View Full Version : Lumina
- Starting Problems! please read
- 1992 Lumina Euro 3.1L Quit can't remove the crank sensor for replacement
- stupid question
- 94 apv 3.1 no spark/ no fuel
- help lady with loud after market fuel pump
- Over heating problem / lumia 97, eng 3100
- 97 chevy lumina
- hard shifting.
- Homelink and OnStar
- Coolant temp sensor location (where is it?)
- Water pump installation
- Where's the coolant?
- upgrading
- could it be?
- Please reply fast if you can help
- 97 Lumina Backfire
- 1995 Lumina Electrical Nightmare...
- anyone ever use this???
- help a beginner!
- 94 3.1 APV Smoke from Tailpipe
- 96 3.1 Check Engine Blinking
- can you tell me if....
- 90 lumina wants to stall
- First time poster needs help w/SES light problem on a 95 Lumina 3.1
- WTB Both driver side door for a 1997 Lumina
- 93 3.1 lumina stalls at idle
- Lumina '92 3.1L Overheats???????
- help with 91 lumina 3.1 v6
- 96 Lumina 3.1
- 93 euro 3.1 auto
- 4T60-E bang and no more 3rd gear
- No timing marks! 1995 Lumina
- 1991 Lumina 3.1 = No Blower Fan
- Looking to buy a 96 Lumina
- 97 lumina camshaft position sensor
- frost plugs
- 96' Lumina with load of Issues
- electrical gurus - need your help - clock radio
- no high speed blower fan
- interior lighting problem with 93 euro...
- minor problems with 93 euro...
- oh oh.."volts" on the dash!
- Little glitches add charm
- 91 AVP 3.1 - Tach Hookup?
- 91 APV 3.1 - Lessons Learned
- Front Strut Cartridge Replacement
- 1998 Lumina Fuel Injector Trouble
- 97 lumina won't start unless wiggle the key
- a real "wth" lumina
- 1997 Lumina intermitant stalling,starting probs fixed
- 92 overheating diagnostic steps
- 93 lumina water in trunk?
- Serious Rust
- Instrument Lights
- 1997 Lumina - is it my Water Pump?
- 96 lumina 3.1 cooling issues
- '97 with clicking ABS pump & weakened brake response
- 98 Lumina LS Code 1401
- help installing cruise control
- Starts for 3 sec then stalls...........
- problems, accel, shift, trans? tcc?
- oil additives?
- 90 Lumina dies on acceleration - intermittently.
- lockout sensor...need 2 disconnect...how do i?
- rough idle in drive
- Manual Transmission
- Timing Chain Cover Help
- Another misfire issue
- Need help for project tomorrow!! (removing rear window carpet)
- 92 Lumina 3.1L V6 Temp Sending Unit
- 94 lumina ac
- AC issues... should be simple.
- converted to lumina!!!
- Antifreeze
- Re: Shuttering at acceleration
- ack transmission trouble
- Rough Idle
- 92 3.1 not getting spark
- 95 transmission removal
- 92 Lumina Z34 Body Kits
- Steering Column Disassembly 99 LTZ
- car wont start
- 93 lumina, what kind of spark plugs??
- engine cleaning?
- changing locks
- Body corrosion , common location?
- Water, water, everywhere....well only in the rear :)
- 97 3.1 poor low rpm accel, good high
- 1995 Lumina 4 door
- idles ruff & hesitates at low speeds
- nasty smell
- Welcome and Congratulations to the New Moderators of Lumina Forum
- location of O2 sensor on 95 3.1
- rumble
- 1999 lumina 3.1
- 1997 chevy lumina help 3.1, no power
- Lumina Head Gasket Failure Rate
- compressing lumina break calibers
- 3.1 air intake question
- 1992 luminia
- overdrive??
- fuel lines
- what spark plugs? and other questions...
- what should I do with this?
- hard morning start
- We can dream...
- Clear Side Marker Light
- WTB: Z34 parts!!!
- lumina wont start
- drums vs. discs.
- bent rim
- Miss?
- brake question
- Car cover
- Yo, Richtazz...suspension question
- 1998 Lumina 3.1 Lower Intake Warpage?
- For lumina owners only!!
- gas mileage?
- best oil for 3.8L Lumina
- OnStar in 1999 LTZ
- MAF Sensor location?
- Tranny Problems
- 1994 Lumina Euro 3.1L
- scratches
- Thanks Everyone
- leather?
- Z34 - Black Smoke
- 99 3.1 hard start problem and fuel pump noise
- how to replace a fuel pump
- 92 3.1 stalling
- Air Intake for 1996 lumina LS 3.1?
- so i think my starter died...again
- fuel pump relay
- undercoating...again
- radiator fan problem
- P0303 - 1996 Lumina need help
- Gas (Fuel) Tank Question
- spark problem on 1-4
- everyone check this out
- how do i check fuel pump
- Evaporator Core
- 99 ltz steering problems.
- ran out of gas
- Finally. Pics of my '99 LTZ
- 99 lumina jerking
- aftermarket speedo
- speedo.
- what is this?
- 92 Lumina Euro 3.1 - door locks
- 95 Lumina Odometer Not Working
- Turn off automatic door lock on '93 Lumina?
- Brought the Lumina to a mechanic today
- 99 Lumina LTZ rear brake lights no work, center light does
- arcing spark plug boots
- 92 Euro passenger mirror
- 1997 Lumina Blower Motor???
- fixing scratches?
- 98 Lumina Starter Relay Fuse Blows
- Stereo Woes
- lumina remote starter
- 1998 Lumina LTZ 3.8 AC Clutch
- What's the difference between LS and Z-34...
- 93 Lumina 3.1 NO Spark.
- Runs HORRIBLE HELP!!!
- 1992 lumina heater/ac problem
- ignition security system
- where's the button??
- PLEASE HELP!! 96' lumina catalyst trouble code..cant figure it out!!!
- tranny problems, i think
- 90 lumina no hot accel.
- what's the point???
- I need help with a new '98 Chevy Lumina I purchased please
- 91 Lumina Coolant Leak?
- 2001 Lumina Front end rattle
- 96 a/c blowing hot...how to check fuse? Just a dummy here
- Help help help
- '97 Lumina A/C issue---HELP?
- my 90lumina euro
- Loud noise from rear of 93 Lumina Euro
- LTZ #'s
- Lumina UTE AND LTZ
- Low fuel pump voltage?
- 93 lumina ecm problem???
- bad radio reception
- Hello all. My 1999 Chevy Lumina for you to see.
- Engine codes
- cooling fan (main) will not turn off
- what to do???
- 90lumina idling @3000rpms?????
- Hey Guys Yep i got another problem
- where's that darn buzz coming from???
- undercoating?
- 96 lumina coolant leak & SES light
- Dead Radio
- How do i get into my car!!!!!
- '97 Lumina Shifting/Transmission/Idling Problems
- 97 Lumina LTZ Dual Zone Climate Control Issue
- 1998 lumina air cond- mixing valve
- 92 Eurosport Battery Removal
- 1995 lumina runs HOT
- what else to check??
- This problem needs to end!!
- Can i put a lumina motor in a cavalier?
- 97 Lumina Engine Heats up
- 90 Lumina
- 98 3.8L cranks but wont start
- Transmission problem
- Running Issues
- 1996 Lumina DIFFERENTIAL PRESSURE SENSOR
- fuel injector cleaner?
- 91 Lumina 3.1 V6 quits when it feels like it..
- Should I buy 1992 lumina euro???
- AC ??? 2001 136,000 mi
- 1996 Lumina intermittent problems
- A/C Service?
- Time for the Graveyard? (97)
- car cover.....somebody....please
- Engine Torque Strut
- 95 Lumina dies suddenly at 50mph and at stop light
- MAP sensor
- alternative to armor all?
- normal???
- 93 lumina, Heating/cooling- direction?
- 1997 Lumina A/C question
- chevy lumina rest in peace
- Can anyone help me here?
- help! ignition problems
- Easiest Question on the Forums!!!!
- 1997 Lumina 3.1 parting out or whole
- best engine???
- coolant
- Brake lights
- 97 lumina waterpump bolt torque setting
- BIG engine Trouble I Think 97 3.1 Lumi... HELP!!!
- 1998 chevy lumina (broken axel)
- car cover
- '93 Coolant leak, oil fine, pump, heater core/pipe OK near fire wall pass side HELP!
- Cooling fan not working
- High/Low Beams
- what price??
- luminn 1998 3.1 spark plugs help
- LT.carguy has a leak
- 3.1 Fresh top end, now zero compression. Help
- AC 1998 lumina 3.1
- 98 Lumina LTZ Service Engine / Idle Problem
- Odd problem
- Check it out
- 92 3.1 Lumina missing
