View Full Version : Lumina
- electronic fuel cutoff
- Replace Spark Plugs 98 Lumina 3,8
- 99 Lumina fuel tank and filler neck replacement
- starts but wont run
- need some help please.....
- a/c problems
- 1997 Lumina 3.1 thermostat change
- 96 Lumina takes couple minutes to start
- 99 lumina oil light
- Want to convert my 97 LS to a LTZ
- 97 Lumina Starting Problem - Please help!
- '96 Lumina Van Won't Idle
- No interior electrical
- transmission shift problem
- 91 3.1 Lumina Starting Problems
- 1990 Lumina won't start when hot
- Just a quick question.
- need a little help with locating tdc
- Metal coolant bypass hose
- brakes?.. maybe
- '92 Z-34 was not enough....
- the jerking is back
- 91 Lumina 3.4 Injectors Pumping too much gas in chambers
- 94 lumina wont shift to 3rd
- 93 lumina cranks/no start-computer throwing weird codes
- 96 3.1 automatic transmission issues
- Need location of
- 95 Lumina 3100 Winding Noise Aud/Vid posted Please Help!!!
- 91 Lumina ~ Quit Running
- Brake light and ABS light stay "ON"
- Motor Mounts
- 1999 Lumina 3.1 Oil in the coolant system
- 97 Lumina flickring lights
- driver window
- Tranny
- 91 Lumina 3.4 No Go AGain Ugh
- wheel noise
- 97 Lumina Power steering and flickring lights
- Crank Position Sensor - '93 3.1 Euro
- 97 Lumina Radio Locked
- 95 lumina no hot restart
- tired
- Turn signal problem
- coolant reservoir
- Surging
- ABS and Brake light
- 1993 Lumina wont run right!!
- changing tranny oil
- 3.4L D.O.H.C Camshaft Carrier Removal with lifters
- FIRE in the rim!
- Cranking two or three times when warm....
- Testing Crank Shaft Sensor on a 1991 Z34 Help Please
- Removing A/C compressor on 1993 Z34
- 3.8 L in 92 Lumina
- 91 Lumina 3.4 Engine Oil Pan Crank Sensor Removal
- cooling problem
- Lumina 1997 Crank no start
- 1994 Chevy Lumina brake lights
- I need help PLEASE
- 2004 Lumina Headers
- Timing Cover Gasket 1997 Lumina
- 97 chevy lumina belt problem
- Brake Light Warning On - 99 Lumina - HELP!
- '97 Lumina strange lack of power---HELP?
- 95 lumina transmission od issues I think
- Replacement Engine for the Z34
- 93 euro tilt steering broken
- 94 euro idles high bucks at high speed
- 93 euro low coolant light
- 93 euro turn signal failure
- 1998 Camshaft Positioning Sensor
- 91 Lumina z34 Where is Crank Shaft Sensor
- 90 lumina stereo wiring diagram
- Intake gasket and valve settings
- help 98 lumina
- parking brake
- 91 Lumina 3.4 engine Engine Shut Down at Intersection
- 97 lumina - starting problem
- Rear caliper
- lumina runs great except at idle
- 93 lumina
- 96 Lumina Hesitation
- help with coolant temp sensor
- emission questions
- 92 lumina
- Volts Light AND Power Steering Failure?
- Break lights
- Power window
- AC Blower inop
- 1990 lumina, doesn't start/goes out, lights flickering, relay clicking
- Fusible links?
- Head Removal 3.4L D.O.H.C
- Head Gasket
- No pressure to rear right brake
- no tail lights
- Shifting and AC..
- replacing heater core
- help!! with lumina
- Lifter replacement In 96 3.1
- 98 lumina power seat
- Lumina Electrical Issues
- Lumina Hesitates
- another brake question
- Homelink Mods
- '92, Lumina, 3.1L, PCV Location?
- Lumina Transmission Swap with GM
- Lumina computer problems???
- Bleeding Air From Coolant System
- Rich, BB, Max, etc, I need serious help
- lousy lumi' brakes!
- 1991 Lumina died
- Headlight Installation
- 97 Lumina- check eng light & gas tank
- 93 Lumina 3.1L - Hesitation. Injecters? Solution?
- 1990 Lumina Acceleration Problems, help!
- 90 Lumina..crank no start
- 96 lumina evaporator
- Evaporative emission control malfuction
- 1998 lumina thermostat location???
- I need Help Like NOW!!!!
- 97 Lumina Intermittant Starting Problems
- governor on my 91
- Replacing brake lights
- 1991 Lumina Speedometer and Low Coolant Light
- 94 Lumina, A/C Turned on/blew Pwr dr/wndws
- 95 3.4L Lumina Cranks, No Start
- 2007 Lumina SS
- New heads, still runs hot
- 97 3.1 Power Steering Pulley
- 97 Lumina shift solenoid
- 97 Lumina Speedo
- 92 Lumina 3.1L starts and drives but sputters/dies intermittently
- 1990 Lumina Problems..
- 1993 Lumina Driveablilty problems
- 98 Chevy Lumina, Low coolant temp
- 1999 Lumina LTZ Stalling at will
- 1991 No start
- 1995 Lumina ABS issue
- 93 Lumina won't accelerate
- Wheel size question
- 91 lumina that thought had a vaccum leak
- Need help with a 93 lumina that will crank but won't start
- Help on a 2.5L GM engine, please look for just one second :)
- Fuel gage not working
- 98 Exhaust
- size of gas tank? 98 lumina ltz?
- Transmission Broken?
- 92 Lumina speedometer quits and car stalls
- 1991 Euro
- part numbers please + surging vehicles
- 92 lumina starts then stalls
- 95 lumina transmission fluid lines
- Mistake on my 1999 LTZ?
- 1990 lumina 2.5L 4 cyl wont restart
- 96 lumina a/c
- 1990 Lumina concerns
- more power for my 91
- Fuel pump
- low gas milage 98 ltz
- 3800 series II? whats so special about them?
- overheating problems again!!
- Strut mount or strut?
- Question? 3.4L D.O.H.C
- 3.1L Code 171/300 - Loss of power
- 95 Lumina problems
- Hub assembly Torque
- 91 lumina problem?
- 91 Lumina 3.1 Tranny Or Stuck Brakes
- 1992 Lumina
- Please Help. 91 Lumina 3.1 Water Pump replacement
- 90 Lumina, please help
- 90 Lumina no dash lights.
- 1995 lumina wont run after rolling car
- 1002 Chevy Lumina Stalls..Help!!!
- 93 lumina Z34 3.4 runs tell it is warm and dies
- Racing seats
- security light on 2001 lumina???
- rocker arms
- chvyman1?????????
- coolant sensor
- measurement for lumina?
- driver door lock gets stuck
- 98 3.1 =16 mpg city-
- electric locks and dome light
- ReUpholster, Lower trim on door panels.
- 98 Lumina LTZ
- 1991 Lumina 3.1 No spark...
- 1990 Lumina jerks when accelerating
- CARFAX Anyone???????
- 98 brake problem(non abs)=
- Brake job not going smoothly...
- Need window help!!!
- Mishap with the 1999 LTZ
- ABS - 1992 Lumina - Please Help!
- Just got a 92' Lumiona Euro 3.1
- Proper valve adjustment procedure
- Wheel Bearing
- Grand Am misfires only in park and neutral
- Custom Brakes needed For 93
- 98 chevy lumina
- Hesitation When Accerlated
- Fuel Problem
- Help, Me Throw Some Seats on this...
- 1993 Z-34,3.4,no Timing Marks!
- 93 lumina will not start due to no spark
- A/C leak
- Stalling and Starting issues.
- Replace condensor.. How too?
- '98 3.8L With Coolant Leak
- Nee Help with Engine
- p1870 code
- Major Gas Mileage Improvement
- Wheel Stud replacement
- Internal Engine Parts
- Need Help!! 99 Lumina LTZ problems.
- Internal engine
- Lumina:Window Not Working!
- 1990 Chevy Lumina Stalled & Won't Start.
- 99 Lumina Break Issues
- Lumina door lock dont work...
- 1991 lumina 3.1 will crank but no start
- Lumina 97 - ABS and BRAKE lights
- 93 lumina electrical ??
- steering wheel controls
- please help! major electrical problem with my van
- wierd science question=
- 1996 Chev Lumina lost key.....
- 1993 Lumina Fuel Problems??
- 1998 Lumina Wiring Question
- PCV system / purge solenoid
- 1994 Lumina Problem - Possibly Fuel Related
- 90 Lumina 3.1 no accel
- More Help needed PLEASE...95 Lumina still wont run
- Engine crossmatch for a 95 Lumina with a 3.1
- din size?
- Speedo calibration??
- Lower Intake Manifold Off. Now What
- BAD brakes
- '92 front coil replacement Lumina Z-34
- Drivers window stuck?
- 94 Lumina idle lowers & sometimes stalls at stop signs etc
- lighting woos
- '98 Lumina LTZ 3.8 - Serp belt
- painting question
- new to forums having problems with 95
- 1996 Lumina is getting Harder to Start
- upgrading alternator
- Child Proof Windows. Disableing?
- LTZ Interior Light Problems
Automotive Network, Inc., Copyright ©2012
