View Full Version : Lumina
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. Pics/Profile
  2. Another question about my 92 z34
  3. 1993 Lumina Z24 Blinker Issues.
  4. 1999 3.1 blows fuse every time i hit the brakes
  5. New Problem: Stiff/Hard Gear Selector
  6. A oil cooler
  7. 97 Lumina 3.1 Front bumper
  8. Sequencial Brake Lights
  9. where does the antifreeze go
  10. 92 lumina 3.1
  11. Mechanics
  12. 97 Lumina wireing
  13. lumina 1992 3.1 problem
  14. heater motor
  15. looseing coolant
  16. Insurance Question
  17. Strange thing with AC
  18. Whats a PVC Hose
  19. 92 Euro brake problem
  20. One more post for Maaco paint Good or Bad
  21. forever lights? 92 z34
  22. Lumina 98 3.8 L Cooling water...
  23. 92 lumina z34 Knock sensor?
  24. Anyone have Engine Codes for Z34 3.4L???
  25. 1992 3.4 Liter Chevy Lumina Euro getting HORRIBLE gas mileage
  26. hydraulic lifters-3.1 L 97 Lumina
  27. where to get diagnostic help.
  28. low coolant light
  29. Dash Lights / Parking Lights don't work
  30. My Lumina is getting too hot! Please help and see if there isn't something cracked!
  31. 90 lumina a/c problems?
  32. 1998 Lumina Speedometer cluster
  33. 1995 Chevrolet Lumina 3.1 (M) Motor>>>>Runs rough at idle and under acceleration
  34. 1992 Lumina tail lights
  35. 93 Lumina 3.1 TCC replacement
  36. Inner tie rod replacement, 1996 Lumina
  37. Car won't crank to start
  38. 1990 Lumina Euro 4 speed automatic transmission
  39. 93 Lumina 3.1 cranks, no start, no spark
  40. Check Fix, Surging, Wanting to die, Service Engine Light
  41. 1991 lumina PROBLEMS
  42. Transmission - Rough Shifts and Whine
  43. Air Intake for Lumina
  44. lumina transmission
  45. hello im new to AF
  46. 98 fuel pump ?
  47. Side Window Lights
  48. 1992 Chevy lumina Euro 3.4 Liter getting terrrrrribble gas mileage
  49. I am completely flustered
  50. Not starting after new timing chain...HELP!
  51. Digital speedo
  52. 95 Lumina dash lights
  53. Pcv Question?????
  54. Cooling problem
  55. Brake fluid? Or some other Problem
  56. ac blows on the floor when i step on the gass
  57. Got The A/c Converted To R134a
  58. rear wheel seals
  59. 93 Lumina ... Gas tanks ?
  60. 1995 Lumina Intermittant Problems
  61. Hypertech Chip
  62. 1990 Chevy Lumina APV - need help with door handles/locks
  63. Lumina start problem
  64. oil cooler on 92 z34
  65. okay not much of a question but you know :P
  66. 97 Lumina Cranks, but won't start
  67. 2000 Lumina 3.1 Lights dim, tach jumps, often needs to be jumped
  68. 95 lumina won't shift
  69. In-Dash Brake Light Flashing
  70. Arrrrrrrrrgh!
  71. 97 Lumina Starter
  72. How do I reconnect the battery cable?
  73. 97 Lumina Starter
  74. Now What Wrong With It?
  75. 94 lumina electrical problem
  76. 92 lumina engine problem
  77. 1996 Lumina 3.1L No Power
  78. 1990 chevy lumina
  79. '96 3.1 exhaust leak?
  80. 1996 Lumina turning signal handle
  81. Need some help making a decision..
  82. 1993 Lumina Euro 3.1 Problems
  83. How much oil do i need to put in ac system?
  84. Remove pulley from power steering pump?
  85. Oil pan gaskets
  86. 94 Lumina will not start.
  87. What Is Your Lumina's Gas Mileage?
  88. Check engine light P0440, P0171
  89. 98 3.1 Lumina Tune-up Help
  90. 93 lumina euro abs light on , brake light is flashing & making a noise
  91. 4th Gear Problem
  92. 96 lumina overheating??
  93. '95 Lumina motor swaps
  94. Help with 1991 Lumina Euro
  95. 95 lumina 3.4 Tranny cooling lines
  96. 93 Lumina Wierd Idle issue
  97. Yet Another Intake
  98. A/c Question
  99. o2 sensor in 92 lumina?
  100. 96 Lumina 3.1, Plat. spark plugs or not?
  101. need help 92 lumina
  102. The Memcal(chip) in 92 Lumina Z34
  103. Low PSI (55) In 6th Cylinder
  104. why wont it work?
  105. 98 Lumina High Beam Indicator Light
  106. 93 Lumina z34 won't start
  107. 2000 Lumina starting prolem
  108. 92 lumina wont start
  109. Huge hydroplane/puddle = louder engine?
  110. 97 Lumina A/C
  111. 95 lumina over heating Help please :)
  112. Check engine light comes and goes
  113. what now?
  114. lumina problems
  115. Where you at?
  116. big deal or not?
  117. lumina "bucks" above 50mph then dies when brakes applied
  118. 97 engine swap
  119. 96 Lumina Alarm/Security Problem, Won't Start
  120. performance mods?
  121. transmission troubles
  122. 1994 Lumina Z34 Has A Ghost!
  123. Negative terminal on a 1996 lumina
  124. 1994 Z34 Keeps Stalling Doesnt Want To run.
  125. 93 lumina charging problem
  126. 95 lumina ls Issues
  127. What is your Cars history?
  128. Need New Engine
  129. Please recommend plugs and wires for 1993 Lumina
  130. 3.4L D.O.H.C Timing Question
  131. Starter?
  132. 95 Lumina - Overheating
  133. 1999 Lumina Heater Fan Servicing
  134. Lumina Z34 Stalling! HELP!
  135. Lumina Z34 Stalling! HELP!
  136. Help with cruise 1990 Lumina
  137. who are you?
  138. '94 lumina chugs funny and dies
  139. Windshield Wiper Problem on 93 Lumina
  140. 97 lumina door panel
  141. My solution to the warped/curling dash problem
  142. just a dumb question
  143. 92 Lumina stumble under acceleration
  144. IAC ? how do u clean
  145. Help ASAP w/ removing fuel pump? 92 lumina euro
  146. no spark /no power to fuel pump
  147. can anyone tell me?
  148. 97 Lumina Brake Light Problem
  149. Possibly buying a lumina?
  150. Things to get changed at 123K?
  151. 1999 lumina radio installation problems
  152. No Turn Signals - 00 Lumina
  153. 3.8L lumina Ltz smoking.
  154. Lumina 98 Transmission Cooling Problem
  155. 95 Lumina Window prob
  156. drivers doorz-34 lumina
  157. 98 Lumina Wobble.
  158. Fuel pump replacememt
  159. help please
  160. 1995 Lumina 3.1 lifter noise
  161. happen to anyone else?
  162. 95 Lumina Hazard/Signal flasher
  163. 92 3.1 water pump changed now enginge dead
  164. 1992 chevy lumina problem
  165. Code 32 And 42
  166. 97 Lumina car strut replacement
  167. Anybody need a hood? 95-01
  168. Cleaning removed fuel injectors yourself?
  169. 92 Lumina sometimes Shakes when hitting about 50-55 mph
  170. Pulling the ,96 Lumina's engine need some advice
  171. 95 Lumina Speedo problem
  172. I have a 1992 lumina 3.4 liter that sometimes needs to be gassed to start?
  173. INTERMITANT idle and stall problem
  174. 3.4 - 3.1?
  175. 1997 Lumina 3.1 dies after 1st start, then hunts
  176. lumina Z34
  177. Which transmission fluid to use?
  178. how to deactivate alarm in a 95 lumina sedan
  179. Locking issue
  180. Replace 1997 Lumina Heater Core
  181. Seatbelt Light? uggghhh.
  182. Best way to drain out all coolant?
  183. 95 chevy lumina fans don't work
  184. help! driver door jammed shut!!!
  185. 97 Lumina EGR Valve and O2 sensor Question?
  186. Tailligths, dashboard lights off all the time
  187. tip for testing radiator fans
  188. Hard Shifting (1st to 2nd)
  189. 191 CID Aluminum Head Issues
  190. 90 lumnia won't start
  191. How to check Engine Code for '95 Lumina
  192. FS lumina ashtray. '95+
  193. Upsize wheels for 90 Lumina
  194. 98 Chevy Lumina Brake Light/Turn Signal Problem
  195. 1997 Lumina Coolant Leak.
  196. 97 lumina brakes clicking
  197. '92 Lumina Heater Controls
  198. 95 Lumina Sedan cooling Issues
  199. 93 Lumina Euro 3.1 - Idle drops every 60 seconds.
  200. 92 Lumina overheating
  201. 92 Lumina 3.1 missing at part throttle
  202. 1999 chevy lumina Stall and acellerate problems
  203. 93 Lumina Euro Trans Slipping
  204. I know this isn't Lumina But...
  205. 2000 lumina beeping noise
  206. I get 32+ mpg with 92 Lumina
  207. KNOCK KNOCK...ugh
  208. 97 lumina won't run
  209. 2000 Lumina - AutoTransmission hard shifts after warm up.
  210. 1993 z34
  211. Brakes acting strange 97 Lumina
  212. Radio installation nightmare
  213. 2001 Lumina 4t65E transmission problum
  214. Z34 Exhaust
  215. Alt Not Charging
  216. A tip to prevent getting stranded on the side of the road
  217. How to locate and install new TCC solenoid? Quick tips?
  218. Quarter Panel fix options
  219. Cant find Hazard Flasher
  220. 96 3.1 lumina runs horrible
  221. Remove O-ring for transmission filter?
  222. Lumina 1995 LS: Airco hesitation below 7 Celsius
  223. Cruise Control Quit
  224. belt tensioner question?
  225. 1996 Lumina Steering Problem Front End
  226. 1996 Chevy Lumina won't start
  227. Another fuse box somewhere??
  228. 94 3.1 - inconsistent spark
  229. 95 Lumina
  230. 96 Lumina Hesitation
  231. Change oil light
  232. 4t60E transmission
  233. 1997 Lumina End Links
  234. egr causing problem when disconnected
  235. Radiator coolant not filling up
  236. 1992 Chev Lumina 3.1L (T) Turn signal fuse blows out all the time
  237. Rear brakes... smoking
  238. Crankshaft Position Sensor
  239. '91 Lumina inj.?
  240. 91 3.4 Lumina Coolant Dripping from Tranny
  241. Intake for a 3.4?
  242. Help with door Panel
  243. RPM Drop while accelerating
  244. '91 Lumina electrical ? Prob
  245. Electrical problem???
  246. 2.8 or 3.1 fuel pressure regulator needed@!
  247. Leaking and dirty coolant. Need help asap.
  248. 92' z34 color codes
  249. 91 3.4 Tranny Slipping
  250. 97 Lumina Low Coolant Lite
