 and 452 1998 lumina
- '96 lumina speedo wont work
- Dome light issues
- Gas Vapours after new tank install / 3.1L 99' Lumina LS
- help 96 lumina
- Passenger-side Carpet Wet from A/C
- Code P0300
- im lost,plz help
- Quick question: Need torque specs for plenum to intake manifold
- 3.8 lumina with supercharged l67
- Bubbling and Stalling
- 96 lumina fuel injectors test
- ODBII Diagnostic Codes
- 99 Chev Lumi 3.1...help
- '91 3.1L fuel pump problems
- newfuel pump new relay help
- '99 LTZ 3.8 Bent Spark Plug Electrode
- Spark Plug Burn image
- obd trouble with misfire
- 95 chevy lumina 3.1 dont run right
- 1998 Lumina LTZ A/C problem
- 1990 lumina a/c system
- 95 lumina ls
- '93 turn signal switch
- drivers side fuse block
- Help with P0327 Knock Sensor low voltage
- monte seats in 98 lumina=
- 93 lumina euro 3.1turn signal switch
- Transmission question
- Rusted fuel filter.
- Groaning/Growling Noise
- 91 lumina 3.1 won,t stay running
- '96 with a 3100 using a lot of oil
- Front end vibration
- Torque Specs
- 93 Lumina Ball Joints
- Ethanol in 3.8L Lumina?
- My Lumi has a few problems...
- 96 Lumina Sluggish acceleration
- Engine Swap...
- Master Cylnder line location
- injector swap--what parts?
- 1997 lumina blower motor
- tail lights
- 96' rear light wiring harness-HELP!
- Rear coilover spring rate ?'s
- performance
- Lumina'97 - strange tranny(?) sound
- 3.1L to 3.4L luminas from 90 to 93 no start problem
- wiper delay problem
- 91 Lumina 3.1L odd noise with high RPM stutter
- 92 Z34 3.4L Stalling/Starting Problem
- '97 Chevy Lumina Problems (possibly with alternator)
- RKE question
- 96 Lumina brake switch replacement help
- Battery draining
- AC Compressor Oil Leak
- Air vents stop blowing air at higher RPMs.
- 97 starting problem
- Speedometer gear
- speedometer gear swap
- 97 lumina p1671 code???
- 95 Lumina Will not Start
- No sparks to plugs
- Turn Signals and High Beams Not Working????
- 94 lumina--what are the 60 amp fuses?
- Rods in the 93 3.1
- quick connect line fittings
- 95 lumina stereo removal
- Regular to dual zone c.c
- 93 Lumina O2 Sensor
- tranny return line-2000 Lumina
- Power Steering Pump Removal (stuck)
- 93 Lumina z34 RPM problem
- Removing "in park" rev limiter
- 1993 chevy Lumina Crankshaft Position Sensor
- replacing o2 sensor on '93 V6/3.1L
- 96 Lumina speedometer erratic at idle
- Fuelline Repair Kit...
- Brake hose banjo bolts
- headlight wiring harness?
- ABS Light on. What to check?
- 96 Lumina shifting problems
- Bleeding Cool Water 3.8L 98's Lum
- 97 Luminia brake/tail light problems
- 90 lumina a/c problem
- Reccomendation re: ABS weirdness
- 92 Chevy Lumina 3.1 Running Issue
- Replaced Head Gaskets and now have Problems
- 1990 lumina euro window motor
- 97 lumina engine compatability?????????
- 90 Lumina 3.1 Error Code 22
- 97 3.1 ECT EGR Short reads -temp
- 1990 Chevy Lumina stalls when warm
- Cylinder head removal
- 99 lumina engine into a 97??
- Were is the temp sensor for 98 LTZ 3800
- 95 Lumina A/C Compressor Noise
- 93 Lumina ABS Light
- Lucas Motor Oil?
- Im SORRY 91 Lumina
- TCC Solenoid ?
- 93 running rough!
- 97 lumina wont start...LIM?
- LIM removed new problem
- Lumina seat
- where is the pcv valve
- Lumina inertia switch location
- 95' Lumina won't stay running
- Tranny issue...please read
- 95 lumina won't start
- 94 lumina cold start flooding
- help me out real quick
- EGR Code..now what ??
- 93 Chevy lumina stops running
- fuel problems 1998 3.1 lumina
- 91 3.1 No start
- AC not cycling
- Almost boiling over when parked
- TCCS and PCS solenoids
- 97 Lumina malfunctioning brake lights
- 4t65-e to 4t65e-hd
- 97 Lumina fuel pump problems
- Accelerator Cable on 95 Lumina
- 92 lumina overheating and stalling problems
- Help-Help-Help
- 1992 Lumina - replacing wheel bearing and scoping out smoking steering wheel
- Brake lights do not turn off. 91' Lumina
- longer wheel studs
- 1998 Lumina front HUB bearing Question
- 1996 chevy lumina 3.1 car
- Perplexing problem
- cooling fans dont come on?
- Cooling fan problem on 91' 3.1l Need some help
- 3.1L coolant leak
- 1993 oil pan
- Coolant Pipe broke WTF? HELP
- 92' Trans. shudder from 4th to 3rd on downshift
- 2001 lumina wont even turn over
- Lowering the Lumina
- 97 Chevy Lumina
- fusible link?
- Lumina Brake Lights
- noisey 1998 =
- 1994 Lumina, 50,000 miles
- 96 Lumina poor performance when cold
- 95 lumina ls 3.4l 88k miles transmission over heat help
- 1990 Euro Lumina With Electronic Problems...
- 97 Lumina
- Whistling Noise
- AC Clutch Scraping
- 97 Lumina Temp Panel lights ??
- Transmission Prob?
- 96' lumina sedan,3.1
- 98 3.8L Lumina Headgasket...
- removing door panels to replace speakers ('97 lumina)
- Help I need parts for my Lumina Z34
- msd plug wires
- Lumina sputtering
- Ashtray light and gauge probelm
- 96 lumina frt. end noise
- 96 Lumina intake or head gasket replacement
- 1992 Lumina Wont Start
- 93 Lumina Z34 no high stop light all of a sudden
- 93 Lumina Z34 Battery went dead now car will not stay running
- clicking noise
- Locks & lights circuit
- 1997 Lumina.....Harmonic Balancer?
- Should I buy a Lumina
- chattering doors
- '98 Lumina - Majorly Strange. HELP!
- Re-using FelPro metal LIM gasket?
- 91 3.1 T injectors
- No Brakes When Applied Hard
- 1996 lumina
- 97 chevy lumina auto, v6, 3.1 engine tapping power loss misfire when warm
- serpentine belt
- 98' Lumina front lug stud R&R
- fuel pump
- 97 lumina engine acting erratically.
- '97 Lumina: Rear Struts or Shocks?
- 1995 lumi ls problems
- Brake lights not working
