View Full Version : Lumina
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. 92' lumina question
  2. '92 Z34 Tranny problem?!?!? (Help Quick)
  3. 90 3.1 Lumina dies then starts when cool
  4. 96 3.1 head gasket help
  5. 1996 Lumina losing coolant, head gasket?
  6. Help with outside door trim - Newbie
  7. 90 Lumina Water Pump
  8. HELP - Messed up my rear disc brakes
  9. Problem with Flashlight
  10. Emergency Signals and Lights + more ('98)
  11. Anyone know how to troubleshoot.....
  12. Help!!! Driving it off a cliff
  13. fuel, but no spark
  14. overheating 96 3.1 Lumina
  15. 1992 3.1 lumina
  16. Lumina Z34 Transmission issues
  17. help with sopmething simple
  18. no start 97
  19. lpg conversion lumina
  20. 1996 3.1L running funny after rebuild
  21. problem aiming headlights
  22. low coolant but no light
  23. How do you time a 92 Chevy Lumina 3.1L
  24. 1993 Lumina 3.1 low idle when warm
  25. Lower intake gasket, which one?
  26. 92 3.1L V6 runs rough/stalls only after a hot soak.
  27. question about lumi wheels
  28. Hard hoses
  29. Rear Struts
  30. code 43...knock sensor
  31. 94 Lumina 3.1 cranks - won't start
  32. Blower motor speed varies with speed
  33. 96 Lumina - Noone knows how to fix (dealers/mechanics)
  34. 99 Lumina overheating
  35. pushrod mix up
  36. swaping lumina engines
  37. 3.1 engine swap has different wiring harness
  38. 95 lumina heater controls
  39. 95 lumina head gasket
  40. 93 chevy lumina runs choppy!
  41. gauges jump with key on but won't start
  42. 1996 Lumina Issues
  43. Radiator cap
  44. 93 service engine, high rev, gas sucker
  45. 98 Lumina Trans/Suspension?
  46. 95 lumina radio removal
  47. disable security system
  48. 97 Runs rough..
  49. 2000 Lumina 3.1L EGR error
  50. 93 Lumina Ignition Rack replacement.
  51. shut off my 93, now won't stay running
  52. Gas leak, and broken fuel injector retaining clips
  53. Oil Sending unit in 92 Lumina Z34
  54. cup holder repair=
  55. Another transmission thread 90 lumina
  56. power door lock problem
  57. Replacing a '97 tranny
  58. 95 Lumina Leaking Coolant and overheating
  59. Power Steering Power Shaft Sheered in half
  60. 1990 lumina. stalling problems
  61. New Parts
  62. Hard to find parts
  63. Change oil light reset
  64. multiple codes
  65. Lumina Gas Gauge
  66. 1992 lumina z34
  67. Door handle
  68. 94 Lumina Antifreeze
  69. @ a loss! gets warm and dies code 42
  70. 92 lumina running rough
  71. 96 lumina ls has srung a tranny leak
  72. 2007 lumina ss
  73. Abs Module 2000 Lumina
  74. 98 lumina front bearing hubs
  75. Hard-shift at 4th gear
  76. Lumina Wont Start
  77. Lumana won't start!!
  78. Stripped hex nut
  79. 97 Lumina oil light on
  80. ignition problem
  81. Charging the AC System condensor replacement
  82. 1996 Chevy Lumina ls 3100v6 - Lots of recent problems.
  83. licence plate bolts
  84. Split on CV joint boot
  85. On Boad Diagnostic System (OBD)
  86. Lumina 96' V6 to V4 conversion
  87. '90 sedan turn signal problems
  88. Lumia Temperature Gauge
  89. Can't unlock drivers door
  90. P0300 code - 1998 Lumina - barely runs
  91. lumina coolant
  92. 1995 Lumina suddenly oveheating
  93. Chugging problem in 95 lumina
  94. spark plug wiring order
  95. How do you find a particular terminal on the PCM?
  96. 1995 Lumina 3.1L valve adjustment procedure?
  97. 1995 Lumina - Running rich and dies
  98. 93 lumina stalled and wont start at all
  99. 94 Lumina Euro With Blown Engine....
  100. Radiator Leak
  101. Changing Z34 Starter... Need help
  102. i need help
  103. 94 lumina heater won't work likely cause?
  104. Poor idle, poor intake manifold vacuum
  105. question about camshaft position sensor
  106. Proscan OBDII system
  107. 93 Z34 wont rev over 3000rpm's
  108. question about 94 lumina with 3.1L
  109. Brake Lights on a 98 Lumina
  110. '90 2.5L now stutters (not right word) when accelerating and maintaining speed
  111. removing key while car running???
  112. 98 Lumina Lower Intake Gasket Issues
  113. hood cable handle broke
  114. 1990 lumina 2.5L firing sequence
  115. 1990 Lumina 2.5L ICM remove and replace guide
  116. dash board seperating and lifting
  117. Turn signals quit
  118. head gasket, intake gaskets?
  119. 93 3.1 Euro Lumina stalling
  120. weird colored antifreeze
  121. Service engine light , coolent light , chng oil soon light.
  122. smelling gas
  123. 1998 Lumina 3.1L belt or chain?
  124. instrument panel
  125. nosiey under high acceleration
  126. 98 Lumina Coolant System
  127. 97 lumina 3.1 intake gasket replacement
  128. 97 lumina with 3.1 transmission slipps only pulls in first gear
  129. Since winter is comming up
  130. water in exhaust???
  131. 96 Lumina Rough Idle, no brakes
  132. 98 lumina shifting problems
  133. '90 Lumina ignition control module r and r problems
  134. security light stuck on
  135. 93 3.1 Lumina Euro Fuel in Air Filter
  136. 99 Lumina LTZ Flasher unit?
  137. 1996 Chevy Lumina Security Key Resistor Overide, only $1.07 at Radio Shack
  138. Heat issue on my 96 3.1 Lumina
  139. 91 lumina loses fuel pressure
  140. code42
  141. 98 Lumina Shift knob button
  142. 1997 Lumina speedometer calibration
  143. 1997 Lumina surges @ 50 MPH
  144. 2001 Starter problems?
  145. 1990 2.5L MSD ignition control module, etc?
  146. Seeking info on lower ball joint removal
  147. 96 Lumina 3.4 Coolant Leak
  148. Cig lighter question
  149. 93 Z34 Oil leak under the intake manifold
  150. 1990 Lumina 2.5L backfiring?
  151. Lumina Euro 3.1 with Error Code 22 Hesitation surging
  152. Thermostat
  153. 97 Lumina DRL Module location
  154. '95 Lumina No Dash Lights
  155. 1999 Lumina Hesitating/lurching/bucking
  156. '90 model w/ multiple problems (Please Help)
  157. 1998 3.1 rpm,s surging=
  158. Need to replace intake manifold gasket on 3.1 lumina 2001
  159. 1998 Lumina turn signal/Brake light problems
  160. 91 Lumina Speed Sensor
  161. '99 chevy lumina keyless entry
  162. Cranking sound
  163. Radio question?
  164. whats a good price
  165. 93 lumina touchy gas in colder weather
  166. Horsepower question?
  167. bent control arm
  168. Radiator drain plug
  169. Low coolant light
  170. 2001 Lumina Engine Noise
  171. '94 Chevy Lumina Euro 3.1L T vin code, Engine erratic
  172. 95+ Lumina/Monte Carlo; same rear suspension?
  173. Transmission Limits?
  174. what do you make of this.....
  175. 91 chevy lumina brake lights
  176. 98 3.1 Starting Problem
  177. question on computers
  178. signal switch going bad...or "flasher"??
  179. 98 3.1 idles funny and sometimes stalls. need help!!!
  180. 93 Lumina 3.1 Starting problem!
  181. White build up on Plugs?
  182. '93 Lumina stalling everytime I brake...
  183. code 12
  184. Problems after plug replacement...
  185. Inst cluster dead
  186. Cassette deck is stuck on FF
  187. 95 lumina brake lights out
  188. 1 quick question
  189. fuel filter on 91 lumina
  190. idle air control
  191. 1993 - 3.1 - Rad. fans not working
  192. what now
  193. shift problem
  194. Lumina 1997, fuel gauge not working
  195. Timing Belt question
  196. Oil Drain Plug
  197. after i put on new timing chain
  198. Installing a Bypass pulley! Depressurizing AC System?
  199. 1997 lumina maf
  200. Current draw draining battery - how to fix?
  201. Whistle sound?
  202. set timing on 91 lumina
  203. 1999 3.1 Lumina T-stat replacement
  204. 1991 lumina Transmission problems??
  205. 93 3.1 Lumina ECM
  206. 98 Lum ina
  207. Service Engine Light 98 chevy Lumina
  208. 91 Euro trunk release button inop.
  209. Cruise Control
  210. Problem Removing Crankshaft Pully
  211. Transmission "popping" noise
  212. 1993 Lumina 3.1 issues
  213. 91 lumina euro keeps overheating chevalltheway
  214. 91 Lumina euro 3.1
  215. What type transmission 97' Lumina
  216. reading codes--need help
  217. 95 Lumina vapor lock???
  218. hello
  219. '92 Chevy Lumina: replacing lighter fuse
  220. Steering Problems In My Lumina
  221. after market part's
  222. 92 lumina wont start
  223. 95 Lumina rear strut bolts
  224. Lumina will not shift into 3rd gear!!
  225. change oil light keeps coming on
  226. underdash power connecter
  227. airbag snafu-2000 lumina
  228. 95 Lumina cranks wont start, Audio included
  229. 98 LTZ Sunroof stuck open
  230. vacuum resevoir?
  231. 91 Lumina Euro 3.1
  232. 91 Lumina Stalls when hot
  233. Z34 cranks but won't start!
  234. 2000 lumina key fob Transmitter Programming
  235. Should both fans run when started?
  236. How to install an aftermarket tachometer
  237. Check differential fluid?
  238. TCC Shift solenoid? Lumina!
  239. Info for Front Wheel Bearing Installation
  240. Is this factory???
  241. Euro Gauges into a base Lumina?
  242. a little help please.
  243. Gasket
  244. 1997 Chevy Lumina 3.1 L - Surging Problem
  245. speedometer does not work
  246. help with ac and heat
  247. 93 hestiation/no power
  248. 1991 lumina 3.1
  249. a/c stops blowing thru vents when I accelerate
  250. 1992 Lumina TH125C Transmission whine problem?
