View Full Version : Lumina
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. 93 Lumina euro front end issue
  2. Lumina Idling Problem
  3. No heat
  4. 96 Lumina Idle Problem
  5. Heater core
  6. Vtech vs. 3.4 liter engine
  7. Emergency Brake Warning: Update with photos
  8. Can I use high-heat engine paint on the exhaust system?
  9. Hunting down Relays - 94 lumina 3.4L v6
  10. Sawing off nuisance battery bracket
  11. Fixing Window Trim - black goop
  12. Replacing Transmission Fluid lines to Rad. How?
  13. Removing the Stupid and Dangerous Rear Spoiler
  14. Tire Rim Corrosion - partial solution
  15. 1990 lumina 3.1 quits running
  16. 1994 lumina, intake manifold gasket
  17. 96 Lumina Throttle Hesitation
  18. How can I get error readouts on my 1994 Lumina 3.4L (PCM = Monte Carlo 95)
  19. Crazy turn signals
  20. Rattle In Drive
  21. Replacing engine coolant,1999 Lumina
  22. Why would someone steal a vehicle owner's manual?
  23. 96 lumina o2 sensor
  24. How do you tell how much life is left on your car?
  25. Fuel line question...
  26. 1997 chevy lumina catalytic converter replacement
  27. 97 Lumina runs bad after moisture
  28. 97 Lumina stalls at stops
  29. 95 Lumina bucks at 50mph after driv 10 min
  30. Chunks of metal in Trans. pan
  31. 94 Euro 3.1 misses
  32. Just pulled engine
  33. 1993 Lumina won't shift down into first gear.
  34. 98 Lumina... buzzing noise?
  35. 97 3.1 to 3.8
  36. Need Ideas On what to do with my z34
  37. help brakes wont work
  38. Back Bumper: needs replacement - how do I remove it?
  39. 91 Lumina Z34 won't Start.
  40. Lumina z34 Coolant boiling/bubbling
  41. 1997 chevy lumina DTC: P0420
  42. Saving the lower door panels for $3
  43. Keyless entry wire question
  44. 94 lumina 3.4L "Engine needs Servicing" Light OBD-I
  45. 97 Lumina thinking about pulling tranny...need advice
  46. Euro Instrument Cluster for Lumina
  47. 10% Gas saving with an undertray...anyone try this?
  48. Shift solenoid error causing misfire
  49. 1997 lumina 3.1 trys to start and stalls.
  50. please help
  51. Can 94 Lumina 3.4L Euro be towed on all four wheels?
  52. 93 Lumina 3.1 L wEngine won't run in reverse
  53. Dexcool...
  54. Brake light problem...
  55. exhaust crossover or exhaust manifold?
  56. doing mufflers myself: from wrecker
  57. Need Help with 1995 chev lumina Ls
  58. Replacing back brake shoes
  59. Ignition Coils and Ingnition Control Module
  60. It is Time! To PAINT!!!!
  61. 3800 3.8 L jumping caused a pop now terrible idle
  62. lumina 3.8 L 3800 idle eratic idle after jump start
  63. Idle Problem?
  64. UGH curse you anti-theft machanism
  65. ECT sensor
  66. 1995 Lumina Sedan Idle Problem, just replaced PCV Valve.
  67. '93 Lumina brake problem
  68. 1997 chevy lumina coolant flush
  69. 1995 lumina 3.1L TBI (FUEL PUMP)
  70. 97 3.1 engine swap
  71. Emergency Brake Ripoff - key warning
  72. 97 lumina still no start
  73. ABS brake sensor cable - a rapscalion to fix
  74. 1990 w/2.5L 4cyl - random rough running
  75. lumina loses all power and dies
  76. 1999 Spedo Stopped Working
  77. Added coolant = Screwed everything
  78. Adding Coolant --> Bleeder Thing
  79. 97 lumina transmission fluid black
  80. 1993 Lumina euro transmission issues
  81. Programming Keyless Entry Remote
  82. 1996 Chevrolet Lumina
  83. High pressure steering line,leak,replace
  84. Luminas for sale?
  85. Replacing a rear Brake Caliper...need some advice/help
  86. Used Lumina for parts: is this a good deal?
  87. The Lowdown
  88. Loosing Coolant "Oringinal Gaskets"
  89. Spark Plug wires...
  90. Rust on Fuel Line...
  91. 3.8 Water Pump
  92. Small Black Bar
  93. maybe you know?
  94. Full size tire replacing spare.
  95. total power loss while driving
  96. Factory Part Numbers
  97. Torque Ange Meter and Water pumps
  98. GM 3.1L lower intake manifold gasket problems
  99. 1997 chevy lumina 3.1L valvetrain rattle/noise?
  100. Spark Plugs...
  101. Engine Rev
  102. 98 lumina brake issue
  103. 97 lumina turn signal switch
  104. Where is the starter relay on my 97 Lumina that has anti theft system
  105. Ive a problem with the a/c on my 98 chevy lumina
  106. alternator
  107. 94 Lumina 3.4L: MAP sensor or MAF sensor system?
  108. Quick Question
  109. Stupid things that make you freak out
  110. 1997 lumina 3.1 oxygen sensor
  111. Any good retailers that do brakes?
  112. Lumina vs. Park Avenue
  113. Knock from the engine! :(
  114. OEM Keyless can I use this Module?
  115. Interesting Find On 93 3.1v-6
  116. Flasher issue...
  117. 97 Chevy Lumina brakes/Master Cylinder
  118. 1997 chevy won't pass smog code P1870
  119. Z34 Very hard to start SOMETIMES
  120. Key Stuck In Ignition
  121. Car knocks/pings when cold
  122. RPMs
  123. 96 Lumina Blowing ECM fuse
  124. 97 Lumina 3.1 leaking coolant
  125. 1990 lumina fuel delivery issue
  126. Gauge Help
  127. 97 Lumina 3.1 leaking coolant
  128. 1994 Z34 Lumina
  129. Cylinder 6 misfire
  130. Question about oil
  131. Driver's Seat Annoying cushion problem fixed.
  132. Front Corner Light Repair - How To
  133. Rattling Hubcaps 97 Lumina
  134. 1990 Lumina will not start, Just keeps cranking
  135. brakeline leads to broken springs?
  136. Safe to run SeaFoam?
  137. Flowmaster 40 muffler (dual out) + 2 cherrybombs?
  138. exhaust shield ??
  139. OEM Keyless Entry install
  140. My 1998 Lumina won't start
  141. 97 Lumina Volts Light
  142. Quick ? regarding replaced alternator
  143. 1997 Lumina "c1236 Low System Voltage"
  144. Starter ? on a 92' 3.4
  145. Can better Exhaust system give better MPG?
  146. Converting to E85/Ethanol or any mixture of Ethanol/gasoline
  147. 91 lumina hunting idle and dieing
  148. '96 front strut cartridge problem
  149. Replaced trunk and glove box locks on Lumina
  150. who is better?
  151. Are cooling fans using to much electricity?
  152. HHO Hydrogen fuel suppliment for better MPH & savings
  153. Neither Fan Turning? is that normal in summer?
  154. Install an overhead light switch: 3 good reasons!
  155. Saving old battery as spare: EDTA reconditioning...
  156. 2nd Alternator in place of AC unit?...
  157. Trunk release button revisted
  158. 1991 lumina
  159. Keyless Remote with universal?
  160. Can these Sparkplugs save 10% of my gas (MPG)?
  161. AC Problem
  162. 1990 Lumina 3.1 Overdrive Transmission Apple Coring/Reluctor Drive Shaft No shift
  163. Not another problem!?!?! 92' lumina z34
  164. Which fuse did I pull??
  165. OEM Keyless entry
  166. Lumina 1998 3.8L RKE Receiver
  167. '96 rear brake drum stuck.....
  168. 97 check engine light problem
  169. 95 lumina rear noise
  170. Cabin air filter
  171. Intermittent problem with Lumina97
  172. 99 Lumina a/c clutch wont engage
  173. 1997 lumina 3.1L Coolant in oil?
  174. Cracking Tire
  175. 91 Lumina Ignition switch problem
  176. Ran then didn't..
  177. 97 Lumina 3.1 High RPM after thermostst change
  178. Spare Tire Replaced with Full Tire
  179. 98 Lumina Will Not Start
  180. air filter
  181. waterpumps
  182. Wires cut coming out of passenger front wheel well and down...
  183. Yet another issue
  184. 1990 Lumina Stalls After Exiting Highway
  185. 93 Lumina Chime Issue
  186. 1996 Lumina starting problem
  187. 1999 lumina turbo
  188. 1991 lumina problems # 2
  189. 95 Lumina A/C Inop
  190. Tie Rod Ends: What torque for castellated nut on steering arm?
  191. What ECM and EPROM should my /94 3.4L v6 be running on?
  192. What Thermostat and Eprom gives best mileage?
  193. How to rebuild your own alternator in 10 minutes!
  194. Where is the DLC on a 99 lumina?
  195. 99 lumina driving me crazy
  196. Mmmm fresh cold AIR!!
  197. Where is "illumination delay relay" for dash lights? /94 lumina
  198. battery draining overnight - dead, 3 problems
  199. Lumina not charging, please help.
  200. Compressor wiring bad?
  201. loosing coolant
  202. A few questions about the z34
  203. 1999 lumina
  204. Getting tired.... Engine Tick.
  205. 1990 Lumina Euro 3.1 Overdrive Automatic Transmission Problem
  206. 96 z28 engine /98 Lumina swap
  207. Spark plug wires - what's good?
  208. crazy mult. problems
  209. 1993 Check coil packs.
  210. 98 Lumina, groaning fuel pump?
  211. 2000 Lumina Needs Your Help
  212. A new A/C issue
  213. Knock and the loss of power
  214. Another 92 Euro 3.4 A/C question
  215. K&N Air Filter (Worth it?)
  216. 92 Lumina Euro 3.4L ABS Brake Problem
  217. ICM, ECU? How do I determine which one?
  218. question for the pro's
  219. Idle issue with 94 Lumina 3.1 V6
  220. Install a Trunk release button
  221. AC only on drivers side?
  222. ‘96 Lumina 3.1 with a rough idle
  223. Speed Sensor Shift Issue 1990 Lumina Euro 3.1
  224. Need a slim jim...
  225. 97 Check Engine Light
  226. 1993 code 42
  227. 3.1 overflow hose part number?
  228. Horn Location in 1999 Lumina
  229. New fuel filter = hard starts?
  230. no a/c no shift check engine light on
  231. engine makin funny noise
  232. Knocking noise
  233. how goes it?
  234. 98 Runs great but starts hard.
  235. Drivers side door lock stuck ('97)
  236. '97 Fuse Block
  237. 95 lumina security lite is on on
  238. 1993 starts then dies. Possible ECM problem?
  239. A/C Problem
  240. Knocking noise from under car.
  241. 94 lumina swap question
  242. Can't find?
  243. 99 Lumina brake lights
  244. 98 lumina ltz
  245. Yeh, 97 Lumina starts again
  246. What Controls the speedometer?
  247. 97 Lumina Won't Start
  248. 92 Lumina Z34 Shifting Issues
  249. Posting Rules
  250. 92 Lumina Diagnostic Error Code List
