View Full Version : Lumina
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. 92 Lumina Engine issue
  2. Question about rad fans for 1996 3.1
  3. Need Brake light help!!
  4. 2000 lumina engine noise
  5. 2000 lumina door lock problems
  6. Vents only work on high!!
  7. Satellite Radio Installation
  8. Question about wobbling sound from right rear
  9. Need help with 1991 Lumina
  10. brake rattle
  11. Lumina 95 Headgasket question
  12. 95 Lumina 3.4L DOHC
  13. Automatic transmission "clutch" noise
  14. 1990 lumina body kits?
  15. 93 lumina starts but but wont stay on
  16. 91 Lumina z34 Regulator or Not? Help please
  17. 91 lumina 3.1 engine trouble
  18. CV Axle
  19. 96 lumina starting trouble
  20. 92 lumina 3.1 top end oil leak
  21. 1995 Lumina not dispensing winshield fluid...
  22. 1996 Lumina no start...Passkey??
  23. 90 3.1 wont start
  24. Recharging A/C .. Need Help
  25. amplifier wire route?
  26. 1991 Problems
  27. Transmissions..ugh
  28. Voltage draw at the battery
  29. Hot Stall-No Start
  30. Do i have a turbo?
  31. Yet Another Intake Question
  32. 91' 3.1 wont stay running
  33. Engine Code P1133 ,???
  34. '95 Lumina sedan turn signal/hazard not working...
  35. 96-3.1 Lumina-TopEnd Ping Noise
  36. electronic fuel cutoff
  37. Replace Spark Plugs 98 Lumina 3,8
  38. 99 Lumina fuel tank and filler neck replacement
  39. starts but wont run
  40. need some help please.....
  41. a/c problems
  42. 1997 Lumina 3.1 thermostat change
  43. 96 Lumina takes couple minutes to start
  44. 99 lumina oil light
  45. Want to convert my 97 LS to a LTZ
  46. 97 Lumina Starting Problem - Please help!
  47. '96 Lumina Van Won't Idle
  48. No interior electrical
  49. transmission shift problem
  50. 91 3.1 Lumina Starting Problems
  51. 1990 Lumina won't start when hot
  52. Just a quick question.
  53. need a little help with locating tdc
  54. Metal coolant bypass hose
  55. brakes?.. maybe
  56. '92 Z-34 was not enough....
  57. the jerking is back
  58. 91 Lumina 3.4 Injectors Pumping too much gas in chambers
  59. 94 lumina wont shift to 3rd
  60. 93 lumina cranks/no start-computer throwing weird codes
  61. 96 3.1 automatic transmission issues
  62. Need location of
  63. 95 Lumina 3100 Winding Noise Aud/Vid posted Please Help!!!
  64. 91 Lumina ~ Quit Running
  65. Brake light and ABS light stay "ON"
  66. Motor Mounts
  67. 1999 Lumina 3.1 Oil in the coolant system
  68. 97 Lumina flickring lights
  69. driver window
  70. Tranny
  71. 97 Lumina flickring lights
  72. 91 Lumina 3.4 No Go AGain Ugh
  73. wheel noise
  74. 97 Lumina Power steering and flickring lights
  75. Crank Position Sensor - '93 3.1 Euro
  76. 97 Lumina Radio Locked
  77. 95 lumina no hot restart
  78. tired
  79. Turn signal problem
  80. coolant reservoir
  81. Surging
  82. ABS and Brake light
  83. 1993 Lumina wont run right!!
  84. changing tranny oil
  85. 3.4L D.O.H.C Camshaft Carrier Removal with lifters
  86. FIRE in the rim!
  87. Cranking two or three times when warm....
  88. Testing Crank Shaft Sensor on a 1991 Z34 Help Please
  89. Removing A/C compressor on 1993 Z34
  90. 3.8 L in 92 Lumina
  91. 91 Lumina 3.4 Engine Oil Pan Crank Sensor Removal
  92. cooling problem
  93. Lumina 1997 Crank no start
  94. 1994 Chevy Lumina brake lights
  95. I need help PLEASE
  96. 2004 Lumina Headers
  97. Timing Cover Gasket 1997 Lumina
  98. 97 chevy lumina belt problem
  99. Brake Light Warning On - 99 Lumina - HELP!
  100. '97 Lumina strange lack of power---HELP?
  101. 95 lumina transmission od issues I think
  102. Replacement Engine for the Z34
  103. 93 euro tilt steering broken
  104. 94 euro idles high bucks at high speed
  105. 93 euro low coolant light
  106. 93 euro turn signal failure
  107. 1998 Camshaft Positioning Sensor
  108. 91 Lumina z34 Where is Crank Shaft Sensor
  109. 90 lumina stereo wiring diagram
  110. Intake gasket and valve settings
  111. help 98 lumina
  112. parking brake
  113. 91 Lumina 3.4 engine Engine Shut Down at Intersection
  114. 97 lumina - starting problem
  115. Rear caliper
  116. lumina runs great except at idle
  117. 93 lumina
  118. 96 Lumina Hesitation
  119. help with coolant temp sensor
  120. emission questions
  121. 92 lumina
  122. Volts Light AND Power Steering Failure?
  123. Break lights
  124. Power window
  125. AC Blower inop
  126. 1990 lumina, doesn't start/goes out, lights flickering, relay clicking
  127. Fusible links?
  128. Head Removal 3.4L D.O.H.C
  129. Head Gasket
  130. No pressure to rear right brake
  131. no tail lights
  132. Shifting and AC..
  133. replacing heater core
  134. help!! with lumina
  135. Lifter replacement In 96 3.1
  136. 98 lumina power seat
  137. Lumina Electrical Issues
  138. Lumina Hesitates
  139. another brake question
  140. Homelink Mods
  141. '92, Lumina, 3.1L, PCV Location?
  142. Lumina Transmission Swap with GM
  143. Lumina computer problems???
  144. Bleeding Air From Coolant System
  145. Rich, BB, Max, etc, I need serious help
  146. lousy lumi' brakes!
  147. 1991 Lumina died
  148. Headlight Installation
  149. 97 Lumina- check eng light & gas tank
  150. 93 Lumina 3.1L - Hesitation. Injecters? Solution?
  151. 1990 Lumina Acceleration Problems, help!
  152. 90 Lumina..crank no start
  153. 96 lumina evaporator
  154. Evaporative emission control malfuction
  155. 1998 lumina thermostat location???
  156. I need Help Like NOW!!!!
  157. 97 Lumina Intermittant Starting Problems
  158. governor on my 91
  159. Replacing brake lights
  160. 1991 Lumina Speedometer and Low Coolant Light
  161. 94 Lumina, A/C Turned on/blew Pwr dr/wndws
  162. 95 3.4L Lumina Cranks, No Start
  163. 2007 Lumina SS
  164. New heads, still runs hot
  165. 97 3.1 Power Steering Pulley
  166. 97 Lumina shift solenoid
  167. 97 Lumina Speedo
  168. 92 Lumina 3.1L starts and drives but sputters/dies intermittently
  169. 1990 Lumina Problems..
  170. 1993 Lumina Driveablilty problems
  171. 98 Chevy Lumina, Low coolant temp
  172. 1999 Lumina LTZ Stalling at will
  173. 1991 No start
  174. 1995 Lumina ABS issue
  175. 93 Lumina won't accelerate
  176. Wheel size question
  177. 91 lumina that thought had a vaccum leak
  178. Need help with a 93 lumina that will crank but won't start
  179. Help on a 2.5L GM engine, please look for just one second :)
  180. Fuel gage not working
  181. 98 Exhaust
  182. size of gas tank? 98 lumina ltz?
  183. Transmission Broken?
  184. 92 Lumina speedometer quits and car stalls
  185. 1991 Euro
  186. part numbers please + surging vehicles
  187. 92 lumina starts then stalls
  188. 95 lumina transmission fluid lines
  189. Mistake on my 1999 LTZ?
  190. 1990 lumina 2.5L 4 cyl wont restart
  191. 96 lumina a/c
  192. 1990 Lumina concerns
  193. more power for my 91
  194. Fuel pump
  195. low gas milage 98 ltz
  196. 3800 series II? whats so special about them?
  197. overheating problems again!!
  198. Strut mount or strut?
  199. Question? 3.4L D.O.H.C
  200. 3.1L Code 171/300 - Loss of power
  201. 95 Lumina problems
  202. Hub assembly Torque
  203. 91 lumina problem?
  204. 91 Lumina 3.1 Tranny Or Stuck Brakes
  205. 1992 Lumina
  206. Please Help. 91 Lumina 3.1 Water Pump replacement
  207. 90 Lumina, please help
  208. 90 Lumina no dash lights.
  209. 1995 lumina wont run after rolling car
  210. 1002 Chevy Lumina Stalls..Help!!!
  211. 93 lumina Z34 3.4 runs tell it is warm and dies
  212. Racing seats
  213. security light on 2001 lumina???
  214. rocker arms
  215. chvyman1?????????
  216. coolant sensor
  217. measurement for lumina?
  218. driver door lock gets stuck
  219. 98 3.1 =16 mpg city-
  220. electric locks and dome light
  221. ReUpholster, Lower trim on door panels.
  222. 98 Lumina LTZ
  223. 1991 Lumina 3.1 No spark...
  224. 1990 Lumina jerks when accelerating
  225. CARFAX Anyone???????
  226. 98 brake problem(non abs)=
  227. Brake job not going smoothly...
  228. Need window help!!!
  229. Mishap with the 1999 LTZ
  230. ABS - 1992 Lumina - Please Help!
  231. Just got a 92' Lumiona Euro 3.1
  232. Proper valve adjustment procedure
  233. Wheel Bearing
  234. Grand Am misfires only in park and neutral
  235. Custom Brakes needed For 93
  236. 98 chevy lumina
  237. Hesitation When Accerlated
  238. Fuel Problem
  239. Help, Me Throw Some Seats on this...
  240. 1993 Z-34,3.4,no Timing Marks!
  241. 93 lumina will not start due to no spark
  242. A/C leak
  243. Stalling and Starting issues.
  244. Replace condensor.. How too?
  245. '98 3.8L With Coolant Leak
  246. Nee Help with Engine
  247. p1870 code
  248. Major Gas Mileage Improvement
  249. Wheel Stud replacement
  250. Internal Engine Parts
