View Full Version : Lumina
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. Cat converter replacement 93 3.1 ?
  2. 93 Lumina radio harness gone?
  3. Please help me figure out this noise in the front of my 93' Euro
  4. 94 Chevy Lumina 3.1 Euro - No Reverse
  5. 1992 Lumina Z34 wont start. Help
  6. beginner intake question
  7. 97 Lumina steering column
  8. 1998 Lumina High RPM's
  9. 93 Lumina did back brakes now leaking
  10. '94 Lumina Euro 3.1 fuel problem?
  11. 1997, 3.1l Lumina - ignition mystery?
  12. Location of crank position sensor on 3.1L
  13. 1999 Lumina LTZ Brakes
  14. 90 Lumina 3.1 dies at acceleration
  15. 1998 Lumina wont shift into gear
  16. 93 Lumina brake light on?
  17. Intake question
  18. 97 lumina, sudden stall and no start
  19. 97 lumina, sudden stall and no start
  20. 1991 Lumina Euro wont start
  21. 1999 Lumina Shuts Off
  22. Odd question
  23. Headlights
  24. 97 Lumina front-end vibration
  25. Cooling System Help....96 Lumina
  26. car only starts atfer it sits for 10 min
  27. 1997 Lumina shakes when braking.
  28. 96 Lumina 3.1 P0420
  29. '98 Lumina won't run
  30. Would you buy again??
  31. Brakes and
  32. 1992 Lumina Z34 idle problem when cold
  33. Power Window Pooped Out
  34. Strut cartridge is off-center!
  35. 93 Chevy Lumina Z34 Coupe
  36. head swap?
  37. 92 Lumina speedo issues
  38. new fuel pump won't stay running
  39. Low Coolant Temperature
  40. Code 32
  41. coolant leak?
  42. 1998 Lumina - Can't shift into gear. Gear shifter button wont push in.
  43. Just did back pads...pad fallin apart?
  44. 1995 Chevy Lumina Won't Start
  45. Blower Motor
  46. W-Body 4T60-E Transmission Problems
  47. 1996 Lumina Stalls and Misses
  48. Service Engine Light
  49. Coolant???? Going where????
  50. Pulley noise?
  51. "granny cars"
  52. Another head question(s)
  53. head gasket cost?
  54. head bolt(s)
  55. Radio removal '99 lumina
  56. Seedometer 2x actual speed?
  57. Lumina hesitation when warm
  58. 1993 Lumina leaking yellow ooze
  59. 92 Lumina 3.1 Corroded Quick Connect Cooling Fitting
  60. 1998 Chevy Lumina stalls while driving...
  61. 1992 Z34 wont start
  62. alternator
  63. New here with prob (go figure huh)
  64. rear strut
  65. heater core bleeder valve
  66. dexcool and electricty
  67. Oil in plenum
  68. ramps
  69. 98 int.manifold job update=
  70. Budsocks
  71. Did back brakes problems still
  72. rear-end creaking
  73. Low Trac Light!
  74. 1992 Z34 Lumina stalling
  75. HELP ME PLZ. Need to replace inner tie-rod
  76. 95 Lumina, Need advice about tranny + Dimmer light
  77. Window falling off track...
  78. Changing my -96 Lumina to -96 Lumina LS?
  79. Any tips? 91 "Parts Car" to 90 dead engine car
  80. 91 Lumina Oil Problem
  81. 92 Lumina rough idle at first,then surges.
  82. 96 lumina throwing code 306
  83. Lumina 93, 3.1 starting mystery.
  84. 1998 lumina electrical problems
  85. security light on dash
  86. 2001 Lumina Oil Filter Question
  87. unknown warning light
  88. Brakes 93 Lumina
  89. Motor mounts or tranny?
  90. 3.1 vs 3.4
  91. 1990 lumina no spark 3.1
  92. follow up on no voltage to fuel pump
  93. 1998 Lumina Heater Not blowing hot air
  94. Lumina stalled out multiple times tonight
  95. temp
  96. Head Gasket Kit Question
  97. Loud Chirping/Squeak Sound
  98. 95 Lumina will not start
  99. egr question
  100. no voltage to fuel pump
  101. Lumina Issues Ugh...
  102. SES light 93
  103. Service Engine Soon - #2 Cylinder
  104. Defrost button
  105. can't open driver door
  106. 98 lumina transmission question
  107. Trans jerk BOOO
  108. timing chain
  109. Clacking noise when brakes are initally applied in morning
  110. crankshaft position sensor
  111. NEw to Luminas
  112. Engine Removal
  113. 91 Lumina 3.1 "T" will not start
  114. 95 Lumina Heater
  115. Got rid of Lumina - thanks - off to F Body Camaro
  116. Belt tensioner question
  117. 93 Lumina not smooth.......
  118. transmission on 92 Z34
  119. what goes here?
  120. 3.1 swap update
  121. Flywheel breaks on 1996 3.1 Lumina
  122. 3.8 Supercharger engine swap
  123. Rack & Pinion Problems
  124. engine revs on its own
  125. wheel bearing
  126. '90-92 3.1 swap
  127. How to fix a short circuit?
  128. 97 lumina oil pump
  129. 98 Lumina 3.1 Lights Flickering
  130. Parting out 91 Lumina Euro 3.1L
  131. Questions about replacing rear strut mount
  132. 1992 Lumina Euro 3.1L won't crank
  133. 1995 lumina has thick gunk in engine ...
  134. 98 lumina stalls at operating temp! help plz
  135. tranny leak
  136. best 93 Lowering Spring???
  137. dimmer switch?
  138. how to set camshaft in timing?
  139. Overheating or bad temp gage?
  140. 97 lumina dash lights-ON then OFF??? HELP!!
  141. 92 After start, Lumina dies from standstill
  142. Lumina Z34 '92 wont crank
  143. Turn signal wand
  144. fixing a manifold coolant leak
  145. 1998 LTZ Sputters While Driving
  146. 91 chevy lumina z34 engine swap
  147. 1998 Lumina Exhaust? Problems HELP
  148. 90 Lumina Euor 3.1L Passing Gear Problems
  149. 97 lumina steering rack?
  150. anyone parting out there 97 lumina
  151. MAP sensor 95 lumina
  152. whining noise from middle/rear of 98 3.1L
  153. 96 Lumina 3.1 NO FUEL PRESSURE AT ALL HELP, please!!
  154. Changing the radio
  155. 96 Lumina remove door panel?
  156. 94 Lumina Euro overheating
  157. 94 3.1 euro tranny problems?
  158. Brake routing diagram? (93)
  159. gas mileage question
  160. stupid wiper question
  161. need help w/ stalling
  162. Rear brakes rub when first starting out
  163. Tranny replacement
  164. Excessive air pressure when removing 1992 Lumina gas cap
  165. How to tell if inner or outer tie rod bad
  166. How to tell if muffler bad in 1992 Lumina
  167. any helpful hints on tranny filter change ?
  168. What should I do part it or sell it whole?
  169. 1997 Lumina wont start
  170. These Wipers Suck!
  171. int manifold torque =-??
  172. 1998 3.1 leaking coolant
  173. 90 Lumina-dies at light-check engine-over 45 drags
  174. Weird Noise From Rear
  175. service engine soon light
  176. front passenger window motor
  177. 91 Lumina ECM issue
  178. Shifting problems
  179. NEED help Fuel problem
  180. how to read codes on 95 lumina
  181. what tranny?
  182. abs light
  183. shift lever difficulty=
  184. 1991 Lumina Euro 3.1 Need Some Help
  185. 205/70/R15 Stock Size
  186. How High Can They Go?
  187. help with 1991 lumina
  188. Body Parts?!
  189. '92 Lumina 3.1 No forward only reverse
  190. a/c problems
  191. 91 Chevy Lumina
  192. Clunk noise
  193. Humming noise around Power steering pump or alternator!!
  194. HELP! fast please
  195. 98 lumina LTZ
  196. 98 lumina starter?
  197. clunking noise please help
  198. **97' lumina- Question Please Help!!!!!!!!!
  199. Milage per tank for 97 Lumina
  200. A Lumina Story
  201. how to replace master cylinder
  202. Wiper problems
  203. Strut cartridge pulls toward center of 94 lumina.
  204. turn signal arm wont click back...help?
  205. 97 lumina wont start
  206. 1995 Lumina with 3.4L DOHC + leaking oil distribution cover
  207. 92 chevy lumia radio removal
  208. 93 Euro Problems.
  209. 1998 cool system bleed valves =-
  210. 98 rad cap question =-
  211. 5 prong trans conecter to 4 prong
  212. gm 3.1 misfire
  213. ABS light on...?
  214. Anti Lock light on Dash
  215. Engine swap
  216. Chevy Decal
  217. have you ever
  218. Typical 90 3.1 Lumina issue
  219. Battery Light on Dash 93 euro
  220. 93 Euro fuel pump or starter problem?
  221. Check engine light
  222. 95 lumina dead
  223. Frozen Air Compressor
  224. 98 lumina hesitation on inclines
  225. changing crank position sensor
  226. I believe it is the starter
  227. Bad Tranny or electrical
  228. cost of these repairs.
  229. Location of ECM
  230. Engine Theft Lock?? Anyone???
  231. 95 chevy lumina blows cold air only
  232. PCV valve hose part #?
  233. Replaced Head Gasket - Knocking??
  234. engine computer question
  235. Not starting when warm
  236. oil pressure gauge?
  237. Bulbs
  238. remote starters with keyless entry
  239. Kocking.. Won't Start
  240. wont start on gas
  241. Will not start
  242. 90 lumina idle speed
  243. Heater
  244. Top Speed
  245. 1996 Lumina Headlights stopped working
  246. Replacing the cigarette lighter in a 1990 Lumina
  247. It's doing it again
  248. exhaust clatter
  249. what is going on??
  250. engine computer
