View Full Version : Lumina
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22
  1. 2nd gear starts - tranny
  2. This has to be a faulty Wire!!! Has anyone got a suggestion which wire it could be?
  3. fuel pump wires?
  4. Why are my brakes so bad?????
  5. 90 lumina leaking gas from throttle body
  6. Idle/Shudder
  7. Pop ups
  8. Stalling when put into reverse
  9. 96 Lumina A/C problems
  10. a/c is only coming through the defrost!
  11. '92 Lumina z34 idle problems
  12. Occasional Tranny Problem
  13. struts
  14. 93 lumina tranny
  15. LuminaAPV-3.8-1993, gas gauge reading high
  16. 92 lumina apv location of tcc harness on trans.
  17. Buying a Lumina
  18. 92 Lumina Vacuum lines location????
  19. start problem (twice start)
  20. need recommended tire pressure
  21. 1990 Lumina clicking while car accelerates
  22. 1990 Lumina won't start hot
  23. Replacing Transmission on 96 Lumina
  24. 1996 Lumina Minivan Headlight Problem
  25. 97 Lumina Deceleration problem
  26. Remote Star For Luminas
  27. 2001 Chevrolet Lumina Interior Spray Paint
  28. hey guys, nothin wrong here
  29. 92 APV 3.1 - fan short
  30. 99 APV 3.2 - Tranny "trailering"?
  31. My stalling 1992 Lumina Euro 3.4
  32. 91 Lumina 3.1L - High Oil Pressure
  33. Dash and Radio lights go out when Headlights are on
  34. muffler shops
  35. Replaceing a Base Cluster(85mph dash) with a Guage Cluster(115mph dash)
  36. The time has come... parting the car out.
  37. Engines shuts down while driving
  38. Hey Mechanics! Car ain't accelerate-in
  39. lumina needs help? will you help me veronica
  40. can bad egr cause crank but no start?
  41. Remove 94 APV rotor removal (How to?)
  42. car stops accelerating
  43. 1992 Chevrolet Lumina 3.1 Euro
  44. Car is not accelerating
  45. Lumina APV 3.8, cruise control not working
  46. What coolent to put in a 93
  47. 4 Sale
  48. how to put a cd player in a 93 lumina
  49. standard or metric
  50. My '92 Lumina starts,runs, dies.
  51. Body Kit for a '98?
  52. Are luminas back
  53. 2001 Chevrolet Performance Upgrades?
  54. Please respond, I know you guys are looking (trip meter)
  55. Electric door switch not working
  56. mass air flow
  57. 2001 Chevy Lumina Air Pump?
  58. 91 3.1 runs rough at idle sometimes
  59. 94 3.8 Lumina APV miss/surge
  60. 3.1 98 lumina ABS light
  61. 96 lumina a/c
  62. Please help a blonde - stalling 1990 Lumina
  63. 93 Lumina 3.1L Timing Chain or Belt?
  64. Starts good but dies after a little while
  65. 1992 Red Z34 Lumina For Sale
  66. Wrong coolant causes problems?
  67. keyless remote
  68. 91 Euro Jarring miss
  69. 91 Lumina Crank Sensor
  70. Putting power windows and door locks on a car without them
  71. Another Transmission Problem
  72. AC Compressor bypass
  73. 92 lumina van front blower motor
  74. Compatible Parts for a 1992 Chevy Lumina Euro
  75. Bleeding brakes?
  76. key stuck in igniton
  77. 2001 Lumina Brakes Squeeking
  78. 96 lumina no start/run
  79. EGR cleaning
  80. manual transmission
  81. can not pop the hood
  82. 93 Lumina APV Radiator (cost?)
  83. a/c help
  84. Low Coolant Light On
  85. power steering vs. altenator
  86. 90 Lumina front right window won't go up.
  87. Help! Lumina overheating!
  88. front end noise
  89. pcv valve
  90. Shaky car
  91. a/c help
  92. lumina 1999 LTZ cuts out
  93. Ciggy lighter burn out on 95
  94. 94 Lumina APV intermitent Start... help
  95. 93 Lumina Won't Start
  96. Fuel Question
  97. 3.8 vs. 3.1 {Again Please}
  98. Changing rear drum brakes?
  99. 91 Euro 3.1 ignition module
  100. Wierd Tranny Shift
  101. 91 Lumina Euro 3.1 Crank Sensor
  102. M38A1 Solex Carburetor
  103. Need Some Help!
  104. 93 lumina.. weird.. just read :)
  105. Stop the Stalling ! !
  106. Stupid car!
  107. ignition control module
  108. 90 lumina 4 door, cd wiring problem
  109. 95 Lumina - Brake lights won't work when left turn signals on
  110. starving for gas
  111. 93 lumina
  112. Are Lumina heaters known for poor peformance?
  113. 93 Lumina dies
  114. Where's the fuse for door locks on '99
  115. Maybe I'm not looking hard enough
  116. Recalls?
  117. Back gate to van doesn't close correctly
  118. changing a 98 lumina serpentine belt
  119. 93 Lumina No start
  120. My Lumina Starts the shut off right after!!! HELP!!! Please!!!
  121. car lacks power
  122. paint recalls??
  123. 1990 Lumina is the ECM my problem?
  124. why luminas suck
  125. Electrical messages
  126. How to remove distributor block off plate 3.1 1993 Lumina Euro?
  127. Van revs like crazy when first started
  128. Help, my entire fuel pump assembly bent 90 degrees..
  129. engine swap
  130. 96 lumina security light always on & intermittent no start
  131. Timing Belt and or Chain Locations
  132. 96 Lumina Service engine light????
  133. stalls for the 1st 15 minutes of driving
  134. possible short in steering column
  135. Lumina Running REALLY Rough
  136. sensor problems?
  137. 93 rear end sag
  138. front struts
  139. Keyless remote receiver
  140. Lumina SS?
  141. Z34 oxygen sensor location!
  142. Bad Coil send an Error Code?
  143. sound stystems wires
  144. alternator removal
  145. Cooling Fans will not turn on unless hardwired.
  146. 1996 lumina ls Timing belt
  147. 1990 Lumina Climate Control
  148. AC going out
  149. 92 Chevy Lumina Wont Start
  150. Rear End Sits Lower, Any Way to Raise?
  151. rear brake rotors
  152. engine shampoo
  153. 95 Lumina APV
  154. wont run
  155. Changing of air filter?
  156. For Sale: New KYB Rear Struts
  157. Intake manifold pitted from leaking coolant
  158. Anyone have seatbelt problems?
  159. Lumina Seat belt light on
  160. twin duel cam V6
  161. Aftermarket deck in 90 lumina
  162. Oil Leak
  163. Trouble Codes Question
  164. 1993 lumina van 3.8 stalling problem.
  165. valve arrangement 3.1
  166. Dashboard display light problem!!
  167. 1995 Lumina Fuel Injection
  168. PCV Valve???
  169. Brake light ? 96 Chevy Lumina
  170. '98 Lumina 3.1 crank sensor
  171. Replacing Rearview Mirror
  172. I think i want to sell my lumina
  173. 92 Lumina Getrag Tranny.
  174. 3.1L 98 Lumina oil leak
  175. GM 3.1, 3.4 and 3.8 Coils
  176. Water pump on 1999 Lumina
  177. Body Kit For 95 Lumina Ls
  178. new ECM on 1993 Lumina car and still stalling
  179. 95 lumina steering
  180. Foamy powersteering fluid
  181. 3.8 vs 3.1??
  182. Somthing Wrong With Me Signals
  183. Clean, Clear, and Under Control....not really...
  184. e brake
  185. New to this forum
  186. Transmission 3.1 95 Lumina Sedan- Hard Reverse
  187. 3.1 jarring miss
  188. lumina sometimes starts other time just clicks?
  189. Air
  190. Body Kits?
  191. got any ideas?
  192. 1998 cheverolet lumina breaklight trouble
  193. Custom Guages!!!!
  194. ABS...Real brain teaser.
  195. what gas mileage do you get?
  196. hey! help bad torque converter clutch solenoid??
  197. Help Asap
  198. Van won't start...fuel drips out of injectors.
  199. 92 lumina power steering problem
  200. Help,turns over but won't run
  201. 90 lumina fuel pump
  202. Where is the Idle Screw to SPEED it up..
  203. Help with thread below this ASAP
  204. HELP PLZ!!!! 93 Lumina apv
  205. No power to the fuel pump relay circuit
  206. 96 lumina,does'nt shift into gears-HELP!!
  207. 3.4L Lumina miss
  208. Can some of You please answer my Threads Below
  209. Freeze Plugs Leaking
  210. hood release
  211. How to Speed up my Idle?? (90 euro 3.1)
  212. Flooring my 1990 3.1 Euro.. Is it Harmful to the Car??
  213. I hate this car....Z34 Lumina, one thing leads to..
  214. 3.1 miss fires
  215. Lumina, how much you think i could get
  216. Typical Lumina Problems?
  217. Coolant Temp Sensor Replaced
  218. oil pump!!!
  219. Lumina APV cruise control n/w
  220. Brakes
  221. Sun roof problems
  222. PCV hose broke
  223. Best Spark Plugs and Wires?
  224. 98 Lumina 3.1, 105,000 mi, brakes vibrate/shake sometimes when braking over 40mph
  225. How do I know if the fuel pump is bad?
  226. 93 Lumina 3.1 horrid noise on braking
  227. Speed Dometer doesn't work 97 Lumina
  228. Instructions for Head Gasket Replacement by a Novice
  229. Brake Noise
  230. 97 Lumina Turn signal don't work
  231. Service Engine Soon - 97 Lumina
  232. Idling/ Stalling problem
  233. Fans run only with coolant sensor unplugged
  234. 94 3.1 Lumina battery drain
  235. 3.1L to 3.8
  236. Coolant Temp Sensor?
  237. Transmission Tune Up
  238. removing parking brake
  239. Brakes
  240. rear brake problem on 90 3.1
  241. EGR valve
  242. sudden over fueling, raw gas, black smoke
  243. 97 Coolant Issues
  244. 93 Lumina APV 3.1 Electric Window Motor replace.....
  245. Strange Noise in Rear
  246. Help
  247. 95 Lumina 3.1 bad temperature gauge?
  248. Possible Battery Drain
  249. car radio 99' lumina
  250. Help replacing rotors on 93 Lumin Euro?
