View Full Version : Lumina
Pages :
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [ 21]
22
- RPM Question
- Missing cylinder in 93 Lumina
- Lumina temp problems
- replacing fuel pump
- Coolant system mystery
- Locations, locations. 1999 Lumina.
- 94 lumina euro 3.1 wont start
- Tail lights for a 95??
- Engine skips at high rpm
- Engine/Tranny overhaul and upgrade...HELP!
- 92 Lumina Euro cooling system
- 92 Lumina
- 92 chevy lumina v6
- can't change defroster setting
- 1990 Lumina Stalls
- Flushing out 99 lumina
- 92 lumina won't start recent engine rebuild
- Please Can SomeOne Help Me
- Please Can Some One Help Me ?
- 94 Lumina Z34, Trying To Sell But Irratic Idle!!! Help Please!!
- Crankshaft Sensor
- Why Do My Brakes Suck?
- Can some one help me Please
- 94 Lumina 3.1 v6 stalls out when put in drive
- 2001 lumina ECM
- 92 Lumina 3.1-Battery or alternator?
- Electronic ignition module location
- 1997 Lumina-front license plate mounting/bracket?
- 96' Lumina:Dash out/Tail lights out, brake lights work
- 94 Chevrolet Lumina Runs For About 10 To 20 Min's Then Stall Out After Its In Drive
- Replace fuel filter: release pressure?
- climate control not working
- Lumina APV wiper fluid leak
- 92 Z34 for Sale
- Remotes
- starter motor
- IDLE problem
- Possible oil pump problem????
- Squeaking and sqawking
- "97 Lumina Struts/Shocks
- 1990 Lumina blowing power door lock fuse
- Can I get check engine codes without a scan tool?
- OBD 1 or 2
- 99 lumina-Tune Up?
- 92 lumina speedometer sticks
- HELP Please!
- transmission problems
- what is the egr and what does it do?
- Lumina APV MAP sensor
- 93 Lumina APV 3.1 Stalling Problem
- How Many Miles on Your Lumina
- 96 Lumina Stumped Techs
- Hard starting and runs rough on humid days
- '93 Lumina APV 3.8 Cruise Control Codes
- Idle began fluctuating after Jump Starting???????????
- 98 Lumina Drum Brake Problem. PLEASE HELP!
- Power Locks problem in '98 Chevy Lumina
- lumina parts
- Why won't this car go when I want it to (I NEED POWER)?
- Heater not working, why?
- 3.4 Z34 coils on a 3.1 Euro?
- 1996 lumina coil firing order
- Flywheel
- My van dies when I touch the brakes...
- IAC Idle Control - where is it located/how to test it?
- power steering hose
- 1992 Dash lights won't go out
- Remove air silencer
- i am selling my '95 lumina
- Thier Shutting Down This Forum?
- Dash Lights
- coils?
- Lumina SS Brake system
- Buying 98 Lumina
- 93 Lumina Heats up when breakes applied
- SELLING 91 Z34 RED unless somebodys got idea to turn motor
- idle problems when slowing or stopping
- 1990 lumina cd player installation-please help
- '93 Lumina Problem - Rough Ride (And Not the Good Kind)
- New Lumina owner
- Lumina jerks and occasionally shuts off
- New member, 1998 Lumina LTZ questions RPOs
- Lumina APV HELP!!!!!
- 98 Lumina Starting Problems
- 1990 Lumina 3.1 problems
- 1992 3.4 lumina ecm codes
- Broke Cam Shaft
- '93 3.4L z34 died this morning
- 93' 3.1L pushrod order
- 92 Lumina Euro I need the wiring for the radio
- 93 Lumina APV transmission trouble
- stuck on high beams 94 apv
- distributor plug
- 93 lumina turn signal
- Factory alarm?
- Code 56?????
- where do I find a motor 96 lumina?
- I am selling my '96
- Rod knock or lifter? 3.1 engine 1996
- 1998 Lumina (car) how to interior door panel
- 94 Lumina APV trickle sound
- Oil Pressure Sensor Swtich 90 Chevy Lumina
- Ground wire/ car stereo/ cd player installation
- Blown intake gasket/Engine clean up
- 92' Lumnia APV Minivan Trans Troubles
- Looking for 93 Lumina z34 parts
- 1993 Lumina 3.1L coupe problems
- No spark 3.8 liter
- 92 3.1 Engine Issues
- 94 Chevy Lumina Euro Failed Emissions
- will it start
- feul pump located
- Help with a Fuel filter
- 1992 lumina apv engine problems
- 98 Lumina LTZ serpentine belt change
- transmission
- 97 Radiator fan problems
- ECM Trouble Code Is it Trouble?
- 3.1L spark plugs loonening?!
- 92 Euro Stalling with Speedo/RPM Problems
- 1995 lumina apv, wiper problem
- 92 Lumina euro stalls when slowing
- Rack and Pinion removal
- 1995 Lumina Brake Lights won
- 96 lumina trans problem-Help!!
- Piece of wheelwell(?) came off when driving
- Replaced alternator but new battery keeps going dead!
- Horrible Sound From Amp....plz Help!!!
- 92 euro 3.1L alternator
- 1996 3.1L Plenum (Upper Intake Manifold) vacuum hose
- 1990 lumina stalls
- '92 Lumina Power Steering Pump
- Turn-on lead in 93 Lumina
- car starts idling up and down till it just stops
- Swapping Lumina Engine
- Instrument Panel Upgrade?
- buy my 93 Z34
- '93 Z34 3.4L Serpentine belt replacement
- 96 lumina electrical problem
- 92 euro lumina has erratic/pulsating rpms
- 3.1L cranks, won't start when warm
- oes stock radio in '93 Lumina has preamp????
- Anyone know how to use Bondo
- About to put some gas and a match to my '92 Lumina Euro. Help ASAP!!
- where to find fuse box in 98 lumina ltz
- 96 Lumina 3.1 rough idle ONLY WHEN WARM
- 92 Z34 runs rough / stalls
- Security Light 97 lumina
- Clicking Coming From dash or Firewall W/braking
- Starting problems w. 98 Lumina
- ABS & Brake (pressure)
- '90 transmission stalling
- Lumina plug wires V6
- 98 lumina engine stalls while driving
- Spark Plug Questions
- Campaign code?/Heater Control Light Bulb
- 92 lumina wont start
- heater coil
- changing brake pads 1995 Lumina van
- Parking Brakes.
- Wheel size, changing from 14" to 16"
- charging problumes on 92 lumina Z-34
- Retracting the brakes...
- Perfomance Chips/Things 3.1 Gen 2 90-94
- CarDomain
- Starting Problems
- Weird Tranny trouble and more, please help!
- Problem With Driver side door after radio install
- ignition module
- Does anyone know where the cabin filter is???
- How to tear apart dash-replacing stock radio
- 92 chevy lumina runs rough and stalls when brakes are applied
- Timing Chain Woes.......
- Heating / AC control panel lighting
- 1993 Lumina Knocking
- a/c compressor
- 3.1 to 3800
- 3.1v6 fuel injectors chattering
- Will 20 inch wheels fit a Lumina ?
- Windshield washer pump
- engine boughs at revs and oxygen sensor removal
- intermitent power to ECM
- 3.1 engine swap
- Master Cylinder and ABS Motor Pack
- 92 3.1L Cranks great, but won't start
- rearend sits too low no springs what to do
- Driver Door Lock Issue
- 1998 radio take out HELP
- Transmission line leak - what's the most likely source?
- replacing ignition lock
- High Idle
- Faulty Starter or Siezed Engine?
- 92 Lumina Battery Dies
- New owner of 97 lumina with keyless entry
- 98 Lumina-water leaking in (outside water)
- Lumina vs Monte Carlo
- heater coil
- my lumina dont start
- Pics of my car
- 92 lumina apv throttle body injectors not working?
- 92 Z34 phantom stalling
- 95 Lumina Wiper Problem – Occasional
- The Horn won't turn off (Help Please)
- overheating/headgaskets/
- 92 Lumina Euro 3.1 FI idle & start problems
- removing the ignition from 1992 3.1 lumnia
- Anyone know where I can find a new engine?
- please help
- Adding power antenna to 95 Lumina
- 96 lumina transmission help!!!!!!
- 90 runs / stops after 10min no spark
- 1998 Lumina
- 92 lumina need help getting wiring straight
- 97 lumina keeps revving up on it's own
- '97 Lumina Engine DEAD! Now What?
- 1992 chevy lumina 3.1 engine
- my 1995 lumina ls, 3.1
- question bout my 93 lumina
- Lost my keys!!!
- need help with 1998 lumina
- 97 Lumina HELP with AIR BAG LIGHT
- bad tranny in 95 lumina sedan?
- Weird Humming sound while driving my 95 Lumina
- Park and Nuetral..Acting like gear engaging.
- Dash lights and power windows help please
- turning signals acting goofy
- '90 euro won't start, need help fast
- 93 lumina euro w/3.1
- What was towing package on '93 Lumina APV
- tranny and speedometer problem
- help again please
- Lumina Z34 Battery Removal
- Lumina SS BODYKITS, CF HOOD ..
- 95 lumina 3.1 cooling fan not kicking on
- Z34 Hood
- 92 Z34 Issue!
- Shudder, vibrations, Shakey on the highway
- 92 lumina 3.1 over heating problems
- z34 lumina
- 95 lumina apv seats
- how to remove air cleaner to remove battery
- 99 Lumina battery keeps dying
- '94 Chevy Lumina Heater Problem
- 90 Lumina APV 3.1 Cranks won't fire! Please help I'm losing my mind!! :)
- Driver's door problem!
- 97, 3.1 Motor Lumina Engine Problems!!!
- How do you remove armrests from 91 Lumina APV
- 93 APV climate control
- ECM Pin Connection Diagram
- does anyone have directions for replacing the intake gaskets on a 3100 (3.1)
