View Full Version : Lumina
- Major Gas Mileage Improvement
- Wheel Stud replacement
- Internal Engine Parts
- Need Help!! 99 Lumina LTZ problems.
- Internal engine
- Lumina:Window Not Working!
- 1990 Chevy Lumina Stalled & Won't Start.
- 99 Lumina Break Issues
- Lumina door lock dont work...
- 1991 lumina 3.1 will crank but no start
- Lumina 97 - ABS and BRAKE lights
- 93 lumina electrical ??
- steering wheel controls
- please help! major electrical problem with my van
- wierd science question=
- 1996 Chev Lumina lost key.....
- 1993 Lumina Fuel Problems??
- 1998 Lumina Wiring Question
- PCV system / purge solenoid
- 1994 Lumina Problem - Possibly Fuel Related
- 90 Lumina 3.1 no accel
- More Help needed PLEASE...95 Lumina still wont run
- Engine crossmatch for a 95 Lumina with a 3.1
- din size?
- Speedo calibration??
- Lower Intake Manifold Off. Now What
- BAD brakes
- '92 front coil replacement Lumina Z-34
- Drivers window stuck?
- 94 Lumina idle lowers & sometimes stalls at stop signs etc
- lighting woos
- '98 Lumina LTZ 3.8 - Serp belt
- painting question
- new to forums having problems with 95
- 1996 Lumina is getting Harder to Start
- upgrading alternator
- Child Proof Windows. Disableing?
- LTZ Interior Light Problems
- 95 lumina engine temp problem??
- Probs with 90 Lumina
- big puddle = big problem
- 97 Lumina throwing codes...
- Car wont start, Gas in Oil...PLEASE HELP???
- 98 Lumina with turn signal problems
- HVAC - burnt out lights
- 1988-1995 Lumina repair manuals
- crank position sensor
- 95 Lumina Overheating
- Best way of removing ball joint rivets on '96 Lumina?
- 97 lumina: I need help taking the factory radio out
- '92 Lumina 3.1L start fine but sputter after warming up.
- 90 Lumina Euro Question (Weirdness in the RPM's)
- 2000 lumina smell antifreeze
- intake manifold gasket how to help
- 93 Lumina dies while driving
- 1990 lumina 3.1 idles, wont stay running
- 98 Lumina LTZ Electric "pulse"
- How to change battery 1997 Lumina
- High Idling
- bob
- 91 Lumina won't start
- transmission swapping
- electrical problem with a 95, classifieds?
- Idles rough then surges
- checking 3.1 injectors
- 93 z34 cant get timing set
- 1993 no start
- Engine lagging, help me guys.
- rust issues
- cracked windshield
- air cond. not working
- 97 3.1 Lumina Overheating..?
- Replacing Radiator...Need Help &Tips
- 1991 Chevy Lumina
- 91 3.1 lumina wont stay running after exhaust repair
- 97 lumina block heater?
- Oil pan removal
- 91 3.4 Lumina Misfiring
- Fuel gauge is bouncing.....
- 92 lumina no air out of vents at all
- Many interior lights out
- common lumina problem?
- My 92 Lumina needs help, runs like it has a rev limiter on it
- lumina is idling high
- amp install help
- 91 3.4 Lumina Spark Plug Gap Setting
- Problems after Warmup
- 96 lumina sedan 3100 motor missing on accelaration
- fuse box 2000 chevy lumina
- Poor mpg
- Power Window and Door Lock Switch?
- Could someone help me with a problem (Possible Leaf Spring?)
- ABS issues "abnormal" constant "clicking"
- 1996 Lumina hesitates when hot
- '92 3.1 Lumina Coolant Temp Light
- Need "How to" inst for a/c clutch removal
- need to know where the wires go on a 99 lumina 3.1 starter
- Help with Relay switch housing (corroded)
- This Sucks.....
- Reoccuring Tire Wear Problem
- Wiper Arm part numbers?
- 91 3.4 Lumina What Spark Plugs To Choose
- Fuel gauge problem
- Anyone have any idea's?
- Computer Module
- is head gasket blown and what can be done
- 1999 Lumina 3.1
- exterior mods?
- 97 Lumina brown foam in EGR
- 98 Lumina Cyl 6 Misfire.
- 90 lumina OBDI code 42
- Instrument panel bulbs
- What are my chances...
- 99 Lumina LTZ 3.8L Coolant level sensor?
- Factory GM Transmission Cooler for the Lumina
- Lumina tire size change??
- Do you own an LTZ?
- Brake shudder- 95 Lumina 3.1 Car
- New heads,, now it wont start
- 90 lumina euro stereo amplified question
- Crank Position Sensor
- Problems pushing button in to engage shifting
- 96-97 Engine Pics Requested
- irratic idle 98,3.1
- Scavenging Euro Parts
- AC knob does work, but the air is coming only through win and under
- 98 Lumina LTZ 3.8 with upper plenum coolant leak.
- 96 3.1 check engine shows 0401 code
- Chg Oil Soon!
- 98 LTZ Engine Knock
- 96 3.1 Oil in Coolant
- Changing Doors On A Lumina Ltz
- 92 Lumina Z34 Will Not Start
- 96 3.1 check engine shows misfire
- need help with tapping noise
- 92 starting problems
- 1998 lumina 3.1 intake
- Water in trunk!!!
- Thank you
- fule pump?
- 99 Lumina LTZ 3.8L Surges at idle sometimes
- 1997 with problems?
- radiator overflow tank question
- Charging Problem
- 95 lumina overheating problem
- cars slugish
- 98 Lumina Body
- Passenger Air Bag
- Bypass AC?
- Headlights don't flash.
- 92 lumina - blown fuel pump fuse
- Still having problems
- winter gas mileage?
- 92 lumina z34 stalled driving down the highway
- '97 tranny problem
- 91 3.4 Lumina Sputters? whats up with that
- 1993 Lumina with overdrive, How fast on D?
- Question about service engine soon light
- Lumina '93 V6 3.1, 200K - Oil question
- 1990 Chev Lumina Oil Pressure
- Using parts from other GM cars
- Should I Replace the Transmission or Fix it?
- 97 lumina.....service engine soon light?
- No Pressure, but have heat and temperature
- 98 lumina ltz stalls which slowing down
- location of coolant bleeder valves
- 91 Lumina New Water Pump Broke???
- 96 Lumina daytime running lights quit working
- Engine Swap From 96 Malibu 3100 Series To 91 Lumina
- 1998 ,water pump question =
- Flutter, shutter, skip, ~ minor annoyance
- New computer?
- Shudders When Idling
- 91 lumina euro will not accelerate past 25 mph
- ecm fuse blows 96 lumina 3.1l
- Fuel Filter
- 91 3.4 lumina Water Pump removal
- t-stat lumina
- Another possible head gasket....
- Transmission Pan
- 1995 Lumina with several odd probs
- heater problem
- 1997 Lumina....Squeak Over Bumps LOL
- Bad ECM?
- spark plugs
- So many lights
- Z34 Leaking Coolant Under AC Compressor
- taking anti freeze
- 98 Lumina loses all electrical power
- 95 Lumina car exhaust manifold
- average mpg
- 95 lumina shifting problems
- 95 Olds Silhouette EGR Valve
- Getting Spare down when Hatch won't open
- Location of TCC plug
- ecm?? just stoped workin
- help 98 lumina 3.1 coolant loss
- 1991 Z34 Exterior Door Handle Replacement
- Spark plug wiring
- Battery
- 1997 Lumina with a screwy gas guage
- 98 Lumina Head Gasket Problem
- need suggestions on car problem
- Need Parts& Assistance! 92' Z34 V6 3.4l 2door Red
- 97 Lumina Passenger Door parts
- 1998 hard starting=
- hot motor,cold radiator,no heat
- 98 lumina
- Replaced motor mount, torque struts, and trans mount on 93' Euro, still have noise :(
- Charging the battery
- 94 Lumina Overheat/Thermostat
- 91 3.1 problems again!
- Low Trac Light
- 91 Lumina Tach and Speedo Help!
- 96 C hevey Lumnia Wont Start
- Is this a fuel pump going out?
- 91 lumina seats
- 1992 leaf spring removal technic
- 95 Lumina problems
- Chevy lumia z34 smoking
- low coolant sensor goes on what direction?
- crank pulley won't turn
- 92 Lumina Z34 3.4 Wants to start, won't
- Something sings in front
- 95 Lumina Down Shift Problem
- Need to replace motor mount and trans mount on my 93' 3.1 Euro, anyone done this?
- Failed Emmision test
- Antifreeze question
- rear of car sitting low
- Winter Problem
- Remote door lock question
- What can you people tell me about a 94 Lumina APV?
- 92' CHEVY Lumina z34 Stalling out
- brake lights out
- Removing blinker switch 93 Lumina
- Power issue ??
- Cooling System problem ??
- 1996 lumina timeing belt
- opinions on 92 lumina Z34 value
- Bent rim
- 1990 Eurosport 3.1 stalled...no start
- Coolant problem?
- Stainless Steel Brake Lines
- Help PLEASE!!! 2000 Lumina 3.1 wont start
- PASS-Key II
- No electricity!
- Lumina Engine Problems/ Running Lean
- Signal
- Low Coolant Light
- Alloy Rims - 15??? WHAT???
