View Full Version : Lumina
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22]
  1. Service manual or repair manual???
  2. Selling a 92 Lumina Z34...
  3. misfire after fixing coolant leak
  4. Replacing the Starter... oxygen sensor?
  5. Electrical Heat controls running lights
  6. ECM reset on battery disconnect and vaccum line question
  7. 94 APV stalls won't start
  8. Another 93 Lumina Problem!!!!
  9. ABS Light On-STEADY Not Flashing
  10. Automatic Door Locks
  11. 92 Euro trans. conversion
  12. 1990 Lumina fuel pump replacement??? Help!!
  13. Heater Control Light up???
  14. Brake Noises
  15. ABS light
  16. Irratic RPMs.....help
  17. 1995 Lumina misses when cold
  18. 1996 Lumina dash light problem
  19. 93 Euro Tranny Being a Wierdo, and idle 2!
  20. power locks open but won't lock 96 Lumina
  21. 01 wont run
  22. Stupid stuff
  23. #1 cooling fan clicks on late!
  24. body kits 88-94 chevy lumina's
  25. 90 Lumina Sedan Problems, plz help.
  26. Please help with Tranny Model #
  27. 98 Lumina Check engine light
  28. '92 Lumina stalling when brakes applied
  29. i am cunfuzzled w/93 euro
  30. stiff gear selector 96 lumina
  31. No Dash and parking lights 96 Lumina
  32. Cooling fans
  33. Noise in 1998 Lumina
  34. 95 Lumina 3100V6 "Shuddering" at low highway acceleration
  35. Transmission
  36. 91 lumina tachometer
  37. 92 3.4 ignition problems please help
  38. Great joke!!!
  39. wanted cutlass strut tower brace
  40. hypertech chip for 3.1
  41. 3.4L to 3.1L engine swap?
  42. ABS constantly clicks
  43. 90 lumina anything
  44. any milwaukee, wi tranny experts?
  45. Lights dim...engine loud HELP!!
  46. 1992 Lumina Transmission
  47. Headers
  48. 98 lumina coolant leak and noise
  49. Service Engine Soon?
  50. Pull Lumina radio
  51. ecm trouble
  52. 91 lumina euro w/ methanol option
  53. 1992 Lumina 3.4 Engine
  54. 1992 Lumina Euro 3.4
  55. 98 lumina
  56. 1998 lumina 3.1
  57. Please Help W/ Unknown Problem
  58. '93 Lumina APV Transmission
  59. Lumina Z34
  60. 1998 Lumina
  61. firing order 3.1 l
  62. Z34 Alternator
  63. 1990 lumina 3.1 sparkplugs installation
  64. coolant problems
  65. lumina wont start please help
  66. 90 lumina bodykit
  67. Yukon 2003 keyless remote
  68. 3.1L to 3.4L Conversion Kit
  69. Transmission
  70. Possible Electrical Problem
  71. Problems with 99 lumina 3.1L
  72. Can't get at the back 3 sparkplugs, any ideas?
  73. need a new window but cant find one
  74. Turbo on a lumina
  75. Crazy Question
  76. Is This Temperature Safe?
  77. Fuel Injection System
  78. help... thinking maybe it's the ignition module
  79. problem with coolant level
  80. Dead battery problem
  81. Starting issue
  82. High Performance Parts
  83. Totalled my Lumina
  84. 99 Lumina LTZ Transmission Shifts Rough
  85. Floating Gas Gauge
  86. Hesitation during slow accel. pls hlp!!
  87. Who here has the best Lumina?
  88. 2 questions
  89. New in South Africa
  90. Delco stereo light out
  91. Long trip planned
  92. '99 leaking coolant
  93. Solution for intermittent no-start/no-run problem
  94. 97 LUMINA starting problem
  95. z 34 speedlimiter
  96. how do i unhook battery
  97. 93 lumina vaccum canister
  98. performance chip
  99. Removing Speed Govenor on my 1998 Lumina??
  100. Crank no Start
  101. head gasket replacement?
  102. 92 Lumina-Sticky brakes
  103. transmission
  104. hazard lights keep blowing fuses
  105. New battery-radio in "LOC" Need a key
  106. Quick Question about installing an AMP
  107. Upper Plenum for Lumina Z34
  108. Classifieds
  109. Z34 ground effects on Lumina Euro
  110. Ground Effects
  111. 96 Lumina - Transmission Computer Chip??
  112. 91 lumina 3.1 euro sport engine swap
  113. 92 Lumina won't stay started!
  114. Love the '92 Z34?
  115. Does anyone know where I could get a wiring diagram for a 99 Lumina LTZ?
  116. Heat control in 96 Grand Prix
  117. Need engine for my Lumina Euro. 3.1 or 3.4?
  118. No dash & parking lights! Related to remote car starter?
  119. 96 Lumina Trans, speedometer, odometer
  120. Trans Slipping
  121. 98 Lumina Hesitates on hard acceleration
  122. 99 Lumina 3.1 - Losing Coolant
  123. 96 lumina Code P0420
  124. starting
  125. 1990 chevy lumina
  126. 90 Lumina help
  127. 1996 remote start help
  128. 96 3.1 V6 hesitation only when warm
  129. I need some advise badly....
  130. 95 Lumina 3.1 creaking problems
  131. Websites
  132. 1993 Lumina ABS Problem
  133. power streering hoses
  134. Replace serpentine belt
  135. transmission
  136. Knocking (Rod knock?) '95 w/ 3.1 V6
  137. 93 lumina headlights
  138. 93 lumina speedometer, odometer, and headlights
  139. '93 Speedometer Not Working
  140. Where is my Fuel Filter?
  141. '96 Coolant Leak
  142. my car
  143. weird starting problem
  144. electronic auto shift kit???
  145. battery? Something else?
  146. how do I get the battery out of my 92 lumina?
  147. Automatic lock question
  148. Where is the engine coolant plug?!?!?
  149. Need help with a leak...
  150. Stalled,,,help!
  151. cruise not working
  152. Stalling/Missing
  153. keyless entry program
  154. Daytime(?) Running Lights
  155. rims rubbin brake caliper?
  156. Rims for Lumina coupe 2003
  157. '98 Lumina: No Brakes in Rain
  158. will these rims fit my car?
  159. No brakes on wet road
  160. Lumina Alarm
  161. 1993 Lumina Z34 3.4 Body Kits
  162. Cool Lighting
  163. won't start Half the time
  164. 2000 Lumina mystery dash lights
  165. 1990 Lumina Brake problem...
  166. keyless entry
  167. transmission
  168. cam shaft
  169. Need some help...
  170. 2001 Lumina LS V6 3.1 - Tuning?
  171. Replacing outer crank seal & Timing Belt....
  172. just a question.....
  173. 1992 caddilac sedan deville
  174. Grille?
  175. Need Body Kit For 91 Euro Coupe
  176. Convert rear brakes from drum to disc?
  177. Weird whistling/skreeching upon accelleration hesitation/stumbling/surging
  178. Fuel Filter Location on a 1998 Chevy Lumina 3.1L
  179. wiring diagram for power door locks for 93
  180. Help with lumina
  181. car won't stay running
  182. Help on '93 Lumina
  183. Z34 question
  184. Couple of questions on my Lumina...
  185. Dtrl
  186. OBD-II Code P0440
  187. Oil Leak!!Help!!
  188. Turbo??Possible?
  189. Reprogramming Lumina Keyless Entry
  190. Two Lumina Z34s ZFor Sale
  191. 81,000 mile blown engine WTF?!?!?!
  192. cooling fans
  193. A Van & A Car?
  194. Disable Electric Door Locks?
  195. Injector replacement
  196. 1990 Lumina Euro 3.1 Sedan
  197. ABS Stalling Engine?
  198. coolant
  199. 98 Lumina No Stop Lamps or Turn Lamps
  200. '98 Lumina ABS Light On!
  201. Transmission Problem - '98 Lumina LS
  202. Lumina Keyless Remote Programming
  203. heating problem
  204. Starting the engine
  205. lumina rims upgrade???
  206. 96 transmission
  207. 94 Lumina Z34
  208. '98 Lumina Keyless Remote Programming - How To?
  209. Keyless Entry Programming
  210. daylight running lights
  211. LTZ package
  212. 90' lumina w/ keylock electrical problems
  213. 98 LTZ front wheels shudder on quick starts
  214. 2003 SS Lumina
  215. 93 lumina euro 3.4 coolent light?
  216. I have an overheating problem
  217. Help!!!!!!!
  218. 92 Z-34
  219. lumina ss
  220. Can the back seat of a 2001 Lumina be removed? How?
  221. Help! Oil in Coolant Resevoir
  222. Knock Sensor
  223. Power Window Problems
  224. 90 Lumina check engine light
  225. DELCO unlock...
  226. 95 baretta low coolant light
  227. Performance Parts
  228. 95 lumina stop lights
  229. 92 Chevy Lumina Mechanical Problem
  230. Hazard Flasher on 96 Lumina
  231. '92 lumina engines
  232. 2002 Lumina SS
  233. 1996 Lumina Intermittent Overheating
  234. Custom Lumina
